[Darshan-commits] [Git][darshan/darshan][master] bump overall version number
Philip Carns
xgitlab at cels.anl.gov
Wed Oct 5 16:12:00 CDT 2016
Philip Carns pushed to branch master at darshan / darshan
Commits:
dc43bfcd by Phil Carns at 2016-10-05T17:11:47-04:00
4 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-util/configure
- darshan-util/configure.in
Changes:
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1,6 +1,6 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.0.
+# Generated by GNU Autoconf 2.69 for darshan-runtime 3.1.1.
# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
@@ -577,8 +577,8 @@ MAKEFLAGS=
# Identity of this package.
PACKAGE_NAME='darshan-runtime'
PACKAGE_TARNAME='darshan-runtime'
-PACKAGE_VERSION='3.1.0'
-PACKAGE_STRING='darshan-runtime 3.1.0'
+PACKAGE_VERSION='3.1.1'
+PACKAGE_STRING='darshan-runtime 3.1.1'
PACKAGE_BUGREPORT=''
PACKAGE_URL=''
@@ -663,6 +663,7 @@ infodir
docdir
oldincludedir
includedir
+runstatedir
localstatedir
sharedstatedir
sysconfdir
@@ -746,6 +747,7 @@ datadir='${datarootdir}'
sysconfdir='${prefix}/etc'
sharedstatedir='${prefix}/com'
localstatedir='${prefix}/var'
+runstatedir='${localstatedir}/run'
includedir='${prefix}/include'
oldincludedir='/usr/include'
docdir='${datarootdir}/doc/${PACKAGE_TARNAME}'
@@ -998,6 +1000,15 @@ do
| -silent | --silent | --silen | --sile | --sil)
silent=yes ;;
+ -runstatedir | --runstatedir | --runstatedi | --runstated \
+ | --runstate | --runstat | --runsta | --runst | --runs \
+ | --run | --ru | --r)
+ ac_prev=runstatedir ;;
+ -runstatedir=* | --runstatedir=* | --runstatedi=* | --runstated=* \
+ | --runstate=* | --runstat=* | --runsta=* | --runst=* | --runs=* \
+ | --run=* | --ru=* | --r=*)
+ runstatedir=$ac_optarg ;;
-sbindir | --sbindir | --sbindi | --sbind | --sbin | --sbi | --sb)
ac_prev=sbindir ;;
-sbindir=* | --sbindir=* | --sbindi=* | --sbind=* | --sbin=* \
@@ -1135,7 +1146,7 @@ fi
for ac_var in exec_prefix prefix bindir sbindir libexecdir datarootdir \
datadir sysconfdir sharedstatedir localstatedir includedir \
oldincludedir docdir infodir htmldir dvidir pdfdir psdir \
- libdir localedir mandir
+ libdir localedir mandir runstatedir
do
eval ac_val=\$$ac_var
# Remove trailing slashes.
@@ -1248,7 +1259,7 @@ if test "$ac_init_help" = "long"; then
# Omit some internal or obsolete options to make the list less imposing.
# This message is too long to be a string in the A/UX 3.1 sh.
cat <<_ACEOF
-\`configure' configures darshan-runtime 3.1.0 to adapt to many kinds of systems.
+\`configure' configures darshan-runtime 3.1.1 to adapt to many kinds of systems.
Usage: $0 [OPTION]... [VAR=VALUE]...
@@ -1288,6 +1299,7 @@ Fine tuning of the installation directories:
--sysconfdir=DIR read-only single-machine data [PREFIX/etc]
--sharedstatedir=DIR modifiable architecture-independent data [PREFIX/com]
--localstatedir=DIR modifiable single-machine data [PREFIX/var]
+ --runstatedir=DIR modifiable per-process data [LOCALSTATEDIR/run]
--libdir=DIR object code libraries [EPREFIX/lib]
--includedir=DIR C header files [PREFIX/include]
--oldincludedir=DIR C header files for non-gcc [/usr/include]
@@ -1309,7 +1321,7 @@ fi
if test -n "$ac_init_help"; then
case $ac_init_help in
- short | recursive ) echo "Configuration of darshan-runtime 3.1.0:";;
+ short | recursive ) echo "Configuration of darshan-runtime 3.1.1:";;
esac
cat <<\_ACEOF
@@ -1419,7 +1431,7 @@ fi
test -n "$ac_init_help" && exit $ac_status
if $ac_init_version; then
cat <<\_ACEOF
-darshan-runtime configure 3.1.0
+darshan-runtime configure 3.1.1
generated by GNU Autoconf 2.69
Copyright (C) 2012 Free Software Foundation, Inc.
@@ -1771,7 +1783,7 @@ cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
-It was created by darshan-runtime $as_me 3.1.0, which was
+It was created by darshan-runtime $as_me 3.1.1, which was
generated by GNU Autoconf 2.69. Invocation command line was
$ $0 $@
@@ -4348,7 +4360,7 @@ else
MPICH_LIB_OLD=0
fi
-DARSHAN_VERSION="3.1.0"
+DARSHAN_VERSION="3.1.1"
@@ -4868,7 +4880,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
-This file was extended by darshan-runtime $as_me 3.1.0, which was
+This file was extended by darshan-runtime $as_me 3.1.1, which was
CONFIG_FILES = $CONFIG_FILES
@@ -4930,7 +4942,7 @@ _ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
-darshan-runtime config.status 3.1.0
+darshan-runtime config.status 3.1.1
configured by $0, generated by GNU Autoconf 2.69,
with options \\"\$ac_cs_config\\"
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -5,7 +5,7 @@ dnl Process this file with autoconf to produce a configure script.
dnl You may need to use autoheader as well if changing any DEFINEs
dnl sanity checks, output header, location of scripts used here
-AC_INIT([darshan-runtime], [3.1.0])
+AC_INIT([darshan-runtime], [3.1.1])
AC_CONFIG_SRCDIR([darshan.h])
AC_CONFIG_AUX_DIR(../maint/config)
AC_CONFIG_HEADER(darshan-runtime-config.h)
--- a/darshan-util/configure
+++ b/darshan-util/configure
@@ -1,6 +1,6 @@
#! /bin/sh
-# Generated by GNU Autoconf 2.69 for darshan-util 3.1.0.
+# Generated by GNU Autoconf 2.69 for darshan-util 3.1.1.
PACKAGE_NAME='darshan-util'
PACKAGE_TARNAME='darshan-util'
-PACKAGE_STRING='darshan-util 3.1.0'
+PACKAGE_STRING='darshan-util 3.1.1'
PACKAGE_URL=''
@@ -661,6 +661,7 @@ infodir
docdir
oldincludedir
includedir
+runstatedir
localstatedir
sharedstatedir
sysconfdir
@@ -734,6 +735,7 @@ datadir='${datarootdir}'
@@ -986,6 +988,15 @@ do
silent=yes ;;
ac_prev=sbindir ;;
@@ -1123,7 +1134,7 @@ fi
do
@@ -1236,7 +1247,7 @@ if test "$ac_init_help" = "long"; then
cat <<_ACEOF
-\`configure' configures darshan-util 3.1.0 to adapt to many kinds of systems.
+\`configure' configures darshan-util 3.1.1 to adapt to many kinds of systems.
@@ -1276,6 +1287,7 @@ Fine tuning of the installation directories:
@@ -1297,7 +1309,7 @@ fi
- short | recursive ) echo "Configuration of darshan-util 3.1.0:";;
+ short | recursive ) echo "Configuration of darshan-util 3.1.1:";;
esac
cat <<\_ACEOF
@@ -1393,7 +1405,7 @@ fi
cat <<\_ACEOF
-darshan-util configure 3.1.0
+darshan-util configure 3.1.1
@@ -1758,7 +1770,7 @@ cat >config.log <<_ACEOF
-It was created by darshan-util $as_me 3.1.0, which was
+It was created by darshan-util $as_me 3.1.1, which was
$ $0 $@
@@ -4105,7 +4117,7 @@ fi
done
-DARSHAN_UTIL_VERSION="3.1.0"
+DARSHAN_UTIL_VERSION="3.1.1"
@@ -4621,7 +4633,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
ac_log="
-This file was extended by darshan-util $as_me 3.1.0, which was
+This file was extended by darshan-util $as_me 3.1.1, which was
@@ -4683,7 +4695,7 @@ _ACEOF
ac_cs_version="\\
-darshan-util config.status 3.1.0
+darshan-util config.status 3.1.1
--- a/darshan-util/configure.in
+++ b/darshan-util/configure.in
-AC_INIT([darshan-util], [3.1.0])
+AC_INIT([darshan-util], [3.1.1])
AC_CONFIG_SRCDIR([darshan-logutils.h])
AC_CONFIG_HEADER(darshan-util-config.h)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/dc43bfcd4d98adc7e330f5049bd98a8191b93e62
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20161005/2b60c519/attachment-0001.html>
More information about the Darshan-commits
