[Darshan-commits] [Git][darshan/darshan][dev-stdio] check more stdio counters in regression
Philip Carns
xgitlab at cels.anl.gov
Sun May 1 07:30:46 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
585615f9 by Phil Carns at 2016-05-01T08:30:30-04:00
1 changed file:
- darshan-test/regression/test-cases/stdio-test.sh
Changes:
--- a/darshan-test/regression/test-cases/stdio-test.sh
+++ b/darshan-test/regression/test-cases/stdio-test.sh
@@ -27,14 +27,36 @@ if [ $? -ne 0 ]; then
exit 1
fi
+# TODO: look for "tail" commands in all of these test cases and remove them
+# later. Right now they are needed to make sure we only check 1 out of 4
+# possible records because reduction is not implemented yet
# check results
# in this case we want to confirm that the STDIO counters were triggered
-# TODO: change this to check aggregate counters; for now we tail -n 1 to get
-# one counter because there is no reduction operator for the stdio module yet
STDIO_OPENS=`grep STDIO_FOPENS $DARSHAN_TMP/${PROG}.darshan.txt |tail -n 1 |cut -f 5`
if [ ! "$STDIO_OPENS" -gt 0 ]; then
echo "Error: STDIO open count of $STDIO_FOPENS is incorrect" 1>&2
exit 1
fi
+# make sure that some of the floating point counters are valid
+# use bc for floating point comparison
+STDIO_F_OPEN_START_TIMESTAMP=`grep STDIO_F_OPEN_START_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt |tail -n 1 |cut -f 5`
+if [ ! $(echo "$STDIO_F_OPEN_START_TIMESTAMP > 0" | bc -l) ]; then
+ echo "Error: counter is incorrect" 1>&2
+ exit 1
+fi
+STDIO_F_OPEN_END_TIMESTAMP=`grep STDIO_F_OPEN_END_TIMESTAMP $DARSHAN_TMP/${PROG}.darshan.txt |tail -n 1 |cut -f 5`
+if [ ! $(echo "$STDIO_F_OPEN_END_TIMESTAMP > 0" | bc -l) ]; then
+ exit 1
+fi
+STDIO_F_META_TIME=`grep STDIO_F_META_TIME $DARSHAN_TMP/${PROG}.darshan.txt |tail -n 1 |cut -f 5`
+if [ ! $(echo "$STDIO_F_META_TIME > 0" | bc -l) ]; then
+ exit 1
+fi
exit 0
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/585615f9b570759487c2b80f9b1c4311cdf740b2
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160501/0a504c9e/attachment.html>
More information about the Darshan-commits
