[Darshan-commits] [Git][darshan/darshan][master] slew of modifications for porting lustre mod over
Shane Snyder xgitlab at cels.anl.gov
Thu Jun 30 17:22:23 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
ec0fcc53 by Shane Snyder at 2016-06-30T15:19:57-07:00
10 changed files:
- darshan-lustre-log-format.h
- darshan-runtime/darshan-lustre.h
- darshan-runtime/lib/darshan-lustre.c
- darshan-runtime/lib/darshan-posix.c
- darshan-util/configure
- darshan-util/darshan-convert.c
- darshan-util/darshan-diff.c
- darshan-util/darshan-lustre-logutils.c
- darshan-util/darshan-merge.c
- darshan-util/darshan-util-config.h.in
Changes:
--- a/darshan-lustre-log-format.h
+++ b/darshan-lustre-log-format.h
@@ -45,8 +45,7 @@ enum darshan_lustre_indices
 struct darshan_lustre_record
-    darshan_record_id rec_id;
-    int64_t rank;
+    struct darshan_base_record base_rec;
     int64_t counters[LUSTRE_NUM_INDICES];
     OST_ID ost_ids[1];
--- a/darshan-runtime/darshan-lustre.h
+++ b/darshan-runtime/darshan-lustre.h
@@ -1,19 +1,17 @@
-struct lustre_record_runtime
+struct lustre_record_ref
     struct darshan_lustre_record *record;
     size_t record_size;
-    UT_hash_handle hlink;
 struct lustre_runtime
-    int    record_count;       /* number of records defined */
-    size_t record_buffer_max;  /* size of the allocated buffer pointed to by record_buffer */
-    size_t record_buffer_used; /* size of the allocated buffer actually used */
-    void   *next_free_record;  /* pointer to end of record_buffer */
-    void   *record_buffer;     /* buffer in which records are created */
-    struct lustre_record_runtime *record_runtime_array;
-    struct lustre_record_runtime *record_runtime_hash;
+    int   record_count;         /* number of records stored in record_id_hash */
+    void *record_id_hash;
+    int   record_buffer_size;   /* size of record_buffer in bytes */
+    void *record_buffer;
+    int   record_ref_array_ndx; /* current index into record_ref_array */
+    struct lustre_record_ref **record_ref_array;
--- a/darshan-runtime/lib/darshan-lustre.c
+++ b/darshan-runtime/lib/darshan-lustre.c
@@ -18,56 +18,55 @@
 #include <pthread.h>
 #include <sys/ioctl.h>
-/* XXX stick this into autoconf .h */
 #include <lustre/lustre_user.h>
-#include "uthash.h"
 #include "darshan.h"
 #include "darshan-dynamic.h"
 #include "darshan-lustre.h"
+static void lustre_runtime_initialize(
+    void);
+static void lustre_subtract_shared_rec_size(
+    void *rec_ref_p);
+static void lustre_set_rec_ref_pointers(
+    void *rec_ref_p);
+static int lustre_record_compare(
+    const void* a_p, const void* b_p);
+int sort_lustre_records(
+    void);
+static void lustre_shutdown(
+    MPI_Comm mod_comm, darshan_record_id *shared_recs,
+    int shared_rec_count, void **lustre_buf, int *lustre_buf_sz);
 struct lustre_runtime *lustre_runtime = NULL;
 static pthread_mutex_t lustre_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
 static int instrumentation_disabled = 0;
 static int my_rank = -1;
-static void lustre_runtime_initialize(void);
-static void lustre_begin_shutdown(void);
-static void lustre_get_output_data(MPI_Comm mod_comm, darshan_record_id *shared_recs,
-    int shared_rec_count, void **lustre_buf, int *lustre_buf_sz);
-static void lustre_shutdown(void);
-static int lustre_record_compare(const void* a_p, const void* b_p);
-static void lustre_record_reduction_op(void* infile_v, void* inoutfile_v,
-    int *len, MPI_Datatype *datatype);
 #define LUSTRE_LOCK() pthread_mutex_lock(&lustre_runtime_mutex)
 #define LUSTRE_UNLOCK() pthread_mutex_unlock(&lustre_runtime_mutex)
 void darshan_instrument_lustre_file(const char* filepath, int fd)
-    struct lustre_record_runtime *rec_rt;
+    struct lustre_record_ref *rec_ref;
     struct darshan_lustre_record *rec;
     struct darshan_fs_info fs_info;
-    int limit_flag;
     int i;
     struct lov_user_md *lum;
     size_t lumsize = sizeof(struct lov_user_md) +
         LOV_MAX_STRIPE_COUNT * sizeof(struct lov_user_ost_data);
     size_t rec_size;
-    char *newname = NULL;
+    int ret;
     LUSTRE_LOCK();
-    if(instrumentation_disabled)
-        LUSTRE_UNLOCK();
-        return;
-    /* make sure the lustre module is already initialized */
-    lustre_runtime_initialize();
+    /* try to init module if not already and if instrumentation isn't disabled */
+    if(!lustre_runtime && !instrumentation_disabled)
+        lustre_runtime_initialize();
+    /* if we aren't initialized, just back out */
     if(!lustre_runtime)
         LUSTRE_UNLOCK();
@@ -93,51 +92,52 @@ void darshan_instrument_lustre_file(const char* filepath, int fd)
         return;
+    rec_id = darshan_core_gen_record_id(filepath);
     rec_size = LUSTRE_RECORD_SIZE( lum->lmm_stripe_count );
-    /* get fully qualified name for record */
-    newname = darshan_clean_file_path(filepath);
-    if(!newname)
-        newname = (char*)filepath;
-        /* broken out for clarity */
-        void *end_of_new_record = (char*)lustre_runtime->next_free_record + rec_size;
-        void *end_of_rec_buffer = (char*)lustre_runtime->record_buffer + lustre_runtime->record_buffer_max;
-        limit_flag = ( end_of_new_record > end_of_rec_buffer );
-    /* register a Lustre file record with Darshan */
-    fs_info.fs_type = -1;
-    darshan_core_register_record(
-        (void *)newname,
-        strlen(newname),
-        DARSHAN_LUSTRE_MOD,
-        1,
-        limit_flag,
-        &rec_id,
-        &fs_info);
-    /* if record id is 0, darshan has no more memory for instrumenting */
-    if(rec_id == 0)
+    /* search the hash table for this file record, and initialize if not found */
+    rec_ref = darshan_lookup_record_ref(lustre_runtime->record_id_hash,
+        &rec_id, sizeof(darshan_record_id));
+    if(!rec_ref)
-        free(lum);
-        LUSTRE_UNLOCK();
-        return;
+        /* not found, allocate and add a new record reference */
+        rec_ref = malloc(sizeof(*rec_ref));
+        if(!rec_ref)
+            free(lum);
+            LUSTRE_UNLOCK();
+            return;
+        ret = darshan_add_record_ref(&(lustre_runtime->record_id_hash),
+            &rec_id, sizeof(darshan_record_id), rec_ref);
+        if(ret == 0)
+            free(rec_ref);
+            free(lum);
+            LUSTRE_UNLOCK();
+            return;
-    /* search the hash table for this file record, and initialize if not found */
-    HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &rec_id, sizeof(darshan_record_id), rec_rt );
-    if ( !rec_rt ) {
-        /* allocate a new lustre record and append it to the array */
-        rec_rt = &(lustre_runtime->record_runtime_array[lustre_runtime->record_count]);
-        rec_rt->record = lustre_runtime->next_free_record;
-        rec_rt->record_size = rec_size;
-        lustre_runtime->next_free_record = (char*)(lustre_runtime->next_free_record) + rec_size;
-        lustre_runtime->record_buffer_used += rec_size;
-        rec = rec_rt->record;
-        rec->rec_id = rec_id;
-        rec->rank = my_rank;
+        /* register a Lustre file record with Darshan */
+        fs_info.fs_type = -1;
+        rec = darshan_core_register_record(
+                rec_id,
+                filepath,
+                DARSHAN_LUSTRE_MOD,
+                rec_size,
+                &fs_info);
+        /* if NULL, darshan has no more memory for instrumenting */
+        if(rec == NULL)
+            darshan_delete_record_ref(&(lustre_runtime->record_id_hash),
+            free(rec_ref);
+            free(lum);
+            LUSTRE_UNLOCK();
+            return;
         /* implicit assumption here that none of these counters will change
          * after the first time a file is opened.  This may not always be
@@ -160,8 +160,10 @@ void darshan_instrument_lustre_file(const char* filepath, int fd)
             rec->ost_ids[i] = lum->lmm_objects[i].l_ost_idx;
         free(lum);
-        HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt);
+        rec->base_rec.id = rec_id;
+        rec->base_rec.rank = my_rank;
+        rec_ref->record = rec;
+        rec_ref->record_size = rec_size;
         lustre_runtime->record_count++;
@@ -171,64 +173,37 @@ void darshan_instrument_lustre_file(const char* filepath, int fd)
 static void lustre_runtime_initialize()
-    int mem_limit;
-    int max_records;
-    struct darshan_module_funcs lustre_mod_fns =
-        .begin_shutdown = &lustre_begin_shutdown,
-        .get_output_data = &lustre_get_output_data,
-        .shutdown = &lustre_shutdown
+    int lustre_buf_size;
-    /* don't do anything if already initialized or instrumenation is disabled */
-    if(lustre_runtime || instrumentation_disabled)
-        return;
+    /* try and store a default number of records for this module, assuming
+     * each file uses 64 OSTs
+    lustre_buf_size = DARSHAN_DEF_MOD_REC_COUNT * LUSTRE_RECORD_SIZE(64);
     /* register the lustre module with darshan-core */
     darshan_core_register_module(
         DARSHAN_LUSTRE_MOD,
-        &lustre_mod_fns,
+        &lustre_shutdown,
+        &lustre_buf_size,
         &my_rank,
-        &mem_limit,
         NULL);
-    /* return if no memory assigned by darshan core */
-    if(mem_limit == 0)
+    if(lustre_buf_size < LUSTRE_RECORD_SIZE(1))
+        /* unregister module if we aren't allocated enough space for
+         * the smallest possible record
+        darshan_core_unregister_module(DARSHAN_LUSTRE_MOD);
         return;
     lustre_runtime = malloc(sizeof(*lustre_runtime));
     if(!lustre_runtime)
-        return;
-    memset(lustre_runtime, 0, sizeof(*lustre_runtime));
-    /* allocate the full size of the memory limit we are given */
-    lustre_runtime->record_buffer= malloc(mem_limit);
-    if(!lustre_runtime->record_buffer)
-        lustre_runtime->record_buffer_max = 0;
-        return;
-    lustre_runtime->record_buffer_max = mem_limit;
-    lustre_runtime->next_free_record = lustre_runtime->record_buffer;
-    memset(lustre_runtime->record_buffer, 0, lustre_runtime->record_buffer_max);
-    /* Allocate array of Lustre runtime data.  We calculate the maximum possible
-     * number of records that will fit into mem_limit by assuming that each
-     * record has the minimum possible OST count, then allocate that many
-     * runtime records.  record_buffer will always run out of memory before
-     * we overflow record_runtime_array.
-    max_records = mem_limit / sizeof(struct darshan_lustre_record);
-    lustre_runtime->record_runtime_array =
-        malloc( max_records * sizeof(struct lustre_record_runtime));
-    if(!lustre_runtime->record_runtime_array)
-        free( lustre_runtime->record_buffer );
         return;
-    memset(lustre_runtime->record_runtime_array, 0,
-        max_records * sizeof(struct lustre_record_runtime));
+    memset(lustre_runtime, 0, sizeof(*lustre_runtime));
     return;
@@ -237,29 +212,20 @@ static void lustre_runtime_initialize()
  * Functions exported by Lustre module for coordinating with darshan-core *
-    assert(lustre_runtime);
-    LUSTRE_LOCK();
-    /* disable further instrumentation while Darshan shuts down */
-    instrumentation_disabled = 1;
-    LUSTRE_UNLOCK();
-    return;
     MPI_Comm mod_comm,
     void **lustre_buf,
     int *lustre_buf_sz)
-    struct lustre_record_runtime *file;
     int i;
+    LUSTRE_LOCK();
+    lustre_runtime->record_buffer = *lustre_buf;
+    lustre_runtime->record_buffer_size = *lustre_buf_sz;
     /* if there are globally shared files, do a shared file reduction */
     /* NOTE: the shared file reduction is also skipped if the
@@ -270,11 +236,11 @@ static void lustre_get_output_data(
         /* necessary initialization of shared records */
         for(i = 0; i < shared_rec_count; i++)
-            HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &shared_recs[i],
-                sizeof(darshan_record_id), file);
-            assert(file);
+                &shared_recs[i], sizeof(darshan_record_id));
+            assert(rec_ref);
-            file->record->rank = -1;
+            rec_ref->record->base_rec.rank = -1;
         /* sort the array of files descending by rank so that we get all of the
@@ -283,47 +249,56 @@ static void lustre_get_output_data(
         sort_lustre_records();
-        /* simply drop all shared records from non-root ranks by truncating
-         * the record array and recalculating the size of the used buffer
+        /* simply drop all shared records from the end of the record array on
+         * non-root ranks simply by recalculating the size of the buffer
         if (my_rank != 0)
-            lustre_runtime->record_count -= shared_rec_count;
-            lustre_runtime->record_buffer_used = 0;
-            for ( i = 0; i < lustre_runtime->record_count; i++ )
-                    LUSTRE_RECORD_SIZE( (lustre_runtime->record_runtime_array[i]).record->counters[LUSTRE_STRIPE_WIDTH] );
+            darshan_iter_record_refs(lustre_runtime->record_id_hash,
+                &lustre_subtract_shared_rec_size);
-    *lustre_buf = (void *)(lustre_runtime->record_buffer);
-    *lustre_buf_sz = lustre_runtime->record_buffer_used;
+    /* modify output buffer size to account for any shared records that were removed */
+    *lustre_buf_sz = lustre_runtime->record_buffer_size;
+    /* cleanup data structures */
+    darshan_clear_record_refs(&(lustre_runtime->record_id_hash), 1);
+    free(lustre_runtime);
+    lustre_runtime = NULL;
+    /* disable further instrumentation */
+    instrumentation_disabled = 1;
+    LUSTRE_UNLOCK();
     return;
+static void lustre_subtract_shared_rec_size(void *rec_ref_p)
+    struct lustre_record_ref *l_rec_ref = (struct lustre_record_ref *)rec_ref_p;
-    HASH_CLEAR(hlink, lustre_runtime->record_runtime_hash);
-    free(lustre_runtime->record_runtime_array);
-    free(lustre_runtime->record_buffer);
-    free(lustre_runtime);
-    lustre_runtime = NULL;
+    if(l_rec_ref->record->base_rec.rank == -1)
+        lustre_runtime->record_buffer_size -=
+            LUSTRE_RECORD_SIZE( l_rec_ref->record->counters[LUSTRE_STRIPE_WIDTH] );
+static void lustre_set_rec_ref_pointers(void *rec_ref_p)
+    lustre_runtime->record_ref_array[lustre_runtime->record_ref_array_ndx] = rec_ref_p;
+    lustre_runtime->record_ref_array_ndx++;
     return;
 /* compare function for sorting file records by descending rank */
-    const struct lustre_record_runtime* a = a_p;
-    const struct lustre_record_runtime* b = b_p;
+    const struct lustre_record_ref* a = a_p;
+    const struct lustre_record_ref* b = b_p;
-    if (a->record->rank < b->record->rank)
+    if (a->record->base_rec.rank < b->record->base_rec.rank)
         return 1;
-    if (a->record->rank > b->record->rank)
+    if (a->record->base_rec.rank > b->record->base_rec.rank)
         return -1;
     /* if ( a->record->rank == b->record->rank ) we MUST do a secondary
@@ -332,12 +307,17 @@ static int lustre_record_compare(const void* a_p, const void* b_p)
      * be affected by rank-specific variations (e.g., the order in which
      * files are first opened).
+    /* sort by ascending darshan record ids */
+    if (a->record->base_rec.id > b->record->base_rec.id)
+        return 1;
+    if (a->record->base_rec.id < b->record->base_rec.id)
+        return -1;
     return 0;
- * Sort the record_runtimes and records by MPI rank to facilitate shared redux.
+ * Sort the record_references and records by MPI rank to facilitate shared redux.
  * This requires craftiness and additional heap utilization because the records
  * (but not record_runtimes) have variable size.  Currently has to temporarily
  * duplicate the entire record_buffer; there is room for more memory-efficient
@@ -346,59 +326,77 @@ static int lustre_record_compare(const void* a_p, const void* b_p)
 int sort_lustre_records()
     int i;
-    struct darshan_lustre_record *rec;
-    struct lustre_record_runtime *rec_rt, *tmp_rec_rt;
     char  *new_buf, *p;
     /* Create a new buffer to store an entire replica of record_buffer.  Since
      * we know the exact size of record_buffer's useful data at this point, we
-     * can allocate the exact amount we need instead of record_buffer_max */
-    new_buf = malloc(lustre_runtime->record_buffer_used);
+     * can allocate the exact amount we need */
+    new_buf = malloc(lustre_runtime->record_buffer_size);
     p = new_buf;
     if ( !new_buf )
         return 1;
+    /* allocate array of record reference pointers that we want to sort */
+    lustre_runtime->record_ref_array = malloc(lustre_runtime->record_count *
+        sizeof(*(lustre_runtime->record_ref_array)));
+    if( !lustre_runtime->record_ref_array )
+        free(new_buf);
+        return 1;
+    /* build the array of record reference pointers we want to sort */
+        &lustre_set_rec_ref_pointers);
     /* qsort breaks the hash table, so delete it now to free its memory buffers
      * and prevent later confusion */
-    HASH_ITER( hlink, lustre_runtime->record_runtime_hash, rec_rt, tmp_rec_rt )
-        HASH_DELETE( hlink, lustre_runtime->record_runtime_hash, rec_rt );
+    darshan_clear_record_refs(&(lustre_runtime->record_id_hash), 0);
     /* sort the runtime records, which is has fixed-length elements */
     qsort(
-        lustre_runtime->record_runtime_array,
+        lustre_runtime->record_ref_array,
         lustre_runtime->record_count,
-        sizeof(struct lustre_record_runtime),
+        sizeof(struct lustre_record_ref),
-    /* rebuild the hash and array with the qsorted runtime records */
+    /* rebuild the hash with the qsorted runtime records, and
+     * create reordered record buffer
-        rec_rt = &(lustre_runtime->record_runtime_array[i]);
-        HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt );
+        rec_ref = lustre_runtime->record_ref_array[i];
-    /* create reordered record buffer, then copy it back in place */
-        memcpy( p, rec_rt->record, rec_rt->record_size );
-        /* fix record pointers within each runtime record too - pre-emptively
+        /* add this record reference back to the hash table */
+        darshan_add_record_ref(&(lustre_runtime->record_id_hash),
+            &(rec_ref->record->base_rec.id), sizeof(darshan_record_id), rec_ref);
+        memcpy( p, rec_ref->record, rec_ref->record_size );
+        /* fix record pointers within each record reference too - pre-emptively
          * point them at where they will live in record_buffer after we memcpy
          * below */
-        rec_rt->record = (struct darshan_lustre_record *)((char*)(lustre_runtime->record_buffer) + (p - new_buf));
-        p += rec_rt->record_size;
+        rec_ref->record = (struct darshan_lustre_record *)
+            ((char*)(lustre_runtime->record_buffer) + (p - new_buf));
+        p += rec_ref->record_size;
+    /* copy sorted records back over to Lustre's record buffer */
     memcpy(
         new_buf,
-        lustre_runtime->record_buffer_used );
+        lustre_runtime->record_buffer_size );
     free(new_buf);
+    free(lustre_runtime->record_ref_array);
     return 0;
+#if 0
+static void lustre_record_reduction_op(
+    void* infile_v, void* inoutfile_v, int *len, MPI_Datatype *datatype);
 /* this is just boilerplate reduction code that isn't currently used */
@@ -413,8 +411,8 @@ static void lustre_record_reduction_op(void* infile_v, void* inoutfile_v,
     for( i=0; i<*len; i++ )
         memset(&tmp_record, 0, sizeof(struct darshan_lustre_record));
-        tmp_record.rec_id = infile->rec_id;
-        tmp_record.rank = -1;
+        tmp_record.base_rec.id = infile->base_rec.id;
+        tmp_record.base_rec.rank = -1;
         /* preserve only rank 0's value */
         for( j = LUSTRE_OSTS; j < LUSTRE_NUM_INDICES; j++)
@@ -492,7 +490,7 @@ void print_hash( void )
     printf("*** DUMPING RECORD LIST BY HASH SEQUENCE\n");
+    HASH_ITER( hlink, lustre_runtime->record_runtim_hash, rec_rt, tmp_rec_rt )
         printf( "*** record %d rank %d osts %d\n",
             rec_rt->record->rec_id,
@@ -501,7 +499,7 @@ void print_hash( void )
     return;
+#endif
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -121,7 +121,6 @@ struct posix_file_record_ref
     int access_count;
     void *stride_root;
     int stride_count;
-    int fs_type; /* same as darshan_fs_info->fs_type */
     struct posix_aio_tracker* aio_list;
@@ -147,7 +146,7 @@ struct posix_aio_tracker
 static void posix_runtime_initialize(
     void);
 static struct posix_file_record_ref *posix_track_new_file_record(
-    darshan_record_id rec_id, const char *path);
+    darshan_record_id rec_id, const char *path, int fd);
 static void posix_aio_tracker_add(
     int fd, void *aiocbp);
 static struct posix_aio_tracker* posix_aio_tracker_del(
@@ -166,10 +165,12 @@ static void posix_shutdown(
     int shared_rec_count, void **posix_buf, int *posix_buf_sz);
+#ifdef DARSHAN_LUSTRE
 /* XXX modules don't expose an API for other modules, so use extern to get
  * Lustre instrumentation function
 extern void darshan_instrument_lustre_file(const char *filepath, int fd);
+#endif
 static struct posix_runtime *posix_runtime = NULL;
 static pthread_mutex_t posix_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
@@ -206,7 +207,7 @@ static int darshan_mem_alignment = 1;
     rec_id = darshan_core_gen_record_id(newpath); \
     rec_ref = darshan_lookup_record_ref(posix_runtime->rec_id_hash, &rec_id, sizeof(darshan_record_id)); \
-    if(!rec_ref) rec_ref = posix_track_new_file_record(rec_id, newpath); \
+    if(!rec_ref) rec_ref = posix_track_new_file_record(rec_id, newpath, __ret); \
     if(!rec_ref) { \
         if(newpath != __path) free(newpath); \
         break; \
@@ -226,8 +227,6 @@ static int darshan_mem_alignment = 1;
     DARSHAN_TIMER_INC_NO_OVERLAP(rec_ref->file_rec->fcounters[POSIX_F_META_TIME], \
         __tm1, __tm2, rec_ref->last_meta_end); \
     darshan_add_record_ref(&(posix_runtime->fd_hash), &__ret, sizeof(int), rec_ref); \
-    if(rec_ref->fs_type == LL_SUPER_MAGIC) \
-        darshan_instrument_lustre_file(__path, __ret); \
 } while(0)
@@ -356,7 +355,7 @@ static int darshan_mem_alignment = 1;
+    if(!rec_ref) rec_ref = posix_track_new_file_record(rec_id, newpath, -1); \
     if(rec_ref) { \
         POSIX_RECORD_STAT(rec_ref, __statbuf, __tm1, __tm2); \
@@ -1452,7 +1451,7 @@ static void posix_runtime_initialize()
     struct darshan_posix_file *file_rec = NULL;
     struct posix_file_record_ref *rec_ref = NULL;
@@ -1497,9 +1496,17 @@ static struct posix_file_record_ref *posix_track_new_file_record(
     file_rec->counters[POSIX_MEM_ALIGNMENT] = darshan_mem_alignment;
     file_rec->counters[POSIX_FILE_ALIGNMENT] = fs_info.block_size;
     rec_ref->file_rec = file_rec;
-    rec_ref->fs_type = fs_info.fs_type;
     posix_runtime->file_rec_count++;
+    if(fd >= 0)
+        /* allow lustre to generate a record if we configured with lustre support */
+        if(fs_info.fs_type == LL_SUPER_MAGIC)
+            darshan_instrument_lustre_file(path, fd);
+#endif
     return(rec_ref);
The diff for this file was not included because it is too large.
--- a/darshan-util/darshan-convert.c
+++ b/darshan-util/darshan-convert.c
@@ -341,14 +341,6 @@ int main(int argc, char **argv)
         return(-1);
-    mod_buf = malloc(DEF_MOD_BUF_SIZE);
-    if (!mod_buf)
-        darshan_log_close(infile);
-        darshan_log_close(outfile);
-        return(-1);
     /* loop over each module and convert it's data to the new format */
     for(i=0; i<DARSHAN_MAX_MODS; i++)
@@ -375,7 +367,6 @@ int main(int argc, char **argv)
             unlink(outfile_name);
-            free(mod_buf);
             return(-1);
@@ -398,7 +389,6 @@ int main(int argc, char **argv)
         } while((ret = mod_logutils[i]->log_get_record(infile, mod_buf)) == 1);
-    free(mod_buf);
--- a/darshan-util/darshan-diff.c
+++ b/darshan-util/darshan-diff.c
@@ -13,8 +13,6 @@
 #include "darshan-logutils.h"
 #include "uthash-1.9.2/src/uthash.h"
-#define DEF_MOD_BUF_SIZE 1024 /* 1 KiB is enough for all current mod records ... */
 struct darshan_mod_record_ref
     int rank;
--- a/darshan-util/darshan-lustre-logutils.c
+++ b/darshan-util/darshan-lustre-logutils.c
@@ -24,8 +24,7 @@ char *lustre_counter_names[] = {
 #undef X
-static int darshan_log_get_lustre_record(darshan_fd fd, void* lustre_buf,
-    darshan_record_id* rec_id);
+static int darshan_log_get_lustre_record(darshan_fd fd, void* lustre_buf);
 static int darshan_log_put_lustre_record(darshan_fd fd, void* lustre_buf, int ver);
 static void darshan_log_print_lustre_record(void *file_rec,
     char *file_name, char *mnt_pt, char *fs_type, int ver);
@@ -42,15 +41,14 @@ struct darshan_mod_logutil_funcs lustre_logutils =
     .log_print_diff = &darshan_log_print_lustre_record_diff
     int i;
     int ret;
     /* retrieve the fixed-size portion of the record */
-    ret = darshan_log_getmod(fd, DARSHAN_LUSTRE_MOD, lustre_buf,
+    ret = darshan_log_get_mod(fd, DARSHAN_LUSTRE_MOD, lustre_buf,
     if(ret < 0)
         return(-1);
@@ -62,15 +60,16 @@ static int darshan_log_get_lustre_record(darshan_fd fd, void* lustre_buf,
     /* swap bytes if necessary */
     if(fd->swap_flag)
-        DARSHAN_BSWAP64(&rec->rec_id);
-        DARSHAN_BSWAP64(&rec->rank);
+        DARSHAN_BSWAP64(&rec->base_rec.id);
+        DARSHAN_BSWAP64(&rec->base_rec.rank);
         for(i=0; i<LUSTRE_NUM_INDICES; i++)
             DARSHAN_BSWAP64(&rec->counters[i]);
+        DARSHAN_BSWAP64(&(rec->ost_ids[0]));
     /* now read the rest of the record */
     if ( rec->counters[LUSTRE_STRIPE_WIDTH] > 1 ) {
             fd,
             DARSHAN_LUSTRE_MOD,
             (void*)(&(rec->ost_ids[1])),
@@ -86,7 +85,6 @@ static int darshan_log_get_lustre_record(darshan_fd fd, void* lustre_buf,
                 DARSHAN_BSWAP64(&(rec->ost_ids[i]));
-    *rec_id = rec->rec_id;
     return(1);
@@ -95,7 +93,7 @@ static int darshan_log_put_lustre_record(darshan_fd fd, void* lustre_buf, int ve
     struct darshan_lustre_record *rec = (struct darshan_lustre_record *)lustre_buf;
     int ret;
-    ret = darshan_log_putmod(fd, DARSHAN_LUSTRE_MOD, rec,
+    ret = darshan_log_put_mod(fd, DARSHAN_LUSTRE_MOD, rec,
         LUSTRE_RECORD_SIZE(rec->counters[LUSTRE_STRIPE_WIDTH]), ver);
     if(ret < 0)
         return(-1);
@@ -113,7 +111,7 @@ static void darshan_log_print_lustre_record(void *rec, char *file_name,
         DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_LUSTRE_MOD],
-            lustre_rec->rank, lustre_rec->rec_id, lustre_counter_names[i],
+            lustre_rec->base_rec.rank, lustre_rec->base_rec.id, lustre_counter_names[i],
             lustre_rec->counters[i], file_name, mnt_pt, fs_type);
@@ -122,8 +120,8 @@ static void darshan_log_print_lustre_record(void *rec, char *file_name,
         char strbuf[25];
         snprintf( strbuf, 25, "LUSTRE_OST_ID_%d", i );
-            lustre_rec->rank,
-            lustre_rec->rec_id,
+            lustre_rec->base_rec.id,
             strbuf,
             lustre_rec->ost_ids[i],
             file_name,
@@ -165,27 +163,27 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
             printf("- ");
-                lustre_rec1->rank, lustre_rec1->rec_id, lustre_counter_names[i],
-                lustre_rec1->counters[i], file_name1, "", "");
+                lustre_rec1->base_rec.rank, lustre_rec1->base_rec.id,
+                lustre_counter_names[i], lustre_rec1->counters[i], file_name1, "", "");
         else if(!lustre_rec1)
             printf("+ ");
-                lustre_rec2->rank, lustre_rec2->rec_id, lustre_counter_names[i],
-                lustre_rec2->counters[i], file_name2, "", "");
+                lustre_rec2->base_rec.rank, lustre_rec2->base_rec.id,
+                lustre_counter_names[i], lustre_rec2->counters[i], file_name2, "", "");
         else if(lustre_rec1->counters[i] != lustre_rec2->counters[i])
             printf("- ");
             printf("+ ");
@@ -199,8 +197,8 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
                 printf("- ");
-                    lustre_rec1->rec_id,
+                    lustre_rec1->base_rec.id,
                     strbuf,
                     lustre_rec1->ost_ids[i],
                     file_name1,
@@ -208,8 +206,8 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
                 printf("+ ");
-                    lustre_rec2->rec_id,
+                    lustre_rec2->base_rec.id,
                     strbuf,
                     lustre_rec2->ost_ids[i],
                     file_name2,
--- a/darshan-util/darshan-merge.c
+++ b/darshan-util/darshan-merge.c
@@ -9,8 +9,6 @@
 struct darshan_shared_record_ref
     darshan_record_id id;
--- a/darshan-util/darshan-util-config.h.in
+++ b/darshan-util/darshan-util-config.h.in
@@ -54,9 +54,6 @@
 /* Define to the one symbol short name of this package. */
 #undef PACKAGE_TARNAME
-/* Define to the home page for this package. */
-#undef PACKAGE_URL
 /* Define to the version of this package. */
 #undef PACKAGE_VERSION
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/ec0fcc537e47df7f5a23ef92fd472fe650483b0c
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160630/ac667e7c/attachment-0001.html>
More information about the Darshan-commits mailing list
