[Darshan-commits] [Git][darshan/darshan][dev-stdio-utils] 8 commits: prepend file system mount point to hashed file name to retain file system info for obfuscated files
Philip Carns
xgitlab at cels.anl.gov
Mon Sep 12 15:32:12 CDT 2016
Philip Carns pushed to branch dev-stdio-utils at darshan / darshan
Commits:
0d1f6e80 by Glenn K. Lockwood at 2016-08-16T13:26:33-07:00
6e75dade by Glenn K. Lockwood at 2016-08-24T09:57:37-07:00
Merge branch 'master' into gkl/obfuscate-fs-fix to pull in fix from d4dc84f
eadbecfd by Glenn K. Lockwood at 2016-08-24T10:00:07-07:00
fix wrong struct type (inconsequential as it may be in the given context)
0ed720e8 by Shane Snyder at 2016-08-24T21:30:03-05:00
filter stderr/stdin/stdout for regression tests
df34ba2b by Shane Snyder at 2016-09-08T15:16:31-07:00
add unique id to mmap log file names
This is needed to distinguish between log files generated with
the same job id (i.e., for jobs that have multiple steps)
7f05cf73 by Shane Snyder at 2016-09-09T16:39:48-05:00
Merge branch 'gkl/obfuscate-fs-fix' into 'master'
gkl/obfuscate fs fix: prepend file path to hashed file name to retain fs info
Prepends the file system path to the hashed file name generated by `darshan-convert --obfuscate` so that darshan-parser can still link obfuscated file records to the mounts table.
See merge request !1
c877a1c1 by Shane Snyder at 2016-09-12T13:28:37-05:00
remove POSIX fstream references from job-summary
4addc19b by Phil Carns at 2016-09-12T16:28:02-04:00
Merge branch 'dev-stdio-utils'
5 changed files:
- darshan-runtime/lib/darshan-core.c
- darshan-test/regression/test-cases/fprintf-fscanf-test.sh
- darshan-test/regression/test-cases/stdio-test.sh
- darshan-util/darshan-convert.c
- darshan-util/darshan-logutils.c
Changes:
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -786,6 +786,9 @@ static void *darshan_init_mmap_log(struct darshan_core_runtime* core, int jobid)
int mmap_size;
int sys_page_size;
char cuser[L_cuserid] = {0};
+ uint64_t hlevel;
+ char hname[HOST_NAME_MAX];
+ uint64_t logmod;
char *envstr;
char *mmap_log_path;
void *mmap_p;
@@ -806,12 +809,25 @@ static void *darshan_init_mmap_log(struct darshan_core_runtime* core, int jobid)
darshan_get_user_name(cuser);
+ /* generate a random number to help differentiate the temporary log */
+ /* NOTE: job id is not sufficient for constructing a unique log file name,
+ * since a job could be composed of multiple application runs, so we also
+ * add a random number component to the log name
+ if(my_rank == 0)
+ hlevel=DARSHAN_MPI_CALL(PMPI_Wtime)() * 1000000;
+ (void)gethostname(hname, sizeof(hname));
+ logmod = darshan_hash((void*)hname,strlen(hname),hlevel);
+ DARSHAN_MPI_CALL(PMPI_Bcast)(&logmod, 1, MPI_UINT64_T, 0, MPI_COMM_WORLD);
/* construct a unique temporary log file name for this process
* to write mmap log data to
snprintf(core->mmap_log_name, PATH_MAX,
- "/%s/%s_%s_id%d_mmap-log-%d.darshan",
- mmap_log_path, cuser, __progname, jobid, my_rank);
+ "/%s/%s_%s_id%d_mmap-log-%" PRIu64 "-%d.darshan",
+ mmap_log_path, cuser, __progname, jobid, logmod, my_rank);
/* create the temporary mmapped darshan log */
mmap_fd = open(core->mmap_log_name, O_CREAT|O_RDWR|O_EXCL , 0644);
--- a/darshan-test/regression/test-cases/fprintf-fscanf-test.sh
+++ b/darshan-test/regression/test-cases/fprintf-fscanf-test.sh
@@ -29,21 +29,21 @@ fi
# check results
-STDIO_OPENS=`grep STDIO_OPENS $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_OPENS=`grep STDIO_OPENS $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! "$STDIO_OPENS" -eq 4 ]; then
echo "Error: STDIO open count of $STDIO_OPENS is incorrect" 1>&2
exit 1
fi
# this will check fprintf counting
-STDIO_BYTES_WRITTEN=`grep STDIO_BYTES_WRITTEN $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_BYTES_WRITTEN=`grep STDIO_BYTES_WRITTEN $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! "$STDIO_BYTES_WRITTEN" -eq 15 ]; then
echo "Error: STDIO bytes written count of $STDIO_BYTES_WRITTEN is incorrect" 1>&2
exit 1
fi
# this will check fscanf counting
-STDIO_BYTES_READ=`grep STDIO_BYTES_READ $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_BYTES_READ=`grep STDIO_BYTES_READ $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! "$STDIO_BYTES_READ" -eq 15 ]; then
echo "Error: STDIO bytes read count of $STDIO_BYTES_READ is incorrect" 1>&2
exit 1
--- a/darshan-test/regression/test-cases/stdio-test.sh
+++ b/darshan-test/regression/test-cases/stdio-test.sh
@@ -31,22 +31,22 @@ fi
# check at least one counter from each general open/read/write/seek category
if [ ! "$STDIO_OPENS" -gt 0 ]; then
exit 1
fi
-STDIO_SEEKS=`grep STDIO_SEEKS $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_SEEKS=`grep STDIO_SEEKS $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! "$STDIO_SEEKS" -gt 0 ]; then
echo "Error: STDIO open count of $STDIO_SEEKS is incorrect" 1>&2
exit 1
fi
if [ ! "$STDIO_BYTES_WRITTEN" -eq 6 ]; then
echo "Error: STDIO open count of $STDIO_BYTES_WRITTEN is incorrect" 1>&2
exit 1
fi
if [ ! "$STDIO_BYTES_READ" -eq 6 ]; then
echo "Error: STDIO open count of $STDIO_BYTES_READ is incorrect" 1>&2
exit 1
@@ -55,32 +55,32 @@ fi
# make sure that some of the floating point counters are valid
# use bc for floating point comparison
-STDIO_F_OPEN_START_TIMESTAMP=`grep STDIO_F_OPEN_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_OPEN_START_TIMESTAMP=`grep STDIO_F_OPEN_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_OPEN_START_TIMESTAMP > 0" | bc -l) ]; then
echo "Error: counter is incorrect" 1>&2
exit 1
fi
-STDIO_F_OPEN_END_TIMESTAMP=`grep STDIO_F_OPEN_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_OPEN_END_TIMESTAMP=`grep STDIO_F_OPEN_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_OPEN_END_TIMESTAMP > 0" | bc -l) ]; then
exit 1
fi
-STDIO_F_META_TIME=`grep STDIO_F_META_TIME $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_META_TIME=`grep STDIO_F_META_TIME $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_META_TIME > 0" | bc -l) ]; then
exit 1
fi
-STDIO_F_WRITE_TIME=`grep STDIO_F_WRITE_TIME $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_WRITE_TIME=`grep STDIO_F_WRITE_TIME $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_WRITE_TIME > 0" | bc -l) ]; then
exit 1
fi
-STDIO_F_CLOSE_START_TIMESTAMP=`grep STDIO_F_CLOSE_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_CLOSE_START_TIMESTAMP=`grep STDIO_F_CLOSE_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_CLOSE_START_TIMESTAMP > 0" | bc -l) ]; then
exit 1
fi
-STDIO_F_CLOSE_END_TIMESTAMP=`grep STDIO_F_CLOSE_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | cut -f 5`
+STDIO_F_CLOSE_END_TIMESTAMP=`grep STDIO_F_CLOSE_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt | grep -vE "STDIN|STDOUT|STDERR" | cut -f 5`
if [ ! $(echo "$STDIO_F_CLOSE_END_TIMESTAMP > 0" | bc -l) ]; then
exit 1
--- a/darshan-util/darshan-convert.c
+++ b/darshan-util/darshan-convert.c
@@ -138,19 +138,41 @@ void obfuscate_exe(int key, char *exe)
return;
-void obfuscate_filenames(int key, struct darshan_name_record_ref *name_hash)
+void obfuscate_filenames(int key, struct darshan_name_record_ref *name_hash, struct darshan_mnt_info *mnt_data_array, int mount_count )
struct darshan_name_record_ref *ref, *tmp;
uint32_t hashed;
- char tmp_string[128] = {0};
+ char tmp_string[PATH_MAX+128] = {0};
darshan_record_id tmp_id;
HASH_ITER(hlink, name_hash, ref, tmp)
+ /* find file system */
+ int j;
+ char *mnt_pt = NULL;
+ /* get mount point and fs type associated with this record */
+ for(j=0; j<mount_count; j++)
+ if(strncmp(mnt_data_array[j].mnt_path, ref->name_record->name,
+ strlen(mnt_data_array[j].mnt_path)) == 0)
+ mnt_pt = mnt_data_array[j].mnt_path;
+ break;
tmp_id = ref->name_record->id;
hashed = darshan_hashlittle(ref->name_record->name,
strlen(ref->name_record->name), key);
- sprintf(tmp_string, "%u", hashed);
+ if ( mnt_pt != NULL )
+ sprintf(tmp_string, "%s/%u", mnt_pt, hashed);
+ else
+ sprintf(tmp_string, "%u", hashed);
free(ref->name_record);
ref->name_record = malloc(sizeof(struct darshan_name_record) +
strlen(tmp_string));
@@ -330,7 +352,7 @@ int main(int argc, char **argv)
/* NOTE: obfuscating filepaths breaks the ability to map files
* to the corresponding FS & mount info maintained by darshan
- if(obfuscate) obfuscate_filenames(key, name_hash);
+ if(obfuscate) obfuscate_filenames(key, name_hash, mnt_data_array, mount_count );
if(hash) remove_hash_recs(&name_hash, hash);
ret = darshan_log_put_namehash(outfile, name_hash);
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -586,7 +586,7 @@ int darshan_log_put_namehash(darshan_fd fd, struct darshan_name_record_ref *hash
struct darshan_fd_int_state *state = fd->state;
- struct darshan_name_record_ref *name_rec;
+ struct darshan_name_record *name_rec;
int name_rec_len;
int wrote;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/e95a46ed1961d61efb351d89fbc536e2e1c672d3...4addc19b7b8ce1944b98884dc83cc085f361cf5e
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160912/69fcefba/attachment-0001.html>
More information about the Darshan-commits
