[Darshan-commits] Build failed in Jenkins: darshan-master-mpich-3.0.4-static #460
jenkins-ci at mcs.anl.gov jenkins-ci at mcs.anl.gov
Tue Jun 28 14:20:45 CDT 2016
See <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-static/460/>
Started by timer
[EnvInject] - Loading node environment variables.
Building remotely on thrash.mcs.anl.gov (mcs) in workspace <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-static/ws/>
Checkout:darshan-master-mpich-3.0.4-static / <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-static/ws/> - hudson.remoting.Channel at 4f8ffc70:thrash.mcs.anl.gov
Using strategy: Default
Last Built Revision: Revision eca097a2849fc1b5db2e5d01dc1427d5e7bf6b2c (origin/master)
Fetching changes from 1 remote Git repository
Fetching upstream changes from origin
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
hudson.plugins.git.GitException: Command "git fetch -t origin +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: error: server certificate verification failed. CAfile: /etc/ssl/certs/ca-certificates.crt CRLfile: none while accessing https://xgitlab.cels.anl.gov/darshan/darshan.git/info/refs
fatal: HTTP request failed
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:774)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommand(CliGitAPIImpl.java:740)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.fetch(CliGitAPIImpl.java:161)
	at hudson.plugins.git.GitAPI.fetch(GitAPI.java:230)
	at hudson.plugins.git.GitSCM.fetchFrom(GitSCM.java:793)
	at hudson.plugins.git.GitSCM.access$000(GitSCM.java:57)
	at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:977)
	at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:942)
	at hudson.FilePath$FileCallableWrapper.call(FilePath.java:2719)
	at hudson.remoting.UserRequest.perform(UserRequest.java:120)
	at hudson.remoting.UserRequest.perform(UserRequest.java:48)
	at hudson.remoting.Request$2.run(Request.java:326)
	at hudson.remoting.InterceptingExecutorService$1.call(InterceptingExecutorService.java:68)
	at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334)
	at java.util.concurrent.FutureTask.run(FutureTask.java:166)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:724)
ERROR: Could not fetch from any repository
java.io.IOException: remote file operation failed: <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-static/ws/> at hudson.remoting.Channel at 4f8ffc70:thrash.mcs.anl.gov: java.io.IOException: Could not fetch from any repository
	at hudson.FilePath.act(FilePath.java:986)
	at hudson.FilePath.act(FilePath.java:968)
	at hudson.plugins.git.GitSCM.determineRevisionToBuild(GitSCM.java:942)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1108)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1269)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:607)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:529)
	at hudson.model.Run.execute(Run.java:1738)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:98)
	at hudson.model.Executor.run(Executor.java:410)
Caused by: java.io.IOException: Could not fetch from any repository
	at hudson.plugins.git.GitSCM$2.invoke(GitSCM.java:986)
	at ......remote call to thrash.mcs.anl.gov(Native Method)
	at hudson.remoting.Channel.attachCallSiteStackTrace(Channel.java:1416)
	at hudson.remoting.UserResponse.retrieve(UserRequest.java:220)
	at hudson.remoting.Channel.call(Channel.java:781)
	at hudson.FilePath.act(FilePath.java:979)
	... 11 more
Recording test results
ERROR: Step ‘Publish JUnit test result report’ failed: Test reports were found but none of them are new. Did tests run?
For example, <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-static/ws/build-result.xml> is 1 day 23 hr old
More information about the Darshan-commits mailing list
