[Darshan-commits] Build failed in Jenkins: darshan-master-mpich-3.0.4-profile-conf #847
help at cels.anl.gov help at cels.anl.gov
Fri Sep 22 15:43:27 CDT 2017
See <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/847/display/redirect?page=changes>
Changes:
[asim] updated for dxt_analyzer from LBNL
[asim] second update for dxt_analyzer from LBNL
[ssnyder] fix dxt_analyzer install for out-of-tree builds
[...truncated 10001 lines...]
make[1]: Leaving directory `<https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/mpich-3.0.4'>
[darshan-master-mpich-3.0.4-profile-conf] $ /bin/bash /tmp/hudson7885005593656380474.sh
[darshan-master-mpich-3.0.4-profile-conf] $ /bin/bash /tmp/hudson2931130594630129521.sh
checking for a BSD-compatible install... /usr/bin/install -c
checking whether the mpicc compiler works... checking for gcc... mpicc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether mpicc accepts -g... yes
checking for mpicc option to accept ISO C89... none needed
yes
checking how to run the C preprocessor... mpicc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for inflateEnd in -lz... yes
checking for BG/Q environment... no
checking lustre/lustre_user.h usability... no
checking lustre/lustre_user.h presence... no
checking for lustre/lustre_user.h... no
checking for inttypes.h... (cached) yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking whether byte ordering is bigendian... no
checking for struct aiocb64... yes
checking for off64_t... yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking for MPI-IO support in MPI... yes
checking for MPI-IO prototypes without const qualifier... no
checking for MPI-IO prototypes with const qualifier... yes
checking for shared libraries in MPI... no
configure: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library
checking for MPIO_Request... yes
checking for old (pre-3.1.1) style MPICH library naming convention... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating darshan-mk-log-dirs.pl
config.status: creating darshan-gen-cc.pl
config.status: creating darshan-gen-cxx.pl
config.status: creating darshan-gen-fortran.pl
config.status: creating darshan-config
config.status: creating share/craype-1.x/darshan-module
config.status: creating share/craype-2.x/darshan-module
config.status: creating lib/pkgconfig/darshan-runtime.pc
config.status: creating share/mpi-profile/darshan-cc.conf
config.status: creating share/mpi-profile/darshan-cxx.conf
config.status: creating share/mpi-profile/darshan-f.conf
config.status: creating share/mpi-profile/darshan-bg-cc.conf
config.status: creating share/mpi-profile/darshan-bg-cxx.conf
config.status: creating share/mpi-profile/darshan-bg-f.conf
config.status: creating share/ld-opts/darshan-base-ld-opts
config.status: creating darshan-runtime-config.h
config.status: darshan-runtime-config.h is unchanged
checking for gcc... gcc
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking if bzlib is wanted... yes
checking for BZ2_bzCompressInit in -lbz2... yes
checking bzlib.h usability... yes
checking bzlib.h presence... yes
checking for bzlib.h... yes
checking for BZ2_bzCompressInit in -lbz2... (cached) yes
checking bzlib in /usr... ok
checking for pdflatex... yes
checking for -halt-on-error argument to pdflatex... yes
checking for strndup... yes
config.status: creating darshan-job-summary/bin/darshan-job-summary.pl
config.status: creating maint/darshan-util.pc
config.status: creating darshan-util-config.h
config.status: darshan-util-config.h is unchanged
[darshan-master-mpich-3.0.4-profile-conf] $ /bin/bash /tmp/hudson6153197364897946352.sh
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib>
install -m 755 lib/libdarshan.a <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib>
install -m 755 lib/libdarshan-stubs.a <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-mk-log-dirs.pl <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-gen-cc.pl <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-gen-cxx.pl <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-gen-fortran.pl <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-config <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/craype-1.x/modulefiles/darshan>
install -m 755 share/craype-1.x/darshan-module <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/craype-1.x/modulefiles/darshan/3.1.4>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/craype-2.x/modulefiles/darshan>
install -m 755 share/craype-2.x/darshan-module <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/craype-2.x/modulefiles/darshan/3.1.4>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/mpi-profile>
install -m 755 share/mpi-profile/darshan-cc.conf <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/mpi-profile/darshan-cc.conf>
install -m 755 share/mpi-profile/darshan-cxx.conf <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/mpi-profile/darshan-cxx.conf>
install -m 755 share/mpi-profile/darshan-f.conf <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/mpi-profile/darshan-f.conf>
install -m 755 share/mpi-profile/darshan-bg-cc.conf <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/mpi-profile/darshan-bg-cc.conf>
install -m 755 share/mpi-profile/darshan-bg-cxx.conf <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/mpi-profile/darshan-bg-cxx.conf>
install -m 755 share/mpi-profile/darshan-bg-f.conf <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/mpi-profile/darshan-bg-f.conf>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/ld-opts>
install -m 644 share/ld-opts/darshan-base-ld-opts <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/ld-opts/darshan-base-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-posix-ld-opts <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/ld-opts/darshan-posix-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-pnetcdf-ld-opts <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/ld-opts/darshan-pnetcdf-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-stdio-ld-opts <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share/ld-opts/darshan-stdio-ld-opts>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib/pkgconfig>
install -m 644 lib/pkgconfig/darshan-runtime.pc <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib/pkgconfig/darshan-runtime.pc>
make: Nothing to be done for `all'.
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 755 darshan-analyzer <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-convert <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-diff <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-parser <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-dxt-parser <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 darshan-merge <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 ../../darshan-util/darshan-summary-per-file.sh <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 ../../darshan-util/dxt_analyzer.py <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -m 755 libdarshan-util.a <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib>
install -m 644 ../../darshan-util/darshan-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-posix-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-mpiio-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-hdf5-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-pnetcdf-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-bgq-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-null-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-lustre-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-stdio-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-dxt-logutils.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-null-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-posix-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-mpiio-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-hdf5-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-pnetcdf-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-bgq-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-lustre-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-stdio-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-dxt-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include/uthash-1.9.2>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include/uthash-1.9.2/src>
install -m 644 uthash-1.9.2/src/uthash.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include/uthash-1.9.2/src/>
install -m 644 ../../darshan-util/../darshan-log-format.h <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/include>
install -m 755 darshan-job-summary/bin/darshan-job-summary.pl <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/bin>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib/TeX>
install -m 644 ../../darshan-util/darshan-job-summary/lib/TeX/Encode.pm <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib/TeX/>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib/Number>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib/Number/Bytes>
install -m 644 ../../darshan-util/darshan-job-summary/lib/Number/Bytes/Human.pm <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib/Number/Bytes>
install -d <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share>
install -m 644 ../../darshan-util/darshan-job-summary/share/* <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/share>
install -m 644 maint/darshan-util.pc <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/install/lib/pkgconfig>
[darshan-master-mpich-3.0.4-profile-conf] $ /bin/bash /tmp/hudson4547465269383131504.sh
Running <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/access-size-counter-test.sh...>
Done.
Running <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/cxxpi.sh...>
Process 0 of 4 is on thrash
Process 2 of 4 is on thrash
Process 3 of 4 is on thrash
pi is approximately 3.14159 Error is 8.33331e-10
wall clock time = 0.00518966
Process 1 of 4 is on thrash
Done.
Running <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/fperf-f77.sh...>
 Access size per process =      4194304  bytes, ntimes =            5
 Write bandwidth without file sync =    1298.2444546918805       Mbytes/sec
 Read bandwidth without prior file sync =    2282.5503317546468       Mbytes/sec
 Write bandwidth including file sync =    81.486520586991332       Mbytes/sec
 Read bandwidth after file sync =    2861.4486083955758       Mbytes/sec
Done.
Running <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/fperf-f90.sh...>
 Write bandwidth without file sync =    1231.1913949376958       Mbytes/sec
 Read bandwidth without prior file sync =    2433.1366196764980       Mbytes/sec
 Write bandwidth including file sync =    75.682731486238765       Mbytes/sec
 Read bandwidth after file sync =    2573.6502149683270       Mbytes/sec
Done.
Running <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/fprintf-fscanf-test.sh...>
# Using stdio calls.
Error: STDIO bytes read count of 0 is incorrect
Error: failed to execute test case <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/fprintf-fscanf-test.sh>
Done.
Running <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/mpi-io-test-dxt.sh...>
# Using mpi-io calls.
nr_procs = 4, nr_iter = 1, blk_sz = 16777216, coll = 0
# total_size = 67108864
# Write: min_t = 0.012038, max_t = 0.045202, mean_t = 0.028573, var_t = 0.000203
# Read:  min_t = 0.018333, max_t = 0.039545, mean_t = 0.030937, var_t = 0.000108
Write bandwidth = 1484.627474 Mbytes/sec
Read bandwidth = 1697.032953 Mbytes/sec
Done.
Running <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/mpi-io-test.sh...>
# Write: min_t = 0.010976, max_t = 0.042630, mean_t = 0.026638, var_t = 0.000187
# Read:  min_t = 0.018214, max_t = 0.039540, mean_t = 0.030915, var_t = 0.000108
Write bandwidth = 1574.218423 Mbytes/sec
Read bandwidth = 1697.237609 Mbytes/sec
Done.
Running <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/darshan-test/regression/test-cases/stdio-test.sh...>
Done.
1 tests failed
Build step 'Execute shell' marked build as failure
Recording test results
More information about the Darshan-commits mailing list
