[Darshan-commits] Build failed in Jenkins: darshan-master-mpich-3.0.4-dynamic #428
jenkins-ci at mcs.anl.gov
Tue Jun 21 11:25:35 CDT 2016
See <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/428/changes>
Changes:
[ssnyder] first cut at mmap logic -- posix mod only for now
[ssnyder] more mmap logic and instrumentation for testing
[ssnyder] update logutils to allow logs with only job info
[ssnyder] runtime now mmaps header and job data to tmp log
[ssnyder] update logutils to read uncompressed log files
[ssnyder] bug fix in mmap region pointer assignment
[ssnyder] updated logutils hash read deserialization method
[ssnyder] update core runtime record hash implementation
[ssnyder] modify register_record routine used by modules
[ssnyder] add new utility to stitch together darshan logs
[ssnyder] runtime now stores mnt & exe data at all ranks
[ssnyder] modify hash write routine to use new serialization
[ssnyder] first cut at the stitch logs utility
[ssnyder] change runtime darshan record_ref struct
[ssnyder] change util record ref structure def
[ssnyder] introduce base record concept in posix mod
[ssnyder] add base record concept to utilities
[ssnyder] update utilities and log format to use base rec
[ssnyder] add an aggregation routine to module logutils
[ssnyder] integrate normal darshan shutdown back into code
[ssnyder] more darshan-util updates for handling tmp logs
[ssnyder] minor reorganization of some runtime code
[ssnyder] integrate new darshan-diff util in mmap branch
[ssnyder] typos in darshan-diff
[ssnyder] forgot to install diff utility in makefile
[ssnyder] update how module & record registration
[ssnyder] apply mmap code changes to other i/o modules
[ssnyder] fix post-merge build errors
[ssnyder] bug fixes from merge of mmap-dev to dev-modular
[ssnyder] bug fix in log aggregation tool
[ssnyder] add aggregation capability to i/o modules
[ssnyder] bug fix in darshan put_header routine
[ssnyder] remove profiling macros from posix module
[ssnyder] rename merge log utility
[ssnyder] autconf/runtime changes for configuring mmap code
[ssnyder] update command line args for log merging utility
[ssnyder] allreduce job start time in darshan-core init.
[ssnyder] autogenerate an example epilog script
[ssnyder] first cut at unifying mmap feature with darshan
[ssnyder] improve slurm epilog script
[ssnyder] allow common counters to be updated on the go
[ssnyder] add common counter aggregation to logutils
[ssnyder] allow job end time to be set by darshan-merge
[ssnyder] add variance counter reduction logic to logutils
[ssnyder] common access counters are now sorted in logs
[ssnyder] bug fix in aggregating common accesses
[ssnyder] add variable-length definition of name records
[ssnyder] darshan-util edits for var. length name records
[ssnyder] remove shared name records on nonzero ranks
[ssnyder] register/lookup_record now use strings explicitly
[ssnyder] numerous darshan-core api changes
[ssnyder] add record_ref interface to darshan-common
[ssnyder] darshan-core code and documentation cleanup
[ssnyder] fix comment and shuffle some more code
[ssnyder] convert to a single module shutdown function
[ssnyder] posix mod cleanup + shutdown func update
[ssnyder] some more POSIX and common code cleanup
[ssnyder] update MPI-IO module to reflect recent changes
[ssnyder] port hdf5 and pnetcdf modules to new API changes
[ssnyder] fix out-of-tree makefile bug in darshan-util
[ssnyder] modifications for sorting module records
[ssnyder] fix compile error when mmap is disabled
[ssnyder] bug fix in initializing static modules
[ssnyder] port bgq module over to new interface changes
[ssnyder] parser shouldn't abort with no-name records
[ssnyder] simplify common counter logic
[ssnyder] logutil backwards compatibility for name records
[ssnyder] cleanup comments in darshan-common
[ssnyder] cleanup makefile & autoconf mmap detection
[ssnyder] fix comment in darshan-config
[ssnyder] ifdef wrap mmap #define
[ssnyder] honor DARSHAN_MODMEM env variable
[ssnyder] fix comments in module log format headers
[ssnyder] port NULL module over to new API changes
[ssnyder] text edits in darshan-runtime docs
[ssnyder] bug fix to byte swap module version array
[ssnyder] move back-compat code out of dedicated directory
[ssnyder] bgq backwards compatibility code
[ssnyder] remove old modularization design docs
[ssnyder] eliminate possible shutdown timing skew
[...truncated 9960 lines...]
/usr/bin/install -c -m 644 MPI_Win_lock.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_lock.3>
/usr/bin/install -c -m 644 MPI_Win_lock_all.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_lock_all.3>
/usr/bin/install -c -m 644 MPI_Win_post.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_post.3>
/usr/bin/install -c -m 644 MPI_Win_set_attr.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_set_attr.3>
/usr/bin/install -c -m 644 MPI_Win_set_errhandler.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_set_errhandler.3>
/usr/bin/install -c -m 644 MPI_Win_set_info.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_set_info.3>
/usr/bin/install -c -m 644 MPI_Win_set_name.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_set_name.3>
/usr/bin/install -c -m 644 MPI_Win_shared_query.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_shared_query.3>
/usr/bin/install -c -m 644 MPI_Win_start.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_start.3>
/usr/bin/install -c -m 644 MPI_Win_sync.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_sync.3>
/usr/bin/install -c -m 644 MPI_Win_test.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_test.3>
/usr/bin/install -c -m 644 MPI_Win_unlock.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_unlock.3>
/usr/bin/install -c -m 644 MPI_Win_unlock_all.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_unlock_all.3>
/usr/bin/install -c -m 644 MPI_Win_wait.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Win_wait.3>
/usr/bin/install -c -m 644 MPI_Wtick.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Wtick.3>
/usr/bin/install -c -m 644 MPI_Wtime.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPI_Wtime.3>
/usr/bin/install -c -m 644 MPIX_Comm_group_failed.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPIX_Comm_group_failed.3>
/usr/bin/install -c -m 644 MPIX_Comm_reenable_anysource.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPIX_Comm_reenable_anysource.3>
/usr/bin/install -c -m 644 MPIX_Comm_remote_group_failed.3 <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/man/man3/MPIX_Comm_remote_group_failed.3>
if [ ! -e <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/doc/mpich> ] ; then mkdir -p <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/doc/mpich> ; fi
if [ -s ./doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644 ./doc/userguide/user.pdf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/doc/mpich/user.pdf> ; fi
if [ -s ./doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644 ./doc/installguide/install.pdf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/doc/mpich/install.pdf> ; fi
if [ -s ./doc/smpd/smpd_pmi.pdf ] ; then /usr/bin/install -c -m 644 ./doc/smpd/smpd_pmi.pdf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/doc/mpich/smpd_pmi.pdf> ; fi
if [ -s ./doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644 ./doc/logging/logging.pdf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/share/doc/mpich/logging.pdf> ; fi
mkdir -p '<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/include'>
/usr/bin/install -c -m 644 src/binding/f90/mpi.mod src/binding/f90/mpi_sizeofs.mod src/binding/f90/mpi_constants.mod src/binding/f90/mpi_base.mod '<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/include'>
/usr/bin/install -c -m 644 src/binding/cxx/mpicxx.h src/binding/f77/mpif.h src/include/mpi.h '<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/include'>
mkdir -p '<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/lib/pkgconfig'>
/usr/bin/install -c -m 644 src/packaging/pkgconfig/mpich.pc '<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-install/lib/pkgconfig'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-3.0.4'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-3.0.4'>
Making install in examples
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-3.0.4/examples'>
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-3.0.4/examples'>
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-3.0.4/examples'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-3.0.4/examples'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/mpich-3.0.4'>
[darshan-master-mpich-3.0.4-dynamic] $ /bin/bash /tmp/hudson3735038193101752671.sh
[darshan-master-mpich-3.0.4-dynamic] $ /bin/bash /tmp/hudson945924922899754491.sh
checking for a BSD-compatible install... /usr/bin/install -c
checking whether the mpicc compiler works... checking for gcc... mpicc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether mpicc accepts -g... yes
checking for mpicc option to accept ISO C89... none needed
yes
checking how to run the C preprocessor... mpicc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for inflateEnd in -lz... yes
checking for BG/Q environment... no
checking for inttypes.h... (cached) yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking whether byte ordering is bigendian... no
checking for struct aiocb64... yes
checking for off64_t... yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking for MPI-IO support in MPI... yes
checking for MPI-IO prototypes without const qualifier... no
checking for MPI-IO prototypes with const qualifier... yes
checking for shared libraries in MPI... yes
checking for MPIO_Request... yes
checking for old (pre-3.1.1) style MPICH library naming convention... yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating darshan-mk-log-dirs.pl
config.status: creating darshan-gen-cc.pl
config.status: creating darshan-gen-cxx.pl
config.status: creating darshan-gen-fortran.pl
config.status: creating darshan-config
config.status: creating share/craype-1.x/darshan-module
config.status: creating share/craype-2.x/darshan-module
config.status: creating lib/pkgconfig/darshan-runtime.pc
config.status: creating share/mpi-profile/darshan-cc.conf
config.status: creating share/mpi-profile/darshan-cxx.conf
config.status: creating share/mpi-profile/darshan-f.conf
config.status: creating share/mpi-profile/darshan-bg-cc.conf
config.status: creating share/mpi-profile/darshan-bg-cxx.conf
config.status: creating share/mpi-profile/darshan-bg-f.conf
config.status: creating share/ld-opts/darshan-base-ld-opts
config.status: creating darshan-runtime-config.h
checking for gcc... gcc
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking if bzlib is wanted... yes
checking for BZ2_bzCompressInit in -lbz2... yes
checking bzlib.h usability... yes
checking bzlib.h presence... yes
checking for bzlib.h... yes
checking for BZ2_bzCompressInit in -lbz2... (cached) yes
checking bzlib in /usr... ok
checking for pdflatex... yes
checking for -halt-on-error argument to pdflatex... yes
checking for strndup... yes
config.status: creating darshan-job-summary/bin/darshan-job-summary.pl
config.status: creating maint/darshan-util.pc
config.status: creating darshan-util-config.h
config.status: darshan-util-config.h is unchanged
[darshan-master-mpich-3.0.4-dynamic] $ /bin/bash /tmp/hudson4332729715480670392.sh
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-core-init-finalize.c -o lib/darshan-core-init-finalize.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-core.c -o lib/darshan-core.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-common.c -o lib/darshan-common.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-posix.c -o lib/darshan-posix.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-mpiio.c -o lib/darshan-mpiio.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-hdf5.c -o lib/darshan-hdf5.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-pnetcdf.c -o lib/darshan-pnetcdf.o
ar rcs lib/libdarshan.a lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darshan-common.o lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o lib/lookup3.o lib/lookup8.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-hdf5-stubs.c -o lib/darshan-hdf5-stubs.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-pnetcdf-stubs.c -o lib/darshan-pnetcdf-stubs.o
ar rcs lib/libdarshan-stubs.a lib/darshan-hdf5-stubs.o lib/darshan-pnetcdf-stubs.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-null.c -o lib/darshan-null.o
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c ../../darshan-runtime/lib/darshan-core-init-finalize.c -o lib/darshan-core-init-finalize.po
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c ../../darshan-runtime/lib/darshan-core.c -o lib/darshan-core.po
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c ../../darshan-runtime/lib/darshan-common.c -o lib/darshan-common.po
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c ../../darshan-runtime/lib/darshan-posix.c -o lib/darshan-posix.po
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c ../../darshan-runtime/lib/darshan-mpiio.c -o lib/darshan-mpiio.po
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c ../../darshan-runtime/lib/darshan-hdf5.c -o lib/darshan-hdf5.po
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c ../../darshan-runtime/lib/darshan-pnetcdf.c -o lib/darshan-pnetcdf.po
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -o lib/libdarshan.so lib/darshan-core-init-finalize.po lib/darshan-core.po lib/darshan-common.po lib/darshan-posix.po lib/darshan-mpiio.po lib/darshan-hdf5.po lib/darshan-pnetcdf.po lib/lookup3.po lib/lookup8.po -lpthread -lrt -lz -ldl
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD -c ../../darshan-runtime/lib/darshan-null.c -o lib/darshan-null.po
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/lib>
install -m 755 lib/libdarshan.a <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/lib>
install -m 755 lib/libdarshan-stubs.a <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/lib>
install -m 755 lib/libdarshan.so <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/lib>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-mk-log-dirs.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-gen-cc.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-gen-cxx.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-gen-fortran.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-config <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/craype-1.x/modulefiles/darshan>
install -m 755 share/craype-1.x/darshan-module <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/craype-1.x/modulefiles/darshan/3.0.1>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/craype-2.x/modulefiles/darshan>
install -m 755 share/craype-2.x/darshan-module <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/craype-2.x/modulefiles/darshan/3.0.1>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/mpi-profile>
install -m 755 share/mpi-profile/darshan-cc.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/mpi-profile/darshan-cc.conf>
install -m 755 share/mpi-profile/darshan-cxx.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/mpi-profile/darshan-cxx.conf>
install -m 755 share/mpi-profile/darshan-f.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/mpi-profile/darshan-f.conf>
install -m 755 share/mpi-profile/darshan-bg-cc.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/mpi-profile/darshan-bg-cc.conf>
install -m 755 share/mpi-profile/darshan-bg-cxx.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/mpi-profile/darshan-bg-cxx.conf>
install -m 755 share/mpi-profile/darshan-bg-f.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/mpi-profile/darshan-bg-f.conf>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/ld-opts>
install -m 644 share/ld-opts/darshan-base-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/ld-opts/darshan-base-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-posix-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/ld-opts/darshan-posix-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-hdf5-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/ld-opts/darshan-hdf5-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-pnetcdf-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/share/ld-opts/darshan-pnetcdf-ld-opts>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/lib/pkgconfig>
install -m 644 lib/pkgconfig/darshan-runtime.pc <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/lib/pkgconfig/darshan-runtime.pc>
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -c ../../darshan-util/darshan-logutils.c -o darshan-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -c ../../darshan-util/darshan-posix-logutils.c -o darshan-posix-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -c ../../darshan-util/darshan-mpiio-logutils.c -o darshan-mpiio-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -c ../../darshan-util/darshan-hdf5-logutils.c -o darshan-hdf5-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -c ../../darshan-util/darshan-pnetcdf-logutils.c -o darshan-pnetcdf-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -c ../../darshan-util/darshan-bgq-logutils.c -o darshan-bgq-logutils.o
ar rcs libdarshan-util.a darshan-logutils.o darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o darshan-bgq-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -c ../../darshan-util/darshan-null-logutils.c -o darshan-null-logutils.o
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -L/usr/lib ../../darshan-util/darshan-analyzer.c libdarshan-util.a -o darshan-analyzer -lz -lbz2
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -L/usr/lib ../../darshan-util/darshan-convert.c lookup3.o libdarshan-util.a -o darshan-convert -lz -lbz2
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -L/usr/lib ../../darshan-util/darshan-diff.c libdarshan-util.a -o darshan-diff -lz -lbz2
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -L/usr/lib ../../darshan-util/darshan-parser.c libdarshan-util.a -o darshan-parser -lz -lbz2
gcc -I . -I .. -I ../../darshan-util -I ../../darshan-util/../ -DDARSHAN_CONFIG_H=\"darshan-util-config.h\" -g -O2 -I/usr/include -L/usr/lib ../../darshan-util/darshan-merge.c libdarshan-util.a -o darshan-merge -lz -lbz2
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 755 darshan-analyzer <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-convert <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-diff <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-parser <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 darshan-merge <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 ../../darshan-util/darshan-summary-per-file.sh <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/bin>
install -m 755 libdarshan-util.a <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/lib>
install -m 644 ../../darshan-util/darshan-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/darshan-posix-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/darshan-mpiio-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/darshan-hdf5-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/darshan-pnetcdf-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/darshan-bgq-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/darshan-null-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/../darshan-null-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/../darshan-posix-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/../darshan-mpiio-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/../darshan-hdf5-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/../darshan-pnetcdf-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -m 644 ../../darshan-util/../darshan-bgq-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include/uthash-1.9.2>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include/uthash-1.9.2/src>
install -m 644 ../../darshan-util/uthash-1.9.2/src/uthash.h <https://jenkins-ci.mcs.anl.gov/job/darshan-master-mpich-3.0.4-dynamic/ws/install/include/uthash-1.9.2/src/>
install: cannot stat `../../darshan-util/uthash-1.9.2/src/uthash.h': No such file or directory
make: *** [install] Error 1
Build step 'Execute shell' marked build as failure
Recording test results
More information about the Darshan-commits
