[Darshan-commits] [Git][darshan/darshan][dev-stdio] implement shared reduction for stdio records
Philip Carns
xgitlab at cels.anl.gov
Tue May 24 15:54:58 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
3d7cc3c6 by Phil Carns at 2016-05-24T16:54:43-04:00
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-stdio-log-format.h
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -5,7 +5,6 @@
/* TODO list (general) for this module:
- * - implement reduction operator
* - add stdio page to darshan-job-summary
* - add regression test cases for all functions captured here
* - especially the scanf and printf variants with variable arguments
@@ -220,6 +219,9 @@ static void stdio_begin_shutdown(void);
static void stdio_get_output_data(MPI_Comm mod_comm, darshan_record_id *shared_recs,
int shared_rec_count, void **stdio_buf, int *stdio_buf_sz);
static void stdio_shutdown(void);
+static void stdio_record_reduction_op(void* infile_v, void* inoutfile_v,
+ int *len, MPI_Datatype *datatype);
+static int stdio_record_compare(const void* a, const void* b);
#define STDIO_LOCK() pthread_mutex_lock(&stdio_runtime_mutex)
#define STDIO_UNLOCK() pthread_mutex_unlock(&stdio_runtime_mutex)
@@ -1152,14 +1154,168 @@ static void stdio_get_output_data(
void **stdio_buf,
int *stdio_buf_sz)
+ struct stdio_file_runtime *file;
+ int i;
+ struct darshan_stdio_record *red_send_buf = NULL;
+ struct darshan_stdio_record *red_recv_buf = NULL;
+ MPI_Datatype red_type;
+ MPI_Op red_op;
assert(stdio_runtime);
+ /* if there are globally shared files, do a shared file reduction */
+ /* NOTE: the shared file reduction is also skipped if the
+ * DARSHAN_DISABLE_SHARED_REDUCTION environment variable is set.
+ if(shared_rec_count && !getenv("DARSHAN_DISABLE_SHARED_REDUCTION"))
+ /* necessary initialization of shared records */
+ for(i = 0; i < shared_rec_count; i++)
+ HASH_FIND(hlink, stdio_runtime->file_hash, &shared_recs[i],
+ sizeof(darshan_record_id), file);
+ assert(file);
+ file->file_record->rank = -1;
+ /* sort the array of files descending by rank so that we get all of the
+ * shared files (marked by rank -1) in a contiguous portion at end
+ * of the array
+ qsort(stdio_runtime->file_record_array, stdio_runtime->file_array_ndx,
+ sizeof(struct darshan_stdio_record), stdio_record_compare);
+ /* make *send_buf point to the shared files at the end of sorted array */
+ red_send_buf =
+ &(stdio_runtime->file_record_array[stdio_runtime->file_array_ndx-shared_rec_count]);
+ /* allocate memory for the reduction output on rank 0 */
+ if(my_rank == 0)
+ red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_stdio_record));
+ if(!red_recv_buf)
+ return;
+ /* construct a datatype for a STDIO file record. This is serving no purpose
+ * except to make sure we can do a reduction on proper boundaries
+ DARSHAN_MPI_CALL(PMPI_Type_contiguous)(sizeof(struct darshan_stdio_record),
+ MPI_BYTE, &red_type);
+ DARSHAN_MPI_CALL(PMPI_Type_commit)(&red_type);
+ /* register a STDIO file record reduction operator */
+ DARSHAN_MPI_CALL(PMPI_Op_create)(stdio_record_reduction_op, 1, &red_op);
+ /* reduce shared STDIO file records */
+ DARSHAN_MPI_CALL(PMPI_Reduce)(red_send_buf, red_recv_buf,
+ shared_rec_count, red_type, red_op, 0, mod_comm);
+ /* clean up reduction state */
+ if(my_rank == 0)
+ int tmp_ndx = stdio_runtime->file_array_ndx - shared_rec_count;
+ memcpy(&(stdio_runtime->file_record_array[tmp_ndx]), red_recv_buf,
+ shared_rec_count * sizeof(struct darshan_stdio_record));
+ free(red_recv_buf);
+ else
+ stdio_runtime->file_array_ndx -= shared_rec_count;
+ DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
+ DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
*stdio_buf = (void *)(stdio_runtime->file_record_array);
*stdio_buf_sz = stdio_runtime->file_array_ndx * sizeof(struct darshan_stdio_record);
return;
+/* compare function for sorting file records by descending rank */
+static int stdio_record_compare(const void* a_p, const void* b_p)
+ const struct darshan_stdio_record* a = a_p;
+ const struct darshan_stdio_record* b = b_p;
+ if(a->rank < b->rank)
+ return 1;
+ if(a->rank > b->rank)
+ return -1;
+ return 0;
+ struct darshan_stdio_record tmp_file;
+ struct darshan_stdio_record *infile = infile_v;
+ struct darshan_stdio_record *inoutfile = inoutfile_v;
+ int i, j;
+ assert(stdio_runtime);
+ for(i=0; i<*len; i++)
+ memset(&tmp_file, 0, sizeof(struct darshan_stdio_record));
+ tmp_file.f_id = infile->f_id;
+ tmp_file.rank = -1;
+ /* sum */
+ for(j=STDIO_OPENS; j<=STDIO_BYTES_READ; j++)
+ tmp_file.counters[j] = infile->counters[j] + inoutfile->counters[j];
+ /* max */
+ for(j=STDIO_MAX_BYTE_READ; j<=STDIO_MAX_BYTE_WRITTEN; j++)
+ if(infile->counters[j] > inoutfile->counters[j])
+ tmp_file.counters[j] = infile->counters[j];
+ else
+ tmp_file.counters[j] = inoutfile->counters[j];
+ /* sum */
+ for(j=STDIO_F_META_TIME; j<=STDIO_F_READ_TIME; j++)
+ tmp_file.fcounters[j] = infile->fcounters[j] + inoutfile->fcounters[j];
+ /* min non-zero (if available) value */
+ for(j=STDIO_F_OPEN_START_TIMESTAMP; j<=STDIO_F_READ_START_TIMESTAMP; j++)
+ if((infile->fcounters[j] < inoutfile->fcounters[j] &&
+ infile->fcounters[j] > 0) || inoutfile->fcounters[j] == 0)
+ tmp_file.fcounters[j] = infile->fcounters[j];
+ else
+ tmp_file.fcounters[j] = inoutfile->fcounters[j];
+ /* max */
+ for(j=STDIO_F_OPEN_END_TIMESTAMP; j<=STDIO_F_READ_END_TIMESTAMP; j++)
+ if(infile->fcounters[j] > inoutfile->fcounters[j])
+ else
+ /* update pointers */
+ *inoutfile = tmp_file;
+ inoutfile++;
+ infile++;
+ return;
static void stdio_shutdown()
struct stdio_file_runtime_ref *ref, *tmp;
--- a/darshan-stdio-log-format.h
+++ b/darshan-stdio-log-format.h
@@ -13,48 +13,48 @@
#define STDIO_COUNTERS \
/* count of fopens */\
X(STDIO_OPENS) \
- /* maximum byte (offset) written */\
- X(STDIO_MAX_BYTE_WRITTEN) \
- /* total bytes written */ \
- X(STDIO_BYTES_WRITTEN) \
- /* number of writes */ \
- X(STDIO_WRITES) \
- /* maximum byte (offset) read */\
- X(STDIO_MAX_BYTE_READ) \
- /* total bytes read */ \
- X(STDIO_BYTES_READ) \
/* number of reads */ \
X(STDIO_READS) \
+ /* number of writes */ \
+ X(STDIO_WRITES) \
/* count of seeks */\
X(STDIO_SEEKS) \
/* count of flushes */\
X(STDIO_FLUSHES) \
+ /* total bytes written */ \
+ X(STDIO_BYTES_WRITTEN) \
+ /* total bytes read */ \
+ X(STDIO_BYTES_READ) \
+ /* maximum byte (offset) read */\
+ X(STDIO_MAX_BYTE_READ) \
+ /* maximum byte (offset) written */\
+ X(STDIO_MAX_BYTE_WRITTEN) \
/* end of counters */\
X(STDIO_NUM_INDICES)
#define STDIO_F_COUNTERS \
+ /* cumulative meta time */\
+ X(STDIO_F_META_TIME) \
+ /* cumulative write time */\
+ X(STDIO_F_WRITE_TIME) \
+ /* cumulative read time */\
+ X(STDIO_F_READ_TIME) \
/* timestamp of first open */\
X(STDIO_F_OPEN_START_TIMESTAMP) \
- /* timestamp of last open completion */\
- X(STDIO_F_OPEN_END_TIMESTAMP) \
/* timestamp of first close */\
X(STDIO_F_CLOSE_START_TIMESTAMP) \
- /* timestamp of last close completion */\
- X(STDIO_F_CLOSE_END_TIMESTAMP) \
/* timestamp of first write */\
X(STDIO_F_WRITE_START_TIMESTAMP) \
- /* timestamp of last write completion */\
- X(STDIO_F_WRITE_END_TIMESTAMP) \
/* timestamp of first read */\
X(STDIO_F_READ_START_TIMESTAMP) \
+ /* timestamp of last open completion */\
+ X(STDIO_F_OPEN_END_TIMESTAMP) \
+ /* timestamp of last close completion */\
+ X(STDIO_F_CLOSE_END_TIMESTAMP) \
+ /* timestamp of last write completion */\
+ X(STDIO_F_WRITE_END_TIMESTAMP) \
/* timestamp of last read completion */\
X(STDIO_F_READ_END_TIMESTAMP) \
- /* cumulative meta time */\
- X(STDIO_F_META_TIME) \
- /* cumulative write time */\
- X(STDIO_F_WRITE_TIME) \
- /* cumulative read time */\
- X(STDIO_F_READ_TIME) \
X(STDIO_F_NUM_INDICES)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/3d7cc3c6996bc031c9876ca274cec36ad8db3ceb
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160524/af7fc2a0/attachment.html>
More information about the Darshan-commits
