[Darshan-commits] [Git][darshan/darshan][master] port darshan-gather-stats.pl from 2.x
Philip Carns
xgitlab at cels.anl.gov
Fri Sep 29 14:19:36 CDT 2017
Philip Carns pushed to branch master at darshan / darshan
Commits:
a9a5654f by Phil Carns at 2017-09-29T19:19:23+00:00
1 changed file:
- + darshan-test/utility-scripts/darshan-gather-stats.pl
Changes:
--- /dev/null
+++ b/darshan-test/utility-scripts/darshan-gather-stats.pl
@@ -0,0 +1,102 @@
+#!/usr/bin/perl -w
+# This script will go through all of the darshan logs in a given
+# subdirectory and summarize a few basic statistics about data usage and
+# performance, producing a text file with text in columns
+#<jobid> <version> <start ascii> <end ascii> <start unix> <end unix> <nprocs> <bytes read> <bytes written> <perf estimate>
+use strict;
+use File::Find;
+sub wanted
+ my $file = $_;
+ my $line;
+ my $version = 0.0;
+ my $nprocs = 0;
+ my $start = 0;
+ my $end = 0;
+ my $start_a = "";
+ my $end_a = "";
+ my $jobid = 0;
+ my $bytes_r = 0;
+ my $bytes_w = 0;
+ my $perf = 0.0;
+ my $nfiles = 0;
+ # only operate on darshan log files
+ $file =~ /\.darshan$/ or return;
+ # grab jobid from name, old logs don't store it in the file
+ if($file =~ /_id(\d+)_/) {
+ $jobid = $1;
+ if(!(open(SUMMARY, "darshan-parser --total --perf --file $file |")))
+ print(STDERR "Failed to parse $File::Find::name\n");
+ return;
+ while ($line = <SUMMARY>) {
+ if($line =~ /log version: (\S+)/) {
+ $version = $1;
+ if($line =~ /nprocs: (\S+)/) {
+ $nprocs = $1;
+ if($line =~ /start_time: (\S+)/) {
+ $start = $1;
+ if($line =~ /end_time: (\S+)/) {
+ $end = $1;
+ if($line =~ /total_POSIX_BYTES_READ: (\S+)/) {
+ $bytes_r = $1;
+ if($line =~ /total_POSIX_BYTES_WRITTEN: (\S+)/) {
+ $bytes_w = $1;
+ if($line =~ /agg_perf_by_slowest: (\S+)/) {
+ $perf = $1;
+ if($line =~ /total: (\S+)/) {
+ $nfiles = $1;
+ if($line =~ /start_time_asci: (.+)/) {
+ $start_a = "$1";
+ if($line =~ /end_time_asci: (.+)/) {
+ $end_a = "$1";
+ close(SUMMARY);
+ print("$jobid\t$version\t\"$start_a\"\t\"$end_a\"\t$start\t$end\t$nprocs\t$bytes_r\t$bytes_w\t$perf\t$nfiles\n");
+sub main
+ my @paths;
+ if($#ARGV < 0) {
+ die("usage: darshan-gather-stats.pl <one or more log directories>\n");
+ @paths = @ARGV;
+ print("<jobid>\t<version>\t<start ascii>\t<end ascii>\t<start unix>\t<end unix>\t<nprocs>\t<bytes read>\t<bytes written>\t<perf estimate>\t<nfiles>\n");
+ find(\&wanted, @paths);
+main();
+# Local variables:
+# c-indent-level: 4
+# c-basic-offset: 4
+# End:
+# vim: ts=8 sts=4 sw=4 expandtab
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/a9a5654f3c4810543559d88897c40d2338c6f0fd
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20170929/48572375/attachment-0001.html>
More information about the Darshan-commits
