[Darshan-commits] [Git][darshan/darshan][master] remove POSIX fstream references from job-summary
Shane Snyder
xgitlab at cels.anl.gov
Mon Sep 12 13:32:27 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
c877a1c1 by Shane Snyder at 2016-09-12T13:28:37-05:00
1 changed file:
- darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
Changes:
--- a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
+++ b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
@@ -396,9 +396,9 @@ close TIME_SUMMARY;
open(PSX_OP_COUNTS, ">$tmp_dir/posix-op-counts.dat") || die("error opening output file: $!\n");
print PSX_OP_COUNTS "# <operation>, <POSIX count>\n";
print PSX_OP_COUNTS
- "Read, ", $summary{POSIX_READS} + $summary{POSIX_FREADS}, "\n",
- "Write, ", $summary{POSIX_WRITES} + $summary{POSIX_FWRITES}, "\n",
- "Open, ", $summary{POSIX_OPENS} + $summary{POSIX_FOPENS}, "\n",
+ "Read, ", $summary{POSIX_READS}, "\n",
+ "Write, ", $summary{POSIX_WRITES}, "\n",
+ "Open, ", $summary{POSIX_OPENS}, "\n",
"Stat, ", $summary{POSIX_STATS}, "\n",
"Seek, ", $summary{POSIX_SEEKS}, "\n",
"Mmap, ", $summary{POSIX_MMAPS}, "\n",
@@ -496,9 +496,9 @@ if (defined $summary{MPIIO_INDEP_OPENS})
# sequential and consecutive access patterns
open (PATTERN, ">$tmp_dir/pattern.dat") || die("error opening output file: $!\n");
print PATTERN "# op total sequential consecutive\n";
-print PATTERN "Read, ", $summary{POSIX_READS} + $summary{POSIX_FREADS}, ", ",
+print PATTERN "Read, ", $summary{POSIX_READS}, ", ",
$summary{POSIX_SEQ_READS}, ", ", $summary{POSIX_CONSEC_READS}, "\n";
-print PATTERN "Write, ", $summary{POSIX_WRITES} + $summary{POSIX_FWRITES}, ", ",
+print PATTERN "Write, ", $summary{POSIX_WRITES}, ", ",
$summary{POSIX_SEQ_WRITES}, ", ", $summary{POSIX_CONSEC_WRITES}, "\n";
close PATTERN;
@@ -1047,7 +1047,6 @@ sub process_file_record
if($file_record{'POSIX_OPENS'} == 0 &&
- $file_record{'POSIX_FOPENS'} == 0 &&
(!defined $file_record{'MPIIO_INDEP_OPENS'} ||
($file_record{'MPIIO_INDEP_OPENS'} == 0 && $file_record{'MPIIO_COLL_OPENS'} == 0)))
@@ -1110,14 +1109,12 @@ sub process_file_record
else
# posix file
- if($file_record{'POSIX_READS'} > 0 ||
- $file_record{'POSIX_FREADS'} > 0)
+ if($file_record{'POSIX_READS'} > 0)
# data was read from the file
$hash_files{$hash}{'was_read'} = 1;
- if($file_record{'POSIX_WRITES'} > 0 ||
- $file_record{'POSIX_FWRITES'} > 0)
+ if($file_record{'POSIX_WRITES'} > 0)
# data was written to the file
$hash_files{$hash}{'was_written'} = 1;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/c877a1c102aafa44155f6584287195ad1e843331
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160912/a98f319b/attachment-0001.html>
More information about the Darshan-commits
