[Darshan-commits] [Git][darshan/darshan][mmap-dev] 2 commits: register/lookup_record now use strings explicitly
Shane Snyder xgitlab at cels.anl.gov
Tue May 31 15:55:25 CDT 2016
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
7d35c45a by Shane Snyder at 2016-05-27T16:36:32-05:00
bfde9eb7 by Shane Snyder at 2016-05-31T15:47:51-05:00
numerous darshan-core api changes
- memory management is now entirely handled by darshan-core for
  module records
    * when registering new records, darshan-core returns the
      corresponding buffer to write it to, rather than allowing
      module to determine this
- modules now decide whether darshan-core should track record
  names by passing either a valid name or NULL to the register
  function
    * this allows modules to register records that aren't really
      tracked by darshan-core
- only the POSIX module has been ported to new changes for this
  commit
8 changed files:
- darshan-runtime/Makefile.in
- darshan-runtime/darshan-core.h
- darshan-runtime/darshan.h
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-pnetcdf.c
- darshan-runtime/lib/darshan-posix.c
Changes:
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -35,7 +35,8 @@ CFLAGS_SHARED = -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I$(srcdir)
 LIBS = -lz @LIBBZ2@
-DARSHAN_STATIC_MOD_OBJS = lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o
+DARSHAN_STATIC_MOD_OBJS = lib/darshan-posix.o
+# TODO: lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o
 DARSHAN_DYNAMIC_MOD_OBJS = lib/darshan-posix.po lib/darshan-mpiio.po lib/darshan-hdf5.po lib/darshan-pnetcdf.po
 ifdef DARSHAN_USE_BGQ
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -52,8 +52,10 @@
 /* structure to track registered modules */
 struct darshan_core_module
-    struct darshan_module_funcs mod_funcs;
-    int mem_avail;
+    void *rec_buf_start;
+    void *rec_buf_p;
+    int rec_mem_avail;
+    struct darshan_module_funcs funcs;
 struct darshan_core_name_record_ref
@@ -78,7 +80,6 @@ struct darshan_core_runtime
     struct darshan_core_module* mod_array[DARSHAN_MAX_MODS];
     int mod_mem_used;
     struct darshan_core_name_record_ref *name_hash;
-    int name_hash_cnt;
     double wtime_offset;
     char *comp_buf;
 #ifdef __DARSHAN_ENABLE_MMAP_LOGS
--- a/darshan-runtime/darshan.h
+++ b/darshan-runtime/darshan.h
@@ -101,8 +101,7 @@ struct darshan_module_funcs
 void darshan_core_register_module(
     darshan_module_id mod_id,
     struct darshan_module_funcs *funcs,
-    int *inout_mod_size,
-    void **mod_buf,
+    int *inout_mod_buf_size,
     int *rank,
     int *sys_mem_alignment);
@@ -114,14 +113,12 @@ void darshan_core_register_module(
 void darshan_core_unregister_module(
     darshan_module_id mod_id);
-/* darshan_core_lookup_record()
+/* darshan_core_gen_record_id()
-void darshan_core_lookup_record(
-    void *name,
-    int name_len,
-    darshan_record_id *rec_id);
+darshan_record_id darshan_core_gen_record_id(
+    char *name);
 /* darshan_core_register_record()
@@ -137,11 +134,11 @@ void darshan_core_lookup_record(
  * correspoing Darshan record identifier and 'file_alignment' is an output
  * pointer storing the file system alignment value for the given record.
-int darshan_core_register_record(
+void *darshan_core_register_record(
     darshan_record_id rec_id,
-    void *name,
+    char *name,
-    int rec_size,
+    int rec_len,
     int *file_alignment);
 /* darshan_core_wtime()
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -94,8 +94,8 @@ static void darshan_log_record_hints_and_ver(
 static void darshan_get_exe_and_mounts(
     struct darshan_core_runtime *core, int argc, char **argv);
 static void darshan_add_name_record_ref(
-    struct darshan_core_runtime *core, char *name,
-    darshan_record_id id, struct darshan_core_name_record_ref **ref);
+    struct darshan_core_runtime *core, darshan_record_id rec_id,
+    char *name, darshan_module_id mod_id);
 static int darshan_block_size_from_path(
     const char *path);
 static void darshan_get_user_name(
@@ -436,7 +436,7 @@ void darshan_core_shutdown()
         if(final_core->mod_array[i])
             local_mod_use[i] = 1;
-            final_core->mod_array[i]->mod_funcs.begin_shutdown();
+            final_core->mod_array[i]->funcs.begin_shutdown();
@@ -640,7 +640,9 @@ void darshan_core_shutdown()
         if(this_mod)
-            this_mod->mod_funcs.get_output_data(MPI_COMM_WORLD, mod_shared_recs,
+            mod_buf = final_core->mod_array[i]->rec_buf_start;
+            mod_buf_sz = final_core->mod_array[i]->rec_buf_p - mod_buf;
+            this_mod->funcs.get_output_data(MPI_COMM_WORLD, mod_shared_recs,
                 mod_shared_rec_cnt, &mod_buf, &mod_buf_sz);
@@ -669,7 +671,7 @@ void darshan_core_shutdown()
         /* shutdown module if registered locally */
         if(this_mod)
-            this_mod->mod_funcs.shutdown();
+            this_mod->funcs.shutdown();
         if(internal_timing_flag)
             mod2[i] = DARSHAN_MPI_CALL(PMPI_Wtime)();
@@ -1219,29 +1221,34 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
     return;
-static void darshan_add_name_record_ref(struct darshan_core_runtime *core, char *name,
+static void darshan_add_name_record_ref(struct darshan_core_runtime *core,
+    darshan_record_id rec_id, char *name, darshan_module_id mod_id)
+    struct darshan_core_name_record_ref *ref;
     int record_size = sizeof(darshan_record_id) + strlen(name) + 1;
     if((record_size + core->log_hdr_p->name_map.len) > DARSHAN_NAME_RECORD_BUF_SIZE)
         return;
-    *ref = malloc(sizeof(**ref));
-    if(*ref)
+    ref = malloc(sizeof(*ref));
+    if(ref)
-        memset(*ref, 0, sizeof(**ref));
+        memset(ref, 0, sizeof(*ref));
-        (*ref)->name_record = (struct darshan_name_record *)
+        ref->name_record = (struct darshan_name_record *)
             ((char *)core->log_name_p + core->log_hdr_p->name_map.len);
-        memset((*ref)->name_record, 0, record_size);
-        (*ref)->name_record->id = id;
-        strcpy((*ref)->name_record->name, name);
+        memset(ref->name_record, 0, record_size);
+        ref->name_record->id = rec_id;
+        strcpy(ref->name_record->name, name);
+        if(!DARSHAN_MOD_FLAG_ISSET(ref->mod_flags, mod_id))
+            DARSHAN_MOD_FLAG_SET(ref->mod_flags, mod_id);
         /* add the record to the hash table */
         HASH_ADD(hlink, core->name_hash, name_record->id,
-            sizeof(darshan_record_id), (*ref));
-        core->name_hash_cnt++;
+            sizeof(darshan_record_id), ref);
         core->log_hdr_p->name_map.len += record_size;
@@ -1252,7 +1259,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
     darshan_record_id **shared_recs, int *shared_rec_cnt)
     int i, j;
-    int tmp_cnt = core->name_hash_cnt;
+    int tmp_cnt = HASH_CNT(hlink, core->name_hash);
     struct darshan_core_name_record_ref *tmp, *ref;
     darshan_record_id *id_array;
     uint64_t *mod_flags;
@@ -1675,17 +1682,15 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
-    void **mod_buf,
     int *rank,
     struct darshan_core_module* mod;
-    int mod_mem_req = *inout_mod_size;
+    int mod_mem_req = *inout_mod_buf_size;
     int mod_mem_avail;
-    *mod_buf = NULL;
-    *inout_mod_size = 0;
+    *inout_mod_buf_size = 0;
     if(!darshan_core || (mod_id >= DARSHAN_MAX_MODS))
         return;
@@ -1706,26 +1711,27 @@ void darshan_core_register_module(
     memset(mod, 0, sizeof(*mod));
-    /* assign a buffer from Darshan's contiguous module memory range for
-     * this module to use for storing record data
+    /* set module's record buffer and max memory usage */
     mod_mem_avail = DARSHAN_MOD_MEM_MAX - darshan_core->mod_mem_used;
     if(mod_mem_avail >= mod_mem_req)
-        *inout_mod_size = mod_mem_req;
+        mod->rec_mem_avail = mod_mem_req;
     else
-        *inout_mod_size = mod_mem_avail;
-    *mod_buf = darshan_core->log_mod_p + darshan_core->mod_mem_used;
+        mod->rec_mem_avail = mod_mem_avail;
+    mod->rec_buf_start = darshan_core->log_mod_p + darshan_core->mod_mem_used;
+    mod->rec_buf_p = mod->rec_buf_start;
+    mod->funcs = *funcs;
     /* register module with darshan */
-    mod->mod_funcs = *funcs;
-    mod->mem_avail = *inout_mod_size;
     darshan_core->mod_array[mod_id] = mod;
-    darshan_core->mod_mem_used += *inout_mod_size;
+    darshan_core->mod_mem_used += mod->rec_mem_avail;
     /* update darshan header */
+    /* TODO: ifdef wrap for mmap ? */
     darshan_core->log_hdr_p->mod_ver[mod_id] = darshan_module_versions[mod_id];
     darshan_core->log_hdr_p->mod_map[mod_id].off =
-        ((char *)*mod_buf - (char *)darshan_core->log_hdr_p);
+        ((char *)mod->rec_buf_start - (char *)darshan_core->log_hdr_p);
+    *inout_mod_buf_size = mod->rec_mem_avail;
     DARSHAN_CORE_UNLOCK();
     /* set the memory alignment and calling process's rank, if desired */
@@ -1771,76 +1777,60 @@ void darshan_core_unregister_module(
     return;
-    void *name,
-    int name_len,
+    char *name)
-    darshan_record_id tmp_rec_id;
-    /* TODO: how do we handle potentially non-ascii record names? */
     /* hash the input name to get a unique id for this record */
-    tmp_rec_id = darshan_hash(name, name_len, 0);
-    *rec_id = tmp_rec_id;
-    return;
+    return darshan_hash((unsigned char *)name, strlen(name), 0);
-    void *name,
+    char *name,
-    int rec_size,
+    int rec_len,
-    int mod_oom = 0;
+    void *rec_buf;
     if(!darshan_core)
-        return 0;
+        return(NULL);
     DARSHAN_CORE_LOCK();
     /* check to see if this module has enough space to store a new record */
-    if(darshan_core->mod_array[mod_id]->mem_avail < rec_size)
-        mod_oom = 1;
-    /* check to see if we've already stored the id->name mapping for this record */
-    HASH_FIND(hlink, darshan_core->name_hash, &rec_id, sizeof(darshan_record_id), ref);
-    if(!ref && !mod_oom)
-        /* no mapping already exists, but this module has memory available for
-         * storing the record being registered, so we create a new id->name
-         * mapping to correspond to the record
-        darshan_add_name_record_ref(darshan_core, name, rec_id, &ref);
-    if(!ref)
+    if(darshan_core->mod_array[mod_id]->rec_mem_avail < rec_len)
-        /* if there still is no mapping for this record, either the
-         * module is out of memory or there is no more memory available for
-         * id->name mappings. just back out and indicate the record was
-         * not registered
         DARSHAN_MOD_FLAG_SET(darshan_core->log_hdr_p->partial_flag, mod_id);
-        return 0;
+        return(NULL);
-    if(!DARSHAN_MOD_FLAG_ISSET(ref->mod_flags, mod_id))
+    /* register a name record if a name is given for this record */
+    if(name)
-        DARSHAN_MOD_FLAG_SET(ref->mod_flags, mod_id);
-        darshan_core->mod_array[mod_id]->mem_avail -= rec_size;
-        darshan_core->log_hdr_p->mod_map[mod_id].len += rec_size;
+        /* check to see if we've already stored the id->name mapping for
+         * this record, and add a new name record if not
+        HASH_FIND(hlink, darshan_core->name_hash, &rec_id,
+        if(!ref)
+            darshan_add_name_record_ref(darshan_core, rec_id, name, mod_id);
+    rec_buf = darshan_core->mod_array[mod_id]->rec_buf_p;
+    darshan_core->mod_array[mod_id]->rec_buf_p += rec_len;
+    darshan_core->mod_array[mod_id]->rec_mem_avail -= rec_len;
+    darshan_core->log_hdr_p->mod_map[mod_id].len += rec_len; /* XXX */
     if(file_alignment)
         *file_alignment = darshan_block_size_from_path(name);
-    return 1;
+    return(rec_buf);;
 /* TODO: */
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -279,8 +279,7 @@ static struct hdf5_file_runtime* hdf5_file_by_name(const char *name)
     /* lookup the unique id for this filename */
-        (void*)newname,
-        strlen(newname),
+        newname,
         &file_id);
     /* search the hash table for this file record, and return if found */
@@ -288,7 +287,7 @@ static struct hdf5_file_runtime* hdf5_file_by_name(const char *name)
     if(!file)
         /* register the record with the darshan core component */
-        ret = darshan_core_register_record(file_id, (void *)newname, DARSHAN_HDF5_MOD,
+        ret = darshan_core_register_record(file_id, newname, DARSHAN_HDF5_MOD,
             sizeof(struct darshan_hdf5_file), NULL);
         if(ret == 1)
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -910,8 +910,7 @@ static struct mpiio_file_runtime* mpiio_file_by_name(const char *name)
-        (void*)newname,
-        strlen(newname),
+        newname,
         &file_id);
@@ -919,7 +918,7 @@ static struct mpiio_file_runtime* mpiio_file_by_name(const char *name)
     if(!file)
-        ret = darshan_core_register_record(file_id, (void *)newname, DARSHAN_MPIIO_MOD,
+        ret = darshan_core_register_record(file_id, newname, DARSHAN_MPIIO_MOD,
             sizeof(struct darshan_mpiio_file), NULL);
         if(ret == 1)
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ b/darshan-runtime/lib/darshan-pnetcdf.c
@@ -291,8 +291,7 @@ static struct pnetcdf_file_runtime* pnetcdf_file_by_name(const char *name)
-        (void*)newname,
-        strlen(newname),
+        newname,
         &file_id);
@@ -300,7 +299,7 @@ static struct pnetcdf_file_runtime* pnetcdf_file_by_name(const char *name)
     if(!file)
-        ret = darshan_core_register_record(file_id, (void *)newname, DARSHAN_PNETCDF_MOD,
+        ret = darshan_core_register_record(file_id, newname, DARSHAN_PNETCDF_MOD,
             sizeof(struct darshan_pnetcdf_file), NULL);
         if(ret == 1)
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -168,9 +168,6 @@ struct posix_file_runtime_ref
 struct posix_runtime
-    struct posix_file_runtime* file_runtime_array;
-    struct darshan_posix_file* file_record_array;
-    int file_array_ndx;
     struct posix_file_runtime* file_hash;
     struct posix_file_runtime_ref* fd_hash;
@@ -1450,9 +1447,7 @@ static void posix_runtime_initialize()
         .get_output_data = &posix_get_output_data,
         .shutdown = &posix_shutdown
-    void *psx_buf;
     int psx_buf_size;
-    int file_array_size;
     /* don't do anything if already initialized or instrumenation is disabled */
     if(posix_runtime || instrumentation_disabled)
@@ -1466,7 +1461,6 @@ static void posix_runtime_initialize()
         DARSHAN_POSIX_MOD,
         &posix_mod_fns,
         &psx_buf_size,
-        &psx_buf,
         &my_rank,
         &darshan_mem_alignment);
@@ -1485,40 +1479,17 @@ static void posix_runtime_initialize()
     memset(posix_runtime, 0, sizeof(*posix_runtime));
-    /* set number of trackable files for the POSIX module according to the
-     * amount of memory returned by darshan-core
-    file_array_size = psx_buf_size / sizeof(struct darshan_posix_file);
-    posix_runtime->file_array_ndx = 0;
-    /* store pointer to POSIX record buffer given by darshan-core */
-    posix_runtime->file_record_array = (struct darshan_posix_file *)psx_buf;
-    /* allocate array of runtime file records */
-    posix_runtime->file_runtime_array = malloc(file_array_size *
-                                               sizeof(struct posix_file_runtime));
-    if(!posix_runtime->file_runtime_array)
-        free(posix_runtime);
-        posix_runtime = NULL;
-        darshan_core_unregister_module(DARSHAN_POSIX_MOD);
-        return;
-    memset(posix_runtime->file_runtime_array, 0, file_array_size *
     return;
 /* get a POSIX file record for the given file path */
 static struct posix_file_runtime* posix_file_by_name(const char *name)
-    struct posix_file_runtime *file = NULL;
-    struct darshan_posix_file *file_rec;
+    struct posix_file_runtime *file_rec_rt;
+    struct darshan_posix_file *file_rec = NULL;
     char *newname = NULL;
     darshan_record_id file_id;
     int file_alignment;
-    int ret;
     if(!posix_runtime || instrumentation_disabled)
         return(NULL);
@@ -1527,42 +1498,44 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
     if(!newname)
         newname = (char*)name;
-    /* lookup the unique id for this filename */
-    darshan_core_lookup_record(
-        (void*)newname,
-        strlen(newname),
-        &file_id);
+    /* lookup the id for this filename */
+    file_id = darshan_core_gen_record_id(newname);
-    HASH_FIND(hlink, posix_runtime->file_hash, &file_id, sizeof(darshan_record_id), file);
-    if(!file)
+    HASH_FIND(hlink, posix_runtime->file_hash, &file_id,
+        sizeof(darshan_record_id), file_rec_rt);
+    if(file_rec_rt == NULL)
-        /* register the record with the darshan core component */
-        ret = darshan_core_register_record(file_id, (void *)newname, DARSHAN_POSIX_MOD,
-            sizeof(struct darshan_posix_file), &file_alignment);
-        if(ret == 1)
+        file_rec_rt = malloc(sizeof(*file_rec_rt));
+        if(file_rec_rt)
-            /* register was successful */
-            file = &(posix_runtime->file_runtime_array[posix_runtime->file_array_ndx]);
-            file->file_record =
-                &(posix_runtime->file_record_array[posix_runtime->file_array_ndx]);
-            file_rec = file->file_record;
+            memset(file_rec_rt, 0, sizeof(*file_rec_rt));
+            /* attempt to register the record with darshan core */
+            file_rec = darshan_core_register_record(file_id, newname, DARSHAN_POSIX_MOD,
+                sizeof(struct darshan_posix_file), &file_alignment);
+            if(!file_rec)
+                free(file_rec_rt);
+        if(file_rec != NULL)
+            /* register was successful, init structures */
             file_rec->base_rec.id = file_id;
             file_rec->base_rec.rank = my_rank;
             file_rec->counters[POSIX_MEM_ALIGNMENT] = darshan_mem_alignment;
             file_rec->counters[POSIX_FILE_ALIGNMENT] = file_alignment;
+            file_rec_rt->file_record = file_rec;
             /* add new record to file hash table */
             HASH_ADD(hlink, posix_runtime->file_hash, file_record->base_rec.id,
-                sizeof(darshan_record_id), file);
-            posix_runtime->file_array_ndx++;
     if(newname != name)
         free(newname);
-    return(file);
+    return(file_rec_rt);
 /* get a POSIX file record for the given file path, and also create a
@@ -1578,7 +1551,6 @@ static struct posix_file_runtime* posix_file_by_name_setfd(const char* name, int
     /* find file record by name first */
     file = posix_file_by_name(name);
     if(!file)
         return(NULL);
@@ -2040,41 +2012,41 @@ static void posix_get_output_data(
     void **posix_buf,
     int *posix_buf_sz)
-    struct posix_file_runtime *file;
-    struct posix_file_runtime *tmp;
-    int i;
+    struct posix_file_runtime *file_rec_rt, *tmp;
+    struct darshan_posix_file *posix_rec_buf = *(struct darshan_posix_file **)posix_buf;
     double posix_time;
+    int posix_rec_count;
     struct darshan_posix_file *red_send_buf = NULL;
     struct darshan_posix_file *red_recv_buf = NULL;
     MPI_Datatype red_type;
     MPI_Op red_op;
+    int i;
     assert(posix_runtime);
+    posix_rec_count = HASH_CNT(hlink, posix_runtime->file_hash);
     /* go through file access data for each record and set the 4 most common
      * stride/access size counters.
-    for(i = 0; i < posix_runtime->file_array_ndx; i++)
+    HASH_ITER(hlink, posix_runtime->file_hash, file_rec_rt, tmp)
-        tmp = &(posix_runtime->file_runtime_array[i]);
 #ifndef __DARSHAN_ENABLE_MMAP_LOGS
         /* walk common counters to get 4 most common -- only if mmap
          * feature is disabled (mmap updates counters on the go)
         /* common accesses */
-        darshan_walk_common_vals(tmp->access_root,
-            &(tmp->file_record->counters[POSIX_ACCESS1_ACCESS]),
-            &(tmp->file_record->counters[POSIX_ACCESS1_COUNT]));
+        darshan_walk_common_vals(file_rec_rt->access_root,
+            &(file_rec_rt->file_record->counters[POSIX_ACCESS1_ACCESS]),
+            &(file_rec_rt->file_record->counters[POSIX_ACCESS1_COUNT]));
         /* common strides */
-        darshan_walk_common_vals(tmp->stride_root,
-            &(tmp->file_record->counters[POSIX_STRIDE1_STRIDE]),
-            &(tmp->file_record->counters[POSIX_STRIDE1_COUNT]));
+        darshan_walk_common_vals(file_rec_rt->stride_root,
+            &(file_rec_rt->file_record->counters[POSIX_STRIDE1_STRIDE]),
+            &(file_rec_rt->file_record->counters[POSIX_STRIDE1_COUNT]));
 #endif
-        tdestroy(tmp->access_root, free);
-        tdestroy(tmp->stride_root, free);
+        tdestroy(file_rec_rt->access_root, free);
+        tdestroy(file_rec_rt->stride_root, free);
     /* if there are globally shared files, do a shared file reduction */
@@ -2087,56 +2059,53 @@ static void posix_get_output_data(
         for(i = 0; i < shared_rec_count; i++)
             HASH_FIND(hlink, posix_runtime->file_hash, &shared_recs[i],
-            assert(file);
+            assert(file_rec_rt);
             posix_time =
-                file->file_record->fcounters[POSIX_F_READ_TIME] +
-                file->file_record->fcounters[POSIX_F_WRITE_TIME] +
-                file->file_record->fcounters[POSIX_F_META_TIME];
+                file_rec_rt->file_record->fcounters[POSIX_F_READ_TIME] +
+                file_rec_rt->file_record->fcounters[POSIX_F_WRITE_TIME] +
+                file_rec_rt->file_record->fcounters[POSIX_F_META_TIME];
             /* initialize fastest/slowest info prior to the reduction */
-            file->file_record->counters[POSIX_FASTEST_RANK] =
-                file->file_record->base_rec.rank;
-            file->file_record->counters[POSIX_FASTEST_RANK_BYTES] =
-                file->file_record->counters[POSIX_BYTES_READ] +
-                file->file_record->counters[POSIX_BYTES_WRITTEN];
-            file->file_record->fcounters[POSIX_F_FASTEST_RANK_TIME] =
+            file_rec_rt->file_record->counters[POSIX_FASTEST_RANK] =
+                file_rec_rt->file_record->base_rec.rank;
+            file_rec_rt->file_record->counters[POSIX_FASTEST_RANK_BYTES] =
+                file_rec_rt->file_record->counters[POSIX_BYTES_READ] +
+                file_rec_rt->file_record->counters[POSIX_BYTES_WRITTEN];
+            file_rec_rt->file_record->fcounters[POSIX_F_FASTEST_RANK_TIME] =
                 posix_time;
             /* until reduction occurs, we assume that this rank is both
              * the fastest and slowest. It is up to the reduction operator
              * to find the true min and max.
-            file->file_record->counters[POSIX_SLOWEST_RANK] =
-                file->file_record->counters[POSIX_FASTEST_RANK];
-            file->file_record->counters[POSIX_SLOWEST_RANK_BYTES] =
-                file->file_record->counters[POSIX_FASTEST_RANK_BYTES];
-            file->file_record->fcounters[POSIX_F_SLOWEST_RANK_TIME] =
-                file->file_record->fcounters[POSIX_F_FASTEST_RANK_TIME];
-            file->file_record->base_rec.rank = -1;
+            file_rec_rt->file_record->counters[POSIX_SLOWEST_RANK] =
+                file_rec_rt->file_record->counters[POSIX_FASTEST_RANK];
+            file_rec_rt->file_record->counters[POSIX_SLOWEST_RANK_BYTES] =
+                file_rec_rt->file_record->counters[POSIX_FASTEST_RANK_BYTES];
+            file_rec_rt->file_record->fcounters[POSIX_F_SLOWEST_RANK_TIME] =
+                file_rec_rt->file_record->fcounters[POSIX_F_FASTEST_RANK_TIME];
+            file_rec_rt->file_record->base_rec.rank = -1;
         /* sort the array of files descending by rank so that we get all of the
          * shared files (marked by rank -1) in a contiguous portion at end
          * of the array
-        qsort(posix_runtime->file_record_array, posix_runtime->file_array_ndx,
-            sizeof(struct darshan_posix_file), posix_record_compare);
+        qsort(posix_rec_buf, posix_rec_count, sizeof(struct darshan_posix_file),
+            posix_record_compare);
         /* make *send_buf point to the shared files at the end of sorted array */
-        red_send_buf =
-            &(posix_runtime->file_record_array[posix_runtime->file_array_ndx-shared_rec_count]);
+        red_send_buf = &(posix_rec_buf[posix_rec_count-shared_rec_count]);
         /* allocate memory for the reduction output on rank 0 */
         if(my_rank == 0)
             red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_posix_file));
             if(!red_recv_buf)
                 return;
         /* construct a datatype for a POSIX file record.  This is serving no purpose
@@ -2160,41 +2129,45 @@ static void posix_get_output_data(
         /* clean up reduction state */
         if(my_rank == 0)
-            int tmp_ndx = posix_runtime->file_array_ndx - shared_rec_count;
-            memcpy(&(posix_runtime->file_record_array[tmp_ndx]), red_recv_buf,
+            int tmp_ndx = posix_rec_count - shared_rec_count;
+            memcpy(&(posix_rec_buf[tmp_ndx]), red_recv_buf,
             free(red_recv_buf);
         else
-            posix_runtime->file_array_ndx -= shared_rec_count;
+            posix_rec_count -= shared_rec_count;
         DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
         DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
-    *posix_buf = (void *)(posix_runtime->file_record_array);
-    *posix_buf_sz = posix_runtime->file_array_ndx * sizeof(struct darshan_posix_file);
+    /* update output buffer size to account for shared file reduction */
+    *posix_buf_sz = posix_rec_count * sizeof(struct darshan_posix_file);
     return;
 static void posix_shutdown()
-    struct posix_file_runtime_ref *ref, *tmp;
+    struct posix_file_runtime_ref *fd_ref, *fd_tmp;
+    struct posix_file_runtime *file_ref, *file_tmp;
-    HASH_ITER(hlink, posix_runtime->fd_hash, ref, tmp)
+    HASH_ITER(hlink, posix_runtime->fd_hash, fd_ref, fd_tmp)
-        HASH_DELETE(hlink, posix_runtime->fd_hash, ref);
-        free(ref);
+        HASH_DELETE(hlink, posix_runtime->fd_hash, fd_ref);
+        free(fd_ref);
-    HASH_CLEAR(hlink, posix_runtime->file_hash); /* these entries are freed all at once below */
+    HASH_ITER(hlink, posix_runtime->file_hash, file_ref, file_tmp)
+        HASH_DELETE(hlink, posix_runtime->file_hash, file_ref);
+        free(file_ref);
-    free(posix_runtime->file_runtime_array);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/8f463e512cf639f9cbd64bba7c758ca0e02ae8d7...bfde9eb7378a95682389a76d677bbef29af8f530
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160531/b41904c4/attachment-0001.html>
More information about the Darshan-commits mailing list
