[Darshan-commits] [Git][darshan/darshan][lustre-mod] 4 commits: forgot to add darshan-lustre.h, which is needed to hook together the module and darshan-core-stub.c
Glenn K. Lockwood
xgitlab at cels.anl.gov
Fri Jun 3 12:39:37 CDT 2016
Glenn K. Lockwood pushed to branch lustre-mod at darshan / darshan
Commits:
6c828abb by Glenn K. Lockwood at 2016-06-03T10:24:19-07:00
3193b2e9 by Glenn K. Lockwood at 2016-06-03T10:34:48-07:00
make ioctl return the full ost map in test app
8aa23fa3 by Glenn K. Lockwood at 2016-06-03T10:37:00-07:00
partly working lustre module supporting ost mapping; shared file agg still doesn't work, and log parsing doesn't either
dc1a9eb9 by Glenn K. Lockwood at 2016-06-03T10:39:14-07:00
add rank shuffling to non-MPI tester
6 changed files:
- darshan-lustre-log-format.h
- + darshan-runtime/darshan-lustre.h
- darshan-runtime/lib/darshan-lustre.c
- darshan-test/2.x/llapi-perf.c
- darshan-test/lustre/Makefile
- darshan-test/lustre/darshan-core-stub.c
Changes:
--- a/darshan-lustre-log-format.h
+++ b/darshan-lustre-log-format.h
@@ -16,12 +16,12 @@
X(LUSTRE_OSTS) \
/* number of MDTs for file system */\
X(LUSTRE_MDTS) \
+ /* index of first OST for file */\
+ X(LUSTRE_STRIPE_OFFSET) \
/* bytes per stripe for file */\
X(LUSTRE_STRIPE_SIZE) \
/* number of stripes (OSTs) for file */\
X(LUSTRE_STRIPE_WIDTH) \
- /* index of first OST for file */\
- X(LUSTRE_STRIPE_OFFSET) \
/* end of counters */\
X(LUSTRE_NUM_INDICES)
@@ -44,6 +44,7 @@ struct darshan_lustre_record
darshan_record_id rec_id;
int64_t rank;
int64_t counters[LUSTRE_NUM_INDICES];
+ int64_t ost_ids[1];
#endif /* __DARSHAN_LUSTRE_LOG_FORMAT_H */
--- /dev/null
+++ b/darshan-runtime/darshan-lustre.h
@@ -0,0 +1,19 @@
+struct lustre_record_runtime
+ struct darshan_lustre_record *record;
+ size_t record_size;
+ UT_hash_handle hlink;
+struct lustre_runtime
+ int record_count; /* number of records defined */
+ size_t record_buffer_max; /* size of the allocated buffer pointed to by record_buffer */
+ size_t record_buffer_used; /* size of the allocated buffer actually used */
+ void *next_free_record; /* pointer to end of record_buffer */
+ void *record_buffer; /* buffer in which records are created */
+ struct lustre_record_runtime *record_runtime_array;
+ struct lustre_record_runtime *record_runtime_hash;
--- a/darshan-runtime/lib/darshan-lustre.c
+++ b/darshan-runtime/lib/darshan-lustre.c
@@ -25,28 +25,9 @@
#include "darshan.h"
#include "darshan-dynamic.h"
+#include "darshan-lustre.h"
-struct lustre_record_runtime
- struct darshan_lustre_record *record;
- UT_hash_handle hlink;
-/* we just use a simple array for storing records. the POSIX module
- * only calls into the Lustre module for new records, so we will never
- * have to search for an existing Lustre record (assuming the Lustre
- * data remains immutable as it is now).
-struct lustre_runtime
- struct darshan_lustre_record *record_array;
- struct lustre_record_runtime *record_runtime_array;
- int record_array_size;
- int record_array_ndx;
- struct lustre_record_runtime *record_hash;
-static struct lustre_runtime *lustre_runtime = NULL;
+struct lustre_runtime *lustre_runtime = NULL;
static pthread_mutex_t lustre_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
static int instrumentation_disabled = 0;
static int my_rank = -1;
@@ -63,20 +44,48 @@ static void lustre_record_reduction_op(void* infile_v, void* inoutfile_v,
#define LUSTRE_LOCK() pthread_mutex_lock(&lustre_runtime_mutex)
#define LUSTRE_UNLOCK() pthread_mutex_unlock(&lustre_runtime_mutex)
+#define LUSTRE_RECORD_SIZE( osts ) ( sizeof(struct darshan_lustre_record) + sizeof(int64_t) * (osts - 1) )
void darshan_instrument_lustre_file(const char* filepath, int fd)
struct lustre_record_runtime *rec_rt;
+ struct darshan_lustre_record *rec;
struct darshan_fs_info fs_info;
int limit_flag;
+ int i;
+ struct lov_user_md *lum;
+ size_t lumsize = sizeof(struct lov_user_md) +
+ LOV_MAX_STRIPE_COUNT * sizeof(struct lov_user_ost_data);
+ size_t rec_size;
LUSTRE_LOCK();
/* make sure the lustre module is already initialized */
lustre_runtime_initialize();
- /* if the array is full, we just back out */
- limit_flag = (lustre_runtime->record_array_ndx >= lustre_runtime->record_array_size);
+ /* if we can't issue ioctl, we have no counter data at all */
+ if ( (lum = calloc(1, lumsize)) == NULL )
+ return;
+ /* find out the OST count of this file so we can allocate memory */
+ lum->lmm_magic = LOV_USER_MAGIC;
+ lum->lmm_stripe_count = LOV_MAX_STRIPE_COUNT;
+ /* -1 means ioctl failed, likely because file isn't on Lustre */
+ if ( ioctl( fd, LL_IOC_LOV_GETSTRIPE, (void *)lum ) == -1 )
+ free(lum);
+ return;
+ rec_size = LUSTRE_RECORD_SIZE( lum->lmm_stripe_count );
+ /* broken out for clarity */
+ void *end_of_new_record = (char*)lustre_runtime->next_free_record + rec_size;
+ void *end_of_rec_buffer = (char*)lustre_runtime->record_buffer + lustre_runtime->record_buffer_max;
+ limit_flag = ( end_of_new_record > end_of_rec_buffer );
/* register a Lustre file record with Darshan */
fs_info.fs_type = -1;
@@ -92,21 +101,20 @@ void darshan_instrument_lustre_file(const char* filepath, int fd)
/* if record id is 0, darshan has no more memory for instrumenting */
if(rec_id == 0)
+ free(lum);
LUSTRE_UNLOCK();
return;
/* search the hash table for this file record, and initialize if not found */
- HASH_FIND(hlink, lustre_runtime->record_hash, &rec_id, sizeof(darshan_record_id), rec_rt );
+ HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &rec_id, sizeof(darshan_record_id), rec_rt );
if ( !rec_rt ) {
- struct darshan_lustre_record *rec;
- struct lov_user_md *lum;
- size_t lumsize = sizeof(struct lov_user_md) +
- LOV_MAX_STRIPE_COUNT * sizeof(struct lov_user_ost_data);
/* allocate a new lustre record and append it to the array */
- rec_rt = &(lustre_runtime->record_runtime_array[lustre_runtime->record_array_ndx]);
- rec_rt->record = &(lustre_runtime->record_array[lustre_runtime->record_array_ndx]);
+ rec_rt = &(lustre_runtime->record_runtime_array[lustre_runtime->record_count]);
+ rec_rt->record = lustre_runtime->next_free_record;
+ rec_rt->record_size = rec_size;
+ lustre_runtime->next_free_record = (char*)(lustre_runtime->next_free_record) + rec_size;
+ lustre_runtime->record_buffer_used += rec_size;
rec = rec_rt->record;
rec->rec_id = rec_id;
rec->rank = my_rank;
@@ -125,24 +133,16 @@ void darshan_instrument_lustre_file(const char* filepath, int fd)
rec->counters[LUSTRE_MDTS] = -1;
- if ( (lum = calloc(1, lumsize)) != NULL ) {
- lum->lmm_magic = LOV_USER_MAGIC;
- /* don't care about the return code for ioctl */
- ioctl( fd, LL_IOC_LOV_GETSTRIPE, (void *)lum );
- rec->counters[LUSTRE_STRIPE_SIZE] = lum->lmm_stripe_size;
- rec->counters[LUSTRE_STRIPE_WIDTH] = lum->lmm_stripe_count;
- rec->counters[LUSTRE_STRIPE_OFFSET] = 0; /* this currently doesn't work; lum->lmm_objects[0].l_ost_idx isn't being populated */
- /* TODO: add explicit list of OSTs */
- free(lum);
- else
- rec->counters[LUSTRE_STRIPE_SIZE] = -1;
- rec->counters[LUSTRE_STRIPE_WIDTH] = -1;
- rec->counters[LUSTRE_STRIPE_OFFSET] = -1;
- HASH_ADD(hlink, lustre_runtime->record_hash, record->rec_id, sizeof(darshan_record_id), rec_rt);
- lustre_runtime->record_array_ndx++;
+ rec->counters[LUSTRE_STRIPE_SIZE] = lum->lmm_stripe_size;
+ rec->counters[LUSTRE_STRIPE_WIDTH] = lum->lmm_stripe_count;
+ rec->counters[LUSTRE_STRIPE_OFFSET] = lum->lmm_stripe_offset;
+ for ( i = 0; i < lum->lmm_stripe_count; i++ )
+ rec->ost_ids[i] = lum->lmm_objects[i].l_ost_idx;
+ free(lum);
+ HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt);
+ lustre_runtime->record_count++;
LUSTRE_UNLOCK();
@@ -152,6 +152,7 @@ void darshan_instrument_lustre_file(const char* filepath, int fd)
static void lustre_runtime_initialize()
int mem_limit;
+ int max_records;
struct darshan_module_funcs lustre_mod_fns =
.begin_shutdown = &lustre_begin_shutdown,
@@ -180,30 +181,34 @@ static void lustre_runtime_initialize()
return;
memset(lustre_runtime, 0, sizeof(*lustre_runtime));
- /* allocate array of Lustre records according to the amount of memory
- * assigned by Darshan
- lustre_runtime->record_array_size = mem_limit / sizeof(struct darshan_lustre_record);
- lustre_runtime->record_array = malloc(lustre_runtime->record_array_size *
- sizeof(struct darshan_lustre_record));
- if(!lustre_runtime->record_array)
+ /* allocate the full size of the memory limit we are given */
+ lustre_runtime->record_buffer= malloc(mem_limit);
+ if(!lustre_runtime->record_buffer)
- lustre_runtime->record_array_size = 0;
+ lustre_runtime->record_buffer_max = 0;
return;
- memset(lustre_runtime->record_array, 0, lustre_runtime->record_array_size *
- lustre_runtime->record_runtime_array = malloc(lustre_runtime->record_array_size *
- sizeof(struct lustre_record_runtime));
+ lustre_runtime->record_buffer_max = mem_limit;
+ lustre_runtime->next_free_record = lustre_runtime->record_buffer;
+ memset(lustre_runtime->record_buffer, 0, lustre_runtime->record_buffer_max);
+ /* Allocate array of Lustre runtime data. We calculate the maximum possible
+ * number of records that will fit into mem_limit by assuming that each
+ * record has the minimum possible OST count, then allocate that many
+ * runtime records. record_buffer will always run out of memory before
+ * we overflow record_runtime_array.
+ max_records = mem_limit / sizeof(struct darshan_lustre_record);
+ lustre_runtime->record_runtime_array =
+ malloc( max_records * sizeof(struct lustre_record_runtime));
if(!lustre_runtime->record_runtime_array)
+ free( lustre_runtime->record_buffer );
return;
- memset(lustre_runtime->record_runtime_array, 0, lustre_runtime->record_array_size *
+ memset(lustre_runtime->record_runtime_array, 0,
+ max_records * sizeof(struct lustre_record_runtime));
return;
@@ -224,6 +229,7 @@ static void lustre_begin_shutdown(void)
return;
+/* XXX - still need to update 5/26/2016 */
static void lustre_get_output_data(
MPI_Comm mod_comm,
darshan_record_id *shared_recs,
@@ -249,7 +255,7 @@ static void lustre_get_output_data(
/* necessary initialization of shared records */
for(i = 0; i < shared_rec_count; i++)
- HASH_FIND(hlink, lustre_runtime->record_hash, &shared_recs[i],
+ HASH_FIND(hlink, lustre_runtime->record_runtime_hash, &shared_recs[i],
sizeof(darshan_record_id), file);
assert(file);
@@ -260,14 +266,14 @@ static void lustre_get_output_data(
* shared files (marked by rank -1) in a contiguous portion at end
* of the array
- qsort(lustre_runtime->record_array, lustre_runtime->record_array_ndx,
- sizeof(struct darshan_lustre_record), lustre_record_compare);
+ sort_lustre_records();
- /* make *send_buf point to the shared files at the end of sorted array */
+ /* make *send_buf point to the shared files at the end of sorted array
red_send_buf =
- &(lustre_runtime->record_array[lustre_runtime->record_array_ndx-shared_rec_count]);
+ &(lustre_runtime->record_runtime_array[lustre_runtime->record_count-shared_rec_count]);
- /* allocate memory for the reduction output on rank 0 */
+ /* allocate memory for the reduction output on rank 0
if(my_rank == 0)
red_recv_buf = malloc(shared_rec_count * sizeof(struct darshan_lustre_record));
@@ -283,26 +289,27 @@ static void lustre_get_output_data(
DARSHAN_MPI_CALL(PMPI_Op_create)(lustre_record_reduction_op, 1, &red_op);
DARSHAN_MPI_CALL(PMPI_Reduce)(red_send_buf, red_recv_buf,
shared_rec_count, red_type, red_op, 0, mod_comm);
- /* clean up reduction state */
+ /* clean up reduction state
if(my_rank == 0)
- int tmp_ndx = lustre_runtime->record_array_ndx - shared_rec_count;
- memcpy(&(lustre_runtime->record_array[tmp_ndx]), red_recv_buf,
+ memcpy(&(lustre_runtime->record_array[lustre_runtime->record_count - shared_rec_count]), red_recv_buf,
free(red_recv_buf);
else
- lustre_runtime->record_array_ndx -= shared_rec_count;
+ lustre_runtime->record_count -= shared_rec_count;
DARSHAN_MPI_CALL(PMPI_Type_free)(&red_type);
DARSHAN_MPI_CALL(PMPI_Op_free)(&red_op);
- *lustre_buf = (void *)(lustre_runtime->record_array);
- *lustre_buf_sz = lustre_runtime->record_array_ndx * sizeof(struct darshan_lustre_record);
+ *lustre_buf = (void *)(lustre_runtime->record_buffer);
+ *lustre_buf_sz = lustre_runtime->record_buffer_used;
return;
@@ -311,9 +318,9 @@ static void lustre_shutdown(void)
assert(lustre_runtime);
- HASH_CLEAR(hlink, lustre_runtime->record_hash);
- free(lustre_runtime->record_array);
+ HASH_CLEAR(hlink, lustre_runtime->record_runtime_hash);
free(lustre_runtime->record_runtime_array);
+ free(lustre_runtime->record_buffer);
free(lustre_runtime);
@@ -323,17 +330,80 @@ static void lustre_shutdown(void)
/* compare function for sorting file records by descending rank */
static int lustre_record_compare(const void* a_p, const void* b_p)
- const struct darshan_lustre_record* a = a_p;
- const struct darshan_lustre_record* b = b_p;
+ const struct lustre_record_runtime* a = a_p;
+ const struct lustre_record_runtime* b = b_p;
- if(a->rank < b->rank)
+ if(a->record->rank < b->record->rank)
return 1;
- if(a->rank > b->rank)
+ if(a->record->rank > b->record->rank)
return -1;
return 0;
+ * Sort the record_runtimes and records by MPI rank to facilitate shared redux.
+ * This requires craftiness and additional heap utilization because the records
+ * (but not record_runtimes) have variable size. Currently has to temporarily
+ * duplicate the entire record_buffer; there is room for more memory-efficient
+ * optimization if this becomes a scalability issue.
+int sort_lustre_records()
+ int i;
+ struct lustre_record_runtime *rec_rt, *tmp_rec_rt;
+ char *new_buf, *p;
+ /* Create a new buffer to store an entire replica of record_buffer. Since
+ * we know the exact size of record_buffer's useful data at this point, we
+ * can allocate the exact amount we need instead of record_buffer_max */
+ new_buf = malloc(lustre_runtime->record_buffer_used);
+ p = new_buf;
+ if ( !new_buf )
+ return 1;
+ /* qsort breaks the hash table, so delete it now to free its memory buffers
+ * and prevent later confusion */
+ HASH_ITER( hlink, lustre_runtime->record_runtime_hash, rec_rt, tmp_rec_rt )
+ HASH_DELETE( hlink, lustre_runtime->record_runtime_hash, rec_rt );
+ /* sort the runtime records, which is has fixed-length elements */
+ qsort(
+ lustre_runtime->record_runtime_array,
+ lustre_runtime->record_count,
+ sizeof(struct lustre_record_runtime),
+ lustre_record_compare
+ /* rebuild the hash and array with the qsorted runtime records */
+ for ( i = 0; i < lustre_runtime->record_count; i++ )
+ rec_rt = &(lustre_runtime->record_runtime_array[i]);
+ HASH_ADD(hlink, lustre_runtime->record_runtime_hash, record->rec_id, sizeof(darshan_record_id), rec_rt );
+ /* create reordered record buffer, then copy it back in place */
+ memcpy( p, rec_rt->record, rec_rt->record_size );
+ /* fix record pointers within each runtime record too - pre-emptively
+ * point them at where they will live in record_buffer after we memcpy
+ * below */
+ rec_rt->record = (struct darshan_lustre_record *)((char*)(lustre_runtime->record_buffer) + (p - new_buf));
+ p += rec_rt->record_size;
+ memcpy(
+ lustre_runtime->record_buffer,
+ new_buf,
+ lustre_runtime->record_buffer_used );
+ free(new_buf);
+ return 0;
/* this is just boilerplate reduction code that isn't currently used */
int *len, MPI_Datatype *datatype)
@@ -374,6 +444,71 @@ static void lustre_record_reduction_op(void* infile_v, void* inoutfile_v,
+ * Dump the memory structure of our records and runtime records
+void print_lustre_runtime( void )
+ int i, j;
+ /* print what we just loaded */
+ rec = (lustre_runtime->record_runtime_array[i]).record;
+ printf( "File %2d\n", i );
+ for ( j = 0; j < LUSTRE_NUM_INDICES; j++ )
+ printf( " Counter %2d: %10ld, addr %ld\n",
+ j,
+ rec->counters[j],
+ (char*)(&(rec->counters[j])) - (char*)(lustre_runtime->record_buffer) );
+ for ( j = 0; j < rec->counters[LUSTRE_STRIPE_WIDTH]; j++ )
+ printf( " Stripe %2d: %10ld, addr %ld\n",
+ j,
+ rec->ost_ids[j],
+ (char*)(&(rec->ost_ids[j])) - (char*)(lustre_runtime->record_buffer) );
+ return;
+ * Dump the order in which records appear in memory
+void print_array( void )
+ int i;
+ struct lustre_record_runtime *rec_rt;
+ printf("*** DUMPING RECORD LIST BY ARRAY SEQUENCE\n");
+ printf( "*** record %d rank %d osts %d\n",
+ rec_rt->record->rec_id,
+ rec_rt->record->rank,
+ rec_rt->record->counters[LUSTRE_STRIPE_WIDTH]);
+void print_hash( void )
+ printf("*** DUMPING RECORD LIST BY HASH SEQUENCE\n");
+ return;
* Local variables:
* c-indent-level: 4
* c-basic-offset: 4
--- a/darshan-test/2.x/llapi-perf.c
+++ b/darshan-test/2.x/llapi-perf.c
@@ -158,6 +158,7 @@ int main(int argc, char **argv)
else if ( opt_ioctl )
ret = ioctl( fd, LL_IOC_LOV_GETSTRIPE, (void *)lum );
#ifdef DEBUG
--- a/darshan-test/lustre/Makefile
+++ b/darshan-test/lustre/Makefile
@@ -1,6 +1,6 @@
.PHONY: clean
BINS = darshan-tester darshan-tester-mpi
-OBJS = darshan-core-stub.o darshan-lustre.o
+OBJS = darshan-lustre.o darshan-core-stub.o
CFLAGS = -O0 -g -I../.. -I../../darshan-runtime
### Include -I. when building non-MPI tests to include the mpi.h stub header
--- a/darshan-test/lustre/darshan-core-stub.c
+++ b/darshan-test/lustre/darshan-core-stub.c
@@ -10,6 +10,8 @@
#include <stdlib.h>
#include <fcntl.h>
* Global variables
@@ -20,6 +22,7 @@ static struct darshan_module_funcs mod_funcs;
* Import routines from Lustre module
+extern struct lustre_runtime *lustre_runtime;
void darshan_core_register_record(
void *name,
@@ -90,6 +93,9 @@ int main( int argc, char **argv )
close(fd);
+ (lustre_runtime->record_runtime_array[i]).record->rank = rand() % 10;
print_lustre_runtime();
darshan_core_shutdown();
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/a61ebca2580f403acfd8c472d2fbb1356003a6b3...dc1a9eb90c044ecb054cc50e7400c2bc3a9080e7
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160603/c71e77f3/attachment-0001.html>
More information about the Darshan-commits
