[Darshan-commits] [Git][darshan/darshan][issue-217-hdf5-abi-switch] add configure option for older HDF5 API
Philip Carns
xgitlab at cels.anl.gov
Mon Jan 23 21:29:51 CST 2017
Philip Carns pushed to branch issue-217-hdf5-abi-switch at darshan / darshan
Commits:
0b434339 by Phil Carns at 2017-01-23T21:29:13-06:00
- also rename option for newer API
- make the two options mutually exclusive
3 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-runtime-config.h.in
Changes:
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -701,7 +701,8 @@ with_log_hints
with_log_path
with_jobid_env
with_mod_mem
-enable_HDF5_post_1_10_abi
+enable_HDF5_post_1_10
+enable_HDF5_pre_1_10
ac_precious_vars='build_alias
host_alias
@@ -1339,8 +1340,10 @@ Optional Features:
--disable-bgq-mod Disables compilation and use of BG/Q module (for BG/Q systems)
--disable-lustre-mod Disables compilation and use of the Lustre module
--enable-mmap-logs Enables ability to mmap I/O data to log file
- --enable-HDF5-post-1.10-abi
+ --enable-HDF5-post-1.10
Enable HDF5 module for HDF5 version 1.10 or later
+ --enable-HDF5-pre-1.10
+ Enable HDF5 module for HDF5 version 1.8 or earlier
Optional Packages:
--with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
@@ -4203,12 +4206,28 @@ exec_prefix=$saveExecprefix
BUILD_HDF5_MODULE=
DARSHAN_HDF5_LD_OPTS=
-# Check whether --enable-HDF5-post-1.10-abi was given.
-if test "${enable_HDF5_post_1_10_abi+set}" = set; then :
- enableval=$enable_HDF5_post_1_10_abi; if test "x$enableval" = "xyes" ; then
+# see if user explicitly enabled support for an HDF5 API
+# Check whether --enable-HDF5-post-1.10 was given.
+if test "${enable_HDF5_post_1_10+set}" = set; then :
+ enableval=$enable_HDF5_post_1_10; if test "x$enableval" = "xyes" ; then
$as_echo "#define __DARSHAN_ENABLE_HDF5110 1" >>confdefs.h
+ if test "x$BUILD_HDF5_MODULE" = "x1"; then
+ as_fn_error $? "Cannot set both --enable-HDF5-post-1.10 and --enable-HDF5-pre-1.10" "$LINENO" 5
+ fi
+ BUILD_HDF5_MODULE=1
+ DARSHAN_HDF5_LD_OPTS="${darshan_share_path}/ld-opts/darshan-hdf5-ld-opts"
+fi
+fi
+# Check whether --enable-HDF5-pre-1.10 was given.
+if test "${enable_HDF5_pre_1_10+set}" = set; then :
+ enableval=$enable_HDF5_pre_1_10; if test "x$enableval" = "xyes" ; then
+ fi
BUILD_HDF5_MODULE=1
fi
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -258,11 +258,26 @@ exec_prefix=$saveExecprefix
BUILD_HDF5_MODULE=
-AC_ARG_ENABLE(HDF5-post-1.10-abi,
-[ --enable-HDF5-post-1.10-abi
+AC_ARG_ENABLE(HDF5-post-1.10,
+[ --enable-HDF5-post-1.10
Enable HDF5 module for HDF5 version 1.10 or later],
[if test "x$enableval" = "xyes" ; then
- AC_DEFINE(__DARSHAN_ENABLE_HDF5110, 1, Set for compatibility with HDF5_1.10.x, breaks use with 1.8.x)
+ AC_DEFINE(__DARSHAN_ENABLE_HDF5110, 1, Set for compatibility with HDF5 1.10.x, breaks use with 1.8.x)
+ AC_MSG_ERROR([Cannot set both --enable-HDF5-post-1.10 and --enable-HDF5-pre-1.10])
+ fi
+fi]
+AC_ARG_ENABLE(HDF5-pre-1.10,
+[ --enable-HDF5-pre-1.10
+ Enable HDF5 module for HDF5 version 1.8 or earlier],
+[if test "x$enableval" = "xyes" ; then
+ fi
BUILD_HDF5_MODULE=1
fi]
--- a/darshan-runtime/darshan-runtime-config.h.in
+++ b/darshan-runtime/darshan-runtime-config.h.in
@@ -87,7 +87,7 @@
/* Define if cuserid() should be disabled */
#undef __DARSHAN_DISABLE_CUSERID
-/* Set for compatibility with HDF5_1.10.x */
+/* Set for compatibility with HDF5 1.10.x */
#undef __DARSHAN_ENABLE_HDF5110
/* Define if Darshan should mmap data structures to log file */
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/0b4343393eec35fd4b229f74a869407db141c179
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20170123/f9d03c48/attachment-0001.html>
More information about the Darshan-commits
