[Darshan-commits] [Git][darshan/darshan][master] 2 commits: added support for DARSHAN_EXCLUDE_DIRS
Shane Snyder
xgitlab at cels.anl.gov
Tue Apr 25 13:18:59 CDT 2017
Shane Snyder pushed to branch master at darshan / darshan
Commits:
7098d866 by Cristian Simarro at 2017-04-20T15:01:11+00:00
fc190c1a by Shane Snyder at 2017-04-25T13:18:56-05:00
Merge branch 'exclude-dirs' into 'master'
See merge request !12
1 changed file:
- darshan-runtime/lib/darshan-core.c
Changes:
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -72,6 +72,9 @@ char* darshan_path_inclusions[] = {
NULL
+/* allow users to override the path exclusions */
+char** user_darshan_path_exclusions = NULL;
#ifdef DARSHAN_BGQ
extern void bgq_runtime_initialize();
#endif
@@ -1044,6 +1047,9 @@ static void darshan_get_exe_and_mounts(struct darshan_core_runtime *core,
char cmdl[DARSHAN_EXE_LEN];
int tmp_index = 0;
int skip = 0;
+ char* env_exclusions;
+ char* string;
+ char* token;
/* skip these fs types */
static char* fs_exclusions[] = {
@@ -1063,6 +1069,42 @@ static void darshan_get_exe_and_mounts(struct darshan_core_runtime *core,
NULL
+ /* Check if user has set the env variable DARSHAN_EXCLUDE_DIRS */
+ env_exclusions = getenv("DARSHAN_EXCLUDE_DIRS");
+ if(env_exclusions)
+ fs_exclusions[0]=NULL;
+ /* if DARSHAN_EXCLUDE_DIRS=none, do not exclude any dir */
+ if(strncmp(env_exclusions,"none",strlen(env_exclusions))>=0)
+ if (my_rank == 0)
+ fprintf(stderr, "INFO: no system dir will be excluded\n");
+ darshan_path_exclusions[0]=NULL;
+ else
+ if (my_rank == 0)
+ fprintf(stderr, "INFO: darshan will exclude these dirs: %s\n",env_exclusions);
+ string = strdupa(env_exclusions);
+ i = 0;
+ /* get the comma separated number of directories */
+ while ((token = strsep(&string, ",")) != NULL)
+ i++;
+ user_darshan_path_exclusions=(char **)malloc((i+1)*sizeof(char *));
+ i = 0;
+ user_darshan_path_exclusions[i]=(char *)malloc(strlen(token)+1);
+ strcpy(user_darshan_path_exclusions[i],token);
+ i++;
+ user_darshan_path_exclusions[i]=NULL;
/* record exe and arguments */
for(i=0; i<argc; i++)
@@ -2088,16 +2130,26 @@ int darshan_core_excluded_path(const char *path)
int tmp_index = 0;
int tmp_jndex;
- /* scan blacklist for paths to exclude */
- while((exclude = darshan_path_exclusions[tmp_index++])) {
- if(!(strncmp(exclude, path, strlen(exclude)))) {
- /* before excluding path, ensure it's not in whitelist */
- tmp_jndex = 0;
- while((include = darshan_path_inclusions[tmp_jndex++])) {
- if(!(strncmp(include, path, strlen(include))))
- return(0); /* whitelist hits are always tracked */
+ /* if user has set DARSHAN_EXCLUDE_DIRS, override the default ones */
+ if (user_darshan_path_exclusions != NULL) {
+ while((exclude = user_darshan_path_exclusions[tmp_index++])) {
+ if(!(strncmp(exclude, path, strlen(exclude))))
+ return(1);
+ else
+ /* scan blacklist for paths to exclude */
+ while((exclude = darshan_path_exclusions[tmp_index++])) {
+ if(!(strncmp(exclude, path, strlen(exclude)))) {
+ /* before excluding path, ensure it's not in whitelist */
+ tmp_jndex = 0;
+ while((include = darshan_path_inclusions[tmp_jndex++])) {
+ if(!(strncmp(include, path, strlen(include))))
+ return(0); /* whitelist hits are always tracked */
+ return(1); /* if not in whitelist, then blacklist it */
- return(1); /* if not in whitelist, then blacklist it */
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/1a7661d8b2fca386d35b7293ab34448b56f84b40...fc190c1a51c8ee9604489c46a9ef7b302a1cd534
More information about the Darshan-commits
