[Darshan-commits] [Git][darshan/darshan][master] 2 commits: skip instrumentation attempts on anonymous mmap()
Shane Snyder
xgitlab at cels.anl.gov
Thu Jan 19 10:34:13 CST 2017
Shane Snyder pushed to branch master at darshan / darshan
Commits:
969b6285 by Phil Carns at 2017-01-19T08:16:46-08:00
Anonymous mmap() calls have no backing file and therefore won't match
any Darshan characterization records, so we can skip the record lookup
in this case. This also fixes a deadlock on Cray systems with hugepages
enabled, see #210.
165118c5 by Shane Snyder at 2017-01-19T10:34:10-06:00
Merge branch 'issue-210-cray-hugepages' into 'master'
Closes #210
See merge request !5
2 changed files:
- ChangeLog
- darshan-runtime/lib/darshan-posix.c
Changes:
ChangeLog
--- a/ChangeLog
+++ b/ChangeLog
@@ -7,6 +7,9 @@ Darshan-3.1.3-pre1
* add --enable-HDF5_1.10 configure option to explicitly enable HDF5 1.10+
support, needed on some platforms for API compatibility
- contributed by Karl-Ulrich Bamberg
+* skip instrumentation attempts for anonymous mmap() calls; this avoids a
+ potentential deadlock condition when used with hugepages on Cray systems.
+ Reported by Glenn Lockwood and Cristian Simarro.
Darshan-3.1.2
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -925,6 +925,14 @@ void* DARSHAN_DECL(mmap)(void *addr, size_t length, int prot, int flags,
MAP_OR_FAIL(mmap);
+ if(fd < 0 || (flags & MAP_ANONYMOUS))
+ /* mmap is not associated with a backing file; skip all Darshan
+ * characterization attempts.
+ return(__real_mmap(addr, length, prot, flags, fd, offset));
ret = __real_mmap(addr, length, prot, flags, fd, offset);
if(ret == MAP_FAILED)
return(ret);
@@ -948,6 +956,14 @@ void* DARSHAN_DECL(mmap64)(void *addr, size_t length, int prot, int flags,
MAP_OR_FAIL(mmap64);
+ return(__real_mmap64(addr, length, prot, flags, fd, offset));
ret = __real_mmap64(addr, length, prot, flags, fd, offset);
return(ret);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/78ac2f2941f971ae63a7fc61ae98ddf3a058da70...165118c5517095ee0060bc25da355f695489cf3f
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20170119/c80327c1/attachment-0001.html>
More information about the Darshan-commits
