[Darshan-commits] [Git][darshan/darshan][master] 4 commits: demonstrator for #218
Shane Snyder xgitlab at cels.anl.gov
Mon Jan 23 16:03:18 CST 2017
Shane Snyder pushed to branch master at darshan / darshan
Commits:
640f20ff by Phil Carns at 2017-01-22T19:32:09-05:00
8a6a35b0 by Phil Carns at 2017-01-22T19:39:16-05:00
script to run reproducer in regression test
ace2260c by Phil Carns at 2017-01-22T19:44:43-05:00
fix segfault in common val counters
1561ab23 by Shane Snyder at 2017-01-23T16:02:49-06:00
Merge branch 'issue-218-val-counter' into 'master'
Issue 218 val counter
Closes #218
See merge request !6
4 changed files:
- ChangeLog
- darshan-runtime/lib/darshan-common.c
- + darshan-test/regression/test-cases/access-size-counter-test.sh
- + darshan-test/regression/test-cases/src/access-size-counter-test.c
Changes:
ChangeLog
--- a/ChangeLog
+++ b/ChangeLog
@@ -10,6 +10,9 @@ Darshan-3.1.3-pre1
 * skip instrumentation attempts for anonymous mmap() calls; this avoids a
   potentential deadlock condition when used with hugepages on Cray systems.
   Reported by Glenn Lockwood and Cristian Simarro.
+* fix segmentation fault in statistics collection for applications that issue
+  operations with a large number of distince access sizes or strides on the
+  same file.  Reported by Glenn Lockwood.
 Darshan-3.1.2
--- a/darshan-runtime/lib/darshan-common.c
+++ b/darshan-runtime/lib/darshan-common.c
@@ -267,9 +267,13 @@ void darshan_common_val_counter(void **common_val_root, int *common_val_count,
         (*common_val_count)++;
-    /* update common access counters as we go */
-    DARSHAN_COMMON_VAL_COUNTER_INC(common_val_p, common_cnt_p,
-        found->val, found->freq, 1);
+    /* update common access counters as we go, as long as we haven't already
+     * hit the limit in the number we are willing to track */
+    if(found)
+        DARSHAN_COMMON_VAL_COUNTER_INC(common_val_p, common_cnt_p,
+            found->val, found->freq, 1);
     return;
--- /dev/null
+++ b/darshan-test/regression/test-cases/access-size-counter-test.sh
@@ -0,0 +1,32 @@
+#!/bin/bash
+PROG=access-size-counter-test
+# set log file path; remove previous log if present
+export DARSHAN_LOGFILE=$DARSHAN_TMP/${PROG}.darshan
+rm -f ${DARSHAN_LOGFILE}
+# compile
+$DARSHAN_CC $DARSHAN_TESTDIR/test-cases/src/${PROG}.c -o $DARSHAN_TMP/${PROG}
+if [ $? -ne 0 ]; then
+    echo "Error: failed to compile ${PROG}" 1>&2
+    exit 1
+fi
+# execute
+$DARSHAN_RUNJOB $DARSHAN_TMP/${PROG} -f $DARSHAN_TMP/${PROG}.tmp.dat
+    echo "Error: failed to execute ${PROG}" 1>&2
+    exit 1
+fi
+# parse log
+$DARSHAN_PATH/bin/darshan-parser $DARSHAN_LOGFILE > $DARSHAN_TMP/${PROG}.darshan.txt
+    echo "Error: failed to parse ${DARSHAN_LOGFILE}" 1>&2
+    exit 1
+fi
+# check results (for now just make sure it didn't crash)
+exit 0
--- /dev/null
+++ b/darshan-test/regression/test-cases/src/access-size-counter-test.c
@@ -0,0 +1,118 @@
+ * (C) 1995-2001 Clemson University and Argonne National Laboratory.
+ * See COPYING in top-level directory.
+#include <stdio.h>
+#include <stdlib.h>
+#include <fcntl.h>
+#include <unistd.h>
+#include <string.h>
+#include <sys/time.h>
+#include <mpi.h>
+#include <errno.h>
+#include <getopt.h>
+/* DEFAULT VALUES FOR OPTIONS */
+static char    opt_file[256] = "test.out";
+/* function prototypes */
+static int parse_args(int argc, char **argv);
+static void usage(void);
+/* global vars */
+static int mynod = 0;
+static int nprocs = 1;
+int main(int argc, char **argv)
+   int namelen;
+   char processor_name[MPI_MAX_PROCESSOR_NAME];
+   char buffer[128] = {0};
+   int fd;
+   int i = 1;
+   int ret;
+   /* startup MPI and determine the rank of this process */
+   MPI_Init(&argc,&argv);
+   MPI_Comm_size(MPI_COMM_WORLD, &nprocs);
+   MPI_Comm_rank(MPI_COMM_WORLD, &mynod);
+   MPI_Get_processor_name(processor_name, &namelen);
+   /* parse the command line arguments */
+   parse_args(argc, argv);
+   if(mynod == 0)
+      fd = open(opt_file, O_WRONLY|O_TRUNC|O_CREAT, S_IRUSR|S_IWUSR|S_IRGRP|S_IWGRP);
+      if(fd<0)
+         perror("open");
+         return(-1);
+      /* cycle through a range of unique write access sizes */
+      for(i=1; i<128; i++)
+         ret = write(fd, buffer, i);
+         if(ret < 0)
+            perror("write");
+            return(-1);
+         if(ret != i)
+            fprintf(stderr, "Short write: %d\n", ret);
+            return(-1);
+      close(fd);
+   MPI_Finalize();
+   return(0);
+   int c;
+   while ((c = getopt(argc, argv, "f:")) != EOF) {
+      switch (c) {
+         case 'f': /* filename */
+            strncpy(opt_file, optarg, 255);
+            break;
+         case '?': /* unknown */
+            if (mynod == 0)
+                usage();
+            exit(1);
+         default:
+            break;
+   return(0);
+    printf("Usage: stdio-test [<OPTIONS>...]\n");
+    printf("\n<OPTIONS> is one of\n");
+    printf(" -f       filename [default: test.out]\n");
+    printf(" -h       print this help\n");
+ * Local variables:
+ *  c-indent-level: 3
+ *  c-basic-offset: 3
+ *  tab-width: 3
+ * vim: ts=3
+ * End:
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/8babcd89206d62f0e004c0769055f5362488d6ef...1561ab231dbda237c064146d05019213dc74c7f8
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20170123/e7fc9993/attachment-0001.html>
More information about the Darshan-commits mailing list
