[Darshan-commits] [Git][darshan/darshan][dev-stdio-utils] filter out unused stdio records
Philip Carns
xgitlab at cels.anl.gov
Sun Sep 18 09:15:16 CDT 2016
Philip Carns pushed to branch dev-stdio-utils at darshan / darshan
Commits:
384e9b5c by Phil Carns at 2016-09-18T10:15:02-04:00
1 changed file:
- darshan-runtime/lib/darshan-stdio.c
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -78,6 +78,8 @@
#include <assert.h>
#include <libgen.h>
#include <pthread.h>
+#include <stdint.h>
+#include <limits.h>
#include "darshan.h"
#include "darshan-dynamic.h"
@@ -488,7 +490,6 @@ int DARSHAN_DECL(vfprintf)(FILE *stream, const char *format, va_list ap)
int ret;
double tm1, tm2;
- long start_off, end_off;
MAP_OR_FAIL(vfprintf);
@@ -1115,6 +1116,8 @@ static void stdio_shutdown(
MPI_Op red_op;
int stdio_rec_count;
double stdio_time;
+ FILE * fp[3];
+ int trim_records = 0;
STDIO_LOCK();
assert(stdio_runtime);
@@ -1219,6 +1222,30 @@ static void stdio_shutdown(
DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
+ /* filter out any records that have no activity on them; this is
+ * specifically meant to filter out unused stdin, stdout, or stderr
+ * entries
+ * NOTE: we can no longer use the darshan_lookup_record_ref()
+ * function at this point to find specific records, because the
+ * logic above has likely broken the mapping to the static array.
+ * We walk it manually here instead.
+ for(i=0; i<stdio_rec_count; i++)
+ if(stdio_rec_buf[i].counters[STDIO_WRITES] == 0 &&
+ stdio_rec_buf[i].counters[STDIO_READS] == 0)
+ if(i != (stdio_rec_count-1))
+ memmove(&stdio_rec_buf[i], &stdio_rec_buf[i+1],
+ (stdio_rec_count-i-1)*sizeof(stdio_rec_buf[i]));
+ stdio_rec_count--;
+ i--;
/* update output buffer size to account for shared file reduction */
*stdio_buf_sz = stdio_rec_count * sizeof(struct darshan_stdio_file);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/384e9b5cf77c0df8529875838b60ea2c2053ab04
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160918/0758e939/attachment-0001.html>
More information about the Darshan-commits
