[Darshan-commits] [Git][darshan/darshan][master] update configure version to 3.1.3
Shane Snyder xgitlab at cels.anl.gov
Fri Feb 10 16:17:19 CST 2017
Shane Snyder pushed to branch master at darshan / darshan
Commits:
7915c2fb by Shane Snyder at 2017-02-10T22:09:25+00:00
4 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-util/configure
- darshan-util/configure.in
Changes:
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1,6 +1,6 @@
 #! /bin/sh
 # Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.3-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.3.
 # Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
 # Identity of this package.
 PACKAGE_NAME='darshan-runtime'
 PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='3.1.3-pre1'
-PACKAGE_STRING='darshan-runtime 3.1.3-pre1'
+PACKAGE_VERSION='3.1.3'
+PACKAGE_STRING='darshan-runtime 3.1.3'
 PACKAGE_BUGREPORT=''
 PACKAGE_URL=''
@@ -665,7 +665,6 @@ infodir
 docdir
 oldincludedir
 includedir
-runstatedir
 localstatedir
 sharedstatedir
 sysconfdir
@@ -751,7 +750,6 @@ datadir='${datarootdir}'
 sysconfdir='${prefix}/etc'
 sharedstatedir='${prefix}/com'
 localstatedir='${prefix}/var'
-runstatedir='${localstatedir}/run'
 includedir='${prefix}/include'
 oldincludedir='/usr/include'
 docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
@@ -1004,15 +1002,6 @@ do
   | -silent | --silent | --silen | --sile | --sil)
     silent=yes ;;
-  -runstatedir | --runstatedir | --runstatedi | --runstated \
-  | --runstate | --runstat | --runsta | --runst | --runs \
-  | --run | --ru | --r)
-    ac_prev=runstatedir ;;
-  -runstatedir=* | --runstatedir=* | --runstatedi=* | --runstated=* \
-  | --runstate=* | --runstat=* | --runsta=* | --runst=* | --runs=* \
-  | --run=* | --ru=* | --r=*)
-    runstatedir=$ac_optarg ;;
   -sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
     ac_prev=sbindir ;;
   -sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
@@ -1150,7 +1139,7 @@ fi
 for ac_var in	exec_prefix prefix bindir sbindir libexecdir datarootdir \
 		datadir sysconfdir sharedstatedir localstatedir includedir \
 		oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
-		libdir localedir mandir runstatedir
+		libdir localedir mandir
 do
   eval ac_val=\$$ac_var
   # Remove trailing slashes.
@@ -1263,7 +1252,7 @@ if test "$ac_init_help" = "long"; then
   # Omit some internal or obsolete options to make the list less imposing.
   # This message is too long to be a string in the A/UX 3.1 sh.
   cat <<_ACEOF
-\`configure' configures darshan-runtime 3.1.3-pre1 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 3.1.3 to adapt to many kinds of systems.
 Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1303,7 +1292,6 @@ Fine tuning of the installation directories:
   --sysconfdir=DIR        read-only single-machine data [PREFIX/etc]
   --sharedstatedir=DIR    modifiable architecture-independent data [PREFIX/com]
   --localstatedir=DIR     modifiable single-machine data [PREFIX/var]
-  --runstatedir=DIR       modifiable per-process data [LOCALSTATEDIR/run]
   --libdir=DIR            object code libraries [EPREFIX/lib]
   --includedir=DIR        C header files [PREFIX/include]
   --oldincludedir=DIR     C header files for non-gcc [/usr/include]
@@ -1325,7 +1313,7 @@ fi
 if test -n "$ac_init_help"; then
   case $ac_init_help in
-     short | recursive ) echo "Configuration of darshan-runtime 3.1.3-pre1:";;
+     short | recursive ) echo "Configuration of darshan-runtime 3.1.3:";;
    esac
   cat <<\_ACEOF
@@ -1439,7 +1427,7 @@ fi
 test -n "$ac_init_help" && exit $ac_status
 if $ac_init_version; then
   cat <<\_ACEOF
-darshan-runtime configure 3.1.3-pre1
+darshan-runtime configure 3.1.3
 generated by GNU Autoconf 2.69
 Copyright (C) 2012 Free Software Foundation, Inc.
@@ -1791,7 +1779,7 @@ cat >config.log <<_ACEOF
 This file contains any messages produced by compilers while
 running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 3.1.3-pre1, which was
+It was created by darshan-runtime $as_me 3.1.3, which was
 generated by GNU Autoconf 2.69.  Invocation command line was
   $ $0 $@
@@ -4400,7 +4388,7 @@ else
   MPICH_LIB_OLD=0
 fi
-DARSHAN_VERSION="3.1.3-pre1"
+DARSHAN_VERSION="3.1.3"
@@ -4922,7 +4910,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 # report actual input values of CONFIG_FILES etc. instead of their
 # values after options handling.
 ac_log="
-This file was extended by darshan-runtime $as_me 3.1.3-pre1, which was
+This file was extended by darshan-runtime $as_me 3.1.3, which was
   CONFIG_FILES    = $CONFIG_FILES
@@ -4984,7 +4972,7 @@ _ACEOF
 cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
 ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
 ac_cs_version="\\
-darshan-runtime config.status 3.1.3-pre1
+darshan-runtime config.status 3.1.3
 configured by $0, generated by GNU Autoconf 2.69,
   with options \\"\$ac_cs_config\\"
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
 dnl You may need to use autoheader as well if changing any DEFINEs
 dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [3.1.3-pre1])
+AC_INIT([darshan-runtime], [3.1.3])
 AC_CONFIG_SRCDIR([darshan.h])
 AC_CONFIG_AUX_DIR(../maint/config)
 AC_CONFIG_HEADER(darshan-runtime-config.h)
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1,6 +1,6 @@
 #! /bin/sh
-# Generated by GNU Autoconf 2.69 for darshan-util 3.1.3-pre1.
+# Generated by GNU Autoconf 2.69 for darshan-util 3.1.3.
 PACKAGE_NAME='darshan-util'
 PACKAGE_TARNAME='darshan-util'
-PACKAGE_STRING='darshan-util 3.1.3-pre1'
+PACKAGE_STRING='darshan-util 3.1.3'
 PACKAGE_URL=''
@@ -661,7 +661,6 @@ infodir
 docdir
 oldincludedir
 includedir
-runstatedir
 localstatedir
 sharedstatedir
 sysconfdir
@@ -735,7 +734,6 @@ datadir='${datarootdir}'
@@ -988,15 +986,6 @@ do
     silent=yes ;;
     ac_prev=sbindir ;;
@@ -1134,7 +1123,7 @@ fi
 do
@@ -1247,7 +1236,7 @@ if test "$ac_init_help" = "long"; then
   cat <<_ACEOF
-\`configure' configures darshan-util 3.1.3-pre1 to adapt to many kinds of systems.
+\`configure' configures darshan-util 3.1.3 to adapt to many kinds of systems.
@@ -1287,7 +1276,6 @@ Fine tuning of the installation directories:
@@ -1309,7 +1297,7 @@ fi
-     short | recursive ) echo "Configuration of darshan-util 3.1.3-pre1:";;
+     short | recursive ) echo "Configuration of darshan-util 3.1.3:";;
    esac
   cat <<\_ACEOF
@@ -1405,7 +1393,7 @@ fi
   cat <<\_ACEOF
-darshan-util configure 3.1.3-pre1
+darshan-util configure 3.1.3
@@ -1770,7 +1758,7 @@ cat >config.log <<_ACEOF
-It was created by darshan-util $as_me 3.1.3-pre1, which was
+It was created by darshan-util $as_me 3.1.3, which was
   $ $0 $@
@@ -4117,7 +4105,7 @@ fi
 done
-DARSHAN_UTIL_VERSION="3.1.3-pre1"
+DARSHAN_UTIL_VERSION="3.1.3"
@@ -4633,7 +4621,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
 ac_log="
-This file was extended by darshan-util $as_me 3.1.3-pre1, which was
+This file was extended by darshan-util $as_me 3.1.3, which was
@@ -4695,7 +4683,7 @@ _ACEOF
 ac_cs_version="\\
-darshan-util config.status 3.1.3-pre1
+darshan-util config.status 3.1.3
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
-AC_INIT([darshan-util], [3.1.3-pre1])
+AC_INIT([darshan-util], [3.1.3])
 AC_CONFIG_SRCDIR([darshan-logutils.h])
 AC_CONFIG_HEADER(darshan-util-config.h)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/7915c2fb772572d5436cb103ca7ea4246f15f10b
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20170210/045dc6d2/attachment-0001.html>
More information about the Darshan-commits mailing list
