[Darshan-commits] [Git][darshan/darshan][master] 2 commits: switch darshan-merge buffer allocation strategy
Shane Snyder
xgitlab at cels.anl.gov
Tue Sep 20 11:49:30 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
426d6161 by Shane Snyder at 2016-09-20T11:48:32-05:00
c8266822 by Shane Snyder at 2016-09-20T11:48:47-05:00
add aggregate function to lustre logutils
2 changed files:
- darshan-util/darshan-lustre-logutils.c
- darshan-util/darshan-merge.c
Changes:
--- a/darshan-util/darshan-lustre-logutils.c
+++ b/darshan-util/darshan-lustre-logutils.c
@@ -31,6 +31,7 @@ static void darshan_log_print_lustre_record(void *file_rec,
static void darshan_log_print_lustre_description(void);
static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
void *rec2, char *file_name2);
+static void darshan_log_agg_lustre_records(void *rec, void *agg_rec, int init_flag);
struct darshan_mod_logutil_funcs lustre_logutils =
@@ -38,7 +39,8 @@ struct darshan_mod_logutil_funcs lustre_logutils =
.log_put_record = &darshan_log_put_lustre_record,
.log_print_record = &darshan_log_print_lustre_record,
.log_print_description = &darshan_log_print_lustre_description,
- .log_print_diff = &darshan_log_print_lustre_record_diff
+ .log_print_diff = &darshan_log_print_lustre_record_diff,
+ .log_agg_records = &darshan_log_agg_lustre_records
static int darshan_log_get_lustre_record(darshan_fd fd, void** lustre_buf_p)
@@ -158,13 +160,12 @@ static void darshan_log_print_lustre_record(void *rec, char *file_name,
static void darshan_log_print_lustre_description()
- /* TODO: add actual counter descriptions here */
printf("\n# description of LUSTRE counters:\n");
printf("# LUSTRE_OSTS: number of OSTs across the entire file system.\n");
printf("# LUSTRE_MDTS: number of MDTs across the entire file system.\n");
+ printf("# LUSTRE_STRIPE_OFFSET: OST ID offset specified when the file was created.\n");
printf("# LUSTRE_STRIPE_SIZE: stripe size for file in bytes.\n");
printf("# LUSTRE_STRIPE_WIDTH: number of OSTs over which file is striped.\n");
- printf("# LUSTRE_STRIPE_OFFSET: OST ID offset specified when the file was created.\n");
printf("# LUSTRE_OST_ID_*: indices of OSTs over which the file is striped.\n");
DARSHAN_PRINT_HEADER();
@@ -244,6 +245,35 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
return;
+ struct darshan_lustre_record *lustre_rec = (struct darshan_lustre_record *)rec;
+ struct darshan_lustre_record *agg_lustre_rec = (struct darshan_lustre_record *)agg_rec;
+ int i;
+ if(init_flag)
+ /* when initializing, just copy over the first record */
+ memcpy(agg_lustre_rec, lustre_rec, LUSTRE_RECORD_SIZE(
+ lustre_rec->counters[LUSTRE_STRIPE_WIDTH]));
+ else
+ /* for remaining records, just sanity check the records are identical */
+ for(i = 0; i < LUSTRE_NUM_INDICES; i++)
+ assert(lustre_rec->counters[i] == agg_lustre_rec->counters[i]);
+ for(i = 0; i < agg_lustre_rec->counters[LUSTRE_STRIPE_WIDTH]; i++)
+ assert(lustre_rec->ost_ids[i] == agg_lustre_rec->ost_ids[i]);
+ return;
* Local variables:
* c-indent-level: 4
--- a/darshan-util/darshan-merge.c
+++ b/darshan-util/darshan-merge.c
@@ -130,10 +130,10 @@ int build_mod_shared_rec_hash(char **infile_list, int n_infiles,
memset(ref, 0, sizeof(*ref));
/* initialize the aggregate record with this rank's record */
+ mod_logutils[mod_id]->log_agg_records(mod_buf, ref->agg_rec, 1);
agg_base = (struct darshan_base_record *)ref->agg_rec;
agg_base->id = base_rec->id;
agg_base->rank = -1;
- mod_logutils[mod_id]->log_agg_records(mod_buf, ref->agg_rec, 1);
ref->id = base_rec->id;
ref->ref_cnt = 1;
@@ -195,7 +195,7 @@ int main(int argc, char *argv[])
struct darshan_shared_record_ref *shared_rec_hash = NULL;
struct darshan_shared_record_ref *sref, *stmp;
struct darshan_base_record *base_rec;
- char mod_buf[DEF_MOD_BUF_SIZE];
+ char *mod_buf;
int i, j;
int ret;
@@ -365,6 +365,15 @@ int main(int argc, char *argv[])
return(-1);
+ mod_buf = malloc(DEF_MOD_BUF_SIZE);
+ if(!mod_buf)
+ fprintf(stderr, "Error: unable to write record table to output darshan log.\n");
+ darshan_log_close(merge_fd);
+ unlink(outlog_path);
+ return(-1);
/* iterate over active darshan modules and gather module data to write
* to the merged output log
@@ -384,6 +393,7 @@ int main(int argc, char *argv[])
darshan_module_names[i]);
+ free(mod_buf);
return(-1);
@@ -399,6 +409,7 @@ int main(int argc, char *argv[])
infile_list[j]);
+ free(mod_buf);
return(-1);
@@ -416,6 +427,7 @@ int main(int argc, char *argv[])
darshan_log_close(in_fd);
+ free(mod_buf);
return(-1);
@@ -439,6 +451,7 @@ int main(int argc, char *argv[])
+ free(mod_buf);
return(-1);
@@ -450,6 +463,7 @@ int main(int argc, char *argv[])
+ free(mod_buf);
return(-1);
@@ -467,6 +481,8 @@ int main(int argc, char *argv[])
+ free(mod_buf);
return(0);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/ab32cf6690d62217a188a1dcf5010331405a6c04...c82668224b7ec433158065ef719d3454e39d0611
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160920/c8009b9b/attachment-0001.html>
More information about the Darshan-commits
