[Darshan-commits] [Git][darshan/darshan][dev-stdio] cleanup sizeof calls
Philip Carns
xgitlab at cels.anl.gov
Fri Jun 24 12:15:42 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
8bb4890f by Phil Carns at 2016-06-24T13:15:28-04:00
1 changed file:
- darshan-runtime/lib/darshan-stdio.c
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -190,7 +190,7 @@ static void stdio_cleanup_runtime();
break; \
rec_id = darshan_core_gen_record_id(newpath); \
- rec_ref = darshan_lookup_record_ref(stdio_runtime->rec_id_hash, &rec_id, sizeof(darshan_record_id)); \
+ rec_ref = darshan_lookup_record_ref(stdio_runtime->rec_id_hash, &rec_id, sizeof(rec_id)); \
if(!rec_ref) rec_ref = stdio_track_new_file_record(rec_id, newpath); \
if(!rec_ref) { \
if(newpath != (char*)__path) free(newpath); \
@@ -211,7 +211,7 @@ static void stdio_cleanup_runtime();
#define STDIO_RECORD_READ(__fp, __bytes, __tm1, __tm2) do{ \
struct stdio_file_record_ref* rec_ref; \
int64_t this_offset; \
- rec_ref = darshan_lookup_record_ref(stdio_runtime->stream_hash, &(__fp), sizeof(int)); \
+ rec_ref = darshan_lookup_record_ref(stdio_runtime->stream_hash, &(__fp), sizeof(__fp)); \
if(!rec_ref) break; \
this_offset = rec_ref->offset; \
rec_ref->offset = this_offset + __bytes; \
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/8bb4890ff50e603d74ea08a531326b3dc6a39680
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160624/580901bf/attachment-0001.html>
More information about the Darshan-commits
