[Darshan-commits] Build failed in Jenkins: darshan-master-mpich-3.0.4-profile-conf #644
help at cels.anl.gov
Wed Mar 1 15:41:02 CST 2017
See <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/644/display/redirect>
Started by timer
[EnvInject] - Loading node environment variables.
Building remotely on churn.mcs.anl.gov (mcs) in workspace <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/>
> git rev-parse --is-inside-work-tree # timeout=10
Fetching changes from the remote Git repository
> git config remote.origin.url https://xgitlab.cels.anl.gov/darshan/darshan.git # timeout=10
Fetching upstream changes from https://xgitlab.cels.anl.gov/darshan/darshan.git
> git --version # timeout=10
> git fetch --tags --progress https://xgitlab.cels.anl.gov/darshan/darshan.git +refs/heads/*:refs/remotes/origin/*
> git rev-parse origin/master^{commit} # timeout=10
Checking out Revision e9bd9496d81f67767f53aeecd1a147939f932a4a (origin/master)
> git config core.sparsecheckout # timeout=10
> git checkout -f e9bd9496d81f67767f53aeecd1a147939f932a4a
> git rev-list e9bd9496d81f67767f53aeecd1a147939f932a4a # timeout=10
> git tag -a -f -m Jenkins Build #644 jenkins-darshan-master-mpich-3.0.4-profile-conf-644 # timeout=10
[darshan-master-mpich-3.0.4-profile-conf] $ /bin/bash /tmp/hudson1322719778622424968.sh
--2017-03-01 15:41:01-- http://www.mpich.org/static/downloads/3.0.4/mpich-3.0.4.tar.gz
Resolving www.mpich.org (www.mpich.org)... 140.221.6.71
Connecting to www.mpich.org (www.mpich.org)|140.221.6.71|:80... connected.
HTTP request sent, awaiting response... 403 Forbidden
2017-03-01 15:41:01 ERROR 403: Forbidden.
Build step 'Execute shell' marked build as failure
Recording test results
ERROR: Step ‘Publish JUnit test result report’ failed: Test reports were found but none of them are new. Did tests run?
For example, <https://jenkins-ci.cels.anl.gov/job/darshan-master-mpich-3.0.4-profile-conf/ws/build-result.xml> is 23 hr old
More information about the Darshan-commits
