[Darshan-commits] [Git][darshan/darshan][master] fix bug in darshan-merge
Shane Snyder xgitlab at cels.anl.gov
Fri Dec 15 14:46:46 CST 2017
Shane Snyder pushed to branch master at darshan / darshan
Commits:
5ff6955f by Shane Snyder at 2017-12-15T14:46:06-06:00
utility was trying to aggregate DXT records, which have no
record aggregation function
1 changed file:
- darshan-util/darshan-merge.c
Changes:
--- a/darshan-util/darshan-merge.c
+++ b/darshan-util/darshan-merge.c
@@ -98,6 +98,10 @@ int build_mod_shared_rec_hash(char **infile_list, int n_infiles,
     int ret;
     int i;
+    /* if this module has no method for aggregating shared records, do nothing */
+    if(!(mod_logutils[mod_id]->log_agg_records))
+        return(0);
     /* loop over each input log file */
     for(i = 0; i < n_infiles; i++)
@@ -233,6 +237,8 @@ int main(int argc, char *argv[])
             return(-1);
+#if 0
+        /* XXX: the darshan_shutdown tag is never set in darshan-core, currently */
         /* if the input darshan log has metadata set indicating the darshan
          * shutdown procedure was called on the log, then we error out. if the
          * shutdown procedure was started, then it's possible the log has
@@ -246,6 +252,7 @@ int main(int argc, char *argv[])
             darshan_log_close(in_fd);
             return(-1);
+#endif
         if(i == 0)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/5ff6955f5d03ea0fbd14a4f82c0a8d72ad42a1ec
You're receiving this email because of your account on xgitlab.cels.anl.gov.
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20171215/a29cdd40/attachment.html>
More information about the Darshan-commits mailing list
