[Darshan-commits] [Git][darshan/darshan][dev-stdio-utils] stdio in op counts table
Philip Carns
xgitlab at cels.anl.gov
Thu Jul 7 20:44:54 CDT 2016
Philip Carns pushed to branch dev-stdio-utils at darshan / darshan
Commits:
4abb4a3c by Phil Carns at 2016-07-07T21:44:38-04:00
1 changed file:
- darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
Changes:
--- a/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
+++ b/darshan-util/darshan-job-summary/bin/darshan-job-summary.pl.in
@@ -425,14 +425,28 @@ close TIME_SUMMARY;
# counts of operations
open(PSX_OP_COUNTS, ">$tmp_dir/posix-op-counts.dat") || die("error opening output file: $!\n");
print PSX_OP_COUNTS "# <operation>, <POSIX count>\n";
-print PSX_OP_COUNTS
- "Read, ", $summary{POSIX_READS} + $summary{POSIX_FREADS}, "\n",
- "Write, ", $summary{POSIX_WRITES} + $summary{POSIX_FWRITES}, "\n",
- "Open, ", $summary{POSIX_OPENS} + $summary{POSIX_FOPENS}, "\n",
- "Stat, ", $summary{POSIX_STATS}, "\n",
- "Seek, ", $summary{POSIX_SEEKS}, "\n",
- "Mmap, ", $summary{POSIX_MMAPS}, "\n",
- "Fsync, ", $summary{POSIX_FSYNCS} + $summary{POSIX_FDSYNCS}, "\n";
+if (defined $summary{POSIX_OPENS})
+ print PSX_OP_COUNTS
+ "Read, ", $summary{POSIX_READS}, "\n",
+ "Write, ", $summary{POSIX_WRITES}, "\n",
+ "Open, ", $summary{POSIX_OPENS}, "\n",
+ "Stat, ", $summary{POSIX_STATS}, "\n",
+ "Seek, ", $summary{POSIX_SEEKS}, "\n",
+ "Mmap, ", $summary{POSIX_MMAPS}, "\n",
+ "Fsync, ", $summary{POSIX_FSYNCS} + $summary{POSIX_FDSYNCS}, "\n";
+else
+ "Read, 0\n",
+ "Write, 0\n",
+ "Open, 0\n",
+ "Stat, 0\n",
+ "Seek, 0\n",
+ "Mmap, 0\n",
+ "Fsync, 0\n";
close PSX_OP_COUNTS;
if (defined $summary{MPIIO_INDEP_OPENS})
@@ -451,6 +465,21 @@ if (defined $summary{MPIIO_INDEP_OPENS})
close MPI_OP_COUNTS;
+if (defined $summary{STDIO_OPENS})
+ open(STDIO_OP_COUNTS, ">$tmp_dir/stdio-op-counts.dat") || die("error opening output file: $!\n");
+ print STDIO_OP_COUNTS "# <operation>, <STDIO count>\n";
+ "Read, ", $summary{STDIO_READS}, "\n",
+ "Write, ", $summary{STDIO_WRITES}, "\n",
+ "Open, ", $summary{STDIO_OPENS}, "\n",
+ "Stat, 0\n",
+ "Seek, ", $summary{STDIO_SEEKS}, "\n",
+ "Mmap, 0\n",
+ "Fsync, ", $summary{STDIO_FLUSHES}, "\n";
+ close STDIO_OP_COUNTS;
# histograms of reads and writes (for POSIX and MPI-IO modules)
open (IO_HIST, ">$tmp_dir/posix-access-hist.dat") || die("error opening output file: $!\n");
print IO_HIST "# <size_range>, <POSIX_reads>, <POSIX_writes>\n";
@@ -984,6 +1013,18 @@ if (defined $summary{MPIIO_INDEP_OPENS})
close OP_COUNTS_PLT;
+# do any extra work needed for plotting stdio graphs
+ open(OP_COUNTS_PLT, ">>$tmp_dir/op-counts-eps.gplt") || die("error opening output file: $!\n");
+ my $tmp_sz = -s "$tmp_dir/op-counts-eps.gplt";
+ # overwrite existing newline
+ truncate(OP_COUNTS_PLT, $tmp_sz-1);
+ print OP_COUNTS_PLT ", \\
+ \"stdio-op-counts.dat\" using 2:xtic(1) title \"STDIO\"\n";
+ close OP_COUNTS_PLT;
# execute base gnuplot scripts
system "$gnuplot time-summary-eps.gplt";
system "$epstopdf time-summary.eps";
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/4abb4a3c72ecb42bba2f2a9b56159e85c9002eff
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160707/9f4d5ad2/attachment-0001.html>
More information about the Darshan-commits
