[Darshan-commits] [Git][darshan/darshan][dev-stdio-utils] implement --perf mode for stdio module
Philip Carns
xgitlab at cels.anl.gov
Thu Jul 7 19:42:04 CDT 2016
Philip Carns pushed to branch dev-stdio-utils at darshan / darshan
Commits:
e9d2b236 by Phil Carns at 2016-07-07T20:41:49-04:00
1 changed file:
- darshan-util/darshan-parser.c
Changes:
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -113,6 +113,8 @@ void mpiio_calc_file(hash_entry_t *file_hash, file_data_t *fdata);
void mpiio_print_total_file(struct darshan_mpiio_file *mfile);
void mpiio_file_list(hash_entry_t *file_hash, struct darshan_name_record_ref *name_hash, int detail_flag);
+void stdio_accum_perf(struct darshan_stdio_file *pfile, perf_data_t *pdata);
void calc_perf(perf_data_t *pdata, int64_t nprocs);
int usage (char *exename)
@@ -389,9 +391,10 @@ int main(int argc, char **argv)
"for module %s, SKIPPING.\n", darshan_module_names[i]);
continue;
- /* currently we only do base parsing for non MPI & POSIX modules */
- else if((i != DARSHAN_POSIX_MOD) && (i != DARSHAN_MPIIO_MOD) &&
- !(mask & OPTION_BASE))
+ /* currently only POSIX, MPIIO, and STDIO modules support non-base
+ * parsing
+ else if((i != DARSHAN_POSIX_MOD) && (i != DARSHAN_MPIIO_MOD) && (i != DARSHAN_STDIO_MOD) && !(mask & OPTION_BASE))
continue;
/* this module has data to be parsed and printed */
@@ -470,10 +473,10 @@ int main(int argc, char **argv)
mnt_pt, fs_type, fd->mod_ver[i]);
- /* we calculate more detailed stats for POSIX and MPI-IO modules,
+ /* we calculate more detailed stats for POSIX, MPI-IO, and STDIO modules,
* if the parser is executed with more than the base option
- if(i != DARSHAN_POSIX_MOD && i != DARSHAN_MPIIO_MOD)
+ if(i != DARSHAN_POSIX_MOD && i != DARSHAN_MPIIO_MOD && i != DARSHAN_STDIO_MOD)
continue;
HASH_FIND(hlink, file_hash, &(base_rec->id), sizeof(darshan_record_id), hfile);
@@ -510,6 +513,10 @@ int main(int argc, char **argv)
mpiio_accum_file((struct darshan_mpiio_file*)mod_buf, hfile, job.nprocs);
mpiio_accum_perf((struct darshan_mpiio_file*)mod_buf, &pdata);
+ else if(i == DARSHAN_STDIO_MOD)
+ stdio_accum_perf((struct darshan_stdio_file*)mod_buf, &pdata);
memset(mod_buf, 0, DEF_MOD_BUF_SIZE);
@@ -523,7 +530,7 @@ int main(int argc, char **argv)
continue;
/* Total Calc */
@@ -1042,6 +1049,89 @@ void mpiio_accum_file(struct darshan_mpiio_file *mfile,
return;
+ perf_data_t *pdata)
+ pdata->total_bytes += pfile->counters[STDIO_BYTES_READ] +
+ pfile->counters[STDIO_BYTES_WRITTEN];
+ * Calculation of Shared File Time
+ * Four Methods!!!!
+ * by_cumul: sum time counters and divide by nprocs
+ * (inaccurate if lots of variance between procs)
+ * by_open: difference between timestamp of open and close
+ * (inaccurate if file is left open without i/o happening)
+ * by_open_lastio: difference between timestamp of open and the
+ * timestamp of last i/o
+ * (similar to above but fixes case where file is left
+ * open after io is complete)
+ * by_slowest: use slowest rank time from log data
+ * (most accurate but requires newer log version)
+ if(pfile->base_rec.rank == -1)
+ /* by_open */
+ if(pfile->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] >
+ pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
+ pdata->shared_time_by_open +=
+ pfile->fcounters[STDIO_F_CLOSE_END_TIMESTAMP] -
+ pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP];
+ /* by_open_lastio */
+ if(pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] >
+ pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP])
+ /* be careful: file may have been opened but not read or written */
+ if(pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] > pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
+ pdata->shared_time_by_open_lastio +=
+ pfile->fcounters[STDIO_F_READ_END_TIMESTAMP] -
+ else
+ if(pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP] > pfile->fcounters[STDIO_F_OPEN_START_TIMESTAMP])
+ pfile->fcounters[STDIO_F_WRITE_END_TIMESTAMP] -
+ pdata->shared_time_by_cumul +=
+ pfile->fcounters[STDIO_F_META_TIME] +
+ pfile->fcounters[STDIO_F_READ_TIME] +
+ pfile->fcounters[STDIO_F_WRITE_TIME];
+ pdata->shared_meta_time += pfile->fcounters[STDIO_F_META_TIME];
+ /* by_slowest */
+ pdata->shared_time_by_slowest +=
+ pfile->fcounters[STDIO_F_SLOWEST_RANK_TIME];
+ * Calculation of Unique File Time
+ * record the data for each file and sum it
+ else
+ pdata->rank_cumul_io_time[pfile->base_rec.rank] +=
+ (pfile->fcounters[STDIO_F_META_TIME] +
+ pfile->fcounters[STDIO_F_WRITE_TIME]);
+ pdata->rank_cumul_md_time[pfile->base_rec.rank] +=
+ pfile->fcounters[STDIO_F_META_TIME];
+ return;
void posix_accum_perf(struct darshan_posix_file *pfile,
perf_data_t *pdata)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/e9d2b236c62769cb3cff212e49a2960b5d3bbb61
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160707/f01ec3c8/attachment-0001.html>
More information about the Darshan-commits
