[Darshan-commits] [Git][darshan/darshan][master] 2 commits: this probably shouldn't have been checked in
Glenn K. Lockwood xgitlab at cels.anl.gov
Tue Jan 24 20:38:23 CST 2017
Glenn K. Lockwood pushed to branch master at darshan / darshan
Commits:
2b1649df by Glenn K. Lockwood at 2017-01-24T18:29:43-08:00
c95a5d88 by Glenn K. Lockwood at 2017-01-24T18:36:18-08:00
fixes #214 (LOV_MAX_STRIPE_COUNT not exposed in lustre_user.h for Lustre < 2.4)
2 changed files:
- darshan-runtime/lib/darshan-lustre.c
- − darshan-runtime/lib/darshan-lustre_old.c
Changes:
--- a/darshan-runtime/lib/darshan-lustre.c
+++ b/darshan-runtime/lib/darshan-lustre.c
@@ -47,6 +47,9 @@ static int my_rank = -1;
 #define LUSTRE_LOCK() pthread_mutex_lock(&lustre_runtime_mutex)
 #define LUSTRE_UNLOCK() pthread_mutex_unlock(&lustre_runtime_mutex)
+#ifndef LOV_MAX_STRIPE_COUNT /* for Lustre < 2.4 */
+    #define LOV_MAX_STRIPE_COUNT 2000
+#endif
 void darshan_instrument_lustre_file(const char* filepath, int fd)
     struct lustre_record_ref *rec_ref;
darshan-runtime/lib/darshan-lustre_old.c deleted
--- a/darshan-runtime/lib/darshan-lustre_old.c
+++ /dev/null
@@ -1,543 +0,0 @@
- * Copyright (C) 2015 University of Chicago.
- * See COPYRIGHT notice in top-level directory.
-#define _XOPEN_SOURCE 500
-#define _GNU_SOURCE
-#include "darshan-runtime-config.h"
-#include <stdio.h>
-#include <unistd.h>
-#include <sys/types.h>
-#include <sys/stat.h>
-#include <time.h>
-#include <stdlib.h>
-#include <assert.h>
-#include <pthread.h>
-#include <sys/ioctl.h>
-/* XXX stick this into autoconf .h */
-#include <lustre/lustre_user.h>
-#include "uthash.h"
-#include "darshan.h"
-#include "darshan-dynamic.h"
-#include "darshan-lustre.h"
-struct lustre_runtime *lustre_runtime = NULL;
-static pthread_mutex_t lustre_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
-static int instrumentation_disabled = 0;
-static int my_rank = -1;
-static void lustre_runtime_initialize(void);
-static void lustre_begin_shutdown(void);
-static void lustre_get_output_data(MPI_Comm mod_comm, darshan_record_id *shared_recs,
-    int shared_rec_count, void **lustre_buf, int *lustre_buf_sz);
-static void lustre_shutdown(void);
-static int lustre_record_compare(const void* a_p, const void* b_p);
-static void lustre_record_reduction_op(void* infile_v, void* inoutfile_v,
-    int *len, MPI_Datatype *datatype);
-#define LUSTRE_LOCK() pthread_mutex_lock(&lustre_runtime_mutex)
-#define LUSTRE_UNLOCK() pthread_mutex_unlock(&lustre_runtime_mutex)
-#define LUSTRE_RECORD_SIZE( osts ) ( sizeof(struct darshan_lustre_record) + sizeof(int64_t) * (osts - 1) )
-void darshan_instrument_lustre_file(const char* filepath, int fd)
-    struct lustre_record_runtime *rec_rt;
-    struct darshan_lustre_record *rec;
-    struct darshan_fs_info fs_info;
-    darshan_record_id rec_id;
-    int limit_flag;
-    int i;
-    struct lov_user_md *lum;
-    size_t lumsize = sizeof(struct lov_user_md) +
-        LOV_MAX_STRIPE_COUNT * sizeof(struct lov_user_ost_data);
-    size_t rec_size;
-    LUSTRE_LOCK();
-    /* make sure the lustre module is already initialized */
-    lustre_runtime_initialize();
-    /* if we can't issue ioctl, we have no counter data at all */
-    if ( (lum = calloc(1, lumsize)) == NULL )
-        return;
-    /* find out the OST count of this file so we can allocate memory */
-    lum->lmm_magic = LOV_USER_MAGIC;
-    lum->lmm_stripe_count = LOV_MAX_STRIPE_COUNT;
-    /* -1 means ioctl failed, likely because file isn't on Lustre */
-    if ( ioctl( fd, LL_IOC_LOV_GETSTRIPE, (void *)lum ) == -1 )
-        free(lum);
-        return;
-    rec_size = LUSTRE_RECORD_SIZE( lum->lmm_stripe_count );
-        /* broken out for clarity */
-        void *end_of_new_record = (char*)lustre_runtime->next_free_record + rec_size;
-        void *end_of_rec_buffer = (char*)lustre_runtime->record_buffer + lustre_runtime->record_buffer_max;
-        limit_flag = ( end_of_new_record > end_of_rec_buffer );
-    /* register a Lustre file record with Darshan */
-    fs_info.fs_type = -1;
-    darshan_core_register_record(
-        (void *)filepath,
-        strlen(filepath),
-        DARSHAN_LUSTRE_MOD,
-        1,
-        limit_flag,
-        &rec_id,
-        &fs_info);
-    /* if record id is 0, darshan has no more memory for instrumenting */
-    if(rec_id == 0)
-        free(lum);
-        LUSTRE_UNLOCK();
-        return;
-    /* search the hash table for this file record, and initialize if not found */
-    HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &rec_id, sizeof(darshan_record_id), rec_rt );
-    if ( !rec_rt ) {
-        /* allocate a new lustre record and append it to the array */
-        rec_rt = &(lustre_runtime->record_runtime_array[lustre_runtime->record_count]);
-        rec_rt->record = lustre_runtime->next_free_record;
-        rec_rt->record_size = rec_size;
-        lustre_runtime->next_free_record = (char*)(lustre_runtime->next_free_record) + rec_size;
-        lustre_runtime->record_buffer_used += rec_size;
-        rec = rec_rt->record;
-        rec->rec_id = rec_id;
-        rec->rank = my_rank;
-        /* implicit assumption here that none of these counters will change
-         * after the first time a file is opened.  This may not always be
-         * true in the future */
-        if ( fs_info.fs_type != -1 )
-            rec->counters[LUSTRE_OSTS] = fs_info.ost_count;
-            rec->counters[LUSTRE_MDTS] = fs_info.mdt_count;
-        else
-            rec->counters[LUSTRE_OSTS] = -1;
-            rec->counters[LUSTRE_MDTS] = -1;
-        rec->counters[LUSTRE_STRIPE_SIZE] = lum->lmm_stripe_size;
-        rec->counters[LUSTRE_STRIPE_WIDTH] = lum->lmm_stripe_count;
-        rec->counters[LUSTRE_STRIPE_OFFSET] = lum->lmm_stripe_offset;
-        for ( i = 0; i < lum->lmm_stripe_count; i++ )
-            rec->ost_ids[i] = lum->lmm_objects[i].l_ost_idx;
-        free(lum);
-        HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt);
-        lustre_runtime->record_count++;
-    LUSTRE_UNLOCK();
-    return;
-static void lustre_runtime_initialize()
-    int mem_limit;
-    int max_records;
-    struct darshan_module_funcs lustre_mod_fns =
-        .begin_shutdown = &lustre_begin_shutdown,
-        .get_output_data = &lustre_get_output_data,
-        .shutdown = &lustre_shutdown
-    /* don't do anything if already initialized or instrumenation is disabled */
-    if(lustre_runtime || instrumentation_disabled)
-        return;
-    /* register the lustre module with darshan-core */
-    darshan_core_register_module(
-        &lustre_mod_fns,
-        &my_rank,
-        &mem_limit,
-        NULL);
-    /* return if no memory assigned by darshan core */
-    if(mem_limit == 0)
-        return;
-    lustre_runtime = malloc(sizeof(*lustre_runtime));
-    if(!lustre_runtime)
-        return;
-    memset(lustre_runtime, 0, sizeof(*lustre_runtime));
-    /* allocate the full size of the memory limit we are given */
-    lustre_runtime->record_buffer= malloc(mem_limit);
-    if(!lustre_runtime->record_buffer)
-        lustre_runtime->record_buffer_max = 0;
-        return;
-    lustre_runtime->record_buffer_max = mem_limit;
-    lustre_runtime->next_free_record = lustre_runtime->record_buffer;
-    memset(lustre_runtime->record_buffer, 0, lustre_runtime->record_buffer_max);
-    /* Allocate array of Lustre runtime data.  We calculate the maximum possible
-     * number of records that will fit into mem_limit by assuming that each
-     * record has the minimum possible OST count, then allocate that many
-     * runtime records.  record_buffer will always run out of memory before
-     * we overflow record_runtime_array.
-    max_records = mem_limit / sizeof(struct darshan_lustre_record);
-    lustre_runtime->record_runtime_array =
-        malloc( max_records * sizeof(struct lustre_record_runtime));
-    if(!lustre_runtime->record_runtime_array)
-        free( lustre_runtime->record_buffer );
-        return;
-    memset(lustre_runtime->record_runtime_array, 0,
-        max_records * sizeof(struct lustre_record_runtime));
-    return;
- * Functions exported by Lustre module for coordinating with darshan-core *
-    assert(lustre_runtime);
-    LUSTRE_LOCK();
-    /* disable further instrumentation while Darshan shuts down */
-    instrumentation_disabled = 1;
-    LUSTRE_UNLOCK();
-    return;
-    MPI_Comm mod_comm,
-    darshan_record_id *shared_recs,
-    void **lustre_buf,
-    int *lustre_buf_sz)
-    struct lustre_record_runtime *file;
-    int i, ishared;
-    int *rec_lengths;
-    size_t shared_rec_size;
-    struct darshan_lustre_record *red_send_buf = NULL;
-    struct darshan_lustre_record *red_recv_buf = NULL;
-    MPI_Datatype red_type;
-    MPI_Aint *rec_offsets;
-    MPI_Op red_op;
-    /* if there are globally shared files, do a shared file reduction */
-    /* NOTE: the shared file reduction is also skipped if the
-     * DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
-    if (shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
-        /* necessary initialization of shared records */
-        for(i = 0; i < shared_rec_count; i++)
-            HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &shared_recs[i],
-                sizeof(darshan_record_id), file);
-            assert(file);
-            file->record->rank = -1;
-        /* sort the array of files descending by rank so that we get all of the
-         * shared files (marked by rank -1) in a contiguous portion at end
-         * of the array
-        sort_lustre_records();
-        /* make red_send_buf point to the first shared-file record */
-        ishared = lustre_runtime->record_count - shared_rec_count;
-        red_send_buf =
-            (lustre_runtime->record_runtime_array[ishared]).record;
-        /* allocate memory for the reduction output on rank 0 */
-        if (my_rank == 0)
-            shared_rec_size = lustre_runtime->record_buffer_used - ((char*)red_send_buf - (char*)lustre_runtime->record_buffer);
-            red_recv_buf = malloc(shared_rec_size);
-            if (!red_recv_buf)
-                return;
-        /* need to build rec_lengths (array of ints) and rec_offsets (array of ints) */
-        rec_lengths = malloc(sizeof(*rec_lengths) * shared_rec_count);
-        rec_offsets = malloc(sizeof(*rec_offsets) * shared_rec_count);
-        for ( i = ishared; i < shared_rec_count; i ++ )
-            rec_lengths[i] = (lustre_runtime->record_runtime_array[i]).record_size;
-            rec_offsets[i] = (char*)((lustre_runtime->record_runtime_array[i]).record) -
-                (char*)((lustre_runtime->record_runtime_array[ishared]).record);
-        DARSHAN_MPI_CALL(PMPI_Type_hindexed)(
-            shared_rec_count,
-            rec_lengths,
-            rec_offsets,
-            MPI_BYTE,
-            &red_type
-        DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
-        DARSHAN_MPI_CALL(PMPI_Op_create)(lustre_record_reduction_op, 1, &red_op);
-        DARSHAN_MPI_CALL(PMPI_Reduce)(red_send_buf, red_recv_buf,
-            shared_rec_count, red_type, red_op, 0, mod_comm);
-        /* clean up reduction state */
-        if (my_rank == 0)
-            memcpy(&(lustre_runtime->record_buffer[ishared]), red_recv_buf,
-                shared_rec_size);
-            free(red_recv_buf);
-        else
-            lustre_runtime->record_count -= shared_rec_count;
-        free(rec_lengths);
-        free(rec_offsets);
-        DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
-        DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
-    *lustre_buf = (void *)(lustre_runtime->record_buffer);
-    *lustre_buf_sz = lustre_runtime->record_buffer_used;
-    return;
-    HASH_CLEAR(hlink, lustre_runtime->record_runtime_hash);
-    free(lustre_runtime->record_runtime_array);
-    free(lustre_runtime->record_buffer);
-    free(lustre_runtime);
-    lustre_runtime = NULL;
-    return;
-/* compare function for sorting file records by descending rank */
-    const struct lustre_record_runtime* a = a_p;
-    const struct lustre_record_runtime* b = b_p;
-    if (a->record->rank < b->record->rank)
-        return 1;
-    if (a->record->rank > b->record->rank)
-        return -1;
-    /* if ( a->record->rank == b->record->rank ) we MUST do a secondary
-     * sort so that the order of qsort is fully deterministic and consistent
-     * across all MPI ranks.  Without a secondary sort, the sort order can
-     * be affected by rank-specific variations (e.g., the order in which
-     * files are first opened).
-    return 0;
- * Sort the record_runtimes and records by MPI rank to facilitate shared redux.
- * This requires craftiness and additional heap utilization because the records
- * (but not record_runtimes) have variable size.  Currently has to temporarily
- * duplicate the entire record_buffer; there is room for more memory-efficient
- * optimization if this becomes a scalability issue.
-int sort_lustre_records()
-    int i;
-    struct lustre_record_runtime *rec_rt, *tmp_rec_rt;
-    char  *new_buf, *p;
-    /* Create a new buffer to store an entire replica of record_buffer.  Since
-     * we know the exact size of record_buffer's useful data at this point, we
-     * can allocate the exact amount we need instead of record_buffer_max */
-    new_buf = malloc(lustre_runtime->record_buffer_used);
-    p = new_buf;
-    if ( !new_buf )
-        return 1;
-    /* qsort breaks the hash table, so delete it now to free its memory buffers
-     * and prevent later confusion */
-    HASH_ITER( hlink, lustre_runtime->record_runtime_hash, rec_rt, tmp_rec_rt )
-        HASH_DELETE( hlink, lustre_runtime->record_runtime_hash, rec_rt );
-    /* sort the runtime records, which is has fixed-length elements */
-    qsort(
-        lustre_runtime->record_runtime_array,
-        lustre_runtime->record_count,
-        sizeof(struct lustre_record_runtime),
-        lustre_record_compare
-    /* rebuild the hash and array with the qsorted runtime records */
-    for ( i = 0; i < lustre_runtime->record_count; i++ )
-        rec_rt = &(lustre_runtime->record_runtime_array[i]);
-        HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt );
-    /* create reordered record buffer, then copy it back in place */
-        memcpy( p, rec_rt->record, rec_rt->record_size );
-        /* fix record pointers within each runtime record too - pre-emptively
-         * point them at where they will live in record_buffer after we memcpy
-         * below */
-        rec_rt->record = (struct darshan_lustre_record *)((char*)(lustre_runtime->record_buffer) + (p - new_buf));
-        p += rec_rt->record_size;
-    memcpy(
-        lustre_runtime->record_buffer,
-        new_buf,
-        lustre_runtime->record_buffer_used );
-    free(new_buf);
-    return 0;
-/* this is just boilerplate reduction code that isn't currently used */
-    struct darshan_lustre_record tmp_record;
-    struct darshan_lustre_record *infile = infile_v;
-    struct darshan_lustre_record *inoutfile = inoutfile_v;
-    int i, j;
-    for( i=0; i<*len; i++ )
-        memset(&tmp_record, 0, sizeof(struct darshan_lustre_record));
-        tmp_record.rec_id = infile->rec_id;
-        tmp_record.rank = -1;
-        /* preserve only rank 0's value */
-        for( j = LUSTRE_OSTS; j < LUSTRE_NUM_INDICES; j++)
-            if ( my_rank == 0 )
-                tmp_record.counters[j] = infile->counters[j];
-            else
-                tmp_record.counters[j] = inoutfile->counters[j];
-        /* update pointers */
-        *inoutfile = tmp_record;
-        inoutfile++;
-        infile++;
-    return;
- *  Dump the memory structure of our records and runtime records
-void print_lustre_runtime( void )
-    int i, j;
-    /* print what we just loaded */
-        rec = (lustre_runtime->record_runtime_array[i]).record;
-        printf( "File %2d\n", i );
-        for ( j = 0; j < LUSTRE_NUM_INDICES; j++ )
-            printf( "  Counter %-2d: %10ld, addr %ld\n",
-                j,
-                rec->counters[j],
-                (char*)(&(rec->counters[j])) - (char*)(lustre_runtime->record_buffer) );
-        for ( j = 0; j < rec->counters[LUSTRE_STRIPE_WIDTH]; j++ )
-            if ( j > 0 && j % 2 == 0 ) printf("\n");
-            printf( "  Stripe  %-2d: %10ld, addr %-9d",
-                j,
-                rec->ost_ids[j],
-                (char*)(&(rec->ost_ids[j])) - (char*)(lustre_runtime->record_buffer) );
-        printf( "\n" );
-    return;
- *  Dump the order in which records appear in memory
-void print_array( void )
-    int i;
-    printf("*** DUMPING RECORD LIST BY ARRAY SEQUENCE\n");
-        printf( "*** record %d rank %d osts %d\n",
-            rec_rt->record->rec_id,
-            rec_rt->record->rank,
-            rec_rt->record->counters[LUSTRE_STRIPE_WIDTH]);
-void print_hash( void )
-    printf("*** DUMPING RECORD LIST BY HASH SEQUENCE\n");
-    return;
- * Local variables:
- *  c-indent-level: 4
- *  c-basic-offset: 4
- * End:
- * vim: ts=8 sts=4 sw=4 expandtab
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/1561ab231dbda237c064146d05019213dc74c7f8...c95a5d88b871c72b6c092f58985235321d52f747
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20170124/ee9c56f4/attachment-0001.html>
More information about the Darshan-commits mailing list
