[Darshan-commits] [Git][darshan/darshan][mmap-dev] 2 commits: add variable-length definition of name records
Shane Snyder xgitlab at cels.anl.gov
Thu May 26 12:54:03 CDT 2016
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
d6dad7f3 by Shane Snyder at 2016-05-26T12:29:34-05:00
also some code clean up to change references of record hash
to name hash to be more clear about what it is actually storing.
999ee9c8 by Shane Snyder at 2016-05-26T12:53:05-05:00
darshan-util edits for var. length name records
17 changed files:
- darshan-log-format.h
- darshan-runtime/darshan-core.h
- darshan-runtime/lib/darshan-core.c
- darshan-util/Makefile.in
- darshan-util/darshan-analyzer.c
- darshan-util/darshan-bgq-logutils.c
- darshan-util/darshan-convert.c
- darshan-util/darshan-diff.c
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-logutils.c
- darshan-util/darshan-logutils.h
- darshan-util/darshan-merge.c
- darshan-util/darshan-mpiio-logutils.c
- darshan-util/darshan-null-logutils.c
- darshan-util/darshan-parser.c
- darshan-util/darshan-pnetcdf-logutils.c
- darshan-util/darshan-posix-logutils.c
Changes:
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -69,7 +69,7 @@ struct darshan_header
     int64_t magic_nr;
     unsigned char comp_type;
     uint32_t partial_flag;
-    struct darshan_log_map rec_map;
+    struct darshan_log_map name_map;
     struct darshan_log_map mod_map[DARSHAN_MAX_MODS];
     uint32_t mod_ver[DARSHAN_MAX_MODS];
@@ -86,6 +86,14 @@ struct darshan_job
     char metadata[DARSHAN_JOB_METADATA_LEN];
+/* record to store name->darshan_id mapping for each registered record */
+struct darshan_name_record
+    darshan_record_id id;
+    char name[1];
+/* base record definition that can be used by modules */
 struct darshan_base_record
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -43,12 +43,27 @@
 /* default path for storing mmap log files is '/tmp' */
 #define DARSHAN_DEF_MMAP_LOG_PATH "/tmp"
-/* default record buf can store 2048 records of size 100 bytes */
-#define DARSHAN_RECORD_BUF_SIZE (2048 * 100)
+/* default name record buf can store 2048 records of size 100 bytes */
+#define DARSHAN_NAME_RECORD_BUF_SIZE (2048 * 100)
 /* Default runtime compression buffer size */
 #define DARSHAN_COMP_BUF_SIZE DARSHAN_MOD_MEM_MAX
+/* structure to track registered modules */
+struct darshan_core_module
+    struct darshan_module_funcs mod_funcs;
+    int mem_avail;
+struct darshan_core_name_record_ref
+    struct darshan_name_record *name_record;
+    uint64_t mod_flags;
+    uint64_t global_mod_flags;
+    UT_hash_handle hlink;
 /* in memory structure to keep up with job level data */
 struct darshan_core_runtime
@@ -56,35 +71,21 @@ struct darshan_core_runtime
     struct darshan_header *log_hdr_p;
     struct darshan_job *log_job_p;
     char *log_exemnt_p;
-    void *log_rec_p;
+    void *log_name_p;
     void *log_mod_p;
     /* darshan-core internal data structures */
-    struct darshan_core_record_ref *rec_hash;
-    int rec_hash_cnt;
     struct darshan_core_module* mod_array[DARSHAN_MAX_MODS];
     int mod_mem_used;
-    char *comp_buf;
+    struct darshan_core_name_record_ref *name_hash;
+    int name_hash_cnt;
     double wtime_offset;
+    char *comp_buf;
 #ifdef __DARSHAN_ENABLE_MMAP_LOGS
     char mmap_log_name[PATH_MAX];
 #endif
-struct darshan_core_module
-    struct darshan_module_funcs mod_funcs;
-    int mem_avail;
-struct darshan_core_record_ref
-    void *rec_p; /* id & name buffer */
-    uint64_t mod_flags;
-    uint64_t global_mod_flags;
-    UT_hash_handle hlink;
 void darshan_core_initialize(int argc, char **argv);
 void darshan_core_shutdown(void);
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -93,9 +93,9 @@ static void darshan_log_record_hints_and_ver(
     struct darshan_core_runtime* core);
 static void darshan_get_exe_and_mounts(
     struct darshan_core_runtime *core, int argc, char **argv);
-static void darshan_add_record_hashref(
+static void darshan_add_name_record_ref(
     struct darshan_core_runtime *core, char *name,
-    darshan_record_id id, struct darshan_core_record_ref **ref);
+    darshan_record_id id, struct darshan_core_name_record_ref **ref);
 static int darshan_block_size_from_path(
     const char *path);
 static void darshan_get_user_name(
@@ -110,7 +110,7 @@ static int darshan_log_open_all(
 static int darshan_deflate_buffer(
     void **pointers, int *lengths, int count, char *comp_buf,
     int *comp_buf_length);
-static int darshan_log_write_record_hash(
+static int darshan_log_write_name_record_hash(
     MPI_File log_fh, struct darshan_core_runtime *core,
     uint64_t *inout_off);
 static int darshan_log_append_all(
@@ -208,11 +208,11 @@ void darshan_core_initialize(int argc, char **argv)
             init_core->log_hdr_p = malloc(sizeof(struct darshan_header));
             init_core->log_job_p = malloc(sizeof(struct darshan_job));
             init_core->log_exemnt_p = malloc(DARSHAN_EXE_LEN+1);
-            init_core->log_rec_p = malloc(DARSHAN_RECORD_BUF_SIZE);
+            init_core->log_name_p = malloc(DARSHAN_NAME_RECORD_BUF_SIZE);
             init_core->log_mod_p = malloc(DARSHAN_MOD_MEM_MAX);
             if(!(init_core->log_hdr_p) || !(init_core->log_job_p) ||
-               !(init_core->log_exemnt_p) || !(init_core->log_rec_p) ||
+               !(init_core->log_exemnt_p) || !(init_core->log_name_p) ||
                !(init_core->log_mod_p))
                 free(init_core);
@@ -222,7 +222,7 @@ void darshan_core_initialize(int argc, char **argv)
             memset(init_core->log_hdr_p, 0, sizeof(struct darshan_header));
             memset(init_core->log_job_p, 0, sizeof(struct darshan_job));
             memset(init_core->log_exemnt_p, 0, DARSHAN_EXE_LEN+1);
-            memset(init_core->log_rec_p, 0, DARSHAN_RECORD_BUF_SIZE);
+            memset(init_core->log_name_p, 0, DARSHAN_NAME_RECORD_BUF_SIZE);
             memset(init_core->log_mod_p, 0, DARSHAN_MOD_MEM_MAX);
 #else
             /* if mmap logs are enabled, we need to initialize the mmap region
@@ -233,7 +233,7 @@ void darshan_core_initialize(int argc, char **argv)
             assert(sys_page_size > 0);
             mmap_size = sizeof(struct darshan_header) + DARSHAN_JOB_RECORD_SIZE +
-                + DARSHAN_RECORD_BUF_SIZE + DARSHAN_MOD_MEM_MAX;
+                + DARSHAN_NAME_RECORD_BUF_SIZE + DARSHAN_MOD_MEM_MAX;
             if(mmap_size % sys_page_size)
                 mmap_size = ((mmap_size / sys_page_size) + 1) * sys_page_size;
@@ -298,14 +298,14 @@ void darshan_core_initialize(int argc, char **argv)
                 ((char *)init_core->log_hdr_p + sizeof(struct darshan_header));
             init_core->log_exemnt_p = (char *)
                 ((char *)init_core->log_job_p + sizeof(struct darshan_job));
-            init_core->log_rec_p = (void *)
+            init_core->log_name_p = (void *)
                 ((char *)init_core->log_exemnt_p + DARSHAN_EXE_LEN + 1);
             init_core->log_mod_p = (void *)
-                ((char *)init_core->log_rec_p + DARSHAN_RECORD_BUF_SIZE);
+                ((char *)init_core->log_name_p + DARSHAN_NAME_RECORD_BUF_SIZE);
             /* set header fields needed for the mmap log mechanism */
             init_core->log_hdr_p->comp_type = DARSHAN_NO_COMP;
-            init_core->log_hdr_p->rec_map.off =
+            init_core->log_hdr_p->name_map.off =
                 sizeof(struct darshan_header) + DARSHAN_JOB_RECORD_SIZE;
 #endif
@@ -564,9 +564,9 @@ void darshan_core_shutdown()
     if(internal_timing_flag)
         rec1 = DARSHAN_MPI_CALL(PMPI_Wtime)();
     /* write the record name->id hash to the log file */
-    out_header.rec_map.off = gz_fp;
-    ret = darshan_log_write_record_hash(log_fh, final_core, &gz_fp);
-    out_header.rec_map.len = gz_fp - out_header.rec_map.off;
+    out_header.name_map.off = gz_fp;
+    ret = darshan_log_write_name_record_hash(log_fh, final_core, &gz_fp);
+    out_header.name_map.len = gz_fp - out_header.name_map.off;
     /* error out if unable to write record hash */
     DARSHAN_MPI_CALL(PMPI_Allreduce)(&ret, &all_ret, 1, MPI_INT,
@@ -601,7 +601,7 @@ void darshan_core_shutdown()
     for(i = 0; i < DARSHAN_MAX_MODS; i++)
         struct darshan_core_module* this_mod = final_core->mod_array[i];
-        struct darshan_core_record_ref *ref = NULL;
+        struct darshan_core_name_record_ref *ref = NULL;
         int mod_shared_rec_cnt = 0;
         void* mod_buf = NULL;
         int mod_buf_sz = 0;
@@ -624,7 +624,7 @@ void darshan_core_shutdown()
         memset(mod_shared_recs, 0, shared_rec_cnt * sizeof(darshan_record_id));
         for(j = 0; j < shared_rec_cnt; j++)
-            HASH_FIND(hlink, final_core->rec_hash, &shared_recs[j],
+            HASH_FIND(hlink, final_core->name_hash, &shared_recs[j],
                 sizeof(darshan_record_id), ref);
             assert(ref);
             if(DARSHAN_MOD_FLAG_ISSET(ref->global_mod_flags, i))
@@ -1219,14 +1219,12 @@ static void darshan_get_logfile_name(char* logfile_name, int jobid, struct tm* s
     return;
-static void darshan_add_record_hashref(struct darshan_core_runtime *core,
-    char *name, darshan_record_id id, struct darshan_core_record_ref **ref)
+static void darshan_add_name_record_ref(struct darshan_core_runtime *core, char *name,
     int record_size = sizeof(darshan_record_id) + strlen(name) + 1;
-    darshan_record_id *id_p;
-    char *name_p;
-    if((record_size + core->log_hdr_p->rec_map.len) > DARSHAN_RECORD_BUF_SIZE)
+    if((record_size + core->log_hdr_p->name_map.len) > DARSHAN_NAME_RECORD_BUF_SIZE)
         return;
     *ref = malloc(sizeof(**ref));
@@ -1234,20 +1232,17 @@ static void darshan_add_record_hashref(struct darshan_core_runtime *core,
         memset(*ref, 0, sizeof(**ref));
-        /* serialize the record id and name into the record map buffer */
-        id_p = (darshan_record_id *)
-            ((char *)core->log_rec_p + core->log_hdr_p->rec_map.len);
-        *id_p = id;
-        name_p = (char *)id_p + sizeof(darshan_record_id);
-        strcpy(name_p, name);
-        /* save pointer to this record mapping buffer */
-        (*ref)->rec_p = id_p;
+        (*ref)->name_record = (struct darshan_name_record *)
+            ((char *)core->log_name_p + core->log_hdr_p->name_map.len);
+        memset((*ref)->name_record, 0, record_size);
+        (*ref)->name_record->id = id;
+        strcpy((*ref)->name_record->name, name);
         /* add the record to the hash table */
-        HASH_ADD_KEYPTR(hlink, core->rec_hash, id_p, sizeof(darshan_record_id), (*ref));
-        core->rec_hash_cnt++;
-        core->log_hdr_p->rec_map.len += record_size;
+        HASH_ADD(hlink, core->name_hash, name_record->id,
+            sizeof(darshan_record_id), (*ref));
+        core->name_hash_cnt++;
+        core->log_hdr_p->name_map.len += record_size;
     return;
@@ -1257,8 +1252,8 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
     darshan_record_id **shared_recs, int *shared_rec_cnt)
     int i, j;
-    int tmp_cnt = core->rec_hash_cnt;
-    struct darshan_core_record_ref *tmp, *ref;
+    int tmp_cnt = core->name_hash_cnt;
+    struct darshan_core_name_record_ref *tmp, *ref;
     darshan_record_id *id_array;
     uint64_t *mod_flags;
     uint64_t *global_mod_flags;
@@ -1281,10 +1276,9 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
     if(my_rank == 0)
         i = 0;
-        HASH_ITER(hlink, core->rec_hash, ref, tmp)
+        HASH_ITER(hlink, core->name_hash, ref, tmp)
-            /* dereference the record pointer to get corresponding id */
-            id_array[i++] = *(darshan_record_id *)ref->rec_p;
+            id_array[i++] = ref->name_record->id;
@@ -1295,7 +1289,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
     /* everyone looks to see if they opened the same records as root */
     for(i=0; i<tmp_cnt; i++)
-        HASH_FIND(hlink, core->rec_hash, &id_array[i], sizeof(darshan_record_id), ref);
+        HASH_FIND(hlink, core->name_hash, &id_array[i], sizeof(darshan_record_id), ref);
         if(ref)
             /* we opened that record too, save the mod_flags */
@@ -1320,7 +1314,7 @@ static void darshan_get_shared_records(struct darshan_core_runtime *core,
              * accessed this module. we need this info to support shared
              * file reductions
             assert(ref);
             ref->global_mod_flags = global_mod_flags[i];
@@ -1483,14 +1477,14 @@ static int darshan_deflate_buffer(void **pointers, int *lengths, int count,
 /* NOTE: the map written to file may contain duplicate id->name entries if a
  *       record is opened by multiple ranks, but not all ranks
-static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_runtime *core,
-    uint64_t *inout_off)
+static int darshan_log_write_name_record_hash(MPI_File log_fh,
+    struct darshan_core_runtime *core, uint64_t *inout_off)
-    struct darshan_core_record_ref *ref, *tmp;
+    struct darshan_core_name_record_ref *ref, *tmp;
     int ret;
     /* serialize the record hash into a buffer for writing */
         /* to avoid duplicate records, only rank 0 will write shared records */
         if(my_rank > 0 && ref->global_mod_flags)
@@ -1500,8 +1494,8 @@ static int darshan_log_write_record_hash(MPI_File log_fh, struct darshan_core_ru
     /* collectively write out the record hash to the darshan log */
-    ret = darshan_log_append_all(log_fh, core, core->log_rec_p,
-        core->log_hdr_p->rec_map.len, inout_off);
+    ret = darshan_log_append_all(log_fh, core, core->log_name_p,
+        core->log_hdr_p->name_map.len, inout_off);
     return(ret);
@@ -1581,12 +1575,12 @@ static int darshan_log_append_all(MPI_File log_fh, struct darshan_core_runtime *
 /* free darshan core data structures to shutdown */
 static void darshan_core_cleanup(struct darshan_core_runtime* core)
     int i;
-        HASH_DELETE(hlink, core->rec_hash, ref);
+        HASH_DELETE(hlink, core->name_hash, ref);
         free(ref);
@@ -1603,7 +1597,7 @@ static void darshan_core_cleanup(struct darshan_core_runtime* core)
     free(core->log_hdr_p);
     free(core->log_job_p);
     free(core->log_exemnt_p);
-    free(core->log_rec_p);
+    free(core->log_name_p);
     free(core->log_mod_p);
 #endif
@@ -1686,7 +1680,7 @@ void darshan_core_register_module(
 void darshan_core_unregister_module(
     darshan_module_id mod_id)
     if(!darshan_core)
         return;
@@ -1694,14 +1688,14 @@ void darshan_core_unregister_module(
     DARSHAN_CORE_LOCK();
     /* iterate all records and disassociate this module from them */
-    HASH_ITER(hlink, darshan_core->rec_hash, ref, tmp)
+    HASH_ITER(hlink, darshan_core->name_hash, ref, tmp)
         /* disassociate this module from the given record id */
         DARSHAN_MOD_FLAG_UNSET(ref->mod_flags, mod_id);
         if(!(ref->mod_flags))
             /* if no other modules are associated with this rec, delete it */
-            HASH_DELETE(hlink, darshan_core->rec_hash, ref);
+            HASH_DELETE(hlink, darshan_core->name_hash, ref);
@@ -1739,7 +1733,7 @@ int darshan_core_register_record(
     int rec_size,
     int *file_alignment)
-    struct darshan_core_record_ref *ref;
+    struct darshan_core_name_record_ref *ref;
     int mod_oom = 0;
     if(!darshan_core)
@@ -1752,14 +1746,14 @@ int darshan_core_register_record(
         mod_oom = 1;
     /* check to see if we've already stored the id->name mapping for this record */
-    HASH_FIND(hlink, darshan_core->rec_hash, &rec_id, sizeof(darshan_record_id), ref);
+    HASH_FIND(hlink, darshan_core->name_hash, &rec_id, sizeof(darshan_record_id), ref);
     if(!ref && !mod_oom)
         /* no mapping already exists, but this module has memory available for
          * storing the record being registered, so we create a new id->name
          * mapping to correspond to the record
-        darshan_add_record_hashref(darshan_core, name, rec_id, &ref);
+        darshan_add_name_record_ref(darshan_core, name, rec_id, &ref);
     if(!ref)
--- a/darshan-util/Makefile.in
+++ b/darshan-util/Makefile.in
@@ -159,7 +159,7 @@ endif
 clean::
-	rm -f *.o *.po *.a *.so darshan-analyzer darshan-convert darshan-parser darshan-merge jenkins-hash-gen
+	rm -f *.o *.po *.a *.so darshan-analyzer darshan-convert darshan-diff darshan-parser darshan-merge jenkins-hash-gen
 distclean:: clean
 	rm -f darshan-runtime-config.h aclocal.m4 autom4te.cache/* config.status config.log Makefile util/bin/darshan-job-summary.pl
--- a/darshan-util/darshan-analyzer.c
+++ b/darshan-util/darshan-analyzer.c
@@ -52,10 +52,10 @@ int process_log(const char *fname, double *io_ratio, int *used_mpio, int *used_p
         return -1;
-    ret = darshan_log_getjob(file, &job);
+    ret = darshan_log_get_job(file, &job);
     if (ret < 0)
-        fprintf(stderr, "darshan_log_getjob() failed on file %s.\n", fname);
+        fprintf(stderr, "darshan_log_get_job() failed on file %s.\n", fname);
         darshan_log_close(file);
         return -1;
--- a/darshan-util/darshan-bgq-logutils.c
+++ b/darshan-util/darshan-bgq-logutils.c
@@ -55,7 +55,7 @@ static int darshan_log_get_bgq_rec(darshan_fd fd, void* bgq_buf)
     int i;
     int ret;
-    ret = darshan_log_getmod(fd, DARSHAN_BGQ_MOD, bgq_buf,
+    ret = darshan_log_get_mod(fd, DARSHAN_BGQ_MOD, bgq_buf,
         sizeof(struct darshan_bgq_record));
     if(ret < 0)
         return(-1);
@@ -84,7 +84,7 @@ static int darshan_log_put_bgq_rec(darshan_fd fd, void* bgq_buf, int ver)
     struct darshan_bgq_record *rec = (struct darshan_bgq_record *)bgq_buf;
     int ret;
-    ret = darshan_log_putmod(fd, DARSHAN_BGQ_MOD, rec,
+    ret = darshan_log_put_mod(fd, DARSHAN_BGQ_MOD, rec,
         sizeof(struct darshan_bgq_record), ver);
     if(ret < 0)
         return(-1);
--- a/darshan-util/darshan-convert.c
+++ b/darshan-util/darshan-convert.c
@@ -140,21 +140,25 @@ void obfuscate_exe(int key, char *exe)
     return;
-void obfuscate_filenames(int key, struct darshan_record_ref *rec_hash)
+void obfuscate_filenames(int key, struct darshan_name_record_ref *name_hash)
-    struct darshan_record_ref *ref, *tmp;
+    struct darshan_name_record_ref *ref, *tmp;
     uint32_t hashed;
     char tmp_string[128] = {0};
+    darshan_record_id tmp_id;
-    HASH_ITER(hlink, rec_hash, ref, tmp)
+    HASH_ITER(hlink, name_hash, ref, tmp)
-        hashed = darshan_hashlittle(ref->name, strlen(ref->name), key);
+        tmp_id = ref->name_record->id;
+        hashed = darshan_hashlittle(ref->name_record->name,
+            strlen(ref->name_record->name), key);
         sprintf(tmp_string, "%u", hashed);
-        free(ref->name);
-        ref->name = malloc(strlen(tmp_string) + 1);
-        assert(ref->name);
-        memcpy(ref->name, tmp_string, strlen(tmp_string));
-        ref->name[strlen(tmp_string)] = '\0';
+        free(ref->name_record);
+        ref->name_record = malloc(sizeof(struct darshan_name_record) +
+            strlen(tmp_string));
+        assert(ref->name_record);
+        ref->name_record->id = tmp_id;
+        strcpy(ref->name_record->name, tmp_string);
     return;
@@ -202,16 +206,17 @@ void add_annotation (char *annotation,
     return;
-static void remove_hash_recs(struct darshan_record_ref **rec_hash, darshan_record_id hash)
+static void remove_hash_recs(struct darshan_name_record_ref **name_hash,
+    darshan_record_id hash)
-    HASH_ITER(hlink, *rec_hash, ref, tmp)
+    HASH_ITER(hlink, *name_hash, ref, tmp)
-        if(ref->id != hash)
+        if(ref->name_record->id != hash)
-            HASH_DELETE(hlink, *rec_hash, ref);
-            free(ref->name);
+            HASH_DELETE(hlink, *name_hash, ref);
             free(ref);
@@ -232,8 +237,8 @@ int main(int argc, char **argv)
     int mount_count;
     char** mnt_pts;
     char** fs_types;
-    struct darshan_record_ref *rec_hash = NULL;
+    struct darshan_name_record_ref *name_hash = NULL;
     char mod_buf[DEF_MOD_BUF_SIZE];
     enum darshan_comp_type comp_type;
     int bzip2;
@@ -259,7 +264,7 @@ int main(int argc, char **argv)
     /* read job info */
-    ret = darshan_log_getjob(infile, &job);
+    ret = darshan_log_get_job(infile, &job);
     if(ret < 0)
         darshan_log_close(infile);
@@ -272,7 +277,7 @@ int main(int argc, char **argv)
     if (obfuscate) obfuscate_job(key, &job);
     if (annotation) add_annotation(annotation, &job);
-    ret = darshan_log_putjob(outfile, &job);
+    ret = darshan_log_put_job(outfile, &job);
     if (ret < 0)
@@ -280,7 +285,7 @@ int main(int argc, char **argv)
         return(-1);
-    ret = darshan_log_getexe(infile, tmp_string);
+    ret = darshan_log_get_exe(infile, tmp_string);
     if(ret < 0)
@@ -291,7 +296,7 @@ int main(int argc, char **argv)
     if (obfuscate) obfuscate_exe(key, tmp_string);
-    ret = darshan_log_putexe(outfile, tmp_string);
+    ret = darshan_log_put_exe(outfile, tmp_string);
     if(ret < 0)
@@ -299,7 +304,7 @@ int main(int argc, char **argv)
         return(-1);
-    ret = darshan_log_getmounts(infile, &mnt_pts, &fs_types, &mount_count);
+    ret = darshan_log_get_mounts(infile, &mnt_pts, &fs_types, &mount_count);
     if(ret < 0)
@@ -308,7 +313,7 @@ int main(int argc, char **argv)
         return(-1);
-    ret = darshan_log_putmounts(outfile, mnt_pts, fs_types, mount_count);
+    ret = darshan_log_put_mounts(outfile, mnt_pts, fs_types, mount_count);
     if(ret < 0)
@@ -316,7 +321,7 @@ int main(int argc, char **argv)
         return(-1);
-    ret = darshan_log_gethash(infile, &rec_hash);
+    ret = darshan_log_get_namehash(infile, &name_hash);
     if(ret < 0)
@@ -328,10 +333,10 @@ int main(int argc, char **argv)
     /* NOTE: obfuscating filepaths breaks the ability to map files
      * to the corresponding FS & mount info maintained by darshan
-    if(obfuscate) obfuscate_filenames(key, rec_hash);
-    if(hash) remove_hash_recs(&rec_hash, hash);
+    if(obfuscate) obfuscate_filenames(key, name_hash);
+    if(hash) remove_hash_recs(&name_hash, hash);
-    ret = darshan_log_puthash(outfile, rec_hash);
+    ret = darshan_log_put_namehash(outfile, name_hash);
     if(ret < 0)
@@ -402,10 +407,10 @@ int main(int argc, char **argv)
         free(fs_types);
-        HASH_DELETE(hlink, rec_hash, ref);
-        free(ref->name);
+        HASH_DELETE(hlink, name_hash, ref);
         free(ref);
--- a/darshan-util/darshan-diff.c
+++ b/darshan-util/darshan-diff.c
@@ -53,8 +53,8 @@ int main(int argc, char *argv[])
     darshan_fd file1, file2;
     struct darshan_job job1, job2;
     char exe1[4096], exe2[4096];
-    struct darshan_record_ref *name_hash1 = NULL, *name_hash2 = NULL;
-    struct darshan_record_ref *name_ref1, *name_ref2;
+    struct darshan_name_record_ref *name_hash1 = NULL, *name_hash2 = NULL;
+    struct darshan_name_record_ref *name_ref1, *name_ref2;
     struct darshan_file_record_ref *rec_hash1 = NULL, *rec_hash2 = NULL;
     struct darshan_file_record_ref *rec_ref1, *rec_ref2, *rec_tmp;
     struct darshan_mod_record_ref *mod_rec1, *mod_rec2;
@@ -89,7 +89,7 @@ int main(int argc, char *argv[])
     /* get job data for each log file */
-    ret = darshan_log_getjob(file1, &job1);
+    ret = darshan_log_get_job(file1, &job1);
     if(ret < 0)
         darshan_log_close(file1);
@@ -98,7 +98,7 @@ int main(int argc, char *argv[])
         return(-1);
-    ret = darshan_log_getjob(file2, &job2);
+    ret = darshan_log_get_job(file2, &job2);
     if(ret < 0)
@@ -108,7 +108,7 @@ int main(int argc, char *argv[])
     /* get exe string for each log file */
-    ret = darshan_log_getexe(file1, exe1);
+    ret = darshan_log_get_exe(file1, exe1);
     if(ret < 0)
@@ -117,7 +117,7 @@ int main(int argc, char *argv[])
         return(-1);
-    ret = darshan_log_getexe(file2, exe2);
+    ret = darshan_log_get_exe(file2, exe2);
     if(ret < 0)
@@ -144,7 +144,7 @@ int main(int argc, char *argv[])
                 (int64_t)(job2.end_time - job2.start_time + 1));
     /* get hash of record ids to file names for each log */
-    ret = darshan_log_gethash(file1, &name_hash1);
+    ret = darshan_log_get_namehash(file1, &name_hash1);
     if(ret < 0)
@@ -153,7 +153,7 @@ int main(int argc, char *argv[])
         return(-1);
-    ret = darshan_log_gethash(file2, &name_hash2);
+    ret = darshan_log_get_namehash(file2, &name_hash2);
     if(ret < 0)
@@ -246,14 +246,14 @@ int main(int argc, char *argv[])
                     HASH_FIND(hlink, name_hash1, &(base_rec1->id),
                         sizeof(darshan_record_id), name_ref1);
                     assert(name_ref1);
-                    file_name1 = name_ref1->name;
+                    file_name1 = name_ref1->name_record->name;
                 if(mod_buf2)
                     HASH_FIND(hlink, name_hash2, &(base_rec2->id),
                         sizeof(darshan_record_id), name_ref2);
                     assert(name_ref2);
-                    file_name2 = name_ref2->name;
+                    file_name2 = name_ref2->name_record->name;
                 mod_logutils[i]->log_print_diff(mod_buf1, file_name1, mod_buf2, file_name2);
@@ -314,7 +314,7 @@ int main(int argc, char *argv[])
                 assert(name_ref2);
                 mod_logutils[i]->log_print_diff(NULL, NULL, mod_rec2->mod_dat, file_name2);
@@ -340,13 +340,13 @@ int main(int argc, char *argv[])
     HASH_ITER(hlink, name_hash1, name_ref1, name_ref2)
         HASH_DELETE(hlink, name_hash1, name_ref1);
-        free(name_ref1->name);
+        free(name_ref1->name_record);
         free(name_ref1);
     HASH_ITER(hlink, name_hash2, name_ref2, name_ref1)
         HASH_DELETE(hlink, name_hash2, name_ref2);
-        free(name_ref2->name);
+        free(name_ref2->name_record);
         free(name_ref2);
--- a/darshan-util/darshan-hdf5-logutils.c
+++ b/darshan-util/darshan-hdf5-logutils.c
@@ -55,7 +55,7 @@ static int darshan_log_get_hdf5_file(darshan_fd fd, void* hdf5_buf)
     int i;
     int ret;
-    ret = darshan_log_getmod(fd, DARSHAN_HDF5_MOD, hdf5_buf,
+    ret = darshan_log_get_mod(fd, DARSHAN_HDF5_MOD, hdf5_buf,
         sizeof(struct darshan_hdf5_file));
     if(ret < 0)
         return(-1);
@@ -84,7 +84,7 @@ static int darshan_log_put_hdf5_file(darshan_fd fd, void* hdf5_buf, int ver)
     struct darshan_hdf5_file *file = (struct darshan_hdf5_file *)hdf5_buf;
     int ret;
-    ret = darshan_log_putmod(fd, DARSHAN_HDF5_MOD, file,
+    ret = darshan_log_put_mod(fd, DARSHAN_HDF5_MOD, file,
         sizeof(struct darshan_hdf5_file), ver);
     if(ret < 0)
         return(-1);
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -27,7 +27,7 @@
 #define DARSHAN_HEADER_REGION_ID    (-3)
 #define DARSHAN_JOB_REGION_ID       (-2)
-#define DARSHAN_REC_MAP_REGION_ID   (-1)
+#define DARSHAN_NAME_MAP_REGION_ID  (-1)
 struct darshan_dz_state
@@ -66,8 +66,8 @@ struct darshan_fd_int_state
     struct darshan_dz_state dz;
-static int darshan_log_getheader(darshan_fd fd);
-static int darshan_log_putheader(darshan_fd fd);
+static int darshan_log_get_header(darshan_fd fd);
+static int darshan_log_put_header(darshan_fd fd);
 static int darshan_log_seek(darshan_fd fd, off_t offset);
 static int darshan_log_read(darshan_fd fd, void *buf, int len);
 static int darshan_log_write(darshan_fd fd, void *buf, int len);
@@ -136,7 +136,7 @@ darshan_fd darshan_log_open(const char *name)
     strncpy(tmp_fd->state->logfile_path, name, PATH_MAX);
     /* read the header from the log file to init fd data structures */
-    ret = darshan_log_getheader(tmp_fd);
+    ret = darshan_log_get_header(tmp_fd);
     if(ret < 0)
         fprintf(stderr, "Error: failed to read darshan log file header.\n");
@@ -229,13 +229,13 @@ darshan_fd darshan_log_create(const char *name, enum darshan_comp_type comp_type
     return(tmp_fd);
-/* darshan_log_getjob()
+/* darshan_log_get_job()
  * read job level metadata from the darshan log file
  * returns 0 on success, -1 on failure
-int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
+int darshan_log_get_job(darshan_fd fd, struct darshan_job *job)
     struct darshan_fd_int_state *state = fd->state;
     char job_buf[DARSHAN_JOB_RECORD_SIZE] = {0};
@@ -275,13 +275,13 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job)
     return(0);
-/* darshan_log_putjob()
+/* darshan_log_put_job()
  * write job level metadata to darshan log file
-int darshan_log_putjob(darshan_fd fd, struct darshan_job *job)
+int darshan_log_put_job(darshan_fd fd, struct darshan_job *job)
     struct darshan_job job_copy;
@@ -316,13 +316,13 @@ int darshan_log_putjob(darshan_fd fd, struct darshan_job *job)
     return(0);
-/* darshan_log_getexe()
+/* darshan_log_get_exe()
  * reads the application exe name from darshan log file
-int darshan_log_getexe(darshan_fd fd, char *buf)
+int darshan_log_get_exe(darshan_fd fd, char *buf)
     char *newline;
@@ -334,7 +334,7 @@ int darshan_log_getexe(darshan_fd fd, char *buf)
     if(!(state->exe_mnt_data))
         struct darshan_job job;
-        ret = darshan_log_getjob(fd, &job);
+        ret = darshan_log_get_job(fd, &job);
         if(ret < 0 || !(state->exe_mnt_data))
             return(-1);
@@ -350,7 +350,7 @@ int darshan_log_getexe(darshan_fd fd, char *buf)
     return (0);
-/* darshan_log_putexe()
+/* darshan_log_put_exe()
  * wrties the application exe name to darshan log file
  * NOTE: this needs to be called immediately following put_job as it
@@ -359,7 +359,7 @@ int darshan_log_getexe(darshan_fd fd, char *buf)
-int darshan_log_putexe(darshan_fd fd, char *buf)
+int darshan_log_put_exe(darshan_fd fd, char *buf)
     int len = strlen(buf);
@@ -378,7 +378,7 @@ int darshan_log_putexe(darshan_fd fd, char *buf)
     return(0);
-/* darshan_log_getmounts()
+/* darshan_log_get_mounts()
  * retrieves mount table information from the log. Note that mnt_pts and
  * fs_types are arrays that will be allocated by the function and must be
@@ -386,7 +386,7 @@ int darshan_log_putexe(darshan_fd fd, char *buf)
-int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
+int darshan_log_get_mounts(darshan_fd fd, char*** mnt_pts,
     char*** fs_types, int* count)
@@ -400,7 +400,7 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
             return(-1);
@@ -453,7 +453,7 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
     return(0);
-/* darshan_log_putmounts()
+/* darshan_log_put_mounts()
  * writes mount information to the darshan log file
  * NOTE: this function call should follow immediately after the call
@@ -462,7 +462,7 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
-int darshan_log_putmounts(darshan_fd fd, char** mnt_pts, char** fs_types, int count)
+int darshan_log_put_mounts(darshan_fd fd, char** mnt_pts, char** fs_types, int count)
     int i;
@@ -496,122 +496,112 @@ int darshan_log_putmounts(darshan_fd fd, char** mnt_pts, char** fs_types, int co
     return(0);
-/* darshan_log_gethash()
+/* darshan_log_get_namehash()
- * read the hash of records from the darshan log file
+ * read the hash of name records from the darshan log file
-int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
+int darshan_log_get_namehash(darshan_fd fd, struct darshan_name_record_ref **hash)
-    char *hash_buf;
-    int hash_buf_sz;
-    char *buf_ptr;
-    darshan_record_id *rec_id_ptr;
-    char *path_ptr;
+    char *name_rec_buf;
     char *tmp_p;
-    struct darshan_record_ref *ref;
+    int name_rec_buf_sz;
     int read;
     int read_req_sz;
+    struct darshan_name_record_ref *ref;
+    struct darshan_name_record *name_rec;
     int buf_rem = 0;
+    int rec_len;
     assert(state);
-    /* just return if there is no record mapping data */
-    if(fd->rec_map.len == 0)
+    /* just return if there is no name record mapping data */
+    if(fd->name_map.len == 0)
         *hash = NULL;
         return(0);
-    /* default to hash buffer twice as big as default compression buf */
-    hash_buf = malloc(DARSHAN_DEF_COMP_BUF_SZ * 2);
-    if(!hash_buf)
+    /* default to buffer twice as big as default compression buf */
+    name_rec_buf_sz = DARSHAN_DEF_COMP_BUF_SZ * 2;
+    name_rec_buf = malloc(name_rec_buf_sz);
+    if(!name_rec_buf)
         return(-1);
-    memset(hash_buf, 0, DARSHAN_DEF_COMP_BUF_SZ * 2);
-    hash_buf_sz = DARSHAN_DEF_COMP_BUF_SZ * 2;
+    memset(name_rec_buf, 0, name_rec_buf_sz);
     do
-        /* read chunks of the darshan record id -> file name mapping from log file,
+        /* read chunks of the darshan record id -> name mapping from log file,
          * constructing a hash table in the process
-        read_req_sz = hash_buf_sz - buf_rem;
-        read = darshan_log_dzread(fd, DARSHAN_REC_MAP_REGION_ID,
-            hash_buf + buf_rem, read_req_sz);
+        read_req_sz = name_rec_buf_sz - buf_rem;
+        read = darshan_log_dzread(fd, DARSHAN_NAME_MAP_REGION_ID,
+            name_rec_buf + buf_rem, read_req_sz);
         if(read < 0)
-            fprintf(stderr, "Error: failed to read record hash from darshan log file.\n");
-            free(hash_buf);
+            fprintf(stderr, "Error: failed to read name hash from darshan log file.\n");
+            free(name_rec_buf);
             return(-1);
+        buf_rem += read;
-        /* work through the hash buffer -- deserialize the mapping data and
+        /* work through the name record buffer -- deserialize the mapping data and
          * add to the output hash table
          * NOTE: these mapping pairs are variable in length, so we have to be able
          * to handle incomplete mappings temporarily here
-        buf_ptr = hash_buf;
-        buf_rem += read;
-        while(buf_rem > (sizeof(darshan_record_id) + 1))
+        name_rec = (struct darshan_name_record *)name_rec_buf;
+        while(buf_rem > sizeof(darshan_record_id) + 1)
-            tmp_p = buf_ptr + sizeof(darshan_record_id);
-            while(tmp_p < (buf_ptr + buf_rem))
+            if(strnlen(name_rec->name, buf_rem - sizeof(darshan_record_id)) ==
+                (buf_rem - sizeof(darshan_record_id)))
-                /* look for terminating null character for record name */
-                if(*tmp_p == '\0')
-                    break;
-                tmp_p++;
-            if(*tmp_p != '\0')
+                /* if this record name's terminating null character is not
+                 * present, we need to read more of the buffer before continuing
                 break;
-            /* get pointers for each field of this darshan record */
-            /* NOTE: darshan record hash serialization method:
-             *          ... darshan_record_id | path '\0' ...
-            rec_id_ptr = (darshan_record_id *)buf_ptr;
-            buf_ptr += sizeof(darshan_record_id);
-            path_ptr = (char *)buf_ptr;
             if(fd->swap_flag)
                 /* we need to sort out endianness issues before deserializing */
-                DARSHAN_BSWAP64(rec_id_ptr);
+                DARSHAN_BSWAP64(&(name_rec->id));
-            HASH_FIND(hlink, *hash, rec_id_ptr, sizeof(darshan_record_id), ref);
+            HASH_FIND(hlink, *hash, &(name_rec->id), sizeof(darshan_record_id), ref);
             if(!ref)
+                rec_len = sizeof(darshan_record_id) + strlen(name_rec->name) + 1;
                 ref = malloc(sizeof(*ref));
                 if(!ref)
-                    free(hash_buf);
                     return(-1);
-                ref->name = malloc(strlen(path_ptr) + 1);
-                if(!ref->name)
+                ref->name_record = malloc(rec_len);
+                if(!ref->name_record)
                     free(ref);
-                    free(hash_buf);
                     return(-1);
-                /* set the fields for this record */
-                ref->id = *rec_id_ptr;
-                strcpy(ref->name, path_ptr);
+                /* copy the name record over from the hash buffer */
+                memcpy(ref->name_record, name_rec, rec_len);
                 /* add this record to the hash */
-                HASH_ADD(hlink, *hash, id, sizeof(darshan_record_id), ref);
+                HASH_ADD(hlink, *hash, name_record->id, sizeof(darshan_record_id), ref);
-            buf_ptr += strlen(path_ptr) + 1;
-            buf_rem -= (sizeof(darshan_record_id) + strlen(path_ptr) + 1);
+            tmp_p = (char *)name_rec + rec_len;
+            name_rec = (struct darshan_name_record *)tmp_p;
+            buf_rem -= rec_len;
         /* copy any leftover data to beginning of buffer to parse next */
-        memcpy(hash_buf, buf_ptr, buf_rem);
+        memcpy(name_rec_buf, name_rec, buf_rem);
         /* we keep reading until we get a short read informing us we have
          * read all of the record hash
@@ -619,74 +609,64 @@ int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash)
     } while(read == read_req_sz);
     assert(buf_rem == 0);
-    free(hash_buf);
     return(0);
-/* darshan_log_puthash()
+/* darshan_log_put_namehash()
- * writes the hash table of records to the darshan log file
+ * writes the hash table of name records to the darshan log file
  * to darshan_log_putmounts(), as it assumes the darshan log file pointer
  * is pointing to the offset immediately following the mount information
-int darshan_log_puthash(darshan_fd fd, struct darshan_record_ref *hash)
+int darshan_log_put_namehash(darshan_fd fd, struct darshan_name_record_ref *hash)
-    char *hash_buf;
-    int hash_buf_sz;
-    char *buf_ptr;
+    struct darshan_name_record_ref *name_rec;
+    int name_rec_len;
     int wrote;
     assert(state);
     /* allocate memory for largest possible hash record */
-    hash_buf_sz = sizeof(darshan_record_id) + PATH_MAX + 1;
-    hash_buf = malloc(hash_buf_sz);
-    if(!hash_buf)
+    name_rec = malloc(sizeof(struct darshan_name_record) + PATH_MAX);
+    if(!name_rec)
         return(-1);
-    memset(hash_buf, 0, hash_buf_sz);
+    memset(name_rec, 0, sizeof(struct darshan_name_record) + PATH_MAX);
     /* individually serialize each hash record and write to log file */
     HASH_ITER(hlink, hash, ref, tmp)
-        /* the hash buffer has space to serialize this record
-         * NOTE: darshan record hash serialization method:
-        *((darshan_record_id *)buf_ptr) = ref->id;
-        strcpy(buf_ptr, ref->name);
-        buf_ptr += strlen(ref->name) + 1;
+        name_rec_len = sizeof(struct darshan_name_record) + strlen(ref->name_record->name);
+        memcpy(name_rec, ref->name_record, name_rec_len);
         /* write this hash entry to log file */
-        wrote = darshan_log_dzwrite(fd, DARSHAN_REC_MAP_REGION_ID,
-            hash_buf, (buf_ptr - hash_buf));
-        if(wrote != (buf_ptr - hash_buf))
+        wrote = darshan_log_dzwrite(fd, DARSHAN_NAME_MAP_REGION_ID,
+            name_rec, name_rec_len);
+        if(wrote != name_rec_len)
             state->err = -1;
-            fprintf(stderr, "Error: failed to write record hash to darshan log file.\n");
-            free(hash_buf);
+            fprintf(stderr, "Error: failed to write name hash to darshan log file.\n");
+            free(name_rec);
             return(-1);
-    free(hash_buf);
+    free(name_rec);
     return(0);
-/* darshan_log_getmod()
+/* darshan_log_get_mod()
  * get a chunk of module data from the darshan log file
  * returns number of bytes read on success, -1 on failure
-int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id,
+int darshan_log_get_mod(darshan_fd fd, darshan_module_id mod_id,
     void *mod_buf, int mod_buf_sz)
@@ -716,7 +696,7 @@ int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id,
     return(ret);
-/* darshan_log_putmod()
+/* darshan_log_put_mod()
  * write a chunk of module data to the darshan log file
  * NOTE: this function call should be called directly after the
@@ -728,7 +708,7 @@ int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id,
  * returns number of bytes written on success, -1 on failure
-int darshan_log_putmod(darshan_fd fd, darshan_module_id mod_id,
+int darshan_log_put_mod(darshan_fd fd, darshan_module_id mod_id,
     void *mod_buf, int mod_buf_sz, int ver)
@@ -798,7 +778,7 @@ void darshan_log_close(darshan_fd fd)
         /* if no errors flushing, write the log header before closing */
         if(state->err != -1)
-            ret = darshan_log_putheader(fd);
+            ret = darshan_log_put_header(fd);
             if(ret < 0)
                 state->err = -1;
@@ -830,7 +810,7 @@ void darshan_log_close(darshan_fd fd)
     struct darshan_header header;
     int i;
@@ -889,8 +869,8 @@ static int darshan_log_getheader(darshan_fd fd)
             fd->swap_flag = 1;
             /* swap the log map variables in the header */
-            DARSHAN_BSWAP64(&(header.rec_map.off));
-            DARSHAN_BSWAP64(&(header.rec_map.len));
+            DARSHAN_BSWAP64(&(header.name_map.off));
+            DARSHAN_BSWAP64(&(header.name_map.len));
                 DARSHAN_BSWAP64(&(header.mod_map[i].off));
@@ -911,12 +891,12 @@ static int darshan_log_getheader(darshan_fd fd)
     memcpy(fd->mod_ver, header.mod_ver, DARSHAN_MAX_MODS * sizeof(uint32_t));
     /* save the mapping of data within log file to this file descriptor */
-    memcpy(&fd->rec_map, &(header.rec_map), sizeof(struct darshan_log_map));
+    memcpy(&fd->name_map, &(header.name_map), sizeof(struct darshan_log_map));
     memcpy(&fd->mod_map, &(header.mod_map), DARSHAN_MAX_MODS * sizeof(struct darshan_log_map));
     /* there may be nothing following the job data, so safety check map */
     fd->job_map.off = sizeof(struct darshan_header);
-    if(fd->rec_map.off == 0)
+    if(fd->name_map.off == 0)
@@ -940,7 +920,7 @@ static int darshan_log_getheader(darshan_fd fd)
     else
-        fd->job_map.len = fd->rec_map.off - fd->job_map.off;
+        fd->job_map.len = fd->name_map.off - fd->job_map.off;
     return(0);
@@ -950,7 +930,7 @@ static int darshan_log_getheader(darshan_fd fd)
     int ret;
@@ -967,7 +947,7 @@ static int darshan_log_putheader(darshan_fd fd)
     header.magic_nr = DARSHAN_MAGIC_NR;
     header.comp_type = fd->comp_type;
     header.partial_flag = fd->partial_flag;
-    memcpy(&header.rec_map, &fd->rec_map, sizeof(struct darshan_log_map));
+    memcpy(&header.name_map, &fd->name_map, sizeof(struct darshan_log_map));
     memcpy(header.mod_map, fd->mod_map, DARSHAN_MAX_MODS * sizeof(struct darshan_log_map));
     memcpy(header.mod_ver, fd->mod_ver, DARSHAN_MAX_MODS * sizeof(uint32_t));
@@ -1200,8 +1180,8 @@ static int darshan_log_dzread(darshan_fd fd, int region_id, void *buf, int len)
     if(region_id == DARSHAN_JOB_REGION_ID)
         map = fd->job_map;
-    else if(region_id == DARSHAN_REC_MAP_REGION_ID)
-        map = fd->rec_map;
+    else if(region_id == DARSHAN_NAME_MAP_REGION_ID)
+        map = fd->name_map;
     else
         map = fd->mod_map[region_id];
@@ -1249,8 +1229,8 @@ static int darshan_log_dzwrite(darshan_fd fd, int region_id, void *buf, int len)
         map_p = &(fd->job_map);
-        map_p = &(fd->rec_map);
+        map_p = &(fd->name_map);
     else
         map_p = &(fd->mod_map[region_id]);
@@ -1404,8 +1384,8 @@ static int darshan_log_libz_flush(darshan_fd fd, int region_id)
     else
@@ -1569,8 +1549,8 @@ static int darshan_log_bzip2_flush(darshan_fd fd, int region_id)
     else
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -33,7 +33,7 @@ struct darshan_fd_s
     /* log file offset/length maps for each log file region */
     struct darshan_log_map job_map;
     /* module-specific log-format versions contained in log */
@@ -43,10 +43,9 @@ struct darshan_fd_s
 typedef struct darshan_fd_s* darshan_fd;
-struct darshan_record_ref
+struct darshan_name_record_ref
-    char *name;
-    darshan_record_id id;
@@ -119,19 +118,19 @@ extern struct darshan_mod_logutil_funcs *mod_logutils[];
 darshan_fd darshan_log_open(const char *name);
 darshan_fd darshan_log_create(const char *name, enum darshan_comp_type comp_type,
     int partial_flag);
-int darshan_log_getjob(darshan_fd fd, struct darshan_job *job);
-int darshan_log_putjob(darshan_fd fd, struct darshan_job *job);
-int darshan_log_getexe(darshan_fd fd, char *buf);
-int darshan_log_putexe(darshan_fd fd, char *buf);
+int darshan_log_get_job(darshan_fd fd, struct darshan_job *job);
+int darshan_log_put_job(darshan_fd fd, struct darshan_job *job);
+int darshan_log_get_exe(darshan_fd fd, char *buf);
+int darshan_log_put_exe(darshan_fd fd, char *buf);
     char*** fs_types, int* count);
     char** fs_types, int count);
-int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash);
-int darshan_log_puthash(darshan_fd fd, struct darshan_record_ref *hash);
+int darshan_log_get_namehash(darshan_fd fd, struct darshan_name_record_ref **hash);
+int darshan_log_put_namehash(darshan_fd fd, struct darshan_name_record_ref *hash);
     void *mod_buf, int mod_buf_sz);
     void *mod_buf, int mod_buf_sz, int ver);
 void darshan_log_close(darshan_fd file);
--- a/darshan-util/darshan-merge.c
+++ b/darshan-util/darshan-merge.c
@@ -192,9 +192,9 @@ int main(int argc, char *argv[])
     char **merge_mnt_pts;
     char **merge_fs_types;
     int merge_mnt_count = 0;
-    struct darshan_record_ref *in_hash = NULL;
-    struct darshan_record_ref *merge_hash = NULL;
-    struct darshan_record_ref *ref, *tmp, *found;
+    struct darshan_name_record_ref *in_hash = NULL;
+    struct darshan_name_record_ref *merge_hash = NULL;
+    struct darshan_name_record_ref *ref, *tmp, *found;
     struct darshan_shared_record_ref *shared_rec_hash = NULL;
     struct darshan_shared_record_ref *sref, *stmp;
     struct darshan_base_record *base_rec;
@@ -225,7 +225,7 @@ int main(int argc, char *argv[])
         /* read job-level metadata from the input file */
-        ret = darshan_log_getjob(in_fd, &in_job);
+        ret = darshan_log_get_job(in_fd, &in_job);
         if(ret < 0)
             fprintf(stderr,
@@ -254,7 +254,7 @@ int main(int argc, char *argv[])
             /* get job data, exe, & mounts directly from the first input log */
             memcpy(&merge_job, &in_job, sizeof(struct darshan_job));
-            ret = darshan_log_getexe(in_fd, merge_exe);
+            ret = darshan_log_get_exe(in_fd, merge_exe);
             if(ret < 0)
                 fprintf(stderr,
@@ -264,7 +264,7 @@ int main(int argc, char *argv[])
                 return(-1);
-            ret = darshan_log_getmounts(in_fd, &merge_mnt_pts,
+            ret = darshan_log_get_mounts(in_fd, &merge_mnt_pts,
                 &merge_fs_types, &merge_mnt_count);
             if(ret < 0)
@@ -285,7 +285,7 @@ int main(int argc, char *argv[])
         /* read the hash of ids->names for the input log */
-        ret = darshan_log_gethash(in_fd, &in_hash);
+        ret = darshan_log_get_namehash(in_fd, &in_hash);
         if(ret < 0)
             fprintf(stderr,
@@ -295,17 +295,19 @@ int main(int argc, char *argv[])
             return(-1);
-        /* iterate the input hash, copying over record_id->file_name mappings
+        /* iterate the input hash, copying over record id->name mappings
          * that have not already been copied to the output hash
         HASH_ITER(hlink, in_hash, ref, tmp)
-            HASH_FIND(hlink, merge_hash, &(ref->id), sizeof(darshan_record_id), found);
+            HASH_FIND(hlink, merge_hash, &(ref->name_record->id),
+                sizeof(darshan_record_id), found);
             if(!found)
-                HASH_ADD(hlink, merge_hash, id, sizeof(darshan_record_id), ref);
+                HASH_ADD(hlink, merge_hash, name_record->id,
+                    sizeof(darshan_record_id), ref);
-            else if(strcmp(ref->name, found->name))
+            else if(strcmp(ref->name_record->name, found->name_record->name))
                 fprintf(stderr,
                     "Error: invalid Darshan record table entry.\n");
@@ -330,7 +332,7 @@ int main(int argc, char *argv[])
     /* write the darshan job info, exe string, and mount data to output file */
-    ret = darshan_log_putjob(merge_fd, &merge_job);
+    ret = darshan_log_put_job(merge_fd, &merge_job);
     if(ret < 0)
         fprintf(stderr, "Error: unable to write job data to output darshan log.\n");
@@ -339,7 +341,7 @@ int main(int argc, char *argv[])
         return(-1);
-    ret = darshan_log_putexe(merge_fd, merge_exe);
+    ret = darshan_log_put_exe(merge_fd, merge_exe);
     if(ret < 0)
         fprintf(stderr, "Error: unable to write exe string to output darshan log.\n");
@@ -348,7 +350,7 @@ int main(int argc, char *argv[])
         return(-1);
-    ret = darshan_log_putmounts(merge_fd, merge_mnt_pts, merge_fs_types, merge_mnt_count);
+    ret = darshan_log_put_mounts(merge_fd, merge_mnt_pts, merge_fs_types, merge_mnt_count);
     if(ret < 0)
         fprintf(stderr, "Error: unable to write mount data to output darshan log.\n");
@@ -358,7 +360,7 @@ int main(int argc, char *argv[])
     /* write the merged table of records to output file */
-    ret = darshan_log_puthash(merge_fd, merge_hash);
+    ret = darshan_log_put_namehash(merge_fd, merge_hash);
     if(ret < 0)
         fprintf(stderr, "Error: unable to write record table to output darshan log.\n");
--- a/darshan-util/darshan-mpiio-logutils.c
+++ b/darshan-util/darshan-mpiio-logutils.c
@@ -55,7 +55,7 @@ static int darshan_log_get_mpiio_file(darshan_fd fd, void* mpiio_buf)
     int i;
     int ret;
-    ret = darshan_log_getmod(fd, DARSHAN_MPIIO_MOD, mpiio_buf,
+    ret = darshan_log_get_mod(fd, DARSHAN_MPIIO_MOD, mpiio_buf,
         sizeof(struct darshan_mpiio_file));
     if(ret < 0)
         return(-1);
@@ -84,7 +84,7 @@ static int darshan_log_put_mpiio_file(darshan_fd fd, void* mpiio_buf, int ver)
     struct darshan_mpiio_file *file = (struct darshan_mpiio_file *)mpiio_buf;
     int ret;
-    ret = darshan_log_putmod(fd, DARSHAN_MPIIO_MOD, file,
+    ret = darshan_log_put_mod(fd, DARSHAN_MPIIO_MOD, file,
         sizeof(struct darshan_mpiio_file), ver);
     if(ret < 0)
         return(-1);
--- a/darshan-util/darshan-null-logutils.c
+++ b/darshan-util/darshan-null-logutils.c
@@ -67,7 +67,7 @@ static int darshan_log_get_null_record(darshan_fd fd, void* null_buf)
     int ret;
     /* read a NULL module record from the darshan log file */
-    ret = darshan_log_getmod(fd, DARSHAN_NULL_MOD, null_buf,
+    ret = darshan_log_get_mod(fd, DARSHAN_NULL_MOD, null_buf,
         sizeof(struct darshan_null_record));
     if(ret < 0)
         return(-1);
@@ -101,7 +101,7 @@ static int darshan_log_put_null_record(darshan_fd fd, void* null_buf, int ver)
     int ret;
     /* append NULL record to darshan log file */
-    ret = darshan_log_putmod(fd, DARSHAN_NULL_MOD, rec,
+    ret = darshan_log_put_mod(fd, DARSHAN_NULL_MOD, rec,
         sizeof(struct darshan_null_record), ver);
     if(ret < 0)
         return(-1);
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -107,13 +107,13 @@ void posix_accum_file(struct darshan_posix_file *pfile, hash_entry_t *hfile, int
 void posix_accum_perf(struct darshan_posix_file *pfile, perf_data_t *pdata);
 void posix_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
 void posix_print_total_file(struct darshan_posix_file *pfile);
-void posix_file_list(hash_entry_t *file_hash, struct darshan_record_ref *rec_hash, int detail_flag);
+void posix_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
 void mpiio_accum_file(struct darshan_mpiio_file *mfile, hash_entry_t *hfile, int64_t nprocs);
 void mpiio_accum_perf(struct darshan_mpiio_file *mfile, perf_data_t *pdata);
 void mpiio_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
 void mpiio_print_total_file(struct darshan_mpiio_file *mfile);
-void mpiio_file_list(hash_entry_t *file_hash, struct darshan_record_ref *rec_hash, int detail_flag);
+void mpiio_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
 void calc_perf(perf_data_t *pdata, int64_t nprocs);
@@ -203,8 +203,8 @@ int main(int argc, char **argv)
     char tmp_string[4096] = {0};
     darshan_fd fd;
-    struct darshan_record_ref *ref, *tmp_ref;
+    struct darshan_name_record_ref *ref, *tmp_ref;
     int mount_count;
     char** mnt_pts;
     char** fs_types;
@@ -234,7 +234,7 @@ int main(int argc, char **argv)
         return(-1);
     /* read darshan job info */
     if(ret < 0)
         darshan_log_close(fd);
@@ -242,7 +242,7 @@ int main(int argc, char **argv)
     /* get the original command line for this job */
-    ret = darshan_log_getexe(fd, tmp_string);
+    ret = darshan_log_get_exe(fd, tmp_string);
     if(ret < 0)
@@ -250,7 +250,7 @@ int main(int argc, char **argv)
     /* get the mount information for this log */
-    ret = darshan_log_getmounts(fd, &mnt_pts, &fs_types, &mount_count);
+    ret = darshan_log_get_mounts(fd, &mnt_pts, &fs_types, &mount_count);
     if(ret < 0)
@@ -258,7 +258,7 @@ int main(int argc, char **argv)
     /* read hash of darshan records */
-    ret = darshan_log_gethash(fd, &rec_hash);
+    ret = darshan_log_get_namehash(fd, &name_hash);
     if(ret < 0)
@@ -317,7 +317,7 @@ int main(int argc, char **argv)
     printf("# -------------------------------------------------------\n");
     printf("# header: %zu bytes (uncompressed)\n", sizeof(struct darshan_header));
     printf("# job data: %zu bytes (compressed)\n", fd->job_map.len);
-    printf("# record table: %zu bytes (compressed)\n", fd->rec_map.len);
+    printf("# record table: %zu bytes (compressed)\n", fd->name_map.len);
     for(i=0; i<DARSHAN_MAX_MODS; i++)
         if(fd->mod_map[i].len)
@@ -426,13 +426,13 @@ int main(int argc, char **argv)
             base_rec = (struct darshan_base_record *)mod_buf;
             /* get the pathname for this record */
-            HASH_FIND(hlink, rec_hash, &(base_rec->id), sizeof(darshan_record_id), ref);
+            HASH_FIND(hlink, name_hash, &(base_rec->id), sizeof(darshan_record_id), ref);
             assert(ref);
             /* get mount point and fs type associated with this record */
             for(j=0; j<mount_count; j++)
-                if(strncmp(mnt_pts[j], ref->name, strlen(mnt_pts[j])) == 0)
+                if(strncmp(mnt_pts[j], ref->name_record->name, strlen(mnt_pts[j])) == 0)
                     mnt_pt = mnt_pts[j];
                     fs_type = fs_types[j];
@@ -447,7 +447,7 @@ int main(int argc, char **argv)
             if(mask & OPTION_BASE)
                 /* print the corresponding module data for this record */
-                mod_logutils[i]->log_print_record(mod_buf, ref->name,
+                mod_logutils[i]->log_print_record(mod_buf, ref->name_record->name,
                     mnt_pt, fs_type, fd->mod_ver[i]);
@@ -598,16 +598,16 @@ int main(int argc, char **argv)
             if(i == DARSHAN_POSIX_MOD)
                 if(mask & OPTION_FILE_LIST_DETAILED)
-                    posix_file_list(file_hash, rec_hash, 1);
+                    posix_file_list(file_hash, name_hash, 1);
                 else
-                    posix_file_list(file_hash, rec_hash, 0);
+                    posix_file_list(file_hash, name_hash, 0);
             else if(i == DARSHAN_MPIIO_MOD)
-                    mpiio_file_list(file_hash, rec_hash, 1);
+                    mpiio_file_list(file_hash, name_hash, 1);
                 else
-                    mpiio_file_list(file_hash, rec_hash, 0);
+                    mpiio_file_list(file_hash, name_hash, 0);
@@ -640,10 +640,10 @@ cleanup:
     free(pdata.rank_cumul_md_time);
     /* free record hash data */
-    HASH_ITER(hlink, rec_hash, ref, tmp_ref)
+    HASH_ITER(hlink, name_hash, ref, tmp_ref)
-        free(ref->name);
         free(ref);
@@ -1413,13 +1413,13 @@ void mpiio_print_total_file(struct darshan_mpiio_file *mfile)
-                     struct darshan_record_ref *rec_hash,
+                     struct darshan_name_record_ref *name_hash,
                      int detail_flag)
     hash_entry_t *curr = NULL;
     hash_entry_t *tmp = NULL;
     struct darshan_posix_file *file_rec = NULL;
-    struct darshan_record_ref *ref = NULL;
+    struct darshan_name_record_ref *ref = NULL;
     int i;
     /* list of columns:
@@ -1477,12 +1477,12 @@ void posix_file_list(hash_entry_t *file_hash,
         file_rec = (struct darshan_posix_file*)curr->rec_dat;
         assert(file_rec);
-        HASH_FIND(hlink, rec_hash, &(curr->rec_id), sizeof(darshan_record_id), ref);
+        HASH_FIND(hlink, name_hash, &(curr->rec_id), sizeof(darshan_record_id), ref);
         assert(ref);
         printf("%" PRIu64 "\t%s\t%" PRId64 "\t%f\t%f",
             curr->rec_id,
-            ref->name,
+            ref->name_record->name,
             curr->procs,
             curr->slowest_time,
             curr->cumul_time/(double)curr->procs);
@@ -1504,13 +1504,13 @@ void posix_file_list(hash_entry_t *file_hash,
                      int detail_flag)
     struct darshan_mpiio_file *file_rec = NULL;
     int i;
     /* list of columns:
@@ -1571,12 +1571,12 @@ void mpiio_file_list(hash_entry_t *file_hash,
         file_rec = (struct darshan_mpiio_file*)curr->rec_dat;
         assert(file_rec);
         assert(ref);
             curr->rec_id,
-            ref->name,
             curr->procs,
             curr->slowest_time,
--- a/darshan-util/darshan-pnetcdf-logutils.c
+++ b/darshan-util/darshan-pnetcdf-logutils.c
@@ -55,7 +55,7 @@ static int darshan_log_get_pnetcdf_file(darshan_fd fd, void* pnetcdf_buf)
     int i;
     int ret;
-    ret = darshan_log_getmod(fd, DARSHAN_PNETCDF_MOD, pnetcdf_buf,
+    ret = darshan_log_get_mod(fd, DARSHAN_PNETCDF_MOD, pnetcdf_buf,
         sizeof(struct darshan_pnetcdf_file));
     if(ret < 0)
         return(-1);
@@ -84,7 +84,7 @@ static int darshan_log_put_pnetcdf_file(darshan_fd fd, void* pnetcdf_buf, int ve
     struct darshan_pnetcdf_file *file = (struct darshan_pnetcdf_file *)pnetcdf_buf;
     int ret;
-    ret = darshan_log_putmod(fd, DARSHAN_PNETCDF_MOD, file,
+    ret = darshan_log_put_mod(fd, DARSHAN_PNETCDF_MOD, file,
         sizeof(struct darshan_pnetcdf_file), ver);
     if(ret < 0)
         return(-1);
--- a/darshan-util/darshan-posix-logutils.c
+++ b/darshan-util/darshan-posix-logutils.c
@@ -55,7 +55,7 @@ static int darshan_log_get_posix_file(darshan_fd fd, void* posix_buf)
     int i;
     int ret;
-    ret = darshan_log_getmod(fd, DARSHAN_POSIX_MOD, posix_buf,
+    ret = darshan_log_get_mod(fd, DARSHAN_POSIX_MOD, posix_buf,
         sizeof(struct darshan_posix_file));
     if(ret < 0)
         return(-1);
@@ -84,7 +84,7 @@ static int darshan_log_put_posix_file(darshan_fd fd, void* posix_buf, int ver)
     struct darshan_posix_file *file = (struct darshan_posix_file *)posix_buf;
     int ret;
-    ret = darshan_log_putmod(fd, DARSHAN_POSIX_MOD, file,
+    ret = darshan_log_put_mod(fd, DARSHAN_POSIX_MOD, file,
         sizeof(struct darshan_posix_file), ver);
     if(ret < 0)
         return(-1);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/94430f41b6f479bf73c4350a26378a1b04c1db0e...999ee9c886eaff3b6a013badbf1f0eb298f2d116
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160526/30da4057/attachment-0001.html>
More information about the Darshan-commits mailing list
