[Darshan-commits] [Git][darshan/darshan][issue-229-negative-stdio] improve bookkeeping and filtering of stdin/out/err
Philip Carns
xgitlab at cels.anl.gov
Fri May 5 12:33:45 CDT 2017
Philip Carns pushed to branch issue-229-negative-stdio at darshan / darshan
Commits:
c4133f01 by Phil Carns at 2017-05-05T12:33:09-05:00
1 changed file:
- darshan-runtime/lib/darshan-stdio.c
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -956,10 +956,12 @@ int DARSHAN_DECL(fsetpos64)(FILE *stream, const fpos64_t *pos)
static void stdio_runtime_initialize()
int stdio_buf_size;
+ struct stdio_file_record_ref *rec_ref;
/* try to store default number of records for this module */
stdio_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_stdio_file);
+ STDIO_LOCK();
/* register the stdio module with darshan core */
darshan_core_register_module(
DARSHAN_STDIO_MOD,
@@ -972,6 +974,7 @@ static void stdio_runtime_initialize()
if(stdio_buf_size < sizeof(struct darshan_stdio_file))
darshan_core_unregister_module(DARSHAN_STDIO_MOD);
+ STDIO_UNLOCK();
return;
@@ -979,14 +982,31 @@ static void stdio_runtime_initialize()
if(!stdio_runtime)
+ STDIO_UNLOCK();
return;
memset(stdio_runtime, 0, sizeof(*stdio_runtime));
/* instantiate records for stdin, stdout, and stderr */
+ /* NOTE: the RECORD_OPEN initializes a record, but then we immediately zero out the
+ * open count because we did not actual observe an explicit open call for these streams
STDIO_RECORD_OPEN(stdin, "<STDIN>", 0, 0);
+ rec_ref = darshan_lookup_record_ref(stdio_runtime->stream_hash, &stdin, sizeof(stdin));
+ assert(rec_ref);
+ rec_ref->file_rec->counters[STDIO_OPENS] = 0;
STDIO_RECORD_OPEN(stdout, "<STDOUT>", 0, 0);
+ rec_ref = darshan_lookup_record_ref(stdio_runtime->stream_hash, &stdout, sizeof(stdout));
+ assert(rec_ref);
STDIO_RECORD_OPEN(stderr, "<STDERR>", 0, 0);
+ rec_ref = darshan_lookup_record_ref(stdio_runtime->stream_hash, &stderr, sizeof(stderr));
+ assert(rec_ref);
+ STDIO_UNLOCK();
@@ -1231,8 +1251,9 @@ static void stdio_shutdown(
for(i=0; i<stdio_rec_count; i++)
- if(stdio_rec_buf[i].counters[STDIO_WRITES] == 0 &&
- stdio_rec_buf[i].counters[STDIO_READS] == 0)
+ if(stdio_rec_buf[i].counters[STDIO_OPENS] == 0 &&
+ stdio_rec_buf[i].counters[STDIO_READS] == 0 &&
+ stdio_rec_buf[i].counters[STDIO_WRITES] == 0)
if(i != (stdio_rec_count-1))
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/c4133f01d66dec65d1cc9425ab983d49ca478726
You're receiving this email because of your account on xgitlab.cels.anl.gov.
More information about the Darshan-commits
