[Darshan-commits] [Git][darshan/darshan][dev-modular] fix some small configure bugs for cray systems
Shane Snyder
xgitlab at cels.anl.gov
Wed Jan 20 13:09:19 CST 2016
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
92ef4cdd by Shane Snyder at 2016-01-20T11:08:32Z
3 changed files:
- darshan-runtime/configure
- darshan-runtime/configure.in
- darshan-runtime/darshan-runtime-config.h.in
Changes:
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -1,20 +1,18 @@
#! /bin/sh
# Guess values for system-dependent variables and create Makefiles.
-# Generated by GNU Autoconf 2.69 for darshan-runtime 3.0.0-pre3.
-# Copyright (C) 1992-1996, 1998-2012 Free Software Foundation, Inc.
+# Generated by GNU Autoconf 2.63 for darshan-runtime 3.0.0-pre3.
+# Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
+# 2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
# This configure script is free software; the Free Software Foundation
# gives unlimited permission to copy, distribute and modify it.
-## M4sh Initialization. ##
+## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
emulate sh
NULLCMD=:
# Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -22,15 +20,23 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in #(
- *posix*) :
- set -o posix ;; #(
+ case `(set -o) 2>/dev/null` in
+ *posix*) set -o posix ;;
esac
fi
+# PATH needs CR
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
as_nl='
export as_nl
@@ -38,13 +44,7 @@ export as_nl
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-# Prefer a ksh shell builtin over an external printf program on Solaris,
-# but without wasting forks for bash or zsh.
-if test -z "$BASH_VERSION$ZSH_VERSION" \
- && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='print -r --'
- as_echo_n='print -rn --'
-elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
as_echo='printf %s\n'
as_echo_n='printf %s'
else
@@ -55,7 +55,7 @@ else
as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
as_echo_n_body='eval
arg=$1;
- case $arg in #(
+ case $arg in
*"$as_nl"*)
expr "X$arg" : "X\\(.*\\)$as_nl";
arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -78,6 +78,13 @@ if test "${PATH_SEPARATOR+set}" != set; then
fi
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+ as_unset=unset
+else
+ as_unset=false
+fi
# IFS
# We need space, tab and new line, in precisely that order. Quoting is
@@ -87,16 +94,15 @@ fi
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-as_myself=
-case $0 in #((
+case $0 in
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
- done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
IFS=$as_save_IFS
@@ -108,16 +114,12 @@ if test "x$as_myself" = x; then
fi
if test ! -f "$as_myself"; then
$as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- exit 1
+ { (exit 1); exit 1; }
fi
-# Unset variables that we do not need and which cause bugs (e.g. in
-# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
-# suppresses any "Segmentation fault" message there. '((' could
-# trigger a bug in pdksh 5.2.14.
-for as_var in BASH_ENV ENV MAIL MAILPATH
-do eval test x\${$as_var+set} = xset \
- && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
+# Work around bugs in pre-3.0 UWIN ksh.
+for as_var in ENV MAIL MAILPATH
+do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
done
PS1='$ '
PS2='> '
@@ -129,344 +131,330 @@ export LC_ALL
LANGUAGE=C
export LANGUAGE
+# Required to use basename.
+if expr a : '\(a\)' >/dev/null 2>&1 &&
+ test "X`expr 00001 : '.*\(...\)'`" = X001; then
+ as_expr=expr
+else
+ as_expr=false
+fi
+if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
+ as_basename=basename
+else
+ as_basename=false
+fi
+# Name of the executable.
+as_me=`$as_basename -- "$0" ||
+$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
+ X"$0" : 'X\(//\)$' \| \
+ X"$0" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X/"$0" |
+ sed '/^.*\/\([^/][^/]*\)\/*$/{
+ s//\1/
+ q
+ /^X\/\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\/\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
# CDPATH.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# Use a proper internal environment variable to ensure we don't fall
- # into an infinite loop, continuously re-executing ourselves.
- if test x"${_as_can_reexec}" != xno && test "x$CONFIG_SHELL" != x; then
- _as_can_reexec=no; export _as_can_reexec;
- # We cannot yet assume a decent shell, so we have to provide a
-# neutralization value for shells without unset; and this also
-# works around shells that cannot unset nonexistent variables.
-# Preserve -v and -x to the replacement shell.
-BASH_ENV=/dev/null
-ENV=/dev/null
-(unset BASH_ENV) >/dev/null 2>&1 && unset BASH_ENV ENV
-case $- in # ((((
- *v*x* | *x*v* ) as_opts=-vx ;;
- *v* ) as_opts=-v ;;
- *x* ) as_opts=-x ;;
- * ) as_opts= ;;
-esac
-exec $CONFIG_SHELL $as_opts "$as_myself" ${1+"$@"}
-# Admittedly, this is quite paranoid, since all the known shells bail
-# out after a failed `exec'.
-$as_echo "$0: could not re-execute with $CONFIG_SHELL" >&2
-as_fn_exit 255
- fi
- # We don't want this to propagate to other subprocesses.
- { _as_can_reexec=; unset _as_can_reexec;}
+$as_unset CDPATH
if test "x$CONFIG_SHELL" = x; then
- as_bourne_compatible="if test -n \"\${ZSH_VERSION+set}\" && (emulate sh) >/dev/null 2>&1; then :
- emulate sh
- NULLCMD=:
- # Pre-4.2 versions of Zsh do word splitting on \${1+\"\$@\"}, which
- # is contrary to our usage. Disable this feature.
- alias -g '\${1+\"\$@\"}'='\"\$@\"'
- setopt NO_GLOB_SUBST
+ if (eval ":") 2>/dev/null; then
+ as_have_required=yes
else
- case \`(set -o) 2>/dev/null\` in #(
- *posix*) :
-esac
+ as_have_required=no
fi
- as_required="as_fn_return () { (exit \$1); }
-as_fn_success () { as_fn_return 0; }
-as_fn_failure () { as_fn_return 1; }
-as_fn_ret_success () { return 0; }
-as_fn_ret_failure () { return 1; }
+ if test $as_have_required = yes && (eval ":
+(as_func_return () {
+ (exit \$1)
+as_func_success () {
+ as_func_return 0
+as_func_failure () {
+ as_func_return 1
+as_func_ret_success () {
+ return 0
+as_func_ret_failure () {
+ return 1
exitcode=0
-as_fn_success || { exitcode=1; echo as_fn_success failed.; }
-as_fn_failure && { exitcode=1; echo as_fn_failure succeeded.; }
-as_fn_ret_success || { exitcode=1; echo as_fn_ret_success failed.; }
-as_fn_ret_failure && { exitcode=1; echo as_fn_ret_failure succeeded.; }
-if ( set x; as_fn_ret_success y && test x = \"\$1\" ); then :
-else
- exitcode=1; echo positional parameters were not saved.
-fi
-test x\$exitcode = x0 || exit 1
-test -x / || exit 1"
- as_suggested=" as_lineno_1=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_1a=\$LINENO
- as_lineno_2=";as_suggested=$as_suggested$LINENO;as_suggested=$as_suggested" as_lineno_2a=\$LINENO
- eval 'test \"x\$as_lineno_1'\$as_run'\" != \"x\$as_lineno_2'\$as_run'\" &&
- test \"x\`expr \$as_lineno_1'\$as_run' + 1\`\" = \"x\$as_lineno_2'\$as_run'\"' || exit 1
-test \$(( 1 + 1 )) = 2 || exit 1"
- if (eval "$as_required") 2>/dev/null; then :
- as_have_required=yes
+if as_func_success; then
else
- as_have_required=no
+ exitcode=1
+ echo as_func_success failed.
+fi
+if as_func_failure; then
+ exitcode=1
+ echo as_func_failure succeeded.
fi
- if test x$as_have_required = xyes && (eval "$as_suggested") 2>/dev/null; then :
+if as_func_ret_success; then
else
- as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
-as_found=false
+ exitcode=1
+ echo as_func_ret_success failed.
+fi
+if as_func_ret_failure; then
+ exitcode=1
+ echo as_func_ret_failure succeeded.
+fi
+if ( set x; as_func_ret_success y && test x = \"\$1\" ); then
+else
+ exitcode=1
+ echo positional parameters were not saved.
+fi
+test \$exitcode = 0) || { (exit 1); exit 1; }
+ as_lineno_1=\$LINENO
+ as_lineno_2=\$LINENO
+ test \"x\$as_lineno_1\" != \"x\$as_lineno_2\" &&
+ test \"x\`expr \$as_lineno_1 + 1\`\" = \"x\$as_lineno_2\") || { (exit 1); exit 1; }
+") 2> /dev/null; then
+else
+ as_candidate_shells=
+ as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in /bin$PATH_SEPARATOR/usr/bin$PATH_SEPARATOR$PATH
do
IFS=$as_save_IFS
- as_found=:
- case $as_dir in #(
+ case $as_dir in
for as_base in sh bash ksh sh5; do
- # Try only shells that exist, to save several forks.
- as_shell=$as_dir/$as_base
- if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
- { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$as_shell"; } 2>/dev/null; then :
- CONFIG_SHELL=$as_shell as_have_required=yes
- if { $as_echo "$as_bourne_compatible""$as_suggested" | as_run=a "$as_shell"; } 2>/dev/null; then :
- break 2
-fi
-fi
+ as_candidate_shells="$as_candidate_shells $as_dir/$as_base"
done;;
esac
- as_found=false
done
-$as_found || { if { test -f "$SHELL" || test -f "$SHELL.exe"; } &&
- { $as_echo "$as_bourne_compatible""$as_required" | as_run=a "$SHELL"; } 2>/dev/null; then :
- CONFIG_SHELL=$SHELL as_have_required=yes
-fi; }
IFS=$as_save_IFS
- if test "x$CONFIG_SHELL" != x; then :
- export CONFIG_SHELL
-BASH_ENV=/dev/null
-ENV=/dev/null
-case $- in # ((((
- * ) as_opts= ;;
+ for as_shell in $as_candidate_shells $SHELL; do
+ # Try only shells that exist, to save several forks.
+ if { test -f "$as_shell" || test -f "$as_shell.exe"; } &&
+ { ("$as_shell") 2> /dev/null <<\_ASEOF
+ emulate sh
+ NULLCMD=:
+ # Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
+ # is contrary to our usage. Disable this feature.
+ alias -g '${1+"$@"}'='"$@"'
+ setopt NO_GLOB_SUBST
+else
esac
-exit 255
-fi
- if test x$as_have_required = xno; then :
- $as_echo "$0: This script requires a shell more modern than all"
- $as_echo "$0: the shells that I found on your system."
- if test x${ZSH_VERSION+set} = xset ; then
- $as_echo "$0: In particular, zsh $ZSH_VERSION has bugs and should"
- $as_echo "$0: be upgraded to zsh 4.3.4 or later."
- else
- $as_echo "$0: Please tell bug-autoconf at gnu.org about your system,
-$0: including any error possibly output before this
-$0: message. Then install a modern shell, or manually run
-$0: the script under such a shell if you do have one."
- fi
- exit 1
-fi
-fi
fi
-SHELL=${CONFIG_SHELL-/bin/sh}
-export SHELL
-# Unset more variables known to interfere with behavior of common tools.
-CLICOLOR_FORCE= GREP_OPTIONS=
-unset CLICOLOR_FORCE GREP_OPTIONS
-## M4sh Shell Functions. ##
-# as_fn_unset VAR
-# Portably unset VAR.
-as_fn_unset ()
- { eval $1=; unset $1;}
-as_unset=as_fn_unset
-# as_fn_set_status STATUS
-# Set $? to STATUS, without forking.
-as_fn_set_status ()
- return $1
-} # as_fn_set_status
+_ASEOF
+}; then
+ CONFIG_SHELL=$as_shell
+ if { "$as_shell" 2> /dev/null <<\_ASEOF
+ emulate sh
+ NULLCMD=:
+else
+esac
-# as_fn_exit STATUS
-# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
-as_fn_exit ()
- set +e
- as_fn_set_status $1
- exit $1
-} # as_fn_exit
-# as_fn_mkdir_p
-# Create "$as_dir" as a directory, including parents if necessary.
-as_fn_mkdir_p ()
+fi
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || eval $as_mkdir_p || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
+ (exit $1)
+ as_func_return 0
+ as_func_return 1
+ return 0
+ return 1
-} # as_fn_mkdir_p
+exitcode=0
+else
+ exitcode=1
+fi
-# as_fn_executable_p FILE
-# Test if FILE is an executable regular file.
-as_fn_executable_p ()
- test -f "$1" && test -x "$1"
-} # as_fn_executable_p
-# as_fn_append VAR VALUE
-# Append the text in VALUE to the end of the definition contained in VAR. Take
-# advantage of any shell optimizations that allow amortized linear growth over
-# repeated appends, instead of the typical quadratic growth present in naive
-# implementations.
-if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
- eval 'as_fn_append ()
- eval $1+=\$2
+ exitcode=1
+fi
else
- as_fn_append ()
- eval $1=\$$1\$2
-fi # as_fn_append
-# as_fn_arith ARG...
-# Perform arithmetic evaluation on the ARGs, and store the result in the
-# global $as_val. Take advantage of shells that can avoid forks. The arguments
-# must be portable across $(()) and expr.
-if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
- eval 'as_fn_arith ()
- as_val=$(( $* ))
+ exitcode=1
+fi
+ exitcode=1
+fi
+if ( set x; as_func_ret_success y && test x = "$1" ); then
else
- as_fn_arith ()
- as_val=`expr "$@" || test $? -eq 1`
-fi # as_fn_arith
+ exitcode=1
+fi
+test $exitcode = 0) || { (exit 1); exit 1; }
-# as_fn_error STATUS ERROR [LINENO LOG_FD]
-# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
-# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
-# script with STATUS, using 1 if that was 0.
-as_fn_error ()
- as_status=$1; test $as_status -eq 0 && as_status=1
- if test "$4"; then
- as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
- fi
- $as_echo "$as_me: error: $2" >&2
- as_fn_exit $as_status
-} # as_fn_error
+ as_lineno_1=$LINENO
+ as_lineno_2=$LINENO
+ test "x$as_lineno_1" != "x$as_lineno_2" &&
+ test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2") || { (exit 1); exit 1; }
-if expr a : '\(a\)' >/dev/null 2>&1 &&
- test "X`expr 00001 : '.*\(...\)'`" = X001; then
- as_expr=expr
+_ASEOF
+}; then
+ break
+fi
+fi
+ done
+ if test "x$CONFIG_SHELL" != x; then
+ for as_var in BASH_ENV ENV
+ do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
+ done
+ export CONFIG_SHELL
+ exec "$CONFIG_SHELL" "$as_myself" ${1+"$@"}
+fi
+ if test $as_have_required = no; then
+ echo This script requires a shell more modern than all the
+ echo shells that I found on your system. Please install a
+ echo modern shell, or manually run the script under such a
+ echo shell if you do have one.
+fi
+fi
+fi
+(eval "as_func_return () {
+ (exit \$1)
+ as_func_return 0
+ as_func_return 1
+ return 0
+ return 1
+exitcode=0
else
- as_expr=false
+ exitcode=1
fi
-if (basename -- /) >/dev/null 2>&1 && test "X`basename -- / 2>&1`" = "X/"; then
- as_basename=basename
+ exitcode=1
+fi
else
- as_basename=false
+ exitcode=1
fi
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
+ exitcode=1
+fi
else
- as_dirname=false
+ exitcode=1
fi
-as_me=`$as_basename -- "$0" ||
-$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
- X"$0" : 'X\(//\)$' \| \
- X"$0" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X/"$0" |
- sed '/^.*\/\([^/][^/]*\)\/*$/{
- s//\1/
- q
- /^X\/\(\/\/\)$/{
- s//\1/
- q
- /^X\/\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
+test \$exitcode = 0") || {
+ echo No shell found that supports shell functions.
+ echo Please tell bug-autoconf at gnu.org about your system,
+ echo including any error possibly output before this message.
+ echo This can help us improve future autoconf versions.
+ echo Configuration will now proceed without shell functions.
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
- as_lineno_1=$LINENO as_lineno_1a=$LINENO
- as_lineno_2=$LINENO as_lineno_2a=$LINENO
- eval 'test "x$as_lineno_1'$as_run'" != "x$as_lineno_2'$as_run'" &&
- test "x`expr $as_lineno_1'$as_run' + 1`" = "x$as_lineno_2'$as_run'"' || {
- # Blame Lee E. McMahon (1931-1989) for sed's syntax. :-)
+ test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
+ # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+ # uniformly replaced by the line number. The first 'sed' inserts a
+ # line-number line after each line using $LINENO; the second 'sed'
+ # does the real work. The second script uses 'N' to pair each
+ # line-number line with the line containing $LINENO, and appends
+ # trailing '-' during substitution so that $LINENO is not a special
+ # case at line end.
+ # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+ # scripts with optimization help from Paolo Bonzini. Blame Lee
+ # E. McMahon (1931-1989) for sed's syntax. :-)
sed -n '
p
/[$]LINENO/=
@@ -483,12 +471,9 @@ as_cr_alnum=$as_cr_Letters$as_cr_digits
s/-\n.*//
' >$as_me.lineno &&
chmod +x "$as_me.lineno" ||
- { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2; as_fn_exit 1; }
+ { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
+ { (exit 1); exit 1; }; }
- # If we had to re-execute with $CONFIG_SHELL, we're ensured to have
- # already done that, so ensure we don't try to do so again and fall
- # in an infinite loop. This has already happened in practice.
# Don't try to exec as it changes $[0], causing all sort of problems
# (the dirname of $[0] is not the place where we might find the
# original and so on. Autoconf is especially sensitive to this).
@@ -497,18 +482,29 @@ as_cr_alnum=$as_cr_Letters$as_cr_digits
exit
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
+else
+ as_dirname=false
+fi
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in #(((((
+case `echo -n x` in
-n*)
- case `echo 'xy\c'` in
+ case `echo 'x\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- xy) ECHO_C='\c';;
- *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
- ECHO_T=' ';;
+ *) ECHO_C='\c';;
esac;;
ECHO_N='-n';;
esac
+ as_expr=expr
+else
+ as_expr=false
+fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
@@ -523,29 +519,49 @@ if (echo >conf$$.file) 2>/dev/null; then
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -pR'.
+ # In both cases, we have to default to `cp -p'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
if mkdir -p . 2>/dev/null; then
- as_mkdir_p='mkdir -p "$as_dir"'
+ as_mkdir_p=:
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-as_test_x='test -x'
-as_executable_p=as_fn_executable_p
+if test -x / >/dev/null 2>&1; then
+ as_test_x='test -x'
+else
+ if ls -dL / >/dev/null 2>&1; then
+ as_ls_L_option=L
+ else
+ as_ls_L_option=
+ fi
+ as_test_x='
+ eval sh -c '\''
+ if test -d "$1"; then
+ test -d "$1/.";
+ else
+ case $1 in
+ -*)set "./$1";;
+ esac;
+ case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
+ ???[sx]*):;;*)false;;esac;fi
+ '\'' sh
+fi
+as_executable_p=$as_test_x
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -554,11 +570,11 @@ as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
-test -n "$DJDIR" || exec 7<&0 </dev/null
-exec 6>&1
+exec 7<&0 </dev/null 6>&1
# Name of the host.
-# hostname on some systems (SVR3.2, old GNU/Linux) returns a bogus exit status,
+# hostname on some systems (SVR3.2, Linux) returns a bogus exit status,
# so uname gets run too.
ac_hostname=`(hostname || uname -n) 2>/dev/null | sed 1q`
@@ -573,6 +589,7 @@ cross_compiling=no
subdirs=
MFLAGS=
MAKEFLAGS=
+SHELL=${CONFIG_SHELL-/bin/sh}
# Identity of this package.
PACKAGE_NAME='darshan-runtime'
@@ -580,7 +597,6 @@ PACKAGE_TARNAME='darshan-runtime'
PACKAGE_VERSION='3.0.0-pre3'
PACKAGE_STRING='darshan-runtime 3.0.0-pre3'
PACKAGE_BUGREPORT=''
-PACKAGE_URL=''
ac_unique_file="darshan.h"
# Factoring default headers for most tests.
@@ -672,7 +688,6 @@ bindir
program_transform_name
prefix
exec_prefix
-PACKAGE_URL
PACKAGE_BUGREPORT
PACKAGE_STRING
PACKAGE_VERSION
@@ -766,9 +781,8 @@ do
fi
case $ac_option in
- *=?*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
- *=) ac_optarg= ;;
- *) ac_optarg=yes ;;
+ *=*) ac_optarg=`expr "X$ac_option" : '[^=]*=\(.*\)'` ;;
+ *) ac_optarg=yes ;;
esac
# Accept the important Cygnus configure options, so we can diagnose typos.
@@ -813,7 +827,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*disable-\(.*\)'`
# Reject names that are not valid shell variable names.
expr "x$ac_useropt" : ".*[^-+._$as_cr_alnum]" >/dev/null &&
- as_fn_error $? "invalid feature name: $ac_useropt"
+ { $as_echo "$as_me: error: invalid feature name: $ac_useropt" >&2
ac_useropt_orig=$ac_useropt
ac_useropt=`$as_echo "$ac_useropt" | sed 's/[-+.]/_/g'`
case $ac_user_opts in
@@ -839,7 +854,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*enable-\([^=]*\)'`
@@ -1043,7 +1059,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*with-\([^=]*\)'`
- as_fn_error $? "invalid package name: $ac_useropt"
+ { $as_echo "$as_me: error: invalid package name: $ac_useropt" >&2
@@ -1059,7 +1076,8 @@ do
ac_useropt=`expr "x$ac_option" : 'x-*without-\(.*\)'`
@@ -1089,17 +1107,17 @@ do
| --x-librar=* | --x-libra=* | --x-libr=* | --x-lib=* | --x-li=* | --x-l=*)
x_libraries=$ac_optarg ;;
- -*) as_fn_error $? "unrecognized option: \`$ac_option'
-Try \`$0 --help' for more information"
+ -*) { $as_echo "$as_me: error: unrecognized option: $ac_option
+Try \`$0 --help' for more information." >&2
ac_envvar=`expr "x$ac_option" : 'x\([^=]*\)='`
- case $ac_envvar in #(
- '' | [0-9]* | *[!_$as_cr_alnum]* )
- as_fn_error $? "invalid variable name: \`$ac_envvar'" ;;
- esac
+ expr "x$ac_envvar" : ".*[^_$as_cr_alnum]" >/dev/null &&
+ { $as_echo "$as_me: error: invalid variable name: $ac_envvar" >&2
eval $ac_envvar=\$ac_optarg
export $ac_envvar ;;
@@ -1108,7 +1126,7 @@ Try \`$0 --help' for more information"
$as_echo "$as_me: WARNING: you should use --build, --host, --target" >&2
expr "x$ac_option" : ".*[^-._$as_cr_alnum]" >/dev/null &&
$as_echo "$as_me: WARNING: invalid host type: $ac_option" >&2
- : "${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}"
+ : ${build_alias=$ac_option} ${host_alias=$ac_option} ${target_alias=$ac_option}
esac
@@ -1116,13 +1134,15 @@ done
if test -n "$ac_prev"; then
ac_option=--`echo $ac_prev | sed 's/_/-/g'`
- as_fn_error $? "missing argument to $ac_option"
+ { $as_echo "$as_me: error: missing argument to $ac_option" >&2
fi
if test -n "$ac_unrecognized_opts"; then
case $enable_option_checking in
no) ;;
- fatal) as_fn_error $? "unrecognized options: $ac_unrecognized_opts" ;;
+ fatal) { $as_echo "$as_me: error: unrecognized options: $ac_unrecognized_opts" >&2
+ { (exit 1); exit 1; }; } ;;
*) $as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2 ;;
esac
fi
@@ -1145,7 +1165,8 @@ do
[\\/$]* | ?:[\\/]* ) continue;;
NONE | '' ) case $ac_var in *prefix ) continue;; esac;;
esac
- as_fn_error $? "expected an absolute directory name for --$ac_var: $ac_val"
+ { $as_echo "$as_me: error: expected an absolute directory name for --$ac_var: $ac_val" >&2
done
# There might be people who depend on the old broken behavior: `$host'
@@ -1159,6 +1180,8 @@ target=$target_alias
if test "x$host_alias" != x; then
if test "x$build_alias" = x; then
cross_compiling=maybe
+ $as_echo "$as_me: WARNING: If you wanted to set the --build type, don't use --host.
+ If a cross compiler is detected then cross compile mode will be used." >&2
elif test "x$build_alias" != "x$host_alias"; then
cross_compiling=yes
fi
@@ -1173,9 +1196,11 @@ test "$silent" = yes && exec 6>/dev/null
ac_pwd=`pwd` && test -n "$ac_pwd" &&
ac_ls_di=`ls -di .` &&
ac_pwd_ls_di=`cd "$ac_pwd" && ls -di .` ||
- as_fn_error $? "working directory cannot be determined"
+ { $as_echo "$as_me: error: working directory cannot be determined" >&2
test "X$ac_ls_di" = "X$ac_pwd_ls_di" ||
- as_fn_error $? "pwd does not report name of working directory"
+ { $as_echo "$as_me: error: pwd does not report name of working directory" >&2
# Find the source files, if location was not specified.
@@ -1214,11 +1239,13 @@ else
fi
if test ! -r "$srcdir/$ac_unique_file"; then
test "$ac_srcdir_defaulted" = yes && srcdir="$ac_confdir or .."
- as_fn_error $? "cannot find sources ($ac_unique_file) in $srcdir"
+ { $as_echo "$as_me: error: cannot find sources ($ac_unique_file) in $srcdir" >&2
fi
ac_msg="sources are in $srcdir, but \`cd $srcdir' does not work"
ac_abs_confdir=`(
- cd "$srcdir" && test -r "./$ac_unique_file" || as_fn_error $? "$ac_msg"
+ cd "$srcdir" && test -r "./$ac_unique_file" || { $as_echo "$as_me: error: $ac_msg" >&2
pwd)`
# When building in place, set srcdir=.
if test "$ac_abs_confdir" = "$ac_pwd"; then
@@ -1258,7 +1285,7 @@ Configuration:
--help=short display options specific to this package
--help=recursive display the short help of all the included packages
-V, --version display version information and exit
- -q, --quiet, --silent do not print \`checking ...' messages
+ -q, --quiet, --silent do not print \`checking...' messages
--cache-file=FILE cache test results in FILE [disabled]
-C, --config-cache alias for \`--cache-file=config.cache'
-n, --no-create do not create output files
@@ -1315,454 +1342,115 @@ Optional Features:
--enable-FEATURE[=ARG] include FEATURE [ARG=yes]
--disable-cuserid Disables attempted use of cuserid() at run time
--disable-ld-preload Disables support for LD_PRELOAD library
- --enable-group-readable-logs Set log files to be group readable
- --disable-bgq-mod Disables compilation and use of BG/Q module (for BG/Q systems)
-Optional Packages:
- --with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
- --without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
- --with-zlib=DIR root directory path of zlib installation defaults to
- /usr/local or /usr if not found in /usr/local
- --without-zlib to disable zlib usage completely
- --with-mem-align=<num> Memory alignment in bytes
- --with-log-path-by-env=<env var list> Comma separated list of environment variables to check for log path location before --with-log-path path
- --with-log-hints=<hint1=x;hint2=y> Semicolon-separated list of MPI-IO hints for log file write
- --with-log-path=<path> Location to store log files at run time
- --with-jobid-env=<name> Name of environment variable that stores the jobid
- (specify "NONE" if no appropriate environment variable is available:
- Darshan will use rank 0's pid instead)
- --with-mod-mem=<num> Maximum amount of memory (in MiB) for each Darshan module
-Some influential environment variables:
- CC C compiler command
- CFLAGS C compiler flags
- LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
- nonstandard directory <lib dir>
- LIBS libraries to pass to the linker, e.g. -l<library>
- CPPFLAGS (Objective) C/C++ preprocessor flags, e.g. -I<include dir> if
- you have headers in a nonstandard directory <include dir>
- CPP C preprocessor
-Use these variables to override the choices made by `configure' or to help
-it to find libraries and programs with nonstandard names/locations.
-Report bugs to the package provider.
-_ACEOF
-ac_status=$?
-fi
-if test "$ac_init_help" = "recursive"; then
- # If there are subdirs, report their specific --help.
- for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
- test -d "$ac_dir" ||
- { cd "$srcdir" && ac_pwd=`pwd` && srcdir=. && test -d "$ac_dir"; } ||
- continue
- ac_builddir=.
-case "$ac_dir" in
-.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;;
- ac_dir_suffix=/`$as_echo "$ac_dir" | sed 's|^\.[\\/]||'`
- # A ".." for each directory in $ac_dir_suffix.
- ac_top_builddir_sub=`$as_echo "$ac_dir_suffix" | sed 's|/[^\\/]*|/..|g;s|/||'`
- case $ac_top_builddir_sub in
- "") ac_top_builddir_sub=. ac_top_build_prefix= ;;
- *) ac_top_build_prefix=$ac_top_builddir_sub/ ;;
- esac ;;
-esac
-ac_abs_top_builddir=$ac_pwd
-ac_abs_builddir=$ac_pwd$ac_dir_suffix
-# for backward compatibility:
-ac_top_builddir=$ac_top_build_prefix
-case $srcdir in
- .) # We are building in place.
- ac_srcdir=.
- ac_top_srcdir=$ac_top_builddir_sub
- ac_abs_top_srcdir=$ac_pwd ;;
- [\\/]* | ?:[\\/]* ) # Absolute name.
- ac_srcdir=$srcdir$ac_dir_suffix;
- ac_top_srcdir=$srcdir
- ac_abs_top_srcdir=$srcdir ;;
- *) # Relative name.
- ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix
- ac_top_srcdir=$ac_top_build_prefix$srcdir
- ac_abs_top_srcdir=$ac_pwd/$srcdir ;;
-esac
-ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix
- cd "$ac_dir" || { ac_status=$?; continue; }
- # Check for guested configure.
- if test -f "$ac_srcdir/configure.gnu"; then
- echo &&
- $SHELL "$ac_srcdir/configure.gnu" --help=recursive
- elif test -f "$ac_srcdir/configure"; then
- echo &&
- $SHELL "$ac_srcdir/configure" --help=recursive
- else
- $as_echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
- fi || ac_status=$?
- cd "$ac_pwd" || { ac_status=$?; break; }
- done
-fi
-test -n "$ac_init_help" && exit $ac_status
-if $ac_init_version; then
- cat <<\_ACEOF
-darshan-runtime configure 3.0.0-pre3
-generated by GNU Autoconf 2.69
-Copyright (C) 2012 Free Software Foundation, Inc.
-This configure script is free software; the Free Software Foundation
-gives unlimited permission to copy, distribute and modify it.
-_ACEOF
- exit
-fi
-## Autoconf initialization. ##
-# ac_fn_c_try_compile LINENO
-# Try to compile conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_compile ()
- as_lineno=${as_lineno-"$1"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- rm -f conftest.$ac_objext
- if { { ac_try="$ac_compile"
-case "(($ac_try" in
- *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
- *) ac_try_echo=$ac_try;;
-esac
-eval ac_try_echo="\"\$as_me:${as_lineno-$LINENO}: $ac_try_echo\""
-$as_echo "$ac_try_echo"; } >&5
- (eval "$ac_compile") 2>conftest.err
- ac_status=$?
- if test -s conftest.err; then
- grep -v '^ *+' conftest.err >conftest.er1
- cat conftest.er1 >&5
- mv -f conftest.er1 conftest.err
- fi
- $as_echo "$as_me:${as_lineno-$LINENO}: \$? = $ac_status" >&5
- test $ac_status = 0; } && {
- test -z "$ac_c_werror_flag" ||
- test ! -s conftest.err
- } && test -s conftest.$ac_objext; then :
- ac_retval=0
-else
- $as_echo "$as_me: failed program was:" >&5
-sed 's/^/| /' conftest.$ac_ext >&5
- ac_retval=1
-fi
- eval $as_lineno_stack; ${as_lineno_stack:+:} unset as_lineno
- as_fn_set_status $ac_retval
-} # ac_fn_c_try_compile
-# ac_fn_c_try_cpp LINENO
-# Try to preprocess conftest.$ac_ext, and return whether this succeeded.
-ac_fn_c_try_cpp ()
- if { { ac_try="$ac_cpp conftest.$ac_ext"
-esac
- (eval "$ac_cpp conftest.$ac_ext") 2>conftest.err
- ac_status=$?
- fi
- test $ac_status = 0; } > conftest.i && {
- test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
- }; then :
- ac_retval=0
-else
- ac_retval=1
-fi
-} # ac_fn_c_try_cpp
-# ac_fn_c_check_header_mongrel LINENO HEADER VAR INCLUDES
-# Tests whether HEADER exists, giving a warning if it cannot be compiled using
-# the include files in INCLUDES and setting the cache variable VAR
-# accordingly.
-ac_fn_c_check_header_mongrel ()
- if eval \${$3+:} false; then :
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for $2" >&5
-$as_echo_n "checking for $2... " >&6; }
-if eval \${$3+:} false; then :
- $as_echo_n "(cached) " >&6
-fi
-eval ac_res=\$$3
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_res" >&5
-$as_echo "$ac_res" >&6; }
-else
- # Is the header compilable?
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 usability" >&5
-$as_echo_n "checking $2 usability... " >&6; }
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-/* end confdefs.h. */
-$4
-#include <$2>
-_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
- ac_header_compiler=yes
-else
- ac_header_compiler=no
-fi
-rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_compiler" >&5
-$as_echo "$ac_header_compiler" >&6; }
-# Is the header present?
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking $2 presence" >&5
-$as_echo_n "checking $2 presence... " >&6; }
-#include <$2>
-_ACEOF
-if ac_fn_c_try_cpp "$LINENO"; then :
- ac_header_preproc=yes
-else
- ac_header_preproc=no
-fi
-rm -f conftest.err conftest.i conftest.$ac_ext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_header_preproc" >&5
-$as_echo "$ac_header_preproc" >&6; }
-# So? What about this header?
-case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in #((
- yes:no: )
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&5
-$as_echo "$as_me: WARNING: $2: accepted by the compiler, rejected by the preprocessor!" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: proceeding with the compiler's result" >&5
-$as_echo "$as_me: WARNING: $2: proceeding with the compiler's result" >&2;}
- no:yes:* )
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: present but cannot be compiled" >&5
-$as_echo "$as_me: WARNING: $2: present but cannot be compiled" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: check for missing prerequisite headers?" >&5
-$as_echo "$as_me: WARNING: $2: check for missing prerequisite headers?" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: see the Autoconf documentation" >&5
-$as_echo "$as_me: WARNING: $2: see the Autoconf documentation" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&5
-$as_echo "$as_me: WARNING: $2: section \"Present But Cannot Be Compiled\"" >&2;}
-esac
-else
- eval "$3=\$ac_header_compiler"
-fi
-eval ac_res=\$$3
-fi
-} # ac_fn_c_check_header_mongrel
+ --enable-group-readable-logs Set log files to be group readable
+ --disable-bgq-mod Disables compilation and use of BG/Q module (for BG/Q systems)
-# ac_fn_c_try_run LINENO
-# Try to link conftest.$ac_ext, and return whether this succeeded. Assumes
-# that executables *can* be run.
-ac_fn_c_try_run ()
- if { { ac_try="$ac_link"
-esac
- (eval "$ac_link") 2>&5
- ac_status=$?
- test $ac_status = 0; } && { ac_try='./conftest$ac_exeext'
- { { case "(($ac_try" in
-esac
- (eval "$ac_try") 2>&5
- ac_status=$?
- test $ac_status = 0; }; }; then :
- ac_retval=0
-else
- $as_echo "$as_me: program exited with status $ac_status" >&5
+Optional Packages:
+ --with-PACKAGE[=ARG] use PACKAGE [ARG=yes]
+ --without-PACKAGE do not use PACKAGE (same as --with-PACKAGE=no)
+ --with-zlib=DIR root directory path of zlib installation defaults to
+ /usr/local or /usr if not found in /usr/local
+ --without-zlib to disable zlib usage completely
+ --with-mem-align=<num> Memory alignment in bytes
+ --with-log-path-by-env=<env var list> Comma separated list of environment variables to check for log path location before --with-log-path path
+ --with-log-hints=<hint1=x;hint2=y> Semicolon-separated list of MPI-IO hints for log file write
+ --with-log-path=<path> Location to store log files at run time
+ --with-jobid-env=<name> Name of environment variable that stores the jobid
+ (specify "NONE" if no appropriate environment variable is available:
+ Darshan will use rank 0's pid instead)
+ --with-mod-mem=<num> Maximum amount of memory (in MiB) for each Darshan module
- ac_retval=$ac_status
-fi
- rm -rf conftest.dSYM conftest_ipa8_conftest.oo
+Some influential environment variables:
+ CC C compiler command
+ CFLAGS C compiler flags
+ LDFLAGS linker flags, e.g. -L<lib dir> if you have libraries in a
+ nonstandard directory <lib dir>
+ LIBS libraries to pass to the linker, e.g. -l<library>
+ CPPFLAGS C/C++/Objective C preprocessor flags, e.g. -I<include dir> if
+ you have headers in a nonstandard directory <include dir>
+ CPP C preprocessor
-} # ac_fn_c_try_run
+Use these variables to override the choices made by `configure' or to help
+it to find libraries and programs with nonstandard names/locations.
-# ac_fn_c_check_header_compile LINENO HEADER VAR INCLUDES
-# Tests whether HEADER exists and can be compiled using the include files in
-# INCLUDES, setting the cache variable VAR accordingly.
-ac_fn_c_check_header_compile ()
-else
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
-$4
-#include <$2>
_ACEOF
- eval "$3=yes"
-else
- eval "$3=no"
-fi
+ac_status=$?
fi
-eval ac_res=\$$3
-} # ac_fn_c_check_header_compile
+if test "$ac_init_help" = "recursive"; then
+ # If there are subdirs, report their specific --help.
+ for ac_dir in : $ac_subdirs_all; do test "x$ac_dir" = x: && continue
+ test -d "$ac_dir" ||
+ { cd "$srcdir" && ac_pwd=`pwd` && srcdir=. && test -d "$ac_dir"; } ||
+ continue
+ ac_builddir=.
-# ac_fn_c_try_link LINENO
-ac_fn_c_try_link ()
- rm -f conftest.$ac_objext conftest$ac_exeext
+case "$ac_dir" in
+.) ac_dir_suffix= ac_top_builddir_sub=. ac_top_build_prefix= ;;
+ ac_dir_suffix=/`$as_echo "$ac_dir" | sed 's|^\.[\\/]||'`
+ # A ".." for each directory in $ac_dir_suffix.
+ ac_top_builddir_sub=`$as_echo "$ac_dir_suffix" | sed 's|/[^\\/]*|/..|g;s|/||'`
+ case $ac_top_builddir_sub in
+ "") ac_top_builddir_sub=. ac_top_build_prefix= ;;
+ *) ac_top_build_prefix=$ac_top_builddir_sub/ ;;
+ esac ;;
esac
- (eval "$ac_link") 2>conftest.err
- ac_status=$?
- fi
- } && test -s conftest$ac_exeext && {
- test "$cross_compiling" = yes ||
- test -x conftest$ac_exeext
- }; then :
- ac_retval=0
-else
+ac_abs_top_builddir=$ac_pwd
+ac_abs_builddir=$ac_pwd$ac_dir_suffix
+# for backward compatibility:
+ac_top_builddir=$ac_top_build_prefix
+case $srcdir in
+ .) # We are building in place.
+ ac_srcdir=.
+ ac_top_srcdir=$ac_top_builddir_sub
+ ac_abs_top_srcdir=$ac_pwd ;;
+ [\\/]* | ?:[\\/]* ) # Absolute name.
+ ac_srcdir=$srcdir$ac_dir_suffix;
+ ac_top_srcdir=$srcdir
+ ac_abs_top_srcdir=$srcdir ;;
+ *) # Relative name.
+ ac_srcdir=$ac_top_build_prefix$srcdir$ac_dir_suffix
+ ac_top_srcdir=$ac_top_build_prefix$srcdir
+ ac_abs_top_srcdir=$ac_pwd/$srcdir ;;
+esac
+ac_abs_srcdir=$ac_abs_top_srcdir$ac_dir_suffix
- ac_retval=1
+ cd "$ac_dir" || { ac_status=$?; continue; }
+ # Check for guested configure.
+ if test -f "$ac_srcdir/configure.gnu"; then
+ echo &&
+ $SHELL "$ac_srcdir/configure.gnu" --help=recursive
+ elif test -f "$ac_srcdir/configure"; then
+ echo &&
+ $SHELL "$ac_srcdir/configure" --help=recursive
+ else
+ $as_echo "$as_me: WARNING: no configuration information is in $ac_dir" >&2
+ fi || ac_status=$?
+ cd "$ac_pwd" || { ac_status=$?; break; }
+ done
fi
- # Delete the IPA/IPO (Inter Procedural Analysis/Optimization) information
- # created by the PGI compiler (conftest_ipa8_conftest.oo), as it would
- # interfere with the next link command; also delete a directory that is
- # left behind by Apple's compiler. We do this before executing the actions.
-} # ac_fn_c_try_link
+test -n "$ac_init_help" && exit $ac_status
+if $ac_init_version; then
+ cat <<\_ACEOF
+darshan-runtime configure 3.0.0-pre3
+generated by GNU Autoconf 2.63
-# ac_fn_c_check_type LINENO TYPE VAR INCLUDES
-# Tests whether TYPE exists after having included INCLUDES, setting cache
-# variable VAR accordingly.
-ac_fn_c_check_type ()
-else
- eval "$3=no"
-$4
-int
-main ()
-if (sizeof ($2))
- return 0;
- return 0;
-_ACEOF
-$4
-int
-main ()
-if (sizeof (($2)))
- return 0;
- return 0;
+Copyright (C) 1992, 1993, 1994, 1995, 1996, 1998, 1999, 2000, 2001,
+2002, 2003, 2004, 2005, 2006, 2007, 2008 Free Software Foundation, Inc.
+This configure script is free software; the Free Software Foundation
+gives unlimited permission to copy, distribute and modify it.
_ACEOF
-else
- eval "$3=yes"
-fi
-fi
+ exit
fi
-eval ac_res=\$$3
-} # ac_fn_c_check_type
cat >config.log <<_ACEOF
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by darshan-runtime $as_me 3.0.0-pre3, which was
-generated by GNU Autoconf 2.69. Invocation command line was
+generated by GNU Autoconf 2.63. Invocation command line was
$ $0 $@
@@ -1798,8 +1486,8 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- $as_echo "PATH: $as_dir"
- done
+ $as_echo "PATH: $as_dir"
+done
IFS=$as_save_IFS
} >&5
@@ -1836,9 +1524,9 @@ do
ac_arg=`$as_echo "$ac_arg" | sed "s/'/'\\\\\\\\''/g"` ;;
esac
case $ac_pass in
- 1) as_fn_append ac_configure_args0 " '$ac_arg'" ;;
+ 1) ac_configure_args0="$ac_configure_args0 '$ac_arg'" ;;
2)
- as_fn_append ac_configure_args1 " '$ac_arg'"
+ ac_configure_args1="$ac_configure_args1 '$ac_arg'"
if test $ac_must_keep_next = true; then
ac_must_keep_next=false # Got value, back to normal.
else
@@ -1854,13 +1542,13 @@ do
-* ) ac_must_keep_next=true ;;
esac
fi
- as_fn_append ac_configure_args " '$ac_arg'"
+ ac_configure_args="$ac_configure_args '$ac_arg'"
esac
done
done
-{ ac_configure_args0=; unset ac_configure_args0;}
-{ ac_configure_args1=; unset ac_configure_args1;}
+$as_unset ac_configure_args0 || test "${ac_configure_args0+set}" != set || { ac_configure_args0=; export ac_configure_args0; }
+$as_unset ac_configure_args1 || test "${ac_configure_args1+set}" != set || { ac_configure_args1=; export ac_configure_args1; }
# When interrupted or exit'd, cleanup temporary files, and complete
# config.log. We remove comments because anyway the quotes in there
@@ -1872,9 +1560,11 @@ trap 'exit_status=$?
echo
- $as_echo "## ---------------- ##
+ cat <<\_ASBOX
## Cache variables. ##
+_ASBOX
echo
# The following way of writing the cache mishandles newlines in values,
@@ -1883,13 +1573,13 @@ trap 'exit_status=$?
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
- *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
+ *_cv_*) { $as_echo "$as_me:$LINENO: WARNING: cache variable $ac_var contains a newline" >&5
$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
esac
case $ac_var in #(
_ | IFS | as_nl) ;; #(
BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
- *) { eval $ac_var=; unset $ac_var;} ;;
+ *) $as_unset $ac_var ;;
esac ;;
esac
done
@@ -1908,9 +1598,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
echo
- $as_echo "## ----------------- ##
+ cat <<\_ASBOX
## Output variables. ##
+_ASBOX
echo
for ac_var in $ac_subst_vars
do
@@ -1923,9 +1615,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
echo
if test -n "$ac_subst_files"; then
- $as_echo "## ------------------- ##
+ cat <<\_ASBOX
## File substitutions. ##
+_ASBOX
echo
for ac_var in $ac_subst_files
do
@@ -1939,9 +1633,11 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
fi
if test -s confdefs.h; then
- $as_echo "## ----------- ##
+ cat <<\_ASBOX
## confdefs.h. ##
+_ASBOX
echo
cat confdefs.h
echo
@@ -1955,39 +1651,37 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
exit $exit_status
' 0
for ac_signal in 1 2 13 15; do
- trap 'ac_signal='$ac_signal'; as_fn_exit 1' $ac_signal
+ trap 'ac_signal='$ac_signal'; { (exit 1); exit 1; }' $ac_signal
done
ac_signal=0
# confdefs.h avoids OS command line length limits that DEFS can exceed.
rm -f -r conftest* confdefs.h
-$as_echo "/* confdefs.h */" > confdefs.h
# Predefined preprocessor variables.
cat >>confdefs.h <<_ACEOF
#define PACKAGE_NAME "$PACKAGE_NAME"
_ACEOF
#define PACKAGE_TARNAME "$PACKAGE_TARNAME"
_ACEOF
#define PACKAGE_VERSION "$PACKAGE_VERSION"
_ACEOF
#define PACKAGE_STRING "$PACKAGE_STRING"
_ACEOF
-cat >>confdefs.h <<_ACEOF
-#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
-_ACEOF
-#define PACKAGE_URL "$PACKAGE_URL"
+#define PACKAGE_BUGREPORT "$PACKAGE_BUGREPORT"
_ACEOF
@@ -1996,12 +1690,7 @@ _ACEOF
ac_site_file1=NONE
ac_site_file2=NONE
if test -n "$CONFIG_SITE"; then
- # We do not want a PATH search for config.site.
- case $CONFIG_SITE in #((
- -*) ac_site_file1=./$CONFIG_SITE;;
- */*) ac_site_file1=$CONFIG_SITE;;
- *) ac_site_file1=./$CONFIG_SITE;;
- esac
+ ac_site_file1=$CONFIG_SITE
elif test "x$prefix" != xNONE; then
ac_site_file1=$prefix/share/config.site
ac_site_file2=$prefix/etc/config.site
@@ -2012,23 +1701,19 @@ fi
for ac_site_file in "$ac_site_file1" "$ac_site_file2"
do
test "x$ac_site_file" = xNONE && continue
- if test /dev/null != "$ac_site_file" && test -r "$ac_site_file"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: loading site script $ac_site_file" >&5
+ if test -r "$ac_site_file"; then
+ { $as_echo "$as_me:$LINENO: loading site script $ac_site_file" >&5
$as_echo "$as_me: loading site script $ac_site_file" >&6;}
sed 's/^/| /' "$ac_site_file" >&5
- . "$ac_site_file" \
- || { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
-as_fn_error $? "failed to load site script $ac_site_file
-See \`config.log' for more details" "$LINENO" 5; }
+ . "$ac_site_file"
fi
done
if test -r "$cache_file"; then
- # Some versions of bash will fail to source /dev/null (special files
- # actually), so we avoid doing that. DJGPP emulates it as a regular file.
- if test /dev/null != "$cache_file" && test -f "$cache_file"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: loading cache $cache_file" >&5
+ # Some versions of bash will fail to source /dev/null (special
+ # files actually), so we avoid doing that.
+ if test -f "$cache_file"; then
+ { $as_echo "$as_me:$LINENO: loading cache $cache_file" >&5
$as_echo "$as_me: loading cache $cache_file" >&6;}
case $cache_file in
[\\/]* | ?:[\\/]* ) . "$cache_file";;
@@ -2036,7 +1721,7 @@ $as_echo "$as_me: loading cache $cache_file" >&6;}
esac
fi
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: creating cache $cache_file" >&5
+ { $as_echo "$as_me:$LINENO: creating cache $cache_file" >&5
$as_echo "$as_me: creating cache $cache_file" >&6;}
>$cache_file
fi
@@ -2051,11 +1736,11 @@ for ac_var in $ac_precious_vars; do
eval ac_new_val=\$ac_env_${ac_var}_value
case $ac_old_set,$ac_new_set in
set,)
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was set to \`$ac_old_val' in the previous run" >&2;}
ac_cache_corrupted=: ;;
,set)
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' was not set in the previous run" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' was not set in the previous run" >&5
$as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
@@ -2065,17 +1750,17 @@ $as_echo "$as_me: error: \`$ac_var' was not set in the previous run" >&2;}
ac_old_val_w=`echo x $ac_old_val`
ac_new_val_w=`echo x $ac_new_val`
if test "$ac_old_val_w" != "$ac_new_val_w"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: \`$ac_var' has changed since the previous run:" >&5
+ { $as_echo "$as_me:$LINENO: error: \`$ac_var' has changed since the previous run:" >&5
$as_echo "$as_me: error: \`$ac_var' has changed since the previous run:" >&2;}
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
+ { $as_echo "$as_me:$LINENO: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&5
$as_echo "$as_me: warning: ignoring whitespace changes in \`$ac_var' since the previous run:" >&2;}
eval $ac_var=\$ac_old_val
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: former value: \`$ac_old_val'" >&5
+ { $as_echo "$as_me:$LINENO: former value: \`$ac_old_val'" >&5
$as_echo "$as_me: former value: \`$ac_old_val'" >&2;}
- { $as_echo "$as_me:${as_lineno-$LINENO}: current value: \`$ac_new_val'" >&5
+ { $as_echo "$as_me:$LINENO: current value: \`$ac_new_val'" >&5
$as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
fi;;
esac
@@ -2087,20 +1772,43 @@ $as_echo "$as_me: current value: \`$ac_new_val'" >&2;}
esac
case " $ac_configure_args " in
*" '$ac_arg' "*) ;; # Avoid dups. Use of quotes ensures accuracy.
- *) as_fn_append ac_configure_args " '$ac_arg'" ;;
+ *) ac_configure_args="$ac_configure_args '$ac_arg'" ;;
esac
fi
done
if $ac_cache_corrupted; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
- { $as_echo "$as_me:${as_lineno-$LINENO}: error: changes in the environment can compromise the build" >&5
+ { $as_echo "$as_me:$LINENO: error: changes in the environment can compromise the build" >&5
$as_echo "$as_me: error: changes in the environment can compromise the build" >&2;}
- as_fn_error $? "run \`make distclean' and/or \`rm $cache_file' and start over" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&5
+$as_echo "$as_me: error: run \`make distclean' and/or \`rm $cache_file' and start over" >&2;}
fi
-## Main body of script. ##
ac_ext=c
ac_cpp='$CPP $CPPFLAGS'
@@ -2127,7 +1835,9 @@ for ac_dir in ../maint/config "$srcdir"/../maint/config; do
fi
done
if test -z "$ac_aux_dir"; then
- as_fn_error $? "cannot find install-sh, install.sh, or shtool in ../maint/config \"$srcdir\"/../maint/config" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&5
+$as_echo "$as_me: error: cannot find install-sh or install.sh in ../maint/config \"$srcdir\"/../maint/config" >&2;}
fi
# These three variables are undocumented and unsupported,
@@ -2156,10 +1866,10 @@ ac_config_headers="$ac_config_headers darshan-runtime-config.h"
# OS/2's system install, which has a completely different semantic
# ./install, which can be erroneously created by make from ./install.sh.
# Reject install programs that cannot install multiple files.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for a BSD-compatible install" >&5
+{ $as_echo "$as_me:$LINENO: checking for a BSD-compatible install" >&5
$as_echo_n "checking for a BSD-compatible install... " >&6; }
if test -z "$INSTALL"; then
-if ${ac_cv_path_install+:} false; then :
+if test "${ac_cv_path_install+set}" = set; then
else
@@ -2167,11 +1877,11 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- # Account for people who put trailing slashes in PATH elements.
-case $as_dir/ in #((
- ./ | .// | /[cC]/* | \
+ # Account for people who put trailing slashes in PATH elements.
+case $as_dir/ in
+ ./ | .// | /cC/* | \
/etc/* | /usr/sbin/* | /usr/etc/* | /sbin/* | /usr/afsws/bin/* | \
- ?:[\\/]os2[\\/]install[\\/]* | ?:[\\/]OS2[\\/]INSTALL[\\/]* | \
+ ?:\\/os2\\/install\\/* | ?:\\/OS2\\/INSTALL\\/* | \
/usr/ucb/* ) ;;
# OSF1 and SCO ODT 3.0 have their own names for install.
@@ -2179,7 +1889,7 @@ case $as_dir/ in #((
# by default.
for ac_prog in ginstall scoinst install; do
for ac_exec_ext in '' $ac_executable_extensions; do
- if as_fn_executable_p "$as_dir/$ac_prog$ac_exec_ext"; then
+ if { test -f "$as_dir/$ac_prog$ac_exec_ext" && $as_test_x "$as_dir/$ac_prog$ac_exec_ext"; }; then
if test $ac_prog = install &&
grep dspmsg "$as_dir/$ac_prog$ac_exec_ext" >/dev/null 2>&1; then
# AIX install. It has an incompatible calling convention.
@@ -2208,7 +1918,7 @@ case $as_dir/ in #((
esac
- done
+done
IFS=$as_save_IFS
rm -rf conftest.one conftest.two conftest.dir
@@ -2224,7 +1934,7 @@ fi
INSTALL=$ac_install_sh
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $INSTALL" >&5
+{ $as_echo "$as_me:$LINENO: result: $INSTALL" >&5
$as_echo "$INSTALL" >&6; }
# Use test -z because SunOS4 sh mishandles braces in ${var-val}.
@@ -2236,7 +1946,7 @@ test -z "$INSTALL_SCRIPT" && INSTALL_SCRIPT='${INSTALL}'
test -z "$INSTALL_DATA" && INSTALL_DATA='${INSTALL} -m 644'
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the mpicc compiler works" >&5
+{ $as_echo "$as_me:$LINENO: checking whether the mpicc compiler works" >&5
$as_echo_n "checking whether the mpicc compiler works... " >&6; }
ac_ext=c
@@ -2246,9 +1956,9 @@ ac_compiler_gnu=$ac_cv_c_compiler_gnu
if test -n "$ac_tool_prefix"; then
# Extract the first word of "${ac_tool_prefix}gcc", so it can be a program name with args.
set dummy ${ac_tool_prefix}gcc; ac_word=$2
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $ac_word" >&5
+{ $as_echo "$as_me:$LINENO: checking for $ac_word" >&5
$as_echo_n "checking for $ac_word... " >&6; }
-if ${ac_cv_prog_CC+:} false; then :
+if test "${ac_cv_prog_CC+set}" = set; then
else
if test -n "$CC"; then
@@ -2259,24 +1969,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
- for ac_exec_ext in '' $ac_executable_extensions; do
- if as_fn_executable_p "$as_dir/$ac_word$ac_exec_ext"; then
+ for ac_exec_ext in '' $ac_executable_extensions; do
+ if { test -f "$as_dir/$ac_word$ac_exec_ext" && $as_test_x "$as_dir/$ac_word$ac_exec_ext"; }; then
ac_cv_prog_CC="${ac_tool_prefix}gcc"
- $as_echo "$as_me:${as_lineno-$LINENO}: found $as_dir/$ac_word$ac_exec_ext" >&5
+ $as_echo "$as_me:$LINENO: found $as_dir/$ac_word$ac_exec_ext" >&5
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $CC" >&5
+ { $as_echo "$as_me:$LINENO: result: $CC" >&5
$as_echo "$CC" >&6; }
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+ { $as_echo "$as_me:$LINENO: result: no" >&5
$as_echo "no" >&6; }
fi
@@ -2286,9 +1996,9 @@ if test -z "$ac_cv_prog_CC"; then
ac_ct_CC=$CC
# Extract the first word of "gcc", so it can be a program name with args.
set dummy gcc; ac_word=$2
-if ${ac_cv_prog_ac_ct_CC+:} false; then :
+if test "${ac_cv_prog_ac_ct_CC+set}" = set; then
else
if test -n "$ac_ct_CC"; then
@@ -2299,24 +2009,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="gcc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
ac_ct_CC=$ac_cv_prog_ac_ct_CC
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_ct_CC" >&5
+ { $as_echo "$as_me:$LINENO: result: $ac_ct_CC" >&5
$as_echo "$ac_ct_CC" >&6; }
else
fi
@@ -2325,7 +2035,7 @@ fi
else
case $cross_compiling:$ac_tool_warned in
yes:)
-{ $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: using cross tools not prefixed with host triplet" >&5
+{ $as_echo "$as_me:$LINENO: WARNING: using cross tools not prefixed with host triplet" >&5
$as_echo "$as_me: WARNING: using cross tools not prefixed with host triplet" >&2;}
ac_tool_warned=yes ;;
esac
@@ -2339,9 +2049,9 @@ if test -z "$CC"; then
# Extract the first word of "${ac_tool_prefix}cc", so it can be a program name with args.
set dummy ${ac_tool_prefix}cc; ac_word=$2
else
@@ -2352,24 +2062,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_CC="${ac_tool_prefix}cc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2379,9 +2089,9 @@ fi
# Extract the first word of "cc", so it can be a program name with args.
set dummy cc; ac_word=$2
else
@@ -2393,18 +2103,18 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
if test "$as_dir/$ac_word$ac_exec_ext" = "/usr/ucb/cc"; then
ac_prog_rejected=yes
continue
fi
ac_cv_prog_CC="cc"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
if test $ac_prog_rejected = yes; then
@@ -2423,10 +2133,10 @@ fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2438,9 +2148,9 @@ if test -z "$CC"; then
do
# Extract the first word of "$ac_tool_prefix$ac_prog", so it can be a program name with args.
set dummy $ac_tool_prefix$ac_prog; ac_word=$2
else
@@ -2451,24 +2161,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_CC="$ac_tool_prefix$ac_prog"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
CC=$ac_cv_prog_CC
else
fi
@@ -2482,9 +2192,9 @@ if test -z "$CC"; then
do
# Extract the first word of "$ac_prog", so it can be a program name with args.
set dummy $ac_prog; ac_word=$2
else
@@ -2495,24 +2205,24 @@ for as_dir in $PATH
do
IFS=$as_save_IFS
ac_cv_prog_ac_ct_CC="$ac_prog"
break 2
fi
done
- done
+done
IFS=$as_save_IFS
fi
fi
else
fi
@@ -2525,7 +2235,7 @@ done
else
yes:)
esac
@@ -2536,37 +2246,57 @@ fi
fi
-test -z "$CC" && { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+test -z "$CC" && { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
-as_fn_error $? "no acceptable C compiler found in \$PATH
+{ { $as_echo "$as_me:$LINENO: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&5
+$as_echo "$as_me: error: no acceptable C compiler found in \$PATH
+See \`config.log' for more details." >&2;}
+ { (exit 1); exit 1; }; }; }
# Provide some information about the compiler.
-$as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler version" >&5
+$as_echo "$as_me:$LINENO: checking for C compiler version" >&5
set X $ac_compile
ac_compiler=$2
-for ac_option in --version -v -V -qversion; do
- { { ac_try="$ac_compiler $ac_option >&5"
+{ (ac_try="$ac_compiler --version >&5"
case "(($ac_try" in
esac
- (eval "$ac_compiler $ac_option >&5") 2>conftest.err
+eval ac_try_echo="\"\$as_me:$LINENO: $ac_try_echo\""
+$as_echo "$ac_try_echo") >&5
+ (eval "$ac_compiler --version >&5") 2>&5
ac_status=$?
- sed '10a\
-... rest of stderr output deleted ...
- 10q' conftest.err >conftest.er1
- fi
- rm -f conftest.er1 conftest.err
-done
+ $as_echo "$as_me:$LINENO: \$? = $ac_status" >&5
+ (exit $ac_status); }
+{ (ac_try="$ac_compiler -v >&5"
+case "(($ac_try" in
+ *\"* | *\`* | *\\*) ac_try_echo=\$ac_try;;
+ *) ac_try_echo=$ac_try;;
+esac
+ (eval "$ac_compiler -v >&5") 2>&5
+ ac_status=$?
+{ (ac_try="$ac_compiler -V >&5"
+esac
+ (eval "$ac_compiler -V >&5") 2>&5
+ ac_status=$?
+cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
+cat confdefs.h >>conftest.$ac_ext
+cat >>conftest.$ac_ext <<_ACEOF
int
@@ -2582,8 +2312,8 @@ ac_clean_files="$ac_clean_files a.out a.out.dSYM a.exe b.out"
# Try to create an executable without -o first, disregard a.out.
# It will help us diagnose broken compilers, and finding out an intuition
# of exeext.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the C compiler works" >&5
-$as_echo_n "checking whether the C compiler works... " >&6; }
+{ $as_echo "$as_me:$LINENO: checking for C compiler default output file name" >&5
+$as_echo_n "checking for C compiler default output file name... " >&6; }
ac_link_default=`$as_echo "$ac_link" | sed 's/ -o *conftest[^ ]*//'`
# The possible output files:
@@ -2599,17 +2329,17 @@ do
done
rm -f $ac_rmfiles
-if { { ac_try="$ac_link_default"
+if { (ac_try="$ac_link_default"
case "(($ac_try" in
esac
(eval "$ac_link_default") 2>&5
ac_status=$?
- test $ac_status = 0; }; then :
+ (exit $ac_status); }; then
# Autoconf-2.13 could set the ac_cv_exeext variable to `no'.
# So ignore a value of `no', otherwise this would lead to `EXEEXT = no'
# in a Makefile. We should not override ac_cv_exeext if it was cached,
@@ -2626,7 +2356,7 @@ do
# certainly right.
break;;
- if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
+ if test "${ac_cv_exeext+set}" = set && test "$ac_cv_exeext" != no;
then :; else
ac_cv_exeext=`expr "$ac_file" : '[^.]*\(\..*\)'`
fi
@@ -2645,41 +2375,84 @@ test "$ac_cv_exeext" = no && ac_cv_exeext=
else
ac_file=''
fi
-if test -z "$ac_file"; then :
-$as_echo "no" >&6; }
-$as_echo "$as_me: failed program was:" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_file" >&5
+$as_echo "$ac_file" >&6; }
+if test -z "$ac_file"; then
+ $as_echo "$as_me: failed program was:" >&5
-{ { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
+{ { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
-as_fn_error 77 "C compiler cannot create executables
-else
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
-$as_echo "yes" >&6; }
+{ { $as_echo "$as_me:$LINENO: error: C compiler cannot create executables
+$as_echo "$as_me: error: C compiler cannot create executables
+ { (exit 77); exit 77; }; }; }
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for C compiler default output file name" >&5
-$as_echo_n "checking for C compiler default output file name... " >&6; }
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_file" >&5
-$as_echo "$ac_file" >&6; }
ac_exeext=$ac_cv_exeext
+# Check that the compiler produces executables we can run. If not, either
+# the compiler is broken, or we cross compile.
+{ $as_echo "$as_me:$LINENO: checking whether the C compiler works" >&5
+$as_echo_n "checking whether the C compiler works... " >&6; }
+# FIXME: These cross compiler hacks should be removed for Autoconf 3.0
+# If not cross compiling, check that we can run a simple program.
+if test "$cross_compiling" != yes; then
+ if { ac_try='./$ac_file'
+ { (case "(($ac_try" in
+esac
+ (eval "$ac_try") 2>&5
+ ac_status=$?
+ (exit $ac_status); }; }; then
+ cross_compiling=no
+ else
+ if test "$cross_compiling" = maybe; then
+ cross_compiling=yes
+ else
+ { { $as_echo "$as_me:$LINENO: error: in \`$ac_pwd':" >&5
+$as_echo "$as_me: error: in \`$ac_pwd':" >&2;}
+{ { $as_echo "$as_me:$LINENO: error: cannot run C compiled programs.
+If you meant to cross compile, use \`--host'.
+$as_echo "$as_me: error: cannot run C compiled programs.
+ fi
+ fi
+fi
+{ $as_echo "$as_me:$LINENO: result: yes" >&5
+$as_echo "yes" >&6; }
rm -f -r a.out a.out.dSYM a.exe conftest$ac_cv_exeext b.out
ac_clean_files=$ac_clean_files_save
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of executables" >&5
+{ $as_echo "$as_me:$LINENO: checking whether we are cross compiling" >&5
+$as_echo_n "checking whether we are cross compiling... " >&6; }
+{ $as_echo "$as_me:$LINENO: result: $cross_compiling" >&5
+$as_echo "$cross_compiling" >&6; }
+{ $as_echo "$as_me:$LINENO: checking for suffix of executables" >&5
$as_echo_n "checking for suffix of executables... " >&6; }
-if { { ac_try="$ac_link"
+if { (ac_try="$ac_link"
case "(($ac_try" in
esac
ac_status=$?
# If both `conftest.exe' and `conftest' are `present' (well, observable)
# catch `conftest.exe'. For instance with Cygwin, `ls conftest' will
# work properly (i.e., refer to `conftest.exe'), while it won't with
@@ -2694,83 +2467,32 @@ for ac_file in conftest.exe conftest conftest.*; do
esac
done
else
- { { $as_echo "$as_me:${as_lineno-$LINENO}: error: in \`$ac_pwd':" >&5
-as_fn_error $? "cannot compute suffix of executables: cannot compile and link
+{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of executables: cannot compile and link
+$as_echo "$as_me: error: cannot compute suffix of executables: cannot compile and link
fi
-rm -f conftest conftest$ac_cv_exeext
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_exeext" >&5
+rm -f conftest$ac_cv_exeext
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_exeext" >&5
$as_echo "$ac_cv_exeext" >&6; }
rm -f conftest.$ac_ext
EXEEXT=$ac_cv_exeext
ac_exeext=$EXEEXT
-#include <stdio.h>
-int
-main ()
-FILE *f = fopen ("conftest.out", "w");
- return ferror (f) || fclose (f) != 0;
- return 0;
-_ACEOF
-ac_clean_files="$ac_clean_files conftest.out"
-# Check that the compiler produces executables we can run. If not, either
-# the compiler is broken, or we cross compile.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are cross compiling" >&5
-$as_echo_n "checking whether we are cross compiling... " >&6; }
-if test "$cross_compiling" != yes; then
- { { ac_try="$ac_link"
-esac
- ac_status=$?
- if { ac_try='./conftest$ac_cv_exeext'
-esac
- ac_status=$?
- cross_compiling=no
- else
- if test "$cross_compiling" = maybe; then
- cross_compiling=yes
- else
-as_fn_error $? "cannot run C compiled programs.
-If you meant to cross compile, use \`--host'.
- fi
- fi
-fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $cross_compiling" >&5
-$as_echo "$cross_compiling" >&6; }
-rm -f conftest.$ac_ext conftest$ac_cv_exeext conftest.out
-ac_clean_files=$ac_clean_files_save
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for suffix of object files" >&5
+{ $as_echo "$as_me:$LINENO: checking for suffix of object files" >&5
$as_echo_n "checking for suffix of object files... " >&6; }
-if ${ac_cv_objext+:} false; then :
+if test "${ac_cv_objext+set}" = set; then
else
+ cat >conftest.$ac_ext <<_ACEOF
+/* confdefs.h. */
+_ACEOF
int
@@ -2782,17 +2504,17 @@ main ()
_ACEOF
rm -f conftest.o conftest.obj
-if { { ac_try="$ac_compile"
+if { (ac_try="$ac_compile"
case "(($ac_try" in
esac
(eval "$ac_compile") 2>&5
ac_status=$?
for ac_file in conftest.o conftest.obj conftest.*; do
test -f "$ac_file" || continue;
case $ac_file in
@@ -2805,23 +2527,31 @@ else
-as_fn_error $? "cannot compute suffix of object files: cannot compile
+{ { $as_echo "$as_me:$LINENO: error: cannot compute suffix of object files: cannot compile
+$as_echo "$as_me: error: cannot compute suffix of object files: cannot compile
fi
rm -f conftest.$ac_cv_objext conftest.$ac_ext
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_objext" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_objext" >&5
$as_echo "$ac_cv_objext" >&6; }
OBJEXT=$ac_cv_objext
ac_objext=$OBJEXT
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether we are using the GNU C compiler" >&5
+{ $as_echo "$as_me:$LINENO: checking whether we are using the GNU C compiler" >&5
$as_echo_n "checking whether we are using the GNU C compiler... " >&6; }
-if ${ac_cv_c_compiler_gnu+:} false; then :
+if test "${ac_cv_c_compiler_gnu+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
int
@@ -2835,16 +2565,37 @@ main ()
return 0;
_ACEOF
+rm -f conftest.$ac_objext
+esac
+ (eval "$ac_compile") 2>conftest.er1
+ ac_status=$?
+ grep -v '^ *+' conftest.er1 >conftest.err
+ rm -f conftest.er1
+ cat conftest.err >&5
+ (exit $ac_status); } && {
+ test -z "$ac_c_werror_flag" ||
+ test ! -s conftest.err
+ } && test -s conftest.$ac_objext; then
ac_compiler_gnu=yes
else
- ac_compiler_gnu=no
+sed 's/^/| /' conftest.$ac_ext >&5
+ ac_compiler_gnu=no
fi
ac_cv_c_compiler_gnu=$ac_compiler_gnu
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_compiler_gnu" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_compiler_gnu" >&5
$as_echo "$ac_cv_c_compiler_gnu" >&6; }
if test $ac_compiler_gnu = yes; then
GCC=yes
@@ -2853,16 +2604,20 @@ else
fi
ac_test_CFLAGS=${CFLAGS+set}
ac_save_CFLAGS=$CFLAGS
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking whether $CC accepts -g" >&5
+{ $as_echo "$as_me:$LINENO: checking whether $CC accepts -g" >&5
$as_echo_n "checking whether $CC accepts -g... " >&6; }
-if ${ac_cv_prog_cc_g+:} false; then :
+if test "${ac_cv_prog_cc_g+set}" = set; then
else
ac_save_c_werror_flag=$ac_c_werror_flag
ac_c_werror_flag=yes
ac_cv_prog_cc_g=no
CFLAGS="-g"
+/* confdefs.h. */
+_ACEOF
int
@@ -2873,11 +2628,35 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_prog_cc_g=yes
else
- CFLAGS=""
+ CFLAGS=""
+/* confdefs.h. */
+_ACEOF
int
@@ -2888,12 +2667,36 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
else
- ac_c_werror_flag=$ac_save_c_werror_flag
+ ac_c_werror_flag=$ac_save_c_werror_flag
CFLAGS="-g"
+/* confdefs.h. */
+_ACEOF
int
@@ -2904,17 +2707,42 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_prog_cc_g=yes
+else
fi
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_g" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_g" >&5
$as_echo "$ac_cv_prog_cc_g" >&6; }
if test "$ac_test_CFLAGS" = set; then
CFLAGS=$ac_save_CFLAGS
@@ -2931,18 +2759,23 @@ else
CFLAGS=
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for $CC option to accept ISO C89" >&5
+{ $as_echo "$as_me:$LINENO: checking for $CC option to accept ISO C89" >&5
$as_echo_n "checking for $CC option to accept ISO C89... " >&6; }
-if ${ac_cv_prog_cc_c89+:} false; then :
+if test "${ac_cv_prog_cc_c89+set}" = set; then
else
ac_cv_prog_cc_c89=no
ac_save_CC=$CC
+/* confdefs.h. */
+_ACEOF
#include <stdarg.h>
#include <stdio.h>
-struct stat;
+#include <sys/types.h>
+#include <sys/stat.h>
/* Most of the following tests are stolen from RCS 5.7's src/conf.sh. */
struct buf { int x; };
FILE * (*rcsopen) (struct buf *, struct stat *, int);
@@ -2994,9 +2827,32 @@ for ac_arg in '' -qlanglvl=extc89 -qlanglvl=ansi -std \
-Ae "-Aa -D_HPUX_SOURCE" "-Xc -D__EXTENSIONS__"
do
CC="$ac_save_CC $ac_arg"
- if ac_fn_c_try_compile "$LINENO"; then :
+ rm -f conftest.$ac_objext
+esac
+ ac_status=$?
ac_cv_prog_cc_c89=$ac_arg
+else
fi
test "x$ac_cv_prog_cc_c89" != "xno" && break
done
@@ -3007,19 +2863,17 @@ fi
# AC_CACHE_VAL
case "x$ac_cv_prog_cc_c89" in
x)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: none needed" >&5
+ { $as_echo "$as_me:$LINENO: result: none needed" >&5
$as_echo "none needed" >&6; } ;;
xno)
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: unsupported" >&5
+ { $as_echo "$as_me:$LINENO: result: unsupported" >&5
$as_echo "unsupported" >&6; } ;;
CC="$CC $ac_cv_prog_cc_c89"
- { $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_prog_cc_c89" >&5
+ { $as_echo "$as_me:$LINENO: result: $ac_cv_prog_cc_c89" >&5
$as_echo "$ac_cv_prog_cc_c89" >&6; } ;;
esac
-if test "x$ac_cv_prog_cc_c89" != xno; then :
-fi
ac_ext=c
@@ -3028,7 +2882,11 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
int
@@ -3039,15 +2897,38 @@ int ret = MPI_Init(0, (void*)0)
return 0;
_ACEOF
+esac
+ ac_status=$?
+ { $as_echo "$as_me:$LINENO: result: yes" >&5
else
- as_fn_error $? "CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line." "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line." >&5
+$as_echo "$as_me: error: CC doesn't appear to be a valid MPI compiler. See INSTALL document or try adding CC=mpicc to your configure command line." >&2;}
fi
ac_ext=c
@@ -3055,14 +2936,14 @@ ac_cpp='$CPP $CPPFLAGS'
ac_compile='$CC -c $CFLAGS $CPPFLAGS conftest.$ac_ext >&5'
ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $LIBS >&5'
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking how to run the C preprocessor" >&5
+{ $as_echo "$as_me:$LINENO: checking how to run the C preprocessor" >&5
$as_echo_n "checking how to run the C preprocessor... " >&6; }
# On Suns, sometimes $CPP names a directory.
if test -n "$CPP" && test -d "$CPP"; then
CPP=
fi
if test -z "$CPP"; then
- if ${ac_cv_prog_CPP+:} false; then :
+ if test "${ac_cv_prog_CPP+set}" = set; then
else
# Double quotes because CPP needs to be expanded
@@ -3077,7 +2958,11 @@ do
# <limits.h> exists even on freestanding compilers.
# On the NeXT, cc -E runs the code through the compiler's parser,
# not just through cpp. "Syntax error" is here to catch this case.
+/* confdefs.h. */
+_ACEOF
#ifdef __STDC__
# include <limits.h>
@@ -3086,34 +2971,78 @@ do
#endif
Syntax error
_ACEOF
+if { (ac_try="$ac_cpp conftest.$ac_ext"
+esac
+ (eval "$ac_cpp conftest.$ac_ext") 2>conftest.er1
+ ac_status=$?
+ (exit $ac_status); } >/dev/null && {
+ test -z "$ac_c_preproc_warn_flag$ac_c_werror_flag" ||
+ }; then
else
# Broken: fails on valid input.
continue
fi
+rm -f conftest.err conftest.$ac_ext
# OK, works on sane cases. Now check whether nonexistent headers
# can be detected and how.
+/* confdefs.h. */
+_ACEOF
#include <ac_nonexistent.h>
_ACEOF
+esac
+ ac_status=$?
+ }; then
# Broken: success on invalid input.
continue
else
# Passes both tests.
ac_preproc_ok=:
break
fi
done
# Because of `break', _AC_PREPROC_IFELSE's cleaning code was skipped.
-rm -f conftest.i conftest.err conftest.$ac_ext
-if $ac_preproc_ok; then :
+if $ac_preproc_ok; then
break
fi
@@ -3125,7 +3054,7 @@ fi
else
ac_cv_prog_CPP=$CPP
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $CPP" >&5
+{ $as_echo "$as_me:$LINENO: result: $CPP" >&5
$as_echo "$CPP" >&6; }
ac_preproc_ok=false
for ac_c_preproc_warn_flag in '' yes
@@ -3136,7 +3065,11 @@ do
+/* confdefs.h. */
+_ACEOF
#ifdef __STDC__
@@ -3145,40 +3078,87 @@ do
#endif
Syntax error
_ACEOF
+esac
+ ac_status=$?
+ }; then
else
continue
fi
+/* confdefs.h. */
+_ACEOF
_ACEOF
+esac
+ ac_status=$?
+ }; then
continue
else
ac_preproc_ok=:
break
fi
done
else
-as_fn_error $? "C preprocessor \"$CPP\" fails sanity check
+{ { $as_echo "$as_me:$LINENO: error: C preprocessor \"$CPP\" fails sanity check
+$as_echo "$as_me: error: C preprocessor \"$CPP\" fails sanity check
fi
ac_ext=c
@@ -3188,9 +3168,9 @@ ac_link='$CC -o conftest$ac_exeext $CFLAGS $CPPFLAGS $LDFLAGS conftest.$ac_ext $
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for grep that handles long lines and -e" >&5
+{ $as_echo "$as_me:$LINENO: checking for grep that handles long lines and -e" >&5
$as_echo_n "checking for grep that handles long lines and -e... " >&6; }
-if ${ac_cv_path_GREP+:} false; then :
+if test "${ac_cv_path_GREP+set}" = set; then
else
if test -z "$GREP"; then
@@ -3201,10 +3181,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
test -z "$as_dir" && as_dir=.
- for ac_prog in grep ggrep; do
+ for ac_prog in grep ggrep; do
ac_path_GREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_GREP" || continue
+ { test -f "$ac_path_GREP" && $as_test_x "$ac_path_GREP"; } || continue
# Check for GNU ac_path_GREP and select it if it is found.
# Check for GNU $ac_path_GREP
case `"$ac_path_GREP" --version 2>&1` in
@@ -3221,7 +3201,7 @@ case `"$ac_path_GREP" --version 2>&1` in
$as_echo 'GREP' >> "conftest.nl"
"$ac_path_GREP" -e 'GREP$' -e '-(cannot match)-' < "conftest.nl" >"conftest.out" 2>/dev/null || break
diff "conftest.out" "conftest.nl" >/dev/null 2>&1 || break
- as_fn_arith $ac_count + 1 && ac_count=$as_val
+ ac_count=`expr $ac_count + 1`
if test $ac_count -gt ${ac_path_GREP_max-0}; then
# Best one so far, save it but keep looking for a better one
ac_cv_path_GREP="$ac_path_GREP"
@@ -3236,24 +3216,26 @@ esac
$ac_path_GREP_found && break 3
done
done
- done
+done
IFS=$as_save_IFS
if test -z "$ac_cv_path_GREP"; then
- as_fn_error $? "no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
+$as_echo "$as_me: error: no acceptable grep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
fi
else
ac_cv_path_GREP=$GREP
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_GREP" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_GREP" >&5
$as_echo "$ac_cv_path_GREP" >&6; }
GREP="$ac_cv_path_GREP"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for egrep" >&5
+{ $as_echo "$as_me:$LINENO: checking for egrep" >&5
$as_echo_n "checking for egrep... " >&6; }
-if ${ac_cv_path_EGREP+:} false; then :
+if test "${ac_cv_path_EGREP+set}" = set; then
else
if echo a | $GREP -E '(a|b)' >/dev/null 2>&1
@@ -3267,10 +3249,10 @@ for as_dir in $PATH$PATH_SEPARATOR/usr/xpg4/bin
do
IFS=$as_save_IFS
- for ac_prog in egrep; do
+ for ac_prog in egrep; do
ac_path_EGREP="$as_dir/$ac_prog$ac_exec_ext"
- as_fn_executable_p "$ac_path_EGREP" || continue
+ { test -f "$ac_path_EGREP" && $as_test_x "$ac_path_EGREP"; } || continue
# Check for GNU ac_path_EGREP and select it if it is found.
# Check for GNU $ac_path_EGREP
case `"$ac_path_EGREP" --version 2>&1` in
@@ -3287,7 +3269,7 @@ case `"$ac_path_EGREP" --version 2>&1` in
$as_echo 'EGREP' >> "conftest.nl"
"$ac_path_EGREP" 'EGREP$' < "conftest.nl" >"conftest.out" 2>/dev/null || break
if test $ac_count -gt ${ac_path_EGREP_max-0}; then
ac_cv_path_EGREP="$ac_path_EGREP"
@@ -3302,10 +3284,12 @@ esac
$ac_path_EGREP_found && break 3
done
done
- done
+done
IFS=$as_save_IFS
if test -z "$ac_cv_path_EGREP"; then
- as_fn_error $? "no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&5
+$as_echo "$as_me: error: no acceptable egrep could be found in $PATH$PATH_SEPARATOR/usr/xpg4/bin" >&2;}
fi
else
ac_cv_path_EGREP=$EGREP
@@ -3313,17 +3297,21 @@ fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_path_EGREP" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_path_EGREP" >&5
$as_echo "$ac_cv_path_EGREP" >&6; }
EGREP="$ac_cv_path_EGREP"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for ANSI C header files" >&5
+{ $as_echo "$as_me:$LINENO: checking for ANSI C header files" >&5
$as_echo_n "checking for ANSI C header files... " >&6; }
-if ${ac_cv_header_stdc+:} false; then :
+if test "${ac_cv_header_stdc+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
#include <stdlib.h>
#include <stdarg.h>
@@ -3338,23 +3326,48 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_header_stdc=yes
else
- ac_cv_header_stdc=no
+ ac_cv_header_stdc=no
fi
if test $ac_cv_header_stdc = yes; then
# SunOS 4.x string.h does not declare mem*, contrary to ANSI.
+/* confdefs.h. */
+_ACEOF
#include <string.h>
_ACEOF
if (eval "$ac_cpp conftest.$ac_ext") 2>&5 |
- $EGREP "memchr" >/dev/null 2>&1; then :
+ $EGREP "memchr" >/dev/null 2>&1; then
else
fi
@@ -3364,14 +3377,18 @@ fi
# ISC 2.0.2 stdlib.h does not declare free, contrary to ANSI.
+/* confdefs.h. */
+_ACEOF
#include <stdlib.h>
_ACEOF
- $EGREP "free" >/dev/null 2>&1; then :
+ $EGREP "free" >/dev/null 2>&1; then
else
fi
@@ -3381,10 +3398,14 @@ fi
# /bin/cc in Irix-4.0.5 gets non-ANSI ctype macros unless using -ansi.
- if test "$cross_compiling" = yes; then :
+ if test "$cross_compiling" = yes; then
else
+/* confdefs.h. */
+_ACEOF
#include <ctype.h>
#include <stdlib.h>
@@ -3411,33 +3432,118 @@ main ()
return 0;
_ACEOF
-if ac_fn_c_try_run "$LINENO"; then :
+rm -f conftest$ac_exeext
+esac
+ (eval "$ac_link") 2>&5
+ ac_status=$?
+ (exit $ac_status); } && { ac_try='./conftest$ac_exeext'
+esac
+ ac_status=$?
else
+ $as_echo "$as_me: program exited with status $ac_status" >&5
+$as_echo "$as_me: failed program was:" >&5
+( exit $ac_status )
+ac_cv_header_stdc=no
fi
-rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext \
- conftest.$ac_objext conftest.beam conftest.$ac_ext
+rm -rf conftest.dSYM
+rm -f core *.core core.conftest.* gmon.out bb.out conftest$ac_exeext conftest.$ac_objext conftest.$ac_ext
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_header_stdc" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_stdc" >&5
$as_echo "$ac_cv_header_stdc" >&6; }
-$as_echo "#define STDC_HEADERS 1" >>confdefs.h
+cat >>confdefs.h <<\_ACEOF
+#define STDC_HEADERS 1
+_ACEOF
fi
# On IRIX 5.3, sys/types and inttypes.h are conflicting.
for ac_header in sys/types.h sys/stat.h stdlib.h string.h memory.h strings.h \
inttypes.h stdint.h unistd.h
-do :
- as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
-ac_fn_c_check_header_compile "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default
-if eval test \"x\$"$as_ac_Header"\" = x"yes"; then :
+do
+as_ac_Header=`$as_echo "ac_cv_header_$ac_header" | $as_tr_sh`
+{ $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
+$as_echo_n "checking for $ac_header... " >&6; }
+if { as_var=$as_ac_Header; eval "test \"\${$as_var+set}\" = set"; }; then
+ $as_echo_n "(cached) " >&6
+else
+/* confdefs.h. */
+_ACEOF
+/* end confdefs.h. */
+$ac_includes_default
+#include <$ac_header>
+_ACEOF
+esac
+ ac_status=$?
+ eval "$as_ac_Header=yes"
+else
+ eval "$as_ac_Header=no"
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+fi
+ac_res=`eval 'as_val=${'$as_ac_Header'}
+ $as_echo "$as_val"'`
+ { $as_echo "$as_me:$LINENO: result: $ac_res" >&5
+$as_echo "$ac_res" >&6; }
+as_val=`eval 'as_val=${'$as_ac_Header'}
+ if test "x$as_val" = x""yes; then
#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
@@ -3451,7 +3557,7 @@ done
# Check whether --with-zlib was given.
-if test "${with_zlib+set}" = set; then :
+if test "${with_zlib+set}" = set; then
withval=$with_zlib; if test "$withval" != no ; then
if test -d "$withval"
then
@@ -3461,31 +3567,166 @@ if test "${with_zlib+set}" = set; then :
__DARSHAN_ZLIB_LINK_FLAGS="-L${ZLIB_HOME}/lib"
__DARSHAN_ZLIB_INCLUDE_FLAGS="-I${ZLIB_HOME}/include"
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: Sorry, $withval does not exist, checking usual places" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: Sorry, $withval does not exist, checking usual places" >&5
$as_echo "$as_me: WARNING: Sorry, $withval does not exist, checking usual places" >&2;}
fi
else
- as_fn_error $? "zlib is required" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: zlib is required" >&5
+$as_echo "$as_me: error: zlib is required" >&2;}
+fi
+fi
+if test "${ac_cv_header_zlib_h+set}" = set; then
+ { $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
+$as_echo_n "checking for zlib.h... " >&6; }
+fi
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_header_zlib_h" >&5
+$as_echo "$ac_cv_header_zlib_h" >&6; }
+else
+ # Is the header compilable?
+{ $as_echo "$as_me:$LINENO: checking zlib.h usability" >&5
+$as_echo_n "checking zlib.h usability... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <zlib.h>
+_ACEOF
+esac
+ ac_status=$?
+ ac_header_compiler=yes
+else
+ ac_header_compiler=no
fi
+{ $as_echo "$as_me:$LINENO: result: $ac_header_compiler" >&5
+$as_echo "$ac_header_compiler" >&6; }
+# Is the header present?
+{ $as_echo "$as_me:$LINENO: checking zlib.h presence" >&5
+$as_echo_n "checking zlib.h presence... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <zlib.h>
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+ ac_header_preproc=yes
+else
+ ac_header_preproc=no
fi
+{ $as_echo "$as_me:$LINENO: result: $ac_header_preproc" >&5
+$as_echo "$ac_header_preproc" >&6; }
+# So? What about this header?
+case $ac_header_compiler:$ac_header_preproc:$ac_c_preproc_warn_flag in
+ yes:no: )
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: zlib.h: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: zlib.h: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: zlib.h: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: zlib.h: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: zlib.h: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: zlib.h: section \"Present But Cannot Be Compiled\"" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: proceeding with the preprocessor's result" >&5
+$as_echo "$as_me: WARNING: zlib.h: proceeding with the preprocessor's result" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: zlib.h: in the future, the compiler will take precedence" >&5
+$as_echo "$as_me: WARNING: zlib.h: in the future, the compiler will take precedence" >&2;}
-ac_fn_c_check_header_mongrel "$LINENO" "zlib.h" "ac_cv_header_zlib_h" "$ac_includes_default"
-if test "x$ac_cv_header_zlib_h" = xyes; then :
+esac
+{ $as_echo "$as_me:$LINENO: checking for zlib.h" >&5
+else
+ ac_cv_header_zlib_h=$ac_header_preproc
+fi
+fi
+if test "x$ac_cv_header_zlib_h" = x""yes; then
else
- as_fn_error $? "z.h not found" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: z.h not found" >&5
+$as_echo "$as_me: error: z.h not found" >&2;}
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for inflateEnd in -lz" >&5
+{ $as_echo "$as_me:$LINENO: checking for inflateEnd in -lz" >&5
$as_echo_n "checking for inflateEnd in -lz... " >&6; }
-if ${ac_cv_lib_z_inflateEnd+:} false; then :
+if test "${ac_cv_lib_z_inflateEnd+set}" = set; then
else
ac_check_lib_save_LIBS=$LIBS
LIBS="-lz $LIBS"
+/* confdefs.h. */
+_ACEOF
/* Override any GCC internal prototype to avoid an error.
@@ -3503,18 +3744,43 @@ return inflateEnd ();
return 0;
_ACEOF
-if ac_fn_c_try_link "$LINENO"; then :
+rm -f conftest.$ac_objext conftest$ac_exeext
+esac
+ (eval "$ac_link") 2>conftest.er1
+ ac_status=$?
+ } && test -s conftest$ac_exeext && {
+ test "$cross_compiling" = yes ||
+ $as_test_x conftest$ac_exeext
+ }; then
ac_cv_lib_z_inflateEnd=yes
else
- ac_cv_lib_z_inflateEnd=no
+ ac_cv_lib_z_inflateEnd=no
fi
-rm -f core conftest.err conftest.$ac_objext \
- conftest$ac_exeext conftest.$ac_ext
+rm -f core conftest.err conftest.$ac_objext conftest_ipa8_conftest.oo \
+ conftest$ac_exeext conftest.$ac_ext
LIBS=$ac_check_lib_save_LIBS
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_lib_z_inflateEnd" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_lib_z_inflateEnd" >&5
$as_echo "$ac_cv_lib_z_inflateEnd" >&6; }
-if test "x$ac_cv_lib_z_inflateEnd" = xyes; then :
+if test "x$ac_cv_lib_z_inflateEnd" = x""yes; then
#define HAVE_LIBZ 1
_ACEOF
@@ -3522,25 +3788,29 @@ _ACEOF
LIBS="-lz $LIBS"
else
- as_fn_error $? "libz not found" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: libz not found" >&5
+$as_echo "$as_me: error: libz not found" >&2;}
fi
# Check whether --enable-cuserid was given.
-if test "${enable_cuserid+set}" = set; then :
+if test "${enable_cuserid+set}" = set; then
enableval=$enable_cuserid; if test "x$enableval" = "xno" ; then
-$as_echo "#define DARSHAN_DISABLE_CUSERID 1" >>confdefs.h
+#define DARSHAN_DISABLE_CUSERID 1
+_ACEOF
fi
fi
# Check whether --enable-ld-preload was given.
-if test "${enable_ld_preload+set}" = set; then :
+if test "${enable_ld_preload+set}" = set; then
enableval=$enable_ld_preload; if test "x$enableval" = "xno" ; then
DISABLE_LDPRELOAD="1"
fi
@@ -3549,10 +3819,12 @@ fi
# Check whether --enable-group-readable-logs was given.
-if test "${enable_group_readable_logs+set}" = set; then :
+if test "${enable_group_readable_logs+set}" = set; then
enableval=$enable_group_readable_logs; if test "x$enableval" = "xyes" ; then
-$as_echo "#define __DARSHAN_GROUP_READABLE_LOGS 1" >>confdefs.h
+#define __DARSHAN_GROUP_READABLE_LOGS 1
+_ACEOF
fi
@@ -3561,9 +3833,11 @@ fi
# Check whether --with-mem-align was given.
-if test "${with_mem_align+set}" = set; then :
+if test "${with_mem_align+set}" = set; then
withval=$with_mem_align; if test x$withval = xyes; then
- as_fn_error $? "--with-mem-align must be given a number in bytes" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-mem-align must be given a number in bytes" >&5
+$as_echo "$as_me: error: --with-mem-align must be given a number in bytes" >&2;}
else
@@ -3578,9 +3852,11 @@ fi
# Check whether --with-log-path-by-env was given.
-if test "${with_log_path_by_env+set}" = set; then :
+if test "${with_log_path_by_env+set}" = set; then
withval=$with_log_path_by_env; if test x$withval = xyes; then
- as_fn_error $? "--with-log-path-by-env must be given at least one variable name" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-log-path-by-env must be given at least one variable name" >&5
+$as_echo "$as_me: error: --with-log-path-by-env must be given at least one variable name" >&2;}
else
@@ -3596,9 +3872,11 @@ fi
# Check whether --with-log-hints was given.
-if test "${with_log_hints+set}" = set; then :
+if test "${with_log_hints+set}" = set; then
withval=$with_log_hints; if test x$withval = xyes; then
- as_fn_error $? "--with-log-hints must be given an argument" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-log-hints must be given an argument" >&5
+$as_echo "$as_me: error: --with-log-hints must be given an argument" >&2;}
else
@@ -3614,9 +3892,11 @@ fi
# Check whether --with-log-path was given.
-if test "${with_log_path+set}" = set; then :
+if test "${with_log_path+set}" = set; then
withval=$with_log_path; if test x$withval = xyes; then
- as_fn_error $? "--with-log-path must be given a pathname" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-log-path must be given a pathname" >&5
+$as_echo "$as_me: error: --with-log-path must be given a pathname" >&2;}
else
@@ -3632,9 +3912,11 @@ fi
# Check whether --with-jobid-env was given.
-if test "${with_jobid_env+set}" = set; then :
+if test "${with_jobid_env+set}" = set; then
withval=$with_jobid_env; if test x$withval = xyes; then
- as_fn_error $? "--with-jobid-env must be given a name" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-jobid-env must be given a name" >&5
+$as_echo "$as_me: error: --with-jobid-env must be given a name" >&2;}
else
@@ -3649,13 +3931,19 @@ fi
if test x$GOT_ALIGNMENT != x1; then
- as_fn_error $? "must provide --with-mem-align=<num> argument to configure." "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: must provide --with-mem-align=<num> argument to configure." >&5
+$as_echo "$as_me: error: must provide --with-mem-align=<num> argument to configure." >&2;}
fi
if test x$GOT_LOG_PATH != x1; then
- as_fn_error $? "must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." >&5
+$as_echo "$as_me: error: must provide --with-log-path=<path> _or_ --with-log-path-by-env=<variable list> argument to configure." >&2;}
fi
if test x$GOT_JOBID != x1; then
- as_fn_error $? "must provide --with-jobid-env=<name> argument to configure." "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: must provide --with-jobid-env=<name> argument to configure." >&5
+$as_echo "$as_me: error: must provide --with-jobid-env=<name> argument to configure." >&2;}
fi
__DARSHAN_LOG_HINTS_DEFAULT="romio_no_indep_rw=true;cb_nodes=4"
if test x$GOT_LOG_HINTS != x1; then
@@ -3668,12 +3956,146 @@ fi
# checks to see how we can print 64 bit values on this architecture
- for ac_header in inttypes.h
-do :
- ac_fn_c_check_header_mongrel "$LINENO" "inttypes.h" "ac_cv_header_inttypes_h" "$ac_includes_default"
-if test "x$ac_cv_header_inttypes_h" = xyes; then :
+for ac_header in inttypes.h
+do
+ { $as_echo "$as_me:$LINENO: checking for $ac_header" >&5
+fi
+else
+{ $as_echo "$as_me:$LINENO: checking $ac_header usability" >&5
+$as_echo_n "checking $ac_header usability... " >&6; }
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+{ $as_echo "$as_me:$LINENO: checking $ac_header presence" >&5
+$as_echo_n "checking $ac_header presence... " >&6; }
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&5
+$as_echo "$as_me: WARNING: $ac_header: accepted by the compiler, rejected by the preprocessor!" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the compiler's result" >&5
+$as_echo "$as_me: WARNING: $ac_header: proceeding with the compiler's result" >&2;}
+ no:yes:* )
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: present but cannot be compiled" >&5
+$as_echo "$as_me: WARNING: $ac_header: present but cannot be compiled" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: check for missing prerequisite headers?" >&5
+$as_echo "$as_me: WARNING: $ac_header: check for missing prerequisite headers?" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: see the Autoconf documentation" >&5
+$as_echo "$as_me: WARNING: $ac_header: see the Autoconf documentation" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&5
+$as_echo "$as_me: WARNING: $ac_header: section \"Present But Cannot Be Compiled\"" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: proceeding with the preprocessor's result" >&5
+$as_echo "$as_me: WARNING: $ac_header: proceeding with the preprocessor's result" >&2;}
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_header: in the future, the compiler will take precedence" >&5
+$as_echo "$as_me: WARNING: $ac_header: in the future, the compiler will take precedence" >&2;}
+esac
+else
+ eval "$as_ac_Header=\$ac_header_preproc"
+fi
+fi
-#define HAVE_INTTYPES_H 1
+#define `$as_echo "HAVE_$ac_header" | $as_tr_cpp` 1
_ACEOF
fi
@@ -3681,13 +4103,17 @@ fi
done
if test $ac_cv_header_inttypes_h = yes; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether the inttypes.h PRIxNN macros are broken" >&5
+ { $as_echo "$as_me:$LINENO: checking whether the inttypes.h PRIxNN macros are broken" >&5
$as_echo_n "checking whether the inttypes.h PRIxNN macros are broken... " >&6; }
-if ${gt_cv_inttypes_pri_broken+:} false; then :
+if test "${gt_cv_inttypes_pri_broken+set}" = set; then
else
+/* confdefs.h. */
+_ACEOF
#include <inttypes.h>
#ifdef PRId32
@@ -3702,15 +4128,36 @@ main ()
return 0;
_ACEOF
-if ac_fn_c_try_compile "$LINENO"; then :
+esac
+ ac_status=$?
gt_cv_inttypes_pri_broken=no
else
- gt_cv_inttypes_pri_broken=yes
+ gt_cv_inttypes_pri_broken=yes
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $gt_cv_inttypes_pri_broken" >&5
+{ $as_echo "$as_me:$LINENO: result: $gt_cv_inttypes_pri_broken" >&5
$as_echo "$gt_cv_inttypes_pri_broken" >&6; }
fi
if test "$gt_cv_inttypes_pri_broken" = yes; then
@@ -3726,32 +4173,175 @@ _ACEOF
if test x$PRI_MACROS_BROKEN == xyes; then
- as_fn_error $? "PRI_xx macros are broken" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: PRI_xx macros are broken" >&5
+$as_echo "$as_me: error: PRI_xx macros are broken" >&2;}
+else
+do
+fi
+else
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ no:yes:* )
+esac
else
-do :
+fi
+fi
_ACEOF
else
- as_fn_error $? "Couldn't find inttypes.h" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: Couldn't find inttypes.h" >&5
+$as_echo "$as_me: error: Couldn't find inttypes.h" >&2;}
fi
done
fi
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking whether byte ordering is bigendian" >&5
+ { $as_echo "$as_me:$LINENO: checking whether byte ordering is bigendian" >&5
$as_echo_n "checking whether byte ordering is bigendian... " >&6; }
-if ${ac_cv_c_bigendian+:} false; then :
+if test "${ac_cv_c_bigendian+set}" = set; then
else
ac_cv_c_bigendian=unknown
# See if we're dealing with a universal compiler.
+/* confdefs.h. */
+_ACEOF
#ifndef __APPLE_CC__
not a universal capable compiler
@@ -3759,34 +4349,46 @@ else
typedef int dummy;
_ACEOF
+esac
+ ac_status=$?
# Check for potential -arch flags. It is not universal unless
- # there are at least two -arch flags with different values.
- ac_arch=
- ac_prev=
- for ac_word in $CC $CFLAGS $CPPFLAGS $LDFLAGS; do
- if test -n "$ac_prev"; then
- case $ac_word in
- i?86 | x86_64 | ppc | ppc64)
- if test -z "$ac_arch" || test "$ac_arch" = "$ac_word"; then
- ac_arch=$ac_word
- else
- ac_cv_c_bigendian=universal
- break
- fi
- esac
- ac_prev=
- elif test "x$ac_word" = "x-arch"; then
- ac_prev=arch
- fi
- done
+ # there are some -arch flags. Note that *ppc* also matches
+ # ppc64. This check is also rather less than ideal.
+ case "${CC} ${CFLAGS} ${CPPFLAGS} ${LDFLAGS}" in #(
+ *-arch*ppc*|*-arch*i386*|*-arch*x86_64*) ac_cv_c_bigendian=universal;;
+ esac
+else
fi
if test $ac_cv_c_bigendian = unknown; then
# See if sys/param.h defines the BYTE_ORDER macro.
+/* confdefs.h. */
+_ACEOF
#include <sys/param.h>
@@ -3804,9 +4406,30 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
# It does; now see whether it defined to BIG_ENDIAN or not.
+/* confdefs.h. */
+_ACEOF
@@ -3822,18 +4445,49 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
ac_cv_c_bigendian=yes
else
- ac_cv_c_bigendian=no
+ ac_cv_c_bigendian=no
fi
+else
fi
fi
# See if <limits.h> defines _LITTLE_ENDIAN or _BIG_ENDIAN (e.g., Solaris).
+/* confdefs.h. */
+_ACEOF
#include <limits.h>
@@ -3848,9 +4502,30 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
# It does; now see whether it defined to _BIG_ENDIAN or not.
+/* confdefs.h. */
+_ACEOF
#include <limits.h>
@@ -3865,20 +4540,51 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
else
fi
+else
fi
fi
# Compile a test program.
# Try to guess by grepping values from an object file.
+/* confdefs.h. */
+_ACEOF
short int ascii_mm[] =
{ 0x4249, 0x4765, 0x6E44, 0x6961, 0x6E53, 0x7953, 0 };
@@ -3904,7 +4610,24 @@ return use_ascii (foo) == use_ebcdic (foo);
return 0;
_ACEOF
+esac
+ ac_status=$?
if grep BIGenDianSyS conftest.$ac_objext >/dev/null; then
fi
@@ -3916,10 +4639,20 @@ if ac_fn_c_try_compile "$LINENO"; then :
fi
fi
+else
fi
else
+/* confdefs.h. */
+_ACEOF
int
@@ -3939,41 +4672,79 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
+esac
+ ac_status=$?
else
- ac_cv_c_bigendian=yes
+ac_cv_c_bigendian=yes
fi
fi
fi
fi
-{ $as_echo "$as_me:${as_lineno-$LINENO}: result: $ac_cv_c_bigendian" >&5
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_c_bigendian" >&5
$as_echo "$ac_cv_c_bigendian" >&6; }
case $ac_cv_c_bigendian in #(
yes)
- $as_echo "#define WORDS_BIGENDIAN 1" >>confdefs.h
+ cat >>confdefs.h <<\_ACEOF
+#define WORDS_BIGENDIAN 1
+_ACEOF
no)
universal)
-$as_echo "#define AC_APPLE_UNIVERSAL_BUILD 1" >>confdefs.h
+#define AC_APPLE_UNIVERSAL_BUILD 1
+_ACEOF
- as_fn_error $? "unknown endianness
- presetting ac_cv_c_bigendian=no (or yes) will help" "$LINENO" 5 ;;
+ { { $as_echo "$as_me:$LINENO: error: unknown endianness
+ presetting ac_cv_c_bigendian=no (or yes) will help" >&5
+$as_echo "$as_me: error: unknown endianness
+ presetting ac_cv_c_bigendian=no (or yes) will help" >&2;}
+ { (exit 1); exit 1; }; } ;;
esac
old_cflags="$CFLAGS"
CFLAGS="$CFLAGS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE64_SOURCE"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for struct aiocb64" >&5
+{ $as_echo "$as_me:$LINENO: checking for struct aiocb64" >&5
$as_echo_n "checking for struct aiocb64... " >&6; }
-cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* confdefs.h. */
+_ACEOF
#include <aio.h>
@@ -3986,25 +4757,52 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
-$as_echo "#define HAVE_AIOCB64 1" >>confdefs.h
+#define HAVE_AIOCB64 1
+_ACEOF
else
fi
CFLAGS="$old_cflags"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for off64_t" >&5
+{ $as_echo "$as_me:$LINENO: checking for off64_t" >&5
$as_echo_n "checking for off64_t... " >&6; }
+/* confdefs.h. */
+_ACEOF
#include <stdio.h>
@@ -4031,25 +4829,182 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
-$as_echo "#define HAVE_OFF64_T 1" >>confdefs.h
+#define HAVE_OFF64_T 1
+_ACEOF
else
fi
for ac_header in mntent.h sys/mount.h
-do :
-ac_fn_c_check_header_mongrel "$LINENO" "$ac_header" "$as_ac_Header" "$ac_includes_default"
+do
+fi
+else
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+else
+fi
+/* confdefs.h. */
+_ACEOF
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+fi
+ yes:no: )
+ no:yes:* )
+esac
+else
+fi
+fi
_ACEOF
@@ -4079,9 +5034,13 @@ prefix=$savePrefix
exec_prefix=$saveExecprefix
# determine if the MPI library includes MPI-IO functions or not
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO support in MPI" >&5
+{ $as_echo "$as_me:$LINENO: checking for MPI-IO support in MPI" >&5
$as_echo_n "checking for MPI-IO support in MPI... " >&6; }
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
int
@@ -4099,22 +5058,53 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
+ }; then
else
- as_fn_error $? "Darshan requires a version of MPI with MPI-IO support" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: Darshan requires a version of MPI with MPI-IO support" >&5
+$as_echo "$as_me: error: Darshan requires a version of MPI with MPI-IO support" >&2;}
fi
# At some point MPI-IO converted most API functions to be const correct. We
# need to test for this to determine how to define MPI-IO wrappers in
# Darshan. First we try compiling without cost qualifiers.
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO prototypes without const qualifier" >&5
+{ $as_echo "$as_me:$LINENO: checking for MPI-IO prototypes without const qualifier" >&5
$as_echo_n "checking for MPI-IO prototypes without const qualifier... " >&6; }
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
@@ -4130,18 +5120,42 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
else
# unable to compile without const qualifiers. Let's try again with
# const qualifiers.
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for MPI-IO prototypes with const qualifier" >&5
+ { $as_echo "$as_me:$LINENO: checking for MPI-IO prototypes with const qualifier" >&5
$as_echo_n "checking for MPI-IO prototypes with const qualifier... " >&6; }
- cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
@@ -4157,16 +5171,42 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
-$as_echo "#define HAVE_MPIIO_CONST 1" >>confdefs.h
+#define HAVE_MPIIO_CONST 1
+_ACEOF
+else
fi
fi
# determine if mpicc can create shared libraries that use MPI functions
@@ -4174,74 +5214,207 @@ old_cflags="$CFLAGS"
CFLAGS="$CFLAGS -shared -fpic -DPIC"
old_libs="$LIBS"
LIBS="$LIBS -ldl"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for shared libraries in MPI" >&5
+{ $as_echo "$as_me:$LINENO: checking for shared libraries in MPI" >&5
$as_echo_n "checking for shared libraries in MPI... " >&6; }
+/* confdefs.h. */
+_ACEOF
+#include <mpi.h>
+int
+main ()
+ int size;
+ MPI_Comm_size(MPI_COMM_WORLD, &size);
+ return 0;
+_ACEOF
+esac
+ ac_status=$?
+ }; then
+else
+$as_echo "no" >&6; }
+ { $as_echo "$as_me:$LINENO: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&5
+$as_echo "$as_me: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&2;}
+ DISABLE_LDPRELOAD="1"
+fi
+CFLAGS="$old_cflags"
+LIBS="$old_libs"
+# if this version of mpi defines an MPIO_Request type, then we assume that
+# we should use it in the nonblocking MPI-IO functions. This is necessary
+# for MPI 1.x implementations that did not use generalized requests yet in
+# MPI-IO. Later MPI implementations might typedef MPIO_Request to MPI_Request
+# so there is no harm in using the former if it is available there.
+{ $as_echo "$as_me:$LINENO: checking for MPIO_Request" >&5
+$as_echo_n "checking for MPIO_Request... " >&6; }
+if test "${ac_cv_type_MPIO_Request+set}" = set; then
+else
+ ac_cv_type_MPIO_Request=no
+/* confdefs.h. */
+_ACEOF
+#include <mpi.h>
+int
+main ()
+if (sizeof (MPIO_Request))
+ return 0;
+ return 0;
+_ACEOF
+esac
+ ac_status=$?
+/* confdefs.h. */
+_ACEOF
#include <mpi.h>
int
main ()
- int size;
- MPI_Comm_size(MPI_COMM_WORLD, &size);
+if (sizeof ((MPIO_Request)))
+ return 0;
return 0;
_ACEOF
+esac
+ ac_status=$?
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&5
-$as_echo "$as_me: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library" >&2;}
- DISABLE_LDPRELOAD="1"
+ ac_cv_type_MPIO_Request=yes
fi
-CFLAGS="$old_cflags"
-LIBS="$old_libs"
-# if this version of mpi defines an MPIO_Request type, then we assume that
-# we should use it in the nonblocking MPI-IO functions. This is necessary
-# for MPI 1.x implementations that did not use generalized requests yet in
-# MPI-IO. Later MPI implementations might typedef MPIO_Request to MPI_Request
-# so there is no harm in using the former if it is available there.
-ac_fn_c_check_type "$LINENO" "MPIO_Request" "ac_cv_type_MPIO_Request" "#include <mpi.h>
-if test "x$ac_cv_type_MPIO_Request" = xyes; then :
+else
+fi
-$as_echo "#define __D_MPI_REQUEST MPIO_Request" >>confdefs.h
+fi
+{ $as_echo "$as_me:$LINENO: result: $ac_cv_type_MPIO_Request" >&5
+$as_echo "$ac_cv_type_MPIO_Request" >&6; }
+if test "x$ac_cv_type_MPIO_Request" = x""yes; then
+#define __D_MPI_REQUEST MPIO_Request
+_ACEOF
else
-$as_echo "#define __D_MPI_REQUEST MPI_Request" >>confdefs.h
+#define __D_MPI_REQUEST MPI_Request
+_ACEOF
fi
-# attempt to detect librarly naming convention in mpi compiler script
-{ $as_echo "$as_me:${as_lineno-$LINENO}: checking for old (pre-3.1.1) style MPICH library naming convention" >&5
+# attempt to detect library naming convention in mpi compiler script
+if $CC -show foo.c -o foo >& /dev/null; then
+ { $as_echo "$as_me:$LINENO: checking for old (pre-3.1.1) style MPICH library naming convention" >&5
$as_echo_n "checking for old (pre-3.1.1) style MPICH library naming convention... " >&6; }
-if $CC -show foo.c -o foo |grep lmpich >& /dev/null; then :
+ if $CC -show foo.c -o foo |grep lmpich >& /dev/null; then
- MPICH_LIB_OLD=1
+ MPICH_LIB_OLD=1
else
- MPICH_LIB_OLD=0
+ MPICH_LIB_OLD=0
+fi
+else
+ MPICH_LIB_OLD=0
fi
# check to see whether the bgq instrumentation module should be built
# Check whether --enable-bgq_mod was given.
-if test "${enable_bgq_mod+set}" = set; then :
+if test "${enable_bgq_mod+set}" = set; then
enableval=$enable_bgq_mod;
else
enable_bgq_mod=check
@@ -4249,9 +5422,13 @@ else
fi
if test x$enable_bgq_mod != xno; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: checking for BG/Q environment" >&5
+ { $as_echo "$as_me:$LINENO: checking for BG/Q environment" >&5
$as_echo_n "checking for BG/Q environment... " >&6; }
+/* confdefs.h. */
+_ACEOF
#ifndef __bgq__
@@ -4266,25 +5443,51 @@ main ()
return 0;
_ACEOF
+esac
+ ac_status=$?
DARSHAN_USE_BGQ=1
else
- if test "x$enable_bgq_mod" = xyes; then :
- as_fn_error $? "BG/Q module enabled in non-BG/Q environment" "$LINENO" 5
+ if test "x$enable_bgq_mod" = xyes; then
+ { { $as_echo "$as_me:$LINENO: error: BG/Q module enabled in non-BG/Q environment" >&5
+$as_echo "$as_me: error: BG/Q module enabled in non-BG/Q environment" >&2;}
fi
fi
fi
# Check whether --with-mod-mem was given.
-if test "${with_mod_mem+set}" = set; then :
+if test "${with_mod_mem+set}" = set; then
withval=$with_mod_mem; if test x$withval = xyes; then
- as_fn_error $? "--with-mod-mem must be given a number" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: --with-mod-mem must be given a number" >&5
+$as_echo "$as_me: error: --with-mod-mem must be given a number" >&2;}
else
cat >>confdefs.h <<_ACEOF
@@ -4305,7 +5508,6 @@ DARSHAN_VERSION="3.0.0-pre3"
ac_config_files="$ac_config_files Makefile darshan-mk-log-dirs.pl darshan-gen-cc.pl darshan-gen-cxx.pl darshan-gen-fortran.pl darshan-base-ld-opts darshan-config share/craype-1.x/darshan-module share/craype-2.x/darshan-module lib/pkgconfig/darshan-runtime.pc share/mpi-profile/darshan-cc.conf share/mpi-profile/darshan-cxx.conf share/mpi-profile/darshan-f.conf share/mpi-profile/darshan-bg-cc.conf share/mpi-profile/darshan-bg-cxx.conf share/mpi-profile/darshan-bg-f.conf"
cat >confcache <<\_ACEOF
@@ -4335,13 +5537,13 @@ _ACEOF
case $ac_val in #(
*${as_nl}*)
case $ac_var in #(
- *_cv_*) { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: cache variable $ac_var contains a newline" >&5
+ *_cv_*) { $as_echo "$as_me:$LINENO: WARNING: cache variable $ac_var contains a newline" >&5
$as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
esac
case $ac_var in #(
_ | IFS | as_nl) ;; #(
BASH_ARGV | BASH_SOURCE) eval $ac_var= ;; #(
- *) { eval $ac_var=; unset $ac_var;} ;;
+ *) $as_unset $ac_var ;;
esac ;;
esac
done
@@ -4349,8 +5551,8 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
(set) 2>&1 |
case $as_nl`(ac_space=' '; set) 2>&1` in #(
*${as_nl}ac_space=\ *)
- # `set' does not quote correctly, so add quotes: double-quote
- # substitution turns \\\\ into \\, and sed turns \\ into \.
+ # `set' does not quote correctly, so add quotes (double-quote
+ # substitution turns \\\\ into \\, and sed turns \\ into \).
sed -n \
"s/'/'\\\\''/g;
s/^\\([_$as_cr_alnum]*_cv_[_$as_cr_alnum]*\\)=\\(.*\\)/\\1='\\2'/p"
@@ -4372,23 +5574,12 @@ $as_echo "$as_me: WARNING: cache variable $ac_var contains a newline" >&2;} ;;
:end' >>confcache
if diff "$cache_file" confcache >/dev/null 2>&1; then :; else
if test -w "$cache_file"; then
- if test "x$cache_file" != "x/dev/null"; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: updating cache $cache_file" >&5
+ test "x$cache_file" != "x/dev/null" &&
+ { $as_echo "$as_me:$LINENO: updating cache $cache_file" >&5
$as_echo "$as_me: updating cache $cache_file" >&6;}
- if test ! -f "$cache_file" || test -h "$cache_file"; then
- cat confcache >"$cache_file"
- else
- case $cache_file in #(
- mv -f confcache "$cache_file"$$ &&
- mv -f "$cache_file"$$ "$cache_file" ;; #(
- mv -f confcache "$cache_file" ;;
- esac
- fi
- fi
+ cat confcache >$cache_file
else
- { $as_echo "$as_me:${as_lineno-$LINENO}: not updating unwritable cache $cache_file" >&5
+ { $as_echo "$as_me:$LINENO: not updating unwritable cache $cache_file" >&5
$as_echo "$as_me: not updating unwritable cache $cache_file" >&6;}
fi
fi
@@ -4402,15 +5593,14 @@ DEFS=-DHAVE_CONFIG_H
ac_libobjs=
ac_ltlibobjs=
-U=
for ac_i in : $LIBOBJS; do test "x$ac_i" = x: && continue
# 1. Remove the extension, and $U if already installed.
ac_script='s/\$U\././;s/\.o$//;s/\.obj$//'
ac_i=`$as_echo "$ac_i" | sed "$ac_script"`
# 2. Prepend LIBOBJDIR. When used with automake>=1.10 LIBOBJDIR
# will be set to the directory where LIBOBJS objects are built.
- as_fn_append ac_libobjs " \${LIBOBJDIR}$ac_i\$U.$ac_objext"
- as_fn_append ac_ltlibobjs " \${LIBOBJDIR}$ac_i"'$U.lo'
+ ac_libobjs="$ac_libobjs \${LIBOBJDIR}$ac_i\$U.$ac_objext"
+ ac_ltlibobjs="$ac_ltlibobjs \${LIBOBJDIR}$ac_i"'$U.lo'
done
LIBOBJS=$ac_libobjs
@@ -4419,14 +5609,13 @@ LTLIBOBJS=$ac_ltlibobjs
-: "${CONFIG_STATUS=./config.status}"
+: ${CONFIG_STATUS=./config.status}
ac_write_fail=0
ac_clean_files_save=$ac_clean_files
ac_clean_files="$ac_clean_files $CONFIG_STATUS"
-{ $as_echo "$as_me:${as_lineno-$LINENO}: creating $CONFIG_STATUS" >&5
+{ $as_echo "$as_me:$LINENO: creating $CONFIG_STATUS" >&5
$as_echo "$as_me: creating $CONFIG_STATUS" >&6;}
-as_write_fail=0
-cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
+cat >$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
#! $SHELL
# Generated by $as_me.
# Run this file to recreate the current configuration.
@@ -4436,18 +5625,17 @@ cat >$CONFIG_STATUS <<_ASEOF || as_write_fail=1
debug=false
ac_cs_recheck=false
ac_cs_silent=false
SHELL=\${CONFIG_SHELL-$SHELL}
-export SHELL
-_ASEOF
-cat >>$CONFIG_STATUS <<\_ASEOF || as_write_fail=1
-## M4sh Initialization. ##
+_ACEOF
+cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
+## M4sh Initialization. ##
# Be more Bourne compatible
DUALCASE=1; export DUALCASE # for MKS sh
-if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
+if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then
emulate sh
NULLCMD=:
# Pre-4.2 versions of Zsh do word splitting on ${1+"$@"}, which
@@ -4455,15 +5643,23 @@ if test -n "${ZSH_VERSION+set}" && (emulate sh) >/dev/null 2>&1; then :
alias -g '${1+"$@"}'='"$@"'
setopt NO_GLOB_SUBST
else
- case `(set -o) 2>/dev/null` in #(
- *posix*) :
- set -o posix ;; #(
+ case `(set -o) 2>/dev/null` in
+ *posix*) set -o posix ;;
esac
fi
+# PATH needs CR
+# Avoid depending upon Character Ranges.
+as_cr_letters='abcdefghijklmnopqrstuvwxyz'
+as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
+as_cr_Letters=$as_cr_letters$as_cr_LETTERS
+as_cr_digits='0123456789'
+as_cr_alnum=$as_cr_Letters$as_cr_digits
as_nl='
export as_nl
@@ -4471,13 +5667,7 @@ export as_nl
as_echo='\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\'
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo
as_echo=$as_echo$as_echo$as_echo$as_echo$as_echo$as_echo
-# Prefer a ksh shell builtin over an external printf program on Solaris,
-# but without wasting forks for bash or zsh.
-if test -z "$BASH_VERSION$ZSH_VERSION" \
- && (test "X`print -r -- $as_echo`" = "X$as_echo") 2>/dev/null; then
- as_echo='print -r --'
- as_echo_n='print -rn --'
-elif (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
+if (test "X`printf %s $as_echo`" = "X$as_echo") 2>/dev/null; then
as_echo='printf %s\n'
as_echo_n='printf %s'
else
@@ -4488,7 +5678,7 @@ else
as_echo_body='eval expr "X$1" : "X\\(.*\\)"'
as_echo_n_body='eval
arg=$1;
- case $arg in #(
+ case $arg in
*"$as_nl"*)
expr "X$arg" : "X\\(.*\\)$as_nl";
arg=`expr "X$arg" : ".*$as_nl\\(.*\\)"`;;
@@ -4511,6 +5701,13 @@ if test "${PATH_SEPARATOR+set}" != set; then
fi
+# Support unset when possible.
+if ( (MAIL=60; unset MAIL) || exit) >/dev/null 2>&1; then
+ as_unset=unset
+else
+ as_unset=false
+fi
# IFS
# We need space, tab and new line, in precisely that order. Quoting is
@@ -4520,16 +5717,15 @@ fi
IFS=" "" $as_nl"
# Find who we are. Look in the path if we contain no directory separator.
-as_myself=
-case $0 in #((
+case $0 in
*[\\/]* ) as_myself=$0 ;;
*) as_save_IFS=$IFS; IFS=$PATH_SEPARATOR
for as_dir in $PATH
do
IFS=$as_save_IFS
- test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
- done
+ test -r "$as_dir/$0" && as_myself=$as_dir/$0 && break
+done
IFS=$as_save_IFS
@@ -4541,16 +5737,12 @@ if test "x$as_myself" = x; then
fi
if test ! -f "$as_myself"; then
$as_echo "$as_myself: error: cannot find myself; rerun with an absolute file name" >&2
- exit 1
fi
-# Unset variables that we do not need and which cause bugs (e.g. in
-# pre-3.0 UWIN ksh). But do not cause bugs in bash 2.01; the "|| exit 1"
-# suppresses any "Segmentation fault" message there. '((' could
-# trigger a bug in pdksh 5.2.14.
-for as_var in BASH_ENV ENV MAIL MAILPATH
-do eval test x\${$as_var+set} = xset \
- && ( (unset $as_var) || exit 1) >/dev/null 2>&1 && unset $as_var || :
+# Work around bugs in pre-3.0 UWIN ksh.
+for as_var in ENV MAIL MAILPATH
+do ($as_unset $as_var) >/dev/null 2>&1 && $as_unset $as_var
done
PS1='$ '
PS2='> '
@@ -4562,89 +5754,7 @@ export LC_ALL
LANGUAGE=C
export LANGUAGE
-# CDPATH.
-(unset CDPATH) >/dev/null 2>&1 && unset CDPATH
-# as_fn_error STATUS ERROR [LINENO LOG_FD]
-# Output "`basename $0`: error: ERROR" to stderr. If LINENO and LOG_FD are
-# provided, also output the error to LOG_FD, referencing LINENO. Then exit the
-# script with STATUS, using 1 if that was 0.
-as_fn_error ()
- as_status=$1; test $as_status -eq 0 && as_status=1
- if test "$4"; then
- as_lineno=${as_lineno-"$3"} as_lineno_stack=as_lineno_stack=$as_lineno_stack
- $as_echo "$as_me:${as_lineno-$LINENO}: error: $2" >&$4
- fi
- $as_echo "$as_me: error: $2" >&2
- as_fn_exit $as_status
-} # as_fn_error
-# as_fn_set_status STATUS
-# Set $? to STATUS, without forking.
-as_fn_set_status ()
- return $1
-} # as_fn_set_status
-# as_fn_exit STATUS
-# Exit the shell with STATUS, even in a "trap 0" or "set -e" context.
-as_fn_exit ()
- set +e
- as_fn_set_status $1
- exit $1
-} # as_fn_exit
-# as_fn_unset VAR
-# Portably unset VAR.
-as_fn_unset ()
- { eval $1=; unset $1;}
-as_unset=as_fn_unset
-# as_fn_append VAR VALUE
-# Append the text in VALUE to the end of the definition contained in VAR. Take
-# advantage of any shell optimizations that allow amortized linear growth over
-# repeated appends, instead of the typical quadratic growth present in naive
-# implementations.
-if (eval "as_var=1; as_var+=2; test x\$as_var = x12") 2>/dev/null; then :
- eval 'as_fn_append ()
- eval $1+=\$2
-else
- as_fn_append ()
- eval $1=\$$1\$2
-fi # as_fn_append
-# as_fn_arith ARG...
-# Perform arithmetic evaluation on the ARGs, and store the result in the
-# global $as_val. Take advantage of shells that can avoid forks. The arguments
-# must be portable across $(()) and expr.
-if (eval "test \$(( 1 + 1 )) = 2") 2>/dev/null; then :
- eval 'as_fn_arith ()
- as_val=$(( $* ))
-else
- as_fn_arith ()
- as_val=`expr "$@" || test $? -eq 1`
-fi # as_fn_arith
+# Required to use basename.
if expr a : '\(a\)' >/dev/null 2>&1 &&
test "X`expr 00001 : '.*\(...\)'`" = X001; then
as_expr=expr
@@ -4658,12 +5768,8 @@ else
as_basename=false
fi
-if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
- as_dirname=dirname
-else
- as_dirname=false
-fi
+# Name of the executable.
as_me=`$as_basename -- "$0" ||
$as_expr X/"$0" : '.*/\([^/][^/]*\)/*$' \| \
X"$0" : 'X\(//\)$' \| \
@@ -4683,25 +5789,76 @@ $as_echo X/"$0" |
s/.*/./; q'`
-# Avoid depending upon Character Ranges.
-as_cr_letters='abcdefghijklmnopqrstuvwxyz'
-as_cr_LETTERS='ABCDEFGHIJKLMNOPQRSTUVWXYZ'
-as_cr_Letters=$as_cr_letters$as_cr_LETTERS
-as_cr_digits='0123456789'
-as_cr_alnum=$as_cr_Letters$as_cr_digits
+# CDPATH.
+$as_unset CDPATH
+ as_lineno_1=$LINENO
+ as_lineno_2=$LINENO
+ test "x$as_lineno_1" != "x$as_lineno_2" &&
+ test "x`expr $as_lineno_1 + 1`" = "x$as_lineno_2" || {
+ # Create $as_me.lineno as a copy of $as_myself, but with $LINENO
+ # uniformly replaced by the line number. The first 'sed' inserts a
+ # line-number line after each line using $LINENO; the second 'sed'
+ # does the real work. The second script uses 'N' to pair each
+ # line-number line with the line containing $LINENO, and appends
+ # trailing '-' during substitution so that $LINENO is not a special
+ # case at line end.
+ # (Raja R Harinath suggested sed '=', and Paul Eggert wrote the
+ # scripts with optimization help from Paolo Bonzini. Blame Lee
+ # E. McMahon (1931-1989) for sed's syntax. :-)
+ sed -n '
+ p
+ /[$]LINENO/=
+ ' <$as_myself |
+ sed '
+ s/[$]LINENO.*/&-/
+ t lineno
+ b
+ :lineno
+ N
+ :loop
+ s/[$]LINENO\([^'$as_cr_alnum'_].*\n\)\(.*\)/\2\1\2/
+ t loop
+ s/-\n.*//
+ ' >$as_me.lineno &&
+ chmod +x "$as_me.lineno" ||
+ { $as_echo "$as_me: error: cannot create $as_me.lineno; rerun with a POSIX shell" >&2
+ # Don't try to exec as it changes $[0], causing all sort of problems
+ # (the dirname of $[0] is not the place where we might find the
+ # original and so on. Autoconf is especially sensitive to this).
+ . "./$as_me.lineno"
+ # Exit status is that of the last command.
+ exit
+if (as_dir=`dirname -- /` && test "X$as_dir" = X/) >/dev/null 2>&1; then
+ as_dirname=dirname
+else
+ as_dirname=false
+fi
ECHO_C= ECHO_N= ECHO_T=
-case `echo -n x` in #(((((
+case `echo -n x` in
-n*)
- case `echo 'xy\c'` in
+ case `echo 'x\c'` in
*c*) ECHO_T=' ';; # ECHO_T is single tab character.
- xy) ECHO_C='\c';;
- *) echo `echo ksh88 bug on AIX 6.1` > /dev/null
- ECHO_T=' ';;
+ *) ECHO_C='\c';;
esac;;
ECHO_N='-n';;
esac
+if expr a : '\(a\)' >/dev/null 2>&1 &&
+ test "X`expr 00001 : '.*\(...\)'`" = X001; then
+ as_expr=expr
+else
+ as_expr=false
+fi
rm -f conf$$ conf$$.exe conf$$.file
if test -d conf$$.dir; then
@@ -4716,85 +5873,49 @@ if (echo >conf$$.file) 2>/dev/null; then
# ... but there are two gotchas:
# 1) On MSYS, both `ln -s file dir' and `ln file dir' fail.
# 2) DJGPP < 2.04 has no symlinks; `ln -s' creates a wrapper executable.
- # In both cases, we have to default to `cp -pR'.
+ # In both cases, we have to default to `cp -p'.
ln -s conf$$.file conf$$.dir 2>/dev/null && test ! -f conf$$.exe ||
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
elif ln conf$$.file conf$$ 2>/dev/null; then
as_ln_s=ln
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
else
- as_ln_s='cp -pR'
+ as_ln_s='cp -p'
fi
rm -f conf$$ conf$$.exe conf$$.dir/conf$$.file conf$$.file
rmdir conf$$.dir 2>/dev/null
-# as_fn_mkdir_p
-# Create "$as_dir" as a directory, including parents if necessary.
-as_fn_mkdir_p ()
- case $as_dir in #(
- -*) as_dir=./$as_dir;;
- esac
- test -d "$as_dir" || eval $as_mkdir_p || {
- as_dirs=
- while :; do
- *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
- *) as_qdir=$as_dir;;
- esac
- as_dirs="'$as_qdir' $as_dirs"
- as_dir=`$as_dirname -- "$as_dir" ||
-$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
- X"$as_dir" : 'X\(//\)[^/]' \| \
- X"$as_dir" : 'X\(//\)$' \| \
- X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
-$as_echo X"$as_dir" |
- sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
- s//\1/
- q
- /^X\(\/\/\)[^/].*/{
- s//\1/
- q
- /^X\(\/\/\)$/{
- s//\1/
- q
- /^X\(\/\).*/{
- s//\1/
- q
- s/.*/./; q'`
- test -d "$as_dir" && break
- done
- test -z "$as_dirs" || eval "mkdir $as_dirs"
- } || test -d "$as_dir" || as_fn_error $? "cannot create directory $as_dir"
-} # as_fn_mkdir_p
if mkdir -p . 2>/dev/null; then
- as_mkdir_p='mkdir -p "$as_dir"'
+ as_mkdir_p=:
else
test -d ./-p && rmdir ./-p
as_mkdir_p=false
fi
-# as_fn_executable_p FILE
-# Test if FILE is an executable regular file.
-as_fn_executable_p ()
- test -f "$1" && test -x "$1"
-} # as_fn_executable_p
-as_test_x='test -x'
-as_executable_p=as_fn_executable_p
+if test -x / >/dev/null 2>&1; then
+ as_test_x='test -x'
+else
+ if ls -dL / >/dev/null 2>&1; then
+ as_ls_L_option=L
+ else
+ as_ls_L_option=
+ fi
+ as_test_x='
+ eval sh -c '\''
+ if test -d "$1"; then
+ test -d "$1/.";
+ else
+ case $1 in
+ -*)set "./$1";;
+ esac;
+ case `ls -ld'$as_ls_L_option' "$1" 2>/dev/null` in
+ ???[sx]*):;;*)false;;esac;fi
+ '\'' sh
+fi
+as_executable_p=$as_test_x
# Sed expression to map a string onto a valid CPP name.
as_tr_cpp="eval sed 'y%*$as_cr_letters%P$as_cr_LETTERS%;s%[^_$as_cr_alnum]%_%g'"
@@ -4804,19 +5925,13 @@ as_tr_sh="eval sed 'y%*+%pp%;s%[^_$as_cr_alnum]%_%g'"
exec 6>&1
-## Main body of $CONFIG_STATUS script. ##
-_ASEOF
-test $as_write_fail = 0 && chmod +x $CONFIG_STATUS || ac_write_fail=1
-cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
-# Save the log message, to keep $0 and so on meaningful, and to
+# Save the log message, to keep $[0] and so on meaningful, and to
# report actual input values of CONFIG_FILES etc. instead of their
# values after options handling.
ac_log="
This file was extended by darshan-runtime $as_me 3.0.0-pre3, which was
-generated by GNU Autoconf 2.69. Invocation command line was
+generated by GNU Autoconf 2.63. Invocation command line was
CONFIG_FILES = $CONFIG_FILES
CONFIG_HEADERS = $CONFIG_HEADERS
@@ -4847,15 +5962,13 @@ _ACEOF
ac_cs_usage="\
-\`$as_me' instantiates files and other configuration actions
-from templates according to the current configuration. Unless the files
-and actions are specified as TAGs, all are instantiated by default.
+\`$as_me' instantiates files from templates according to the
+current configuration.
-Usage: $0 [OPTION]... [TAG]...
+Usage: $0 [OPTION]... [FILE]...
-h, --help print this help, then exit
-V, --version print version number and configuration settings, then exit
- --config print configuration, then exit
-q, --quiet, --silent
do not print progress messages
-d, --debug don't remove temporary files
@@ -4871,17 +5984,16 @@ $config_files
Configuration headers:
$config_headers
-Report bugs to the package provider."
+Report bugs to <bug-autoconf at gnu.org>."
_ACEOF
cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
-ac_cs_config="`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`"
ac_cs_version="\\
darshan-runtime config.status 3.0.0-pre3
-configured by $0, generated by GNU Autoconf 2.69,
- with options \\"\$ac_cs_config\\"
+configured by $0, generated by GNU Autoconf 2.63,
+ with options \\"`$as_echo "$ac_configure_args" | sed 's/^ //; s/[\\""\`\$]/\\\\&/g'`\\"
-Copyright (C) 2012 Free Software Foundation, Inc.
+Copyright (C) 2008 Free Software Foundation, Inc.
This config.status script is free software; the Free Software Foundation
gives unlimited permission to copy, distribute and modify it."
@@ -4897,16 +6009,11 @@ ac_need_defaults=:
while test $# != 0
do
case $1 in
ac_option=`expr "X$1" : 'X\([^=]*\)='`
ac_optarg=`expr "X$1" : 'X[^=]*=\(.*\)'`
ac_shift=:
- ac_option=`expr "X$1" : 'X\([^=]*\)='`
- ac_optarg=
- ac_shift=:
ac_option=$1
ac_optarg=$2
@@ -4920,29 +6027,27 @@ do
ac_cs_recheck=: ;;
--version | --versio | --versi | --vers | --ver | --ve | --v | -V )
$as_echo "$ac_cs_version"; exit ;;
- --config | --confi | --conf | --con | --co | --c )
- $as_echo "$ac_cs_config"; exit ;;
--debug | --debu | --deb | --de | --d | -d )
debug=: ;;
--file | --fil | --fi | --f )
$ac_shift
case $ac_optarg in
*\'*) ac_optarg=`$as_echo "$ac_optarg" | sed "s/'/'\\\\\\\\''/g"` ;;
- '') as_fn_error $? "missing file argument" ;;
esac
- as_fn_append CONFIG_FILES " '$ac_optarg'"
+ CONFIG_FILES="$CONFIG_FILES '$ac_optarg'"
ac_need_defaults=false;;
--header | --heade | --head | --hea )
$ac_shift
case $ac_optarg in
esac
- as_fn_append CONFIG_HEADERS " '$ac_optarg'"
+ CONFIG_HEADERS="$CONFIG_HEADERS '$ac_optarg'"
--he | --h)
# Conflict between --help and --header
- as_fn_error $? "ambiguous option: \`$1'
-Try \`$0 --help' for more information.";;
+ { $as_echo "$as_me: error: ambiguous option: $1
+Try \`$0 --help' for more information." >&2
+ { (exit 1); exit 1; }; };;
--help | --hel | -h )
$as_echo "$ac_cs_usage"; exit ;;
-q | -quiet | --quiet | --quie | --qui | --qu | --q \
@@ -4950,10 +6055,11 @@ Try \`$0 --help' for more information.";;
ac_cs_silent=: ;;
# This is an error.
- -*) as_fn_error $? "unrecognized option: \`$1'
-Try \`$0 --help' for more information." ;;
+ -*) { $as_echo "$as_me: error: unrecognized option: $1
- *) as_fn_append ac_config_targets " $1"
+ *) ac_config_targets="$ac_config_targets $1"
ac_need_defaults=false ;;
esac
@@ -4970,7 +6076,7 @@ fi
_ACEOF
if \$ac_cs_recheck; then
- set X $SHELL '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
+ set X '$SHELL' '$0' $ac_configure_args \$ac_configure_extra_args --no-create --no-recursion
shift
\$as_echo "running CONFIG_SHELL=$SHELL \$*" >&6
CONFIG_SHELL='$SHELL'
@@ -5017,7 +6123,9 @@ do
"share/mpi-profile/darshan-bg-cxx.conf") CONFIG_FILES="$CONFIG_FILES share/mpi-profile/darshan-bg-cxx.conf" ;;
"share/mpi-profile/darshan-bg-f.conf") CONFIG_FILES="$CONFIG_FILES share/mpi-profile/darshan-bg-f.conf" ;;
- *) as_fn_error $? "invalid argument: \`$ac_config_target'" "$LINENO" 5;;
+ *) { { $as_echo "$as_me:$LINENO: error: invalid argument: $ac_config_target" >&5
+$as_echo "$as_me: error: invalid argument: $ac_config_target" >&2;}
esac
done
@@ -5039,24 +6147,26 @@ fi
# after its creation but before its name has been assigned to `$tmp'.
$debug ||
- tmp= ac_tmp=
+ tmp=
trap 'exit_status=$?
- : "${ac_tmp:=$tmp}"
- { test ! -d "$ac_tmp" || rm -fr "$ac_tmp"; } && exit $exit_status
+ { test -z "$tmp" || test ! -d "$tmp" || rm -fr "$tmp"; } && exit $exit_status
' 0
- trap 'as_fn_exit 1' 1 2 13 15
+ trap '{ (exit 1); exit 1; }' 1 2 13 15
# Create a (secure) tmp directory for tmp files.
tmp=`(umask 077 && mktemp -d "./confXXXXXX") 2>/dev/null` &&
- test -d "$tmp"
+ test -n "$tmp" && test -d "$tmp"
tmp=./conf$$-$RANDOM
(umask 077 && mkdir "$tmp")
-} || as_fn_error $? "cannot create a temporary directory in ." "$LINENO" 5
-ac_tmp=$tmp
+ $as_echo "$as_me: cannot create a temporary directory in ." >&2
# Set up the scripts for CONFIG_FILES section.
# No need to generate them if there are no CONFIG_FILES.
@@ -5064,13 +6174,7 @@ ac_tmp=$tmp
if test -n "$CONFIG_FILES"; then
-ac_cr=`echo X | tr X '\015'`
-# On cygwin, bash can eat \r inside `` if the user requested igncr.
-# But we know of no other shell where ac_cr would be empty at this
-# point, so we can use a bashism as a fallback.
-if test "x$ac_cr" = x; then
- eval ac_cr=\$\'\\r\'
-fi
+ac_cr='
ac_cs_awk_cr=`$AWK 'BEGIN { print "a\rb" }' </dev/null 2>/dev/null`
if test "$ac_cs_awk_cr" = "a${ac_cr}b"; then
ac_cs_awk_cr='\\r'
@@ -5078,7 +6182,7 @@ else
ac_cs_awk_cr=$ac_cr
fi
-echo 'BEGIN {' >"$ac_tmp/subs1.awk" &&
+echo 'BEGIN {' >"$tmp/subs1.awk" &&
_ACEOF
@@ -5087,18 +6191,24 @@ _ACEOF
echo "$ac_subst_vars" | sed 's/.*/&!$&$ac_delim/' &&
echo "_ACEOF"
} >conf$$subs.sh ||
- as_fn_error $? "could not make $CONFIG_STATUS" "$LINENO" 5
-ac_delim_num=`echo "$ac_subst_vars" | grep -c '^'`
+ { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_STATUS" >&5
+$as_echo "$as_me: error: could not make $CONFIG_STATUS" >&2;}
+ac_delim_num=`echo "$ac_subst_vars" | grep -c '$'`
ac_delim='%!_!# '
for ac_last_try in false false false false false :; do
. ./conf$$subs.sh ||
ac_delim_n=`sed -n "s/.*$ac_delim\$/X/p" conf$$subs.awk | grep -c X`
if test $ac_delim_n = $ac_delim_num; then
break
elif $ac_last_try; then
else
ac_delim="$ac_delim!$ac_delim _$ac_delim!! "
fi
@@ -5106,7 +6216,7 @@ done
rm -f conf$$subs.sh
-cat >>"\$ac_tmp/subs1.awk" <<\\_ACAWK &&
+cat >>"\$tmp/subs1.awk" <<\\_ACAWK &&
_ACEOF
sed -n '
h
@@ -5120,7 +6230,7 @@ s/'"$ac_delim"'$//
t delim
:nl
h
-s/\(.\{148\}\)..*/\1/
+s/\(.\{148\}\).*/\1/
t more1
s/["\\]/\\&/g; s/^/"/; s/$/\\n"\\/
p
@@ -5134,7 +6244,7 @@ s/.\{148\}//
t nl
:delim
h
t more2
s/["\\]/\\&/g; s/^/"/; s/$/"/
p
@@ -5154,7 +6264,7 @@ t delim
rm -f conf$$subs.awk
_ACAWK
-cat >>"\$ac_tmp/subs1.awk" <<_ACAWK &&
+cat >>"\$tmp/subs1.awk" <<_ACAWK &&
for (key in S) S_is_set[key] = 1
FS = ""
@@ -5186,29 +6296,23 @@ if sed "s/$ac_cr//" < /dev/null > /dev/null 2>&1; then
sed "s/$ac_cr\$//; s/$ac_cr/$ac_cs_awk_cr/g"
else
cat
-fi < "$ac_tmp/subs1.awk" > "$ac_tmp/subs.awk" \
- || as_fn_error $? "could not setup config files machinery" "$LINENO" 5
+fi < "$tmp/subs1.awk" > "$tmp/subs.awk" \
+ || { { $as_echo "$as_me:$LINENO: error: could not setup config files machinery" >&5
+$as_echo "$as_me: error: could not setup config files machinery" >&2;}
_ACEOF
-# VPATH may cause trouble with some makes, so we remove sole $(srcdir),
-# ${srcdir} and @srcdir@ entries from VPATH if srcdir is ".", strip leading and
+# VPATH may cause trouble with some makes, so we remove $(srcdir),
+# ${srcdir} and @srcdir@ from VPATH if srcdir is ".", strip leading and
# trailing colons and then remove the whole line if VPATH becomes empty
# (actually we leave an empty line to preserve line numbers).
if test "x$srcdir" = x.; then
- ac_vpsub='/^[ ]*VPATH[ ]*=[ ]*/{
-h
-s///
-s/^/:/
-s/[ ]*$/:/
-s/:\$(srcdir):/:/g
-s/:\${srcdir}:/:/g
-s/:@srcdir@:/:/g
-s/^:*//
+ ac_vpsub='/^[ ]*VPATH[ ]*=/{
+s/:*\$(srcdir):*/:/
+s/:*\${srcdir}:*/:/
+s/:*@srcdir@:*/:/
+s/^\([^=]*=[ ]*\):*/\1/
s/:*$//
-x
-s/\(=[ ]*\).*/\1/
-G
-s/\n//
s/^[^=]*=[ ]*$//
fi
@@ -5220,7 +6324,7 @@ fi # test -n "$CONFIG_FILES"
# No need to generate them if there are no CONFIG_HEADERS.
# This happens for instance with `./config.status Makefile'.
if test -n "$CONFIG_HEADERS"; then
-cat >"$ac_tmp/defines.awk" <<\_ACAWK ||
+cat >"$tmp/defines.awk" <<\_ACAWK ||
BEGIN {
_ACEOF
@@ -5232,11 +6336,13 @@ _ACEOF
# handling of long lines.
ac_delim='%!_!# '
for ac_last_try in false false :; do
- ac_tt=`sed -n "/$ac_delim/p" confdefs.h`
- if test -z "$ac_tt"; then
+ ac_t=`sed -n "/$ac_delim/p" confdefs.h`
+ if test -z "$ac_t"; then
break
- as_fn_error $? "could not make $CONFIG_HEADERS" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: could not make $CONFIG_HEADERS" >&5
+$as_echo "$as_me: error: could not make $CONFIG_HEADERS" >&2;}
else
fi
@@ -5321,7 +6427,9 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
_ACAWK
_ACEOF
- as_fn_error $? "could not setup config headers machinery" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: could not setup config headers machinery" >&5
+$as_echo "$as_me: error: could not setup config headers machinery" >&2;}
fi # test -n "$CONFIG_HEADERS"
@@ -5334,7 +6442,9 @@ do
esac
case $ac_mode$ac_tag in
:[FHL]*:*);;
- :L* | :C*:*) as_fn_error $? "invalid tag \`$ac_tag'" "$LINENO" 5;;
+ :L* | :C*:*) { { $as_echo "$as_me:$LINENO: error: invalid tag $ac_tag" >&5
+$as_echo "$as_me: error: invalid tag $ac_tag" >&2;}
:[FH]-) ac_tag=-:-;;
:[FH]*) ac_tag=$ac_tag:$ac_tag.in;;
esac
@@ -5353,7 +6463,7 @@ do
for ac_f
do
case $ac_f in
- -) ac_f="$ac_tmp/stdin";;
+ -) ac_f="$tmp/stdin";;
*) # Look for the file first in the build tree, then in the source tree
# (if the path is not absolute). The absolute path cannot be DOS-style,
# because $ac_f cannot contain `:'.
@@ -5362,10 +6472,12 @@ do
[\\/$]*) false;;
*) test -f "$srcdir/$ac_f" && ac_f="$srcdir/$ac_f";;
esac ||
- as_fn_error 1 "cannot find input file: \`$ac_f'" "$LINENO" 5;;
+ { { $as_echo "$as_me:$LINENO: error: cannot find input file: $ac_f" >&5
+$as_echo "$as_me: error: cannot find input file: $ac_f" >&2;}
esac
case $ac_f in *\'*) ac_f=`$as_echo "$ac_f" | sed "s/'/'\\\\\\\\''/g"`;; esac
- as_fn_append ac_file_inputs " '$ac_f'"
+ ac_file_inputs="$ac_file_inputs '$ac_f'"
done
# Let's still pretend it is `configure' which instantiates (i.e., don't
@@ -5376,7 +6488,7 @@ do
`' by configure.'
if test x"$ac_file" != x-; then
configure_input="$ac_file. $configure_input"
- { $as_echo "$as_me:${as_lineno-$LINENO}: creating $ac_file" >&5
+ { $as_echo "$as_me:$LINENO: creating $ac_file" >&5
$as_echo "$as_me: creating $ac_file" >&6;}
fi
# Neutralize special characters interpreted by sed in replacement strings.
@@ -5388,8 +6500,10 @@ $as_echo "$as_me: creating $ac_file" >&6;}
esac
case $ac_tag in
- *:-:* | *:-) cat >"$ac_tmp/stdin" \
- || as_fn_error $? "could not create $ac_file" "$LINENO" 5 ;;
+ *:-:* | *:-) cat >"$tmp/stdin" \
+ || { { $as_echo "$as_me:$LINENO: error: could not create $ac_file" >&5
+$as_echo "$as_me: error: could not create $ac_file" >&2;}
esac
esac
@@ -5417,7 +6531,47 @@ $as_echo X"$ac_file" |
q
s/.*/./; q'`
- as_dir="$ac_dir"; as_fn_mkdir_p
+ { as_dir="$ac_dir"
+ case $as_dir in #(
+ -*) as_dir=./$as_dir;;
+ esac
+ test -d "$as_dir" || { $as_mkdir_p && mkdir -p "$as_dir"; } || {
+ as_dirs=
+ while :; do
+ *\'*) as_qdir=`$as_echo "$as_dir" | sed "s/'/'\\\\\\\\''/g"`;; #'(
+ *) as_qdir=$as_dir;;
+ esac
+ as_dirs="'$as_qdir' $as_dirs"
+ as_dir=`$as_dirname -- "$as_dir" ||
+$as_expr X"$as_dir" : 'X\(.*[^/]\)//*[^/][^/]*/*$' \| \
+ X"$as_dir" : 'X\(//\)[^/]' \| \
+ X"$as_dir" : 'X\(//\)$' \| \
+ X"$as_dir" : 'X\(/\)' \| . 2>/dev/null ||
+$as_echo X"$as_dir" |
+ sed '/^X\(.*[^/]\)\/\/*[^/][^/]*\/*$/{
+ s//\1/
+ q
+ /^X\(\/\/\)[^/].*/{
+ s//\1/
+ q
+ /^X\(\/\/\)$/{
+ s//\1/
+ q
+ /^X\(\/\).*/{
+ s//\1/
+ q
+ s/.*/./; q'`
+ test -d "$as_dir" && break
+ done
+ test -z "$as_dirs" || eval "mkdir $as_dirs"
+ } || test -d "$as_dir" || { { $as_echo "$as_me:$LINENO: error: cannot create directory $as_dir" >&5
+$as_echo "$as_me: error: cannot create directory $as_dir" >&2;}
+ { (exit 1); exit 1; }; }; }
ac_builddir=.
case "$ac_dir" in
@@ -5469,6 +6623,7 @@ cat >>$CONFIG_STATUS <<\_ACEOF || ac_write_fail=1
# If the template does not know about datarootdir, expand it.
# FIXME: This hack should be removed a few years after 2.60.
ac_datarootdir_hack=; ac_datarootdir_seen=
ac_sed_dataroot='
/datarootdir/ {
p
@@ -5478,11 +6633,12 @@ ac_sed_dataroot='
/@docdir@/p
/@infodir@/p
/@localedir@/p
-/@mandir@/p'
+/@mandir@/p
case `eval "sed -n \"\$ac_sed_dataroot\" $ac_file_inputs"` in
*datarootdir*) ac_datarootdir_seen=yes;;
*@datadir@*|*@docdir@*|*@infodir@*|*@localedir@*|*@mandir@*)
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&5
$as_echo "$as_me: WARNING: $ac_file_inputs seems to ignore the --datarootdir setting" >&2;}
_ACEOF
@@ -5492,7 +6648,7 @@ cat >>$CONFIG_STATUS <<_ACEOF || ac_write_fail=1
s&@infodir@&$infodir&g
s&@localedir@&$localedir&g
s&@mandir@&$mandir&g
- s&\\\${datarootdir}&$datarootdir&g' ;;
+ s&\\\${datarootdir}&$datarootdir&g' ;;
esac
_ACEOF
@@ -5519,24 +6675,27 @@ s&@abs_top_builddir@&$ac_abs_top_builddir&;t t
s&@INSTALL@&$ac_INSTALL&;t t
$ac_datarootdir_hack
-eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$ac_tmp/subs.awk" \
- >$ac_tmp/out || as_fn_error $? "could not create $ac_file" "$LINENO" 5
+eval sed \"\$ac_sed_extra\" "$ac_file_inputs" | $AWK -f "$tmp/subs.awk" >$tmp/out \
test -z "$ac_datarootdir_hack$ac_datarootdir_seen" &&
- { ac_out=`sed -n '/\${datarootdir}/p' "$ac_tmp/out"`; test -n "$ac_out"; } &&
- { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' \
- "$ac_tmp/out"`; test -z "$ac_out"; } &&
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined" >&5
+ { ac_out=`sed -n '/\${datarootdir}/p' "$tmp/out"`; test -n "$ac_out"; } &&
+ { ac_out=`sed -n '/^[ ]*datarootdir[ ]*:*=/p' "$tmp/out"`; test -z "$ac_out"; } &&
+ { $as_echo "$as_me:$LINENO: WARNING: $ac_file contains a reference to the variable \`datarootdir'
+which seems to be undefined. Please make sure it is defined." >&5
$as_echo "$as_me: WARNING: $ac_file contains a reference to the variable \`datarootdir'
-which seems to be undefined. Please make sure it is defined" >&2;}
+which seems to be undefined. Please make sure it is defined." >&2;}
- rm -f "$ac_tmp/stdin"
+ rm -f "$tmp/stdin"
case $ac_file in
- -) cat "$ac_tmp/out" && rm -f "$ac_tmp/out";;
- *) rm -f "$ac_file" && mv "$ac_tmp/out" "$ac_file";;
+ -) cat "$tmp/out" && rm -f "$tmp/out";;
+ *) rm -f "$ac_file" && mv "$tmp/out" "$ac_file";;
esac \
:H)
@@ -5545,21 +6704,27 @@ which seems to be undefined. Please make sure it is defined" >&2;}
$as_echo "/* $configure_input */" \
- && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs"
- } >"$ac_tmp/config.h" \
- if diff "$ac_file" "$ac_tmp/config.h" >/dev/null 2>&1; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: $ac_file is unchanged" >&5
+ && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs"
+ } >"$tmp/config.h" \
+ if diff "$ac_file" "$tmp/config.h" >/dev/null 2>&1; then
+ { $as_echo "$as_me:$LINENO: $ac_file is unchanged" >&5
$as_echo "$as_me: $ac_file is unchanged" >&6;}
else
rm -f "$ac_file"
- mv "$ac_tmp/config.h" "$ac_file" \
+ mv "$tmp/config.h" "$ac_file" \
fi
else
- && eval '$AWK -f "$ac_tmp/defines.awk"' "$ac_file_inputs" \
- || as_fn_error $? "could not create -" "$LINENO" 5
+ && eval '$AWK -f "$tmp/defines.awk"' "$ac_file_inputs" \
+ || { { $as_echo "$as_me:$LINENO: error: could not create -" >&5
+$as_echo "$as_me: error: could not create -" >&2;}
fi
@@ -5569,12 +6734,15 @@ $as_echo "$as_me: $ac_file is unchanged" >&6;}
done # for ac_tag
-as_fn_exit 0
+{ (exit 0); exit 0; }
_ACEOF
+chmod +x $CONFIG_STATUS
ac_clean_files=$ac_clean_files_save
test $ac_write_fail = 0 ||
- as_fn_error $? "write failure creating $CONFIG_STATUS" "$LINENO" 5
+ { { $as_echo "$as_me:$LINENO: error: write failure creating $CONFIG_STATUS" >&5
+$as_echo "$as_me: error: write failure creating $CONFIG_STATUS" >&2;}
# configure is writing to config.log, and then calls config.status.
@@ -5595,10 +6763,10 @@ if test "$no_create" != yes; then
exec 5>>config.log
# Use ||, not &&, to avoid exiting from the if with $? = 1, which
# would make configure fail if this is the last instruction.
- $ac_cs_success || as_fn_exit 1
+ $ac_cs_success || { (exit 1); exit 1; }
fi
if test -n "$ac_unrecognized_opts" && test "$enable_option_checking" != no; then
- { $as_echo "$as_me:${as_lineno-$LINENO}: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
+ { $as_echo "$as_me:$LINENO: WARNING: unrecognized options: $ac_unrecognized_opts" >&5
$as_echo "$as_me: WARNING: unrecognized options: $ac_unrecognized_opts" >&2;}
fi
darshan-runtime/configure.in
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -27,7 +27,7 @@ CHECK_ZLIB
AC_ARG_ENABLE(cuserid,
[ --disable-cuserid Disables attempted use of cuserid() at run time],
[if test "x$enableval" = "xno" ; then
- AC_DEFINE(DARSHAN_DISABLE_CUSERID, 1, Define if cuserid() should be disabled),
+ AC_DEFINE(DARSHAN_DISABLE_CUSERID, 1, Define if cuserid() should be disabled)
fi]
@@ -270,13 +270,15 @@ AC_CHECK_TYPE([MPIO_Request],
AC_DEFINE(__D_MPI_REQUEST, MPI_Request, Generalized request type for MPI-IO)
,[#include <mpi.h>])
-AC_MSG_CHECKING(for old (pre-3.1.1) style MPICH library naming convention)
-AS_IF([$CC -show foo.c -o foo |grep lmpich >& /dev/null],
- AC_MSG_RESULT(yes)
- MPICH_LIB_OLD=1,
- AC_MSG_RESULT(no)
- MPICH_LIB_OLD=0)
+AS_IF([$CC -show foo.c -o foo >& /dev/null],
+ AC_MSG_CHECKING(for old (pre-3.1.1) style MPICH library naming convention)
+ AS_IF([$CC -show foo.c -o foo |grep lmpich >& /dev/null],
+ AC_MSG_RESULT(yes)
+ MPICH_LIB_OLD=1,
+ AC_MSG_RESULT(no)
+ MPICH_LIB_OLD=0),
+ MPICH_LIB_OLD=0)
AC_ARG_ENABLE(
@@ -310,7 +312,6 @@ AC_ARG_WITH(mod-mem,
DARSHAN_VERSION="AC_PACKAGE_VERSION"
AC_SUBST(darshan_lib_path)
AC_SUBST(darshan_share_path)
AC_SUBST(LDFLAGS)
darshan-runtime/darshan-runtime-config.h.in
--- a/darshan-runtime/darshan-runtime-config.h.in
+++ b/darshan-runtime/darshan-runtime-config.h.in
@@ -63,9 +63,6 @@
/* Define to the one symbol short name of this package. */
#undef PACKAGE_TARNAME
-/* Define to the home page for this package. */
-#undef PACKAGE_URL
/* Define to the version of this package. */
#undef PACKAGE_VERSION
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/92ef4cdd30b0bee6c27a193821dbdf5881d35d31
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160120/276b0a4b/attachment-0001.html>
More information about the Darshan-commits
