[Darshan-commits] [Git][darshan/darshan][mmap-dev] 2 commits: fix comments in module log format headers
Shane Snyder xgitlab at cels.anl.gov
Fri Jun 17 18:38:02 CDT 2016
Shane Snyder pushed to branch mmap-dev at darshan / darshan
Commits:
ba0f880b by Shane Snyder at 2016-06-17T16:51:11-05:00
b70be200 by Shane Snyder at 2016-06-17T18:29:14-05:00
port NULL module over to new API changes
8 changed files:
- darshan-bgq-log-format.h
- darshan-hdf5-log-format.h
- darshan-mpiio-log-format.h
- darshan-null-log-format.h
- darshan-pnetcdf-log-format.h
- darshan-posix-log-format.h
- darshan-runtime/Makefile.in
- darshan-runtime/lib/darshan-null.c
Changes:
--- a/darshan-bgq-log-format.h
+++ b/darshan-bgq-log-format.h
@@ -60,8 +60,7 @@ enum darshan_bgq_f_indices
  * which would actually be logged to file by Darshan for the "BGQ" example
  * module. This example implementation logs the following data for each
  * record:
- *      - a corresponding Darshan record identifier
- *      - the rank of the process responsible for the record
+ *      - a darshan_base_record structure, which contains the record id & rank
  *      - integer I/O counters (operation counts, I/O sizes, etc.)
  *      - floating point I/O counters (timestamps, cumulative timers, etc.)
--- a/darshan-hdf5-log-format.h
+++ b/darshan-hdf5-log-format.h
@@ -41,8 +41,7 @@ enum darshan_hdf5_f_indices
 /* file record structure for HDF5 files. a record is created and stored for
  * every HDF5 file opened by the original application. For the HDF5 module,
  * the record includes:
- *      - a corresponding record identifier (created by hashing the file path)
- *      - the rank of the process which opened the file (-1 for shared files)
  *      - integer file I/O statistics (open, read/write counts, etc)
  *      - floating point I/O statistics (timestamps, cumulative timers, etc.)
--- a/darshan-mpiio-log-format.h
+++ b/darshan-mpiio-log-format.h
@@ -140,8 +140,7 @@ enum darshan_mpiio_f_indices
 /* file record structure for MPI-IO files. a record is created and stored for
  * every MPI-IO file opened by the original application. For the MPI-IO module,
--- a/darshan-null-log-format.h
+++ b/darshan-null-log-format.h
@@ -44,8 +44,7 @@ enum darshan_null_f_indices
  * which would actually be logged to file by Darshan for the "NULL" example
  * record:
--- a/darshan-pnetcdf-log-format.h
+++ b/darshan-pnetcdf-log-format.h
@@ -43,8 +43,7 @@ enum darshan_pnetcdf_f_indices
 /* file record structure for PNETCDF files. a record is created and stored for
  * every PNETCDF file opened by the original application. For the PNETCDF module,
--- a/darshan-posix-log-format.h
+++ b/darshan-posix-log-format.h
@@ -164,8 +164,7 @@ enum darshan_posix_f_indices
 /* file record structure for POSIX files. a record is created and stored for
  * every POSIX file opened by the original application. For the POSIX module,
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -1,5 +1,4 @@
-all: lib/libdarshan.a lib/libdarshan-stubs.a
-#TODO: lib/darshan-null.o
+all: lib/libdarshan.a lib/libdarshan-stubs.a lib/darshan-null.o
 #TODO: each module provides own makefile with module-specific objects, build options, etc.
@@ -24,9 +23,8 @@ DARSHAN_LOG_FORMAT = $(srcdir)/../darshan-log-format.h
 DARSHAN_VERSION = @DARSHAN_VERSION@
 ifndef DISABLE_LDPRELOAD
-all: lib/libdarshan.so
+all: lib/libdarshan.so lib/darshan-null.po
 endif
-#TODO: lib/darshan-null.po
 VPATH = $(srcdir)
--- a/darshan-runtime/lib/darshan-null.c
+++ b/darshan-runtime/lib/darshan-null.c
@@ -12,10 +12,11 @@
 #include <unistd.h>
 #include <stdlib.h>
 #include <pthread.h>
+#include <string.h>
 #include <assert.h>
-#include "uthash.h"
 #include "darshan.h"
+#include "darshan-dynamic.h"
 /* The "NULL" module is an example instrumentation module implementation provided
  * with Darshan, primarily to indicate how arbitrary modules may be integrated
@@ -28,88 +29,72 @@
 /* The DARSHAN_FORWARD_DECL macro (defined in darshan.h) is used to provide forward
- * declarations for wrapped funcions, regardless if Darshan is used with statically
- * or dynamically linked executables.
+ * declarations for wrapped funcions, regardless of whether Darshan is used with
+ * statically or dynamically linked executables.
 DARSHAN_FORWARD_DECL(foo, int, (const char *name, int arg1, int arg2));
-/* The null_record_runtime structure maintains necessary runtime metadata
- * for a "NULL" module data record (darshan_null_record structure, defined
- * in darshan-null-log-format.h). This metadata assists with the instrumenting
- * of specific statistics in the file record.
+/* The null_record_ref structure maintains necessary runtime metadata
+ * for the NULL module record (darshan_null_record structure, defined in
+ * darshan-null-log-format.h) pointed to by 'record_p'. This metadata
+ * assists with the instrumenting of specific statistics in the record.
- * RATIONALE: In general, a module may need to track some stateful, volatile
- * information regarding specific I/O statistics to aid in the instrumentation
- * process. However, this information should not be stored in the darshan_null_record
- * struct because we don't want it to appear in the final darshan log file.
- * We therefore associate a null_record_runtime structure with each darshan_null_record
- * structure in order to track this information.
+ * RATIONALE: the NULL module needs to track some stateful, volatile
+ * information about each record it has registered (for instance, most
+ * recent  access time, amount of bytes transferred) to aid in instrumentation,
+ * but this information can't be stored in the darshan_null_record struct
+ * because we don't want it to appear in the final darshan log file.  We
+ * therefore associate a null_record_ref struct with each darshan_null_record
+ * struct in order to track this information (i.e., the mapping between
+ * null_record_ref structs to darshan_null_record structs is one-to-one).
- * NOTE: The null_record_runtime struct contains a pointer to a darshan_null_record
- * struct (see the *record_p member) rather than simply embedding an entire
- * darshan_null_record struct.  This is done so that all of the darshan_null_record
- * structs can be kept contiguous in memory as a single array to simplify
- * reduction, compression, and storage.
+ * NOTE: we use the 'darshan_record_ref' interface (in darshan-common) to
+ * associate different types of handles with this null_record_ref struct.
+ * This allows us to index this struct (and the underlying record) by using
+ * either the corresponding Darshan record identifier or by any other arbitrary
+ * handle. For the NULL module, the only handle we use to track record
+ * references are Darshan record identifiers.
-struct null_record_runtime
+struct null_record_ref
     /* Darshan record for the "NULL" example module */
-    struct darshan_null_record* record_p;
+    struct darshan_null_record *record_p;
     /* ... other runtime data ... */
-    /* hash table link for this record */
-    /* NOTE: it is entirely up to the module developer how to persist module
-     * records in memory as the instrumented application runs. These records
-     * could just as easily be stored in an array or linked list. That said,
-     * the data structure selection should be mindful of the resulting memory
-     * footprint and search time complexity to attempt minimize Darshan overheads.
-     * hash table and linked list implementations are available in uthash.h and
-     * utlist.h, respectively.
-    UT_hash_handle hlink;
-/* The null_runtime structure simply encapsulates global data structures needed
- * by the module for instrumenting functions of interest and providing the output
- * I/O data for this module to the darshan-core component at shutdown time.
+/* The null_runtime structure maintains necessary state for storing
+ * NULL records and for coordinating with darshan-core at shutdown time.
 struct null_runtime
-    /* runtime_record_array is the array of runtime records for the "NULL" module. */
-    struct null_record_runtime* runtime_record_array;
-    /* record_array is the array of high-level Darshan records for the "NULL" module,
-     * each corresponding to the the runtime record structure stored at the same array
-     * index in runtime_record_array.
-    struct darshan_null_record* record_array;
-    /* file_array_size is the maximum amount of records that can be stored in
-     * record_array (and consequentially, runtime_record_array).
-    int rec_array_size;
-    /* file_array_ndx is the current index into both runtime_record_array and
-     * record_array.
-    int rec_array_ndx;
-    /* record_hash is a pointer to a hash table of null_record_runtime structures
-     * currently maintained by the "NULL" module.
+    /* rec_id_hash is a pointer to a hash table of NULL module record
+     * references, indexed by Darshan record id
-    struct null_record_runtime* record_hash;
-    /* total_record is a pointer to a buffer for storing an aggregate record for
-     * all "NULL" module records. This buffer is pointed at the appropriate
-     * region of a mmapped partial log file managed by darshan-core -- this
-     * partial log file is used to get at least *some* i/o data out to a log
-     * file if Darshan does not shut down properly.
-    struct darshan_null_record *total_record;
+    void *rec_id_hash;
+    /* number of records currently tracked */
+    int rec_count;
+/* internal helper functions for the NULL module */
+static void null_runtime_initialize(
+    void);
+static struct null_record_ref *null_track_new_record(
+    darshan_record_id rec_id, const char *name);
+static void null_cleanup_runtime(
+    void);
+/* forward declaration for NULL shutdown function needed to interface
+ * with darshan-core
+static void null_shutdown(MPI_Comm mod_comm, darshan_record_id *shared_recs,
+    int shared_rec_count, void **null_buf, int *null_buf_sz);
 /* null_runtime is the global data structure encapsulating "NULL" module state */
 static struct null_runtime *null_runtime = NULL;
 /* The null_runtime_mutex is a lock used when updating the null_runtime global
  * structure (or any other global data structures). This is necessary to avoid race
- * conditions as multiple threads execute function wrappers and update module state.
+ * conditions as multiple threads may execute function wrappers and update module state.
  * NOTE: Recursive mutexes are used in case functions wrapped by this module call
  * other wrapped functions that would result in deadlock, otherwise. This mechanism
  * may not be necessary for all instrumentation modules.
@@ -120,40 +105,57 @@ static int instrumentation_disabled = 0;
 /* my_rank indicates the MPI rank of this process */
 static int my_rank = -1;
-/* internal helper functions for the "NULL" module */
-static void null_runtime_initialize(void);
-static struct null_record_runtime* null_record_by_name(const char *name);
-/* forward declaration for module functions needed to interface with darshan-core */
-static void null_begin_shutdown(void);
-static void null_get_output_data(MPI_Comm mod_comm, darshan_record_id *shared_recs,
-    int shared_rec_count, void **null_buf, int *null_buf_sz);
-static void null_shutdown(void);
 /* macros for obtaining/releasing the "NULL" module lock */
 #define NULL_LOCK() pthread_mutex_lock(&null_runtime_mutex)
 #define NULL_UNLOCK() pthread_mutex_unlock(&null_runtime_mutex)
+/* the NULL_PRE_RECORD macro is executed before performing NULL
+ * module instrumentation of a call. It obtains a lock for updating
+ * module data strucutres, and ensure the NULL module has been properly
+ * initialized before instrumenting.
+#define NULL_PRE_RECORD() do { \
+    NULL_LOCK(); \
+    if(!null_runtime && !instrumentation_disabled) null_runtime_initialize(); \
+    if(!null_runtime) { \
+        NULL_UNLOCK(); \
+        return(ret); \
+} while(0)
+/* the NULL_POST_RECORD macro is executed after performing NULL
+ * module instrumentation. It simply releases the module lock.
+#define NULL_POST_RECORD() do { \
+    NULL_UNLOCK(); \
+} while(0)
 /* macro for instrumenting the "NULL" module's foo function */
 /* NOTE: this macro makes use of the DARSHAN_COUNTER_* macros defined
  * and documented in darshan.h.
 #define NULL_RECORD_FOO(__ret, __name, __dat, __tm1, __tm2) do{ \
-    struct null_record_runtime* rec; \
-    double elapsed = __tm2 - __tm1; \
+    darshan_record_id rec_id; \
+    struct null_record_ref *rec_ref; \
+    double __elapsed = __tm2 - __tm1; \
     /* if foo returns error (return code < 0), don't instrument anything */ \
     if(__ret < 0) break; \
-    /* use '__name' to lookup a corresponding "NULL" record */ \
-    rec = null_record_by_name(__name); \
-    if(!rec) break; \
+    /* use '__name' to generate a unique Darshan record id */ \
+    rec_id = darshan_core_gen_record_id(__name); \
+    /* look up a record reference for this record id using darshan rec_ref interface */ \
+    rec_ref = darshan_lookup_record_ref(null_runtime->rec_id_hash, &rec_id, sizeof(darshan_record_id)); \
+    /* if no reference was found, track a new one for this record */ \
+    if(!rec_ref) null_track_new_record(rec_id, __name); \
+    /* if we still don't have a valid reference, back out */ \
+    if(!rec_ref) break; \
     /* increment counter indicating number of calls to 'bar' */ \
-    rec->record_p->counters[NULL_BARS] += 1; \
+    rec_ref->record_p->counters[NULL_BARS] += 1; \
     /* store data value for most recent call to 'bar' */ \
-    rec->record_p->counters[NULL_BAR_DAT] = __dat; \
+    rec_ref->record_p->counters[NULL_BAR_DAT] = __dat; \
     /* store timestamp of most recent call to 'bar' */ \
-    rec->record_p->fcounters[NULL_F_BAR_TIMESTAMP] = __tm1; \
+    rec_ref->record_p->fcounters[NULL_F_BAR_TIMESTAMP] = __tm1; \
     /* store duration of most recent call to 'bar' */ \
-    rec->record_p->fcounters[NULL_F_BAR_DURATION] = elapsed; \
+    rec_ref->record_p->fcounters[NULL_F_BAR_DURATION] = __elapsed; \
 } while(0)
@@ -182,182 +184,135 @@ int DARSHAN_DECL(foo)(const char* name, int arg1, int arg2)
     ret = __real_foo(name, arg1, arg2);
     tm2 = darshan_core_wtime();
-    NULL_LOCK();
-    /* Before attempting to instrument I/O statistics for function foo, make
-     * sure the "NULL" module runtime environment has been initialized.
-     * NOTE: this runtime environment is initialized only once -- if the
-     * appropriate structures have already been initialized, this function simply
-     * returns.
-    null_runtime_initialize();
+    NULL_PRE_RECORD();
     /* Call macro for instrumenting data for foo function calls. */
     NULL_RECORD_FOO(ret, name, arg1+arg2, tm1, tm2);
-    NULL_UNLOCK();
+    NULL_POST_RECORD();
     return(ret);
- * Internal functions for manipulating POSIX module state *
+ * Internal functions for manipulating NULL module state *
-/* Initialize internal POSIX module data structures and register with darshan-core. */
+/* Initialize internal NULL module data structures and register with darshan-core. */
 static void null_runtime_initialize()
-    int mmap_buf_size;
-    /* struct of function pointers for interfacing with darshan-core */
-    struct darshan_module_funcs null_mod_fns =
-        .begin_shutdown = &null_begin_shutdown,
-        .get_output_data = &null_get_output_data,
-        .shutdown = &null_shutdown
-    int mem_limit; /* max. memory this module can consume, dictated by darshan-core */
-    /* don't do anything if already initialized or instrumenation is disabled */
-    if(null_runtime || instrumentation_disabled)
-        return;
+    int null_buf_size;
-    /* register the "NULL" module with the darshan-core component */
+    /* try and store a default number of records for this module */
+    null_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_null_record);
+    /* register the NULL module with the darshan-core component */
     darshan_core_register_module(
         DARSHAN_NULL_MOD,   /* Darshan module identifier, defined in darshan-log-format.h */
-        &null_mod_fns,
+        &null_shutdown,
+        &null_buf_size,
         &my_rank,
-        &mem_limit,
-        (void **)&null_runtime->total_record,
-        &mmap_buf_size,
         NULL);
-    /* return if no memory assigned by darshan-core */
-    if(mem_limit == 0)
+    /* return if darshan-core does not provide enough module memory for at
+     * least one NULL record
+    if(null_buf_size < sizeof(struct darshan_null_record))
+        darshan_core_unregister_module(DARSHAN_NULL_MOD);
         return;
     /* initialize module's global state */
     null_runtime = malloc(sizeof(*null_runtime));
     if(!null_runtime)
-        return;
-    memset(null_runtime, 0, sizeof(*null_runtime));
-    /* Set the maximum number of data records this module may track, as indicated
-     * by mem_limit (set by darshan-core).
-     * NOTE: We interpret the maximum memory limit to be related to the maximum
-     * amount of data which may be written to log by a single process for a given
-     * module. We therefore use this maximum memory limit to determine how many
-     * darshan_null_record structures we can track per process.
-    null_runtime->rec_array_size = mem_limit / sizeof(struct darshan_null_record);
-    null_runtime->rec_array_ndx = 0;
-    /* allocate both record arrays (runtime and high-level records) */
-    null_runtime->runtime_record_array = malloc(null_runtime->rec_array_size *
-                                                sizeof(struct null_record_runtime));
-    null_runtime->record_array = malloc(null_runtime->rec_array_size *
-                                        sizeof(struct darshan_null_record));
-    if(!null_runtime->runtime_record_array || !null_runtime->record_array)
-        null_runtime->rec_array_size = 0;
         return;
-    memset(null_runtime->runtime_record_array, 0, null_runtime->rec_array_size *
-    memset(null_runtime->record_array, 0, null_runtime->rec_array_size *
+    memset(null_runtime, 0, sizeof(*null_runtime));
     return;
-/* Search for and return a "NULL" module record corresponding to name parameter. */
+/* allocate and track a new NULL module record */
-    struct null_record_runtime *rec = NULL;
-    darshan_record_id rec_id;
-    int limit_flag;
+    struct darshan_null_record *record_p = NULL;
+    struct null_record_ref *rec_ref = NULL;
+    int ret;
-    /* Don't search for a record if the "NULL" module is not initialized or
-     * if instrumentation has been toggled off.
-    if(!null_runtime || instrumentation_disabled)
+    rec_ref = malloc(sizeof(*rec_ref));
+    if(!rec_ref)
         return(NULL);
+    memset(rec_ref, 0, sizeof(*rec_ref));
-    /* stop tracking new records if we are tracking our maximum count */
-    limit_flag = (null_runtime->rec_array_ndx >= null_runtime->rec_array_size);
-    /* get a unique record identifier for this record from darshan-core */
-    darshan_core_register_record(
-        (void*)name,
-        strlen(name),
-        DARSHAN_NULL_MOD,
-        1,
-        limit_flag,
-        &rec_id,
-        NULL);
-    /* the file record id is set to 0 if no memory is available for tracking
-     * new records -- just fall through and ignore this record
+    /* allocate a new NULL record reference and add it to the hash
+     * table, using the Darshan record identifier as the handle
-    if(rec_id == 0)
+    ret = darshan_add_record_ref(&(null_runtime->rec_id_hash), &rec_id,
+        sizeof(darshan_record_id), rec_ref);
+    if(ret == 0)
+        free(rec_ref);
         return(NULL);
-    /* search the hash table for this file record, and return if found */
-    HASH_FIND(hlink, null_runtime->record_hash, &rec_id, sizeof(darshan_record_id), rec);
-    if(rec)
+    /* register the actual file record with darshan-core so it is persisted
+     * in the log file
+    record_p = darshan_core_register_record(
+        rec_id,
+        name,
+        DARSHAN_NULL_MOD,
+        sizeof(struct darshan_null_record),
+        NULL);
+    if(!record_p)
-        return(rec);
+        /* if registration fails, delete record reference and return */
+        darshan_delete_record_ref(&(null_runtime->rec_id_hash),
+            &rec_id, sizeof(darshan_record_id));
+        free(rec_ref);
+        return(NULL);
-    /* no existing record, assign a new one from the global array */
-    rec = &(null_runtime->runtime_record_array[null_runtime->rec_array_ndx]);
-    rec->record_p = &(null_runtime->record_array[null_runtime->rec_array_ndx]);
-    /* set the darshan record id and corresponding process rank for this record */
-    rec->record_p->f_id = rec_id;
-    rec->record_p->rank = my_rank;
-    /* add new record to file hash table */
-    HASH_ADD(hlink, null_runtime->record_hash, record_p->f_id, sizeof(darshan_record_id), rec);
-    null_runtime->rec_array_ndx++;
+    /* registering this file record was successful, so initialize some fields */
+    record_p->base_rec.id = rec_id;
+    record_p->base_rec.rank = my_rank;
+    rec_ref->record_p = record_p;
+    null_runtime->rec_count++;
-    return(rec);
+    /* return pointer to the record reference */
+    return(rec_ref);
- * Functions exported by the "NULL" module for coordinating with darshan-core *
-/* Perform any necessary steps prior to shutting down for the "NULL" module. */
-static void null_begin_shutdown()
+/* cleanup NULL module internal data structures */
+static void null_cleanup_runtime()
-    assert(null_runtime);
-    NULL_LOCK();
-    /* In general, we want to disable all wrappers while Darshan shuts down.
-     * This is to avoid race conditions and ensure data consistency, as
-     * executing wrappers could potentially modify module state while Darshan
-     * is in the process of shutting down.
-    instrumentation_disabled = 1;
-    /* ... any other code which needs to be executed before beginning shutdown process ... */
+    /* iterate the hash of record references and free them */
+    darshan_clear_record_refs(&(null_runtime->rec_id_hash), 1);
-    NULL_UNLOCK();
+    free(null_runtime);
+    null_runtime = NULL;
     return;
-/* Pass output data for the "NULL" module back to darshan-core to log to file. */
+ * shutdown function exported by the "NULL" module for coordinating with darshan-core *
+/* Pass output data for the "NULL" module back to darshan-core to log to file,
+ * and shutdown/free internal data structures.
     MPI_Comm mod_comm,
     void **null_buf,
     int *null_buf_sz)
+    NULL_LOCK();
     /* NOTE: this function can be used to run collective operations prior to
@@ -370,27 +325,21 @@ static void null_get_output_data(
      * functionality.
-    /* Just set the output buffer to point at the array of the "NULL" module's
-     * I/O records, and set the output size according to the number of records
-     * currently being tracked.
+    /* Just set the output size according to the number of records currently
+     * being tracked. In general, the module can decide to throw out records
+     * that have been previously registered by shuffling around memory in
+     * 'null_buf' -- 'null_buf' and 'null_buf_sz' both are passed as pointers
+     * so they can be updated by the shutdown function potentially.
-    *null_buf = (void *)(null_runtime->record_array);
-    *null_buf_sz = null_runtime->rec_array_ndx * sizeof(struct darshan_null_record);
-    return;
-/* Shutdown the "NULL" module by freeing up all data structures. */
-static void null_shutdown()
+    *null_buf_sz = null_runtime->rec_count * sizeof(struct darshan_null_record);
-    HASH_CLEAR(hlink, null_runtime->record_hash); /* these hash entries are freed all at once below */
+    /* shutdown internal structures used for instrumenting */
+    null_cleanup_runtime();
-    free(null_runtime->runtime_record_array);
-    free(null_runtime);
-    null_runtime = NULL;
+    /* disable further instrumentation */
+    instrumentation_disabled = 1;
+    NULL_UNLOCK();
     return;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/bb9d68c0bf4f5146539b12186881f65f62ade8df...b70be20011c789832b8bd314a457a17bbdc37e07
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160617/0b433c0b/attachment-0001.html>
More information about the Darshan-commits mailing list
