[Darshan-commits] [Git][darshan/darshan][dev-stdio] update stdio module logutils to match new apis
Philip Carns
xgitlab at cels.anl.gov
Fri Jun 24 11:44:55 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
af5dfe77 by Phil Carns at 2016-06-24T12:44:27-04:00
1 changed file:
- darshan-util/darshan-stdio-logutils.c
Changes:
--- a/darshan-util/darshan-stdio-logutils.c
+++ b/darshan-util/darshan-stdio-logutils.c
@@ -32,8 +32,7 @@ char *stdio_f_counter_names[] = {
#undef X
/* prototypes for each of the STDIO module's logutil functions */
-static int darshan_log_get_stdio_record(darshan_fd fd, void* stdio_buf,
- darshan_record_id* rec_id);
+static int darshan_log_get_stdio_record(darshan_fd fd, void* stdio_buf);
static int darshan_log_put_stdio_record(darshan_fd fd, void* stdio_buf, int ver);
static void darshan_log_print_stdio_record(void *file_rec,
char *file_name, char *mnt_pt, char *fs_type, int ver);
@@ -55,41 +54,37 @@ struct darshan_mod_logutil_funcs stdio_logutils =
/* retrieve a STDIO record from log file descriptor 'fd', storing the
- * buffer in 'stdio_buf' and the corresponding Darshan record id in
- * 'rec_id'. Return 1 on successful record read, 0 on no more data,
- * and -1 on error.
+ * buffer in 'stdio_buf'. Return 1 on successful record read, 0 on no
+ * more data, and -1 on error.
- struct darshan_stdio_record *rec;
+ struct darshan_stdio_file *file;
int i;
int ret;
/* read a STDIO module record from the darshan log file */
- ret = darshan_log_getmod(fd, DARSHAN_STDIO_MOD, stdio_buf,
- sizeof(struct darshan_stdio_record));
+ ret = darshan_log_get_mod(fd, DARSHAN_STDIO_MOD, stdio_buf,
+ sizeof(struct darshan_stdio_file));
if(ret < 0)
return(-1);
- else if(ret < sizeof(struct darshan_stdio_record))
+ else if(ret < sizeof(struct darshan_stdio_file))
return(0);
else
/* if the read was successful, do any necessary byte-swapping */
- rec = (struct darshan_stdio_record *)stdio_buf;
+ file = (struct darshan_stdio_file *)stdio_buf;
if(fd->swap_flag)
/* swap bytes if necessary */
- DARSHAN_BSWAP64(&rec->f_id);
- DARSHAN_BSWAP64(&rec->rank);
+ DARSHAN_BSWAP64(&file->base_rec.id);
+ DARSHAN_BSWAP64(&file->base_rec.rank);
for(i=0; i<STDIO_NUM_INDICES; i++)
- DARSHAN_BSWAP64(&rec->counters[i]);
+ DARSHAN_BSWAP64(&file->counters[i]);
for(i=0; i<STDIO_F_NUM_INDICES; i++)
- DARSHAN_BSWAP64(&rec->fcounters[i]);
+ DARSHAN_BSWAP64(&file->fcounters[i]);
- /* set the output record id */
- *rec_id = rec->f_id;
return(1);
@@ -99,12 +94,12 @@ static int darshan_log_get_stdio_record(darshan_fd fd, void* stdio_buf,
- struct darshan_stdio_record *rec = (struct darshan_stdio_record *)stdio_buf;
+ struct darshan_stdio_file *rec = (struct darshan_stdio_file *)stdio_buf;
int ret;
/* append STDIO record to darshan log file */
- ret = darshan_log_putmod(fd, DARSHAN_STDIO_MOD, rec,
- sizeof(struct darshan_stdio_record), ver);
+ ret = darshan_log_put_mod(fd, DARSHAN_STDIO_MOD, rec,
+ sizeof(struct darshan_stdio_file), ver);
if(ret < 0)
return(-1);
@@ -116,15 +111,15 @@ static void darshan_log_print_stdio_record(void *file_rec, char *file_name,
int i;
- struct darshan_stdio_record *stdio_rec =
- (struct darshan_stdio_record *)file_rec;
+ struct darshan_stdio_file *stdio_rec =
+ (struct darshan_stdio_file *)file_rec;
/* print each of the integer and floating point counters for the STDIO module */
/* macro defined in darshan-logutils.h */
DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_STDIO_MOD],
- stdio_rec->rank, stdio_rec->f_id, stdio_counter_names[i],
+ stdio_rec->base_rec.rank, stdio_rec->base_rec.id, stdio_counter_names[i],
stdio_rec->counters[i], file_name, mnt_pt, fs_type);
@@ -132,7 +127,7 @@ static void darshan_log_print_stdio_record(void *file_rec, char *file_name,
DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_STDIO_MOD],
- stdio_rec->rank, stdio_rec->f_id, stdio_f_counter_names[i],
+ stdio_rec->base_rec.rank, stdio_rec->base_rec.id, stdio_f_counter_names[i],
stdio_rec->fcounters[i], file_name, mnt_pt, fs_type);
@@ -156,8 +151,8 @@ static void darshan_log_print_stdio_description()
static void darshan_log_print_stdio_record_diff(void *file_rec1, char *file_name1,
void *file_rec2, char *file_name2)
- struct darshan_stdio_record *file1 = (struct darshan_stdio_record *)file_rec1;
- struct darshan_stdio_record *file2 = (struct darshan_stdio_record *)file_rec2;
+ struct darshan_stdio_file *file1 = (struct darshan_stdio_file *)file_rec1;
+ struct darshan_stdio_file *file2 = (struct darshan_stdio_file *)file_rec2;
int i;
/* NOTE: we assume that both input records are the same module format version */
@@ -168,7 +163,7 @@ static void darshan_log_print_stdio_record_diff(void *file_rec1, char *file_name
printf("- ");
- file1->rank, file1->f_id, stdio_counter_names[i],
+ file1->base_rec.rank, file1->base_rec.id, stdio_counter_names[i],
file1->counters[i], file_name1, "", "");
@@ -176,18 +171,18 @@ static void darshan_log_print_stdio_record_diff(void *file_rec1, char *file_name
printf("+ ");
- file2->rank, file2->f_id, stdio_counter_names[i],
+ file2->base_rec.rank, file2->base_rec.id, stdio_counter_names[i],
file2->counters[i], file_name2, "", "");
else if(file1->counters[i] != file2->counters[i])
printf("- ");
printf("+ ");
@@ -198,7 +193,7 @@ static void darshan_log_print_stdio_record_diff(void *file_rec1, char *file_name
printf("- ");
- file1->rank, file1->f_id, stdio_f_counter_names[i],
+ file1->base_rec.rank, file1->base_rec.id, stdio_f_counter_names[i],
file1->fcounters[i], file_name1, "", "");
@@ -206,18 +201,18 @@ static void darshan_log_print_stdio_record_diff(void *file_rec1, char *file_name
printf("+ ");
- file2->rank, file2->f_id, stdio_f_counter_names[i],
+ file2->base_rec.rank, file2->base_rec.id, stdio_f_counter_names[i],
file2->fcounters[i], file_name2, "", "");
else if(file1->fcounters[i] != file2->fcounters[i])
printf("- ");
printf("+ ");
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/af5dfe776eb68599211b1b8f5f21f7c840e27cc1
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160624/27162300/attachment-0001.html>
More information about the Darshan-commits
