[Darshan-commits] [Git][darshan/darshan][master] add cray regression test scripts (for alcf)
Shane Snyder
xgitlab at cels.anl.gov
Thu Apr 27 12:37:31 CDT 2017
Shane Snyder pushed to branch master at darshan / darshan
Commits:
df0b800d by Shane Snyder at 2017-04-27T17:37:06+00:00
3 changed files:
- + darshan-test/regression/cray-module-alcf/cobalt-submit.sh
- + darshan-test/regression/cray-module-alcf/env.sh
- + darshan-test/regression/cray-module-alcf/runjob.sh
Changes:
--- /dev/null
+++ b/darshan-test/regression/cray-module-alcf/cobalt-submit.sh
@@ -0,0 +1,10 @@
+#!/bin/bash
+nprocs=$DARSHAN_DEFAULT_NPROCS
+nnodes=$COBALT_PARTSIZE
+ppn=$((nprocs / nnodes))
+aprun -n $nprocs -N $ppn $@
+EXIT_STATUS=$?
+exit $EXIT_STATUS
--- /dev/null
+++ b/darshan-test/regression/cray-module-alcf/env.sh
@@ -0,0 +1,34 @@
+#!/bin/bash
+# General notes
+# Script to set up the environment for tests on this platform. Must export
+# the following environment variables:
+# DARSHAN_CC: command to compile C programs
+# DARSHAN_CXX: command to compile C++ programs
+# DARSHAN_F90: command to compile Fortran90 programs
+# DARSHAN_F77: command to compile Fortran77 programs
+# DARSHAN_RUNJOB: command to execute a job and wait for its completion
+# This script may load optional modules (as in a Cray PE), set LD_PRELOAD
+# variables (as in a dynamically linked environment), or generate mpicc
+# wrappers (as in a statically linked environment).
+# Notes specific to this platform (cray-module-alcf)
+# Use Cray's default compiler wrappers and load the module associated with
+# this darshan install
+# RUNJOB is responsible for submitting a cobalt job, waiting for its
+# completion, and checking its return status
+export DARSHAN_CC=cc
+export DARSHAN_CXX=CC
+export DARSHAN_F77=ftn
+export DARSHAN_F90=ftn
+export DARSHAN_RUNJOB="cray-module-alcf/runjob.sh"
+module load $DARSHAN_PATH/share/craype-2.x/modulefiles/
--- /dev/null
+++ b/darshan-test/regression/cray-module-alcf/runjob.sh
@@ -0,0 +1,34 @@
+#!/bin/bash
+# submit job and get job id
+jobid=`qsub --env DARSHAN_LOGFILE=$DARSHAN_LOGFILE --env DARSHAN_DEFAULT_NPROCS=$DARSHAN_DEFAULT_NPROCS --proccount $DARSHAN_DEFAULT_NPROCS -A EarlyPerf_theta -t 10 -n 1 --output $DARSHAN_TMP/$$-tmp.out --error $DARSHAN_TMP/$$-tmp.err --debuglog $DARSHAN_TMP/$$-tmp.debuglog $DARSHAN_TESTDIR/$DARSHAN_PLATFORM/cobalt-submit.sh "$@"`
+if [ $? -ne 0 ]; then
+ echo "Error: failed to qsub $@"
+ exit 1
+fi
+output="foo"
+rc=0
+# loop as long as qstat succeeds and shows information about job
+while [ -n "$output" -a "$rc" -eq 0 ]; do
+ sleep 5
+ output=`qstat $jobid`
+ rc=$?
+done
+# look for return code
+grep "exit code of 0" $DARSHAN_TMP/$$-tmp.debuglog >& /dev/null
+ # sleep to give time for exit code line to appear in log file
+ sleep 5
+ grep "exit code of 0" $DARSHAN_TMP/$$-tmp.debuglog >& /dev/null
+ if [ $? -ne 0 ]; then
+ exit 1
+ else
+ exit 0
+ fi
+else
+ exit 0
+fi
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/df0b800d794c03f4921b8734e6827a5bc785d5cd
More information about the Darshan-commits
