[Darshan-commits] [Git][darshan/darshan][dev-stdio] getw wrapper
Philip Carns
xgitlab at cels.anl.gov
Mon May 23 20:26:57 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
d4fc0944 by Phil Carns at 2016-05-23T21:26:48-04:00
getw wrapper
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -43,7 +43,7 @@
* int fscanf(FILE *, const char *, ...); DONE
* int vfscanf(FILE *, const char *, va_list); DONE
* int getc(FILE *); DONE
- * int getw(FILE *);
+ * int getw(FILE *); DONE
* functions for writing data
@@ -104,6 +104,7 @@ DARSHAN_FORWARD_DECL(fflush, int, (FILE *fp));
DARSHAN_FORWARD_DECL(fwrite, size_t, (const void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fread, size_t, (void *ptr, size_t size, size_t nmemb, FILE *stream));
DARSHAN_FORWARD_DECL(fgetc, int, (FILE *stream));
+DARSHAN_FORWARD_DECL(getw, int, (FILE *stream));
DARSHAN_FORWARD_DECL(_IO_getc, int, (FILE *stream));
DARSHAN_FORWARD_DECL(fscanf, int, (FILE *stream, const char *format, ...));
DARSHAN_FORWARD_DECL(vfscanf, int, (FILE *stream, const char *format, va_list ap));
@@ -477,6 +478,27 @@ size_t DARSHAN_DECL(_IO_getc)(FILE *stream)
return(ret);
+size_t DARSHAN_DECL(getw)(FILE *stream)
+ int ret;
+ double tm1, tm2;
+ MAP_OR_FAIL(getw);
+ tm1 = darshan_core_wtime();
+ ret = __real_getw(stream);
+ tm2 = darshan_core_wtime();
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ if(ret != EOF || ferror(stream) == 0)
+ STDIO_RECORD_READ(stream, sizeof(int), tm1, tm2);
+ STDIO_UNLOCK();
+ return(ret);
int DARSHAN_DECL(fscanf)(FILE *stream, const char *format, ...)
int ret;
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -11,5 +11,6 @@
--wrap=fscanf
--wrap=vfscanf
--wrap=_IO_getc
+--wrap=getw
--wrap=fgets
--wrap=fseek
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/d4fc0944526352ca3c07041b0ca6e5d195f919e0
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160523/5b50cdd8/attachment.html>
More information about the Darshan-commits
