[Darshan-commits] [Git][darshan/darshan][lustre-mod] 3 commits: fixed a bug preventing shared file reduction from working correctly
Glenn K. Lockwood xgitlab at cels.anl.gov
Wed Jun 15 16:26:03 CDT 2016
Glenn K. Lockwood pushed to branch lustre-mod at darshan / darshan
Commits:
4264247f by Glenn K. Lockwood at 2016-06-15T13:42:28-07:00
735fc530 by Glenn K. Lockwood at 2016-06-15T14:18:37-07:00
moved the temporary record buffer used in darshan-{convert,parser} into the heap; darshan_diff remains on the stack
b51c463b by Glenn K. Lockwood at 2016-06-15T14:19:47-07:00
working set of tools to parse darshan lustre-mod logfiles
7 changed files:
- darshan-lustre-log-format.h
- darshan-runtime/lib/darshan-lustre.c
- darshan-util/darshan-convert.c
- darshan-util/darshan-diff.c
- darshan-util/darshan-logutils.h
- darshan-util/darshan-lustre-logutils.c
- darshan-util/darshan-parser.c
Changes:
--- a/darshan-lustre-log-format.h
+++ b/darshan-lustre-log-format.h
@@ -7,10 +7,14 @@
 #ifndef __DARSHAN_LUSTRE_LOG_FORMAT_H
 #define __DARSHAN_LUSTRE_LOG_FORMAT_H
+/* NOTE -- redefining the size of OST_ID will require changing the DARSHAN_BSWAP
+ * macro used in darshan-util/darshan-lustre-logutils.c as well
+typedef int64_t OST_ID;
 /* current Lustre log format version */
 #define DARSHAN_LUSTRE_VER 1
-/* TODO: add integer counters here (e.g., counter for stripe width, stripe size, etc etc) */
 #define LUSTRE_COUNTERS \
     /* number of OSTs for file system */\
     X(LUSTRE_OSTS) \
@@ -44,7 +48,12 @@ struct darshan_lustre_record
     darshan_record_id rec_id;
     int64_t rank;
     int64_t counters[LUSTRE_NUM_INDICES];
-    int64_t ost_ids[1];
+    OST_ID ost_ids[1];
+ *  helper function to calculate the size of a record
+#define LUSTRE_RECORD_SIZE( osts ) ( sizeof(struct darshan_lustre_record) + sizeof(OST_ID) * (osts - 1) )
 #endif /* __DARSHAN_LUSTRE_LOG_FORMAT_H */
--- a/darshan-runtime/lib/darshan-lustre.c
+++ b/darshan-runtime/lib/darshan-lustre.c
@@ -44,7 +44,6 @@ static void lustre_record_reduction_op(void* infile_v, void* inoutfile_v,
 #define LUSTRE_LOCK() pthread_mutex_lock(&lustre_runtime_mutex)
 #define LUSTRE_UNLOCK() pthread_mutex_unlock(&lustre_runtime_mutex)
-#define LUSTRE_RECORD_SIZE( osts ) ( sizeof(struct darshan_lustre_record) + sizeof(int64_t) * (osts - 1) )
 void darshan_instrument_lustre_file(const char* filepath, int fd)
@@ -263,9 +262,17 @@ static void lustre_get_output_data(
         sort_lustre_records();
-        /* allocate memory for the reduction output on rank 0 */
+        /* simply drop all shared records from non-root ranks by truncating
+         * the record array and recalculating the size of the used buffer
         if (my_rank != 0)
             lustre_runtime->record_count -= shared_rec_count;
+            lustre_runtime->record_buffer_used = 0;
+            for ( i = 0; i < lustre_runtime->record_count; i++ )
+                lustre_runtime->record_buffer_used +=
+                    LUSTRE_RECORD_SIZE( (lustre_runtime->record_runtime_array[i]).record->counters[LUSTRE_STRIPE_WIDTH] );
     *lustre_buf = (void *)(lustre_runtime->record_buffer);
--- a/darshan-util/darshan-convert.c
+++ b/darshan-util/darshan-convert.c
@@ -19,8 +19,6 @@
 #include "darshan-logutils.h"
-#define DEF_MOD_BUF_SIZE 1024 /* 1 KiB is enough for all current mod records ... */
 extern uint32_t darshan_hashlittle(const void *key, size_t length, uint32_t initval);
 int usage (char *exename)
@@ -233,7 +231,7 @@ int main(int argc, char **argv)
     struct darshan_mnt_info *mnt_data_array;
     struct darshan_record_ref *rec_hash = NULL;
     struct darshan_record_ref *ref, *tmp;
-    char mod_buf[DEF_MOD_BUF_SIZE];
+    char *mod_buf;
     enum darshan_comp_type comp_type;
     int bzip2;
     int obfuscate;
@@ -338,6 +336,14 @@ int main(int argc, char **argv)
         return(-1);
+    mod_buf = malloc(DEF_MOD_BUF_SIZE);
+    if (!mod_buf)
+        darshan_log_close(infile);
+        darshan_log_close(outfile);
+        return(-1);
     /* loop over each module and convert it's data to the new format */
     for(i=0; i<DARSHAN_MAX_MODS; i++)
@@ -364,6 +370,7 @@ int main(int argc, char **argv)
             unlink(outfile_name);
+            free(mod_buf);
             return(-1);
@@ -384,6 +391,7 @@ int main(int argc, char **argv)
         } while((ret = mod_logutils[i]->log_get_record(infile, mod_buf, &rec_id)) == 1);
+    free(mod_buf);
--- a/darshan-util/darshan-diff.c
+++ b/darshan-util/darshan-diff.c
@@ -13,8 +13,6 @@
 #include "uthash-1.9.2/src/uthash.h"
 /* XXX: this structure is a temporary hack to get at the rank for each module's record */
 struct darshan_base_rec
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -17,6 +17,11 @@
 #include "darshan-log-format.h"
+/* Maximum size of a record - Lustre OST lists can get huge, but 81920 is enough
+ * for 10K OSTs
+#define DEF_MOD_BUF_SIZE 81920 /* 640 KiB */
 struct darshan_fd_int_state;
 /* darshan file descriptor definition */
--- a/darshan-util/darshan-lustre-logutils.c
+++ b/darshan-util/darshan-lustre-logutils.c
@@ -49,27 +49,45 @@ static int darshan_log_get_lustre_record(darshan_fd fd, void* lustre_buf,
     int i;
     int ret;
+    /* retrieve the fixed-size portion of the record */
     ret = darshan_log_getmod(fd, DARSHAN_LUSTRE_MOD, lustre_buf,
         sizeof(struct darshan_lustre_record));
     if(ret < 0)
         return(-1);
     else if(ret < sizeof(struct darshan_lustre_record))
         return(0);
-    else
+    rec = (struct darshan_lustre_record *)lustre_buf;
+    /* swap bytes if necessary */
+    if(fd->swap_flag)
-        rec = (struct darshan_lustre_record *)lustre_buf;
-        if(fd->swap_flag)
-            /* swap bytes if necessary */
-            DARSHAN_BSWAP64(&rec->rec_id);
-            DARSHAN_BSWAP64(&rec->rank);
-            for(i=0; i<LUSTRE_NUM_INDICES; i++)
-                DARSHAN_BSWAP64(&rec->counters[i]);
+        DARSHAN_BSWAP64(&rec->rec_id);
+        DARSHAN_BSWAP64(&rec->rank);
+        for(i=0; i<LUSTRE_NUM_INDICES; i++)
+            DARSHAN_BSWAP64(&rec->counters[i]);
-        *rec_id = rec->rec_id;
-        return(1);
+    /* now read the rest of the record */
+    if ( rec->counters[LUSTRE_STRIPE_WIDTH] > 1 ) {
+        ret = darshan_log_getmod(
+            fd,
+            DARSHAN_LUSTRE_MOD,
+            (void*)(&(rec->ost_ids[1])),
+            (rec->counters[LUSTRE_STRIPE_WIDTH] - 1)*sizeof(OST_ID)
+        if(ret < 0)
+            return(-1);
+        else if(ret < sizeof(struct darshan_lustre_record))
+            return(0);
+        if ( fd->swap_flag )
+            for (i = 1; i < rec->counters[LUSTRE_STRIPE_WIDTH]; i++ )
+                DARSHAN_BSWAP64(&(rec->ost_ids[i]));
+    *rec_id = rec->rec_id;
+    return(1);
 static int darshan_log_put_lustre_record(darshan_fd fd, void* lustre_buf, int ver)
@@ -78,7 +96,7 @@ static int darshan_log_put_lustre_record(darshan_fd fd, void* lustre_buf, int ve
     int ret;
     ret = darshan_log_putmod(fd, DARSHAN_LUSTRE_MOD, rec,
-        sizeof(struct darshan_lustre_record), ver);
+        LUSTRE_RECORD_SIZE(rec->counters[LUSTRE_STRIPE_WIDTH]), ver);
     if(ret < 0)
         return(-1);
@@ -99,6 +117,20 @@ static void darshan_log_print_lustre_record(void *rec, char *file_name,
             lustre_rec->counters[i], file_name, mnt_pt, fs_type);
+    for (i = 0; i < lustre_rec->counters[LUSTRE_STRIPE_WIDTH]; i++ )
+        char strbuf[25];
+        snprintf( strbuf, 25, "LUSTRE_OST_ID_%d", i );
+        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_LUSTRE_MOD],
+            lustre_rec->rank,
+            lustre_rec->rec_id,
+            strbuf,
+            lustre_rec->ost_ids[i],
+            file_name,
+            mnt_pt,
+            fs_type);
     return;
@@ -110,7 +142,8 @@ static void darshan_log_print_lustre_description()
     printf("#   LUSTRE_MDTS: number of MDTs across the entire file system.\n");
     printf("#   LUSTRE_STRIPE_SIZE: stripe size for file in bytes.\n");
     printf("#   LUSTRE_STRIPE_WIDTH: number of OSTs over which file is striped.\n");
-    printf("#   LUSTRE_STRIPE_OFFSET: OBD index of the file's first stripe.\n");
+    printf("#   LUSTRE_STRIPE_OFFSET: OST ID offset specified when the file was created.\n");
+    printf("#   LUSTRE_OST_ID_*: indices of OSTs over which the file is striped.\n");
     DARSHAN_PRINT_HEADER();
@@ -156,6 +189,36 @@ static void darshan_log_print_lustre_record_diff(void *rec1, char *file_name1,
+    /* would it be more or less useful to sort the OST IDs before comparing? */
+    if ( lustre_rec1->counters[LUSTRE_STRIPE_WIDTH] == lustre_rec2->counters[LUSTRE_STRIPE_WIDTH] ) {
+        for (i = 0; i < lustre_rec1->counters[LUSTRE_STRIPE_WIDTH]; i++ )
+            if (lustre_rec1->ost_ids[i] != lustre_rec2->ost_ids[i])
+                char strbuf[25];
+                printf("- ");
+                    lustre_rec1->rank,
+                    lustre_rec1->rec_id,
+                    strbuf,
+                    lustre_rec1->ost_ids[i],
+                    file_name1,
+                printf("+ ");
+                    lustre_rec2->rank,
+                    lustre_rec2->rec_id,
+                    strbuf,
+                    lustre_rec2->ost_ids[i],
+                    file_name2,
     return;
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -20,8 +20,6 @@
  * Options
@@ -211,7 +209,7 @@ int main(int argc, char **argv)
     char *save;
     char buffer[DARSHAN_JOB_METADATA_LEN];
     int empty_mods = 0;
+    char *mod_buf;
     hash_entry_t *file_hash = NULL;
     hash_entry_t *curr = NULL;
@@ -350,6 +348,12 @@ int main(int argc, char **argv)
         memset(pdata.rank_cumul_md_time, 0, sizeof(double)*job.nprocs);
+    if (!mod_buf) {
+        darshan_log_close(fd);
+        return(-1);
@@ -624,6 +628,7 @@ cleanup:
     free(pdata.rank_cumul_io_time);
     free(pdata.rank_cumul_md_time);
+    free(mod_buf);
     /* free record hash data */
     HASH_ITER(hlink, rec_hash, ref, tmp_ref)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/fad7e81662c2b6c1c4a749c9299d6bb65537c022...b51c463b59485b4d3f2abd90f63285ff8d72d06f
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160615/454e9cf5/attachment-0001.html>
More information about the Darshan-commits mailing list
