[Darshan-commits] [Git][darshan/darshan][master] bump versions for 3.1.4 release
Shane Snyder
xgitlab at cels.anl.gov
Thu Apr 6 15:44:47 CDT 2017
Shane Snyder pushed to branch master at darshan / darshan
Commits:
1d473ebb by Shane Snyder at 2017-04-06T15:44:12-05:00
4 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-util/configure
- darshan-util/configure.in
Changes:
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1,6 +1,6 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.3.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.4.
# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
# Identity of this package.
PACKAGE_NAME='darshan-runtime'
PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='3.1.3'
-PACKAGE_STRING='darshan-runtime 3.1.3'
+PACKAGE_VERSION='3.1.4'
+PACKAGE_STRING='darshan-runtime 3.1.4'
PACKAGE_BUGREPORT=''
PACKAGE_URL=''
@@ -1263,7 +1263,7 @@ if test "$ac_init_help" = "long"; then
# Omit some internal or obsolete options to make the list less imposing.
# This message is too long to be a string in the A/UX 3.1 sh.
cat <<_ACEOF
-\`configure' configures darshan-runtime 3.1.3 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 3.1.4 to adapt to many kinds of systems.
Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1325,7 +1325,7 @@ fi
if test -n "$ac_init_help"; then
case $ac_init_help in
- short | recursive ) echo "Configuration of darshan-runtime 3.1.3:";;
+ short | recursive ) echo "Configuration of darshan-runtime 3.1.4:";;
esac
cat <<\_ACEOF
@@ -1439,7 +1439,7 @@ fi
test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
cat <<\_ACEOF
-darshan-runtime configure 3.1.3
+darshan-runtime configure 3.1.4
generated by GNU Autoconf 2.69
Copyright (C) 2012 Free Software Foundation, Inc.
@@ -1791,7 +1791,7 @@ cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 3.1.3, which was
+It was created by darshan-runtime $as_me 3.1.4, which was
generated by GNU Autoconf 2.69. Invocation command line was
$ $0 $@
@@ -4400,7 +4400,7 @@ else
MPICH_LIB_OLD=0
fi
-DARSHAN_VERSION="3.1.3"
+DARSHAN_VERSION="3.1.4"
@@ -4922,7 +4922,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
-This file was extended by darshan-runtime $as_me 3.1.3, which was
+This file was extended by darshan-runtime $as_me 3.1.4, which was
CONFIG_FILES = $CONFIG_FILES
@@ -4984,7 +4984,7 @@ _ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
-darshan-runtime config.status 3.1.3
+darshan-runtime config.status 3.1.4
configured by $0, generated by GNU Autoconf 2.69,
with options \\"\$ac_cs_config\\"
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
dnl You may need to use autoheader as well if changing any DEFINEs
dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [3.1.3])
+AC_INIT([darshan-runtime], [3.1.4])
AC_CONFIG_SRCDIR([darshan.h])
AC_CONFIG_AUX_DIR(../maint/config)
AC_CONFIG_HEADER(darshan-runtime-config.h)
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1,6 +1,6 @@
#! /bin/sh
-# Generated by GNU Autoconf 2.69 for darshan-util 3.1.3.
+# Generated by GNU Autoconf 2.69 for darshan-util 3.1.4.
PACKAGE_NAME='darshan-util'
PACKAGE_TARNAME='darshan-util'
-PACKAGE_STRING='darshan-util 3.1.3'
+PACKAGE_STRING='darshan-util 3.1.4'
PACKAGE_URL=''
@@ -1247,7 +1247,7 @@ if test "$ac_init_help" = "long"; then
cat <<_ACEOF
-\`configure' configures darshan-util 3.1.3 to adapt to many kinds of systems.
+\`configure' configures darshan-util 3.1.4 to adapt to many kinds of systems.
@@ -1309,7 +1309,7 @@ fi
- short | recursive ) echo "Configuration of darshan-util 3.1.3:";;
+ short | recursive ) echo "Configuration of darshan-util 3.1.4:";;
esac
cat <<\_ACEOF
@@ -1405,7 +1405,7 @@ fi
cat <<\_ACEOF
-darshan-util configure 3.1.3
+darshan-util configure 3.1.4
@@ -1770,7 +1770,7 @@ cat >config.log <<_ACEOF
-It was created by darshan-util $as_me 3.1.3, which was
+It was created by darshan-util $as_me 3.1.4, which was
$ $0 $@
@@ -4117,7 +4117,7 @@ fi
done
-DARSHAN_UTIL_VERSION="3.1.3"
+DARSHAN_UTIL_VERSION="3.1.4"
@@ -4633,7 +4633,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
ac_log="
-This file was extended by darshan-util $as_me 3.1.3, which was
+This file was extended by darshan-util $as_me 3.1.4, which was
@@ -4695,7 +4695,7 @@ _ACEOF
ac_cs_version="\\
-darshan-util config.status 3.1.3
+darshan-util config.status 3.1.4
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
-AC_INIT([darshan-util], [3.1.3])
+AC_INIT([darshan-util], [3.1.4])
AC_CONFIG_SRCDIR([darshan-logutils.h])
AC_CONFIG_HEADER(darshan-util-config.h)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/1d473ebba4060d3057a9683eb841af920103637a
More information about the Darshan-commits
