[Darshan-commits] Build failed in Jenkins: darshan-master-mpich-3.0.4-static #554
jenkins-ci at mcs.anl.gov jenkins-ci at mcs.anl.gov
Fri Nov 4 14:22:42 CDT 2016
See <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-static/554/>
[...truncated 2568 lines...]
mpich-3.0.4/src/pm/mpd/test/testall.sh
mpich-3.0.4/src/pm/mpd/test/test5.py
mpich-3.0.4/src/pm/mpd/test/test4.py
mpich-3.0.4/src/pm/mpd/test/test3.py
mpich-3.0.4/src/pm/mpd/test/test2.py
mpich-3.0.4/src/pm/mpd/test/test1.py
mpich-3.0.4/src/pm/mpd/sleeploop.c
mpich-3.0.4/src/pm/mpd/sigcatcher.c
mpich-3.0.4/src/pm/mpd/setup_pm
mpich-3.0.4/src/pm/mpd/proxy.c
mpich-3.0.4/src/pm/mpd/pmitest.c
mpich-3.0.4/src/pm/mpd/pcp.c
mpich-3.0.4/src/pm/mpd/newkmpds.py
mpich-3.0.4/src/pm/mpd/newboot.py
mpich-3.0.4/src/pm/mpd/mtv_setup.py
mpich-3.0.4/src/pm/mpd/mtv.c
mpich-3.0.4/src/pm/mpd/mpiexec.py
mpich-3.0.4/src/pm/mpd/mpichprereq
mpich-3.0.4/src/pm/mpd/mpdwrapcli.py
mpich-3.0.4/src/pm/mpd/mpdtrace.py
mpich-3.0.4/src/pm/mpd/mpdsigjob.py
mpich-3.0.4/src/pm/mpd/mpdroot.h
mpich-3.0.4/src/pm/mpd/mpdroot.c
mpich-3.0.4/src/pm/mpd/mpdringtest.py
mpich-3.0.4/src/pm/mpd/mpdman.py
mpich-3.0.4/src/pm/mpd/mpdlistjobs.py
mpich-3.0.4/src/pm/mpd/mpdlib.py
mpich-3.0.4/src/pm/mpd/mpdkilljob.py
mpich-3.0.4/src/pm/mpd/mpdhelp.py
mpich-3.0.4/src/pm/mpd/mpdgdbdrv.py
mpich-3.0.4/src/pm/mpd/mpdexit.py
mpich-3.0.4/src/pm/mpd/mpdcleanup.py
mpich-3.0.4/src/pm/mpd/mpdchkpyver.py
mpich-3.0.4/src/pm/mpd/mpdcheck.py
mpich-3.0.4/src/pm/mpd/mpdboot.py
mpich-3.0.4/src/pm/mpd/mpdallexit.py
mpich-3.0.4/src/pm/mpd/mpd.py
mpich-3.0.4/src/pm/mpd/install.sh
mpich-3.0.4/src/pm/mpd/infloop.c
mpich-3.0.4/src/pm/mpd/exittest_nompi.c
mpich-3.0.4/src/pm/mpd/ex3.xml
mpich-3.0.4/src/pm/mpd/ex2.xml
mpich-3.0.4/src/pm/mpd/ex1.xml
mpich-3.0.4/src/pm/mpd/edi2.xml
mpich-3.0.4/src/pm/mpd/configure.ac
mpich-3.0.4/src/pm/mpd/autogen.sh
mpich-3.0.4/src/pm/mpd/README
mpich-3.0.4/src/pm/mpd/Makefile.am
mpich-3.0.4/src/pm/hydra/
mpich-3.0.4/src/pm/hydra/Makefile.in
mpich-3.0.4/src/pm/hydra/configure
mpich-3.0.4/src/pm/hydra/aclocal.m4
mpich-3.0.4/src/pm/hydra/version.m4
mpich-3.0.4/src/pm/hydra/confdb/
mpich-3.0.4/src/pm/hydra/confdb/depcomp
mpich-3.0.4/src/pm/hydra/confdb/missing
mpich-3.0.4/src/pm/hydra/confdb/install-sh
mpich-3.0.4/src/pm/hydra/confdb/config.sub
mpich-3.0.4/src/pm/hydra/confdb/config.guess
mpich-3.0.4/src/pm/hydra/coyes
checking whether pthread_mutexattr_settype needs a declaration... no
checking for thread local storage specifier... __thread
checking for getpid... yes
checking sched.h usability... yes
checking sched.h presence... yes
checking for sched.h... yes
checking for unistd.h... (cached) yes
checking sys/select.h usability... yes
checking sys/select.h presence... yes
checking for sys/select.h... yes
checking for sched_yield... yes
checking for yield... no
checking for usleep... yes
checking for sleep... yes
checking for select... yes
checking whether usleep needs a declaration... no
checking for sched_setaffinity... yes
checking for sched_getaffinity... yes
checking for bindprocessor... no
checking for thread_policy_set... no
checking whether cpu_set_t available... yes
checking whether the CPU_SET and CPU_ZERO macros are defined... no
configure: RUNNING CONFIGURE FOR F90 CODE
checking whether ln -s works... yes
checking for extension for Fortran 90 programs... f90
checking for the precision and range of reals...  6 , 37
checking for the precision and range of double precision...  15 , 307
checking for the range of integer...  9
checking for available integer kinds...  2 , 1, 4 , 2, 9 , 4, 18 , 8,
checking for available integer ranges...  {  2 , 1 , 1 }, {  4 , 2 , 2 }, {  9 , 4 , 4 }, {  18 , 8 , 8 },
checking for string.h... (cached) yes
checking for stdlib.h... (cached) yes
checking for sys/socket.h... (cached) yes
checking for strings.h... (cached) yes
checking for assert.h... (cached) yes
checking for snprintf... (cached) yes
checking whether snprintf needs a declaration... (cached) no
checking for strncasecmp... (cached) yes
checking for sys/types.h... (cached) yes
checking for sys/param.h... (cached) yes
checking netinet/in.h usability... yes
checking netinet/in.h presence... yes
checking for netinet/in.h... yes
checking netinet/tcp.h usability... yes
checking netinet/tcp.h presence... yes
checking for netinet/tcp.h... yes
checking sys/un.h usability... yes
checking sys/un.h presence... yes
checking for sys/un.h... yes
checking netdb.h usability... yes
checking netdb.h presence... yes
checking for netdb.h... yes
checking for library containing socket... none required
checking for library containing gethostbyname... none required
checking for socket... yes
checking for setsockopt... yes
checking for gethostbyname... yes
checking whether socklen_t is defined (in sys/socket.h if present)... yes
checking whether struct hostent contains h_addr_list... yes
checking whether __attribute__ allowed... (cached) yes
checking whether __attribute__((format)) allowed... (cached) yes
configure: RUNNING CONFIGURE FOR CH3 DEVICE
checking for limits.h... (cached) yes
checking for sys/uio.h... (cached) yes
checking uuid/uuid.h usability... yes
checking uuid/uuid.h presence... yes
checking for uuid/uuid.h... yes
checking time.h usability... yes
checking time.h presence... yes
checking for time.h... yes
checking ctype.h usability... yes
checking ctype.h presence... yes
checking for ctype.h... yes
checking arpa/inet.h usability... yes
checking arpa/inet.h presence... yes
checking for arpa/inet.h... yes
checking for net/if.h... yes
checking for pid_t... yes
checking for inet_pton... yes
checking for gethostname... yes
checking whether gethostname needs a declaration... no
checking for CFUUIDCreate... no
checking for uuid_generate... no
checking for time... yes
checking for OpenPA atomic primitive availability... yes
checking whether byte ordering is bigendian... (cached) no
configure: RUNNING CONFIGURE FOR ch3:nemesis
checking for netdb.h... (cached) yes
checking for sched.h... (cached) yes
checking sys/mman.h usability... yes
checking sys/mman.h presence... yes
checking for sys/mman.h... yes
checking sys/ioctl.h usability... yes
checking sys/ioctl.h presence... yes
checking for sys/ioctl.h... yes
checking sys/sockio.h usability... no
checking sys/sockio.h presence... no
checking for sys/sockio.h... no
checking for errno.h... (cached) yes
checking sys/ipc.h usability... yes
checking sys/ipc.h presence... yes
checking for sys/ipc.h... yes
checking sys/shm.h usability... yes
checking sys/shm.h presence... yes
checking for sys/shm.h... yes
checking for netinet/in.h... (cached) yes
checking signal.h usability... yes
checking signal.h presence... yes
checking for signal.h... yes
checking for signal... yes
checking for mkstemp... (cached) yes
checking for rand... yes
checking for srand... yes
checking for mmap... yes
checking for munmap... yes
configure: Using a memory-mapped file for shared memory
checking whether struct hostent contains h_addr_list... (cached) yes
checking whether we can use struct ifconf... yes
checking whether we can use struct ifreq... yes
checking knem_io.h usability... no
checking knem_io.h presence... no
checking for knem_io.h... no
configure: ===== configuring src/mpi/romio =====
configure: running /bin/sh ./configure --disable-option-checking '--prefix=/sandbox/jenkins-ci/workspace/darshan-master-mpich-3.0.4-static/mpich-install'  '--enable-shared=no' '--enable-static=yes' --cache-file=/dev/null --srcdir=.
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... yes
checking for style of include used by make... GNU
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether cc accepts -g... yes
checking for cc option to accept ISO C89... none needed
checking dependency style of cc... gcc3
checking the archiver (ar) interface... ar
checking build system type... x86_64-unknown-linux-gnu
checking host system type... x86_64-unknown-linux-gnu
checking how to print strings... printf
checking for a sed that does not truncate output... /bin/sed
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for fgrep... /bin/grep -F
checking for ld used by cc... /usr/bin/ld -m elf_x86_64
checking if the linker (/usr/bin/ld -m elf_x86_64) is GNU ld... yes
checking for BSD- or MS-compatible name lister (nm)... /usr/bin/nm -B
checking the name lister (/usr/bin/nm -B) interface... BSD nm
checking the maximum length of command line arguments... 1572864
checking whether the shell understands some XSI constructs... yes
checking whether the shell understands "+="... yes
checking how to convert x86_64-unknown-linux-gnu file names to x86_64-unknown-linux-gnu format... func_convert_file_noop
checking how to convert x86_64-unknown-linux-gnu file names to toolchain format... func_convert_file_noop
checking for /usr/bin/ld -m elf_x86_64 option to reload object files... -r
checking for objdump... objdump
checking how to recognize dependent libraries... pass_all
checking for dlltool... no
checking how to associate runtime and link libraries... printf %s\n
checking for archiver @FILE support... @
checking for strip... strip
checking for ranlib... ranlib
checking command to parse /usr/bin/nm -B output from cc object... ok
checking for sysroot... no
checking for mt... mt
checking if mt is a manifest tool... no
checking how to run the C preprocessor... cc -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for str
More information about the Darshan-commits mailing list
