[Darshan-commits] [Git][darshan/darshan][dev-stdio] move fclose	wrapper to stdio module
    Philip Carns
    xgitlab at cels.anl.gov
    Sun May  1 08:00:46 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
29b23f7e by Phil Carns at 2016-05-01T09:00:35-04:00
7 changed files:
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/lib/darshan-stdio.c
- darshan-runtime/share/ld-opts/darshan-posix-ld-opts
- darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
- darshan-stdio-log-format.h
- darshan-test/regression/test-cases/stdio-test.sh
- darshan-util/darshan-stdio-logutils.c
Changes:
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -71,7 +71,6 @@ DARSHAN_FORWARD_DECL(mmap64, void*, (void *addr, size_t length, int prot, int fl
 DARSHAN_FORWARD_DECL(fsync, int, (int fd));
 DARSHAN_FORWARD_DECL(fdatasync, int, (int fd));
 DARSHAN_FORWARD_DECL(close, int, (int fd));
-DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
 DARSHAN_FORWARD_DECL(aio_read, int, (struct aiocb *aiocbp));
 DARSHAN_FORWARD_DECL(aio_write, int, (struct aiocb *aiocbp));
 DARSHAN_FORWARD_DECL(aio_read64, int, (struct aiocb64 *aiocbp));
@@ -1162,38 +1161,6 @@ int DARSHAN_DECL(close)(int fd)
     return(ret);
-int DARSHAN_DECL(fclose)(FILE *fp)
-    struct posix_file_runtime* file;
-    int fd = fileno(fp);
-    double tm1, tm2;
-    int ret;
-    MAP_OR_FAIL(fclose);
-    tm1 = darshan_core_wtime();
-    ret = __real_fclose(fp);
-    tm2 = darshan_core_wtime();
-    POSIX_LOCK();
-    posix_runtime_initialize();
-    file = posix_file_by_fd(fd);
-    if(file)
-        file->last_byte_written = 0;
-        file->last_byte_read = 0;
-        file->file_record->fcounters[POSIX_F_CLOSE_TIMESTAMP] =
-            darshan_core_wtime();
-        DARSHAN_TIMER_INC_NO_OVERLAP(
-            file->file_record->fcounters[POSIX_F_META_TIME],
-            tm1, tm2, file->last_meta_end);
-        posix_file_close_fd(fd);
-    POSIX_UNLOCK();
-    return(ret);
 int DARSHAN_DECL(aio_read)(struct aiocb *aiocbp)
     int ret;
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -33,6 +33,7 @@
 DARSHAN_FORWARD_DECL(fopen, FILE*, (const char *path, const char *mode));
 DARSHAN_FORWARD_DECL(fopen64, FILE*, (const char *path, const char *mode));
+DARSHAN_FORWARD_DECL(fclose, int, (FILE *fp));
 /* The stdio_file_runtime structure maintains necessary runtime metadata
  * for the STDIO file record (darshan_stdio_record structure, defined in
@@ -201,6 +202,39 @@ FILE* DARSHAN_DECL(fopen64)(const char *path, const char *mode)
     return(ret);
+int DARSHAN_DECL(fclose)(FILE *fp)
+    struct stdio_file_runtime* file;
+    double tm1, tm2;
+    int ret;
+    MAP_OR_FAIL(fclose);
+    tm1 = darshan_core_wtime();
+    ret = __real_fclose(fp);
+    tm2 = darshan_core_wtime();
+    STDIO_LOCK();
+    stdio_runtime_initialize();
+    file = stdio_file_by_stream(fp);
+    if(file)
+        file->last_byte_written = 0;
+        file->last_byte_read = 0;
+        if(file->file_record->fcounters[STDIO_F_CLOSE_START_TIMESTAMP] == 0 ||
+         file->file_record->fcounters[STDIO_F_CLOSE_START_TIMESTAMP] > tm1)
+           file->file_record->fcounters[STDIO_F_CLOSE_START_TIMESTAMP] = tm1;
+        file->file_record->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] = tm2;
+        DARSHAN_TIMER_INC_NO_OVERLAP(
+            file->file_record->fcounters[STDIO_F_META_TIME],
+            tm1, tm2, file->last_meta_end);
+        stdio_file_close_stream(fp);
+    STDIO_UNLOCK();
+    return(ret);
  * Internal functions for manipulating STDIO module state *
--- a/darshan-runtime/share/ld-opts/darshan-posix-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-posix-ld-opts
@@ -30,7 +30,6 @@
 --wrap=fsync
 --wrap=fdatasync
 --wrap=close
---wrap=fclose
 --wrap=aio_read
 --wrap=aio_write
 --wrap=aio_read64
--- a/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
+++ b/darshan-runtime/share/ld-opts/darshan-stdio-ld-opts
@@ -1,3 +1,4 @@
 --undefined=__wrap_fopen
 --wrap=fopen
 --wrap=fopen64
+--wrap=fclose
--- a/darshan-stdio-log-format.h
+++ b/darshan-stdio-log-format.h
@@ -66,6 +66,10 @@
     X(STDIO_F_OPEN_START_TIMESTAMP) \
     /* timestamp of last open completion */\
     X(STDIO_F_OPEN_END_TIMESTAMP) \
+    /* timestamp of first close */\
+    X(STDIO_F_CLOSE_START_TIMESTAMP) \
+    /* timestamp of last close completion */\
+    X(STDIO_F_CLOSE_END_TIMESTAMP) \
     /* cumulative meta time */\
     X(STDIO_F_META_TIME) \
     /* end of counters */\
--- a/darshan-test/regression/test-cases/stdio-test.sh
+++ b/darshan-test/regression/test-cases/stdio-test.sh
@@ -57,6 +57,16 @@ if [ ! $(echo "$STDIO_F_META_TIME > 0" | bc -l) ]; then
     echo "Error: counter is incorrect" 1>&2
     exit 1
 fi
+STDIO_F_CLOSE_START_TIMESTAMP=`grep STDIO_F_CLOSE_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt |tail -n 1 |cut -f 5`
+if [ ! $(echo "$STDIO_F_CLOSE_START_TIMESTAMP > 0" | bc -l) ]; then
+    echo "Error: counter is incorrect" 1>&2
+    exit 1
+fi
+STDIO_F_CLOSE_END_TIMESTAMP=`grep STDIO_F_CLOSE_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt |tail -n 1 |cut -f 5`
+if [ ! $(echo "$STDIO_F_CLOSE_END_TIMESTAMP > 0" | bc -l) ]; then
+    exit 1
+fi
 exit 0
--- a/darshan-util/darshan-stdio-logutils.c
+++ b/darshan-util/darshan-stdio-logutils.c
@@ -146,6 +146,8 @@ static void darshan_log_print_stdio_description()
     printf("#   STDIO_FOPENS: number of 'fopen' function calls.\n");
     printf("#   STDIO_F_OPEN_START_TIMESTAMP: timestamp of the first call to function 'fopen'.\n");
     printf("#   STDIO_F_OPEN_END_TIMESTAMP: timestamp of the completion of the last call to 'fopen'.\n");
+    printf("#   STDIO_F_CLOSE_START_TIMESTAMP: timestamp of the first call to function 'fclose'.\n");
+    printf("#   STDIO_F_CLOSE_END_TIMESTAMP: timestamp of the completion of the last call to 'fclose'.\n");
     printf("#   STDIO_F_META_TIME: cumulative time spent in metadata operations.\n");
     return;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/29b23f7e94967b0638a1ac399a433ce3d46d9690
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160501/fd4c00ca/attachment.html>
More information about the Darshan-commits
