[Darshan-commits] [Git][darshan/darshan][master] 2 commits: Revert "tweak autoconf help language"
Philip Carns xgitlab at cels.anl.gov
Sun Jan 22 17:22:20 CST 2017
Philip Carns pushed to branch master at darshan / darshan
Commits:
8ce9fd26 by Phil Carns at 2017-01-22T18:21:05-05:00
This reverts commit 3f12e72167ee2b15817081a9b9cf6b866010d5bb.
(Previous stronger language was more accurate)
a3c7d14b by Phil Carns at 2017-01-22T18:21:58-05:00
regen configure script
3 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-runtime-config.h.in
Changes:
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -663,6 +663,7 @@ infodir
 docdir
 oldincludedir
 includedir
+runstatedir
 localstatedir
 sharedstatedir
 sysconfdir
@@ -747,6 +748,7 @@ datadir='${datarootdir}'
 sysconfdir='${prefix}/etc'
 sharedstatedir='${prefix}/com'
 localstatedir='${prefix}/var'
+runstatedir='${localstatedir}/run'
 includedir='${prefix}/include'
 oldincludedir='/usr/include'
 docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
@@ -999,6 +1001,15 @@ do
   | -silent | --silent | --silen | --sile | --sil)
     silent=yes ;;
+  -runstatedir | --runstatedir | --runstatedi | --runstated \
+  | --runstate | --runstat | --runsta | --runst | --runs \
+  | --run | --ru | --r)
+    ac_prev=runstatedir ;;
+  -runstatedir=* | --runstatedir=* | --runstatedi=* | --runstated=* \
+  | --runstate=* | --runstat=* | --runsta=* | --runst=* | --runs=* \
+  | --run=* | --ru=* | --r=*)
+    runstatedir=$ac_optarg ;;
   -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
     ac_prev=sbindir ;;
   -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
@@ -1136,7 +1147,7 @@ fi
 for ac_var in	exec_prefix prefix bindir sbindir libexecdir datarootdir \
 		datadir sysconfdir sharedstatedir localstatedir includedir \
 		oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
-		libdir localedir mandir
+		libdir localedir mandir runstatedir
 do
   eval ac_val=\$$ac_var
   # Remove trailing slashes.
@@ -1289,6 +1300,7 @@ Fine tuning of the installation directories:
   --sysconfdir=DIR        read-only single-machine data [PREFIX/etc]
   --sharedstatedir=DIR    modifiable architecture-independent data [PREFIX/com]
   --localstatedir=DIR     modifiable single-machine data [PREFIX/var]
+  --runstatedir=DIR       modifiable per-process data [LOCALSTATEDIR/run]
   --libdir=DIR            object code libraries [EPREFIX/lib]
   --includedir=DIR        C header files [PREFIX/include]
   --oldincludedir=DIR     C header files for non-gcc [/usr/include]
@@ -1322,7 +1334,7 @@ Optional Features:
   --disable-cuserid       Disables attempted use of cuserid() at run time
   --enable-group-readable-logs
                           Set log files to be group readable
-  --enable-HDF5_1.10      Enable explicit support for HDF5 1.10.x API
+  --enable-HDF5_1.10       Compile for use with HDF5 1.10.x
   --disable-bgq-mod       Disables compilation and use of BG/Q module (for BG/Q systems)
   --disable-lustre-mod    Disables compilation and use of the Lustre module
   --enable-mmap-logs      Enables ability to mmap I/O data to log file
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -47,9 +47,9 @@ fi]
 AC_ARG_ENABLE(HDF5_1.10,
-[  --enable-HDF5_1.10      Enable explicit support for HDF5 1.10.x API],
+[  --enable-HDF5_1.10       Compile for use with HDF5 1.10.x],
 [if test "x$enableval" = "xyes" ; then
-    AC_DEFINE(__DARSHAN_ENABLE_HDF5110, 1, Explicitly enable HDF5_1.10.x support, will break 1.8.x compatibility on 32bit platforms)
+    AC_DEFINE(__DARSHAN_ENABLE_HDF5110, 1, Set for compatibility with HDF5_1.10.x, breaks use with 1.8.x)
 fi]
--- a/darshan-runtime/darshan-runtime-config.h.in
+++ b/darshan-runtime/darshan-runtime-config.h.in
@@ -87,7 +87,7 @@
 /* Define if cuserid() should be disabled */
 #undef __DARSHAN_DISABLE_CUSERID
-/* Explicitly enable HDF5_1.10.x support */
+/* Set for compatibility with HDF5_1.10.x */
 #undef __DARSHAN_ENABLE_HDF5110
 /* Define if Darshan should mmap data structures to log file */
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/165118c5517095ee0060bc25da355f695489cf3f...a3c7d14b288a6b1e8f796cdaea9759c85085b6ce
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20170122/27063e80/attachment-0001.html>
More information about the Darshan-commits mailing list
