[Darshan-commits] [Git][darshan/darshan][dev-modular] add diff routines to remaining modules
Shane Snyder
xgitlab at cels.anl.gov
Fri Jan 8 17:07:25 CST 2016
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
4bbe8e64 by Shane Snyder at 2016-01-08T17:07:01Z
5 changed files:
- darshan-util/darshan-bgq-logutils.c
- darshan-util/darshan-hdf5-logutils.c
- darshan-util/darshan-mpiio-logutils.c
- darshan-util/darshan-null-logutils.c
- darshan-util/darshan-pnetcdf-logutils.c
Changes:
--- a/darshan-util/darshan-bgq-logutils.c
+++ b/darshan-util/darshan-bgq-logutils.c
@@ -19,7 +19,7 @@
#include "darshan-logutils.h"
-/* counter name strings for the POSIX module */
+/* counter name strings for the BGQ module */
#define X(a) #a,
char *bgq_counter_names[] = {
BGQ_COUNTERS
@@ -36,13 +36,16 @@ static int darshan_log_put_bgq_rec(darshan_fd fd, void* bgq_buf, int ver);
static void darshan_log_print_bgq_rec(void *file_rec,
char *file_name, char *mnt_pt, char *fs_type, int ver);
static void darshan_log_print_bgq_description(void);
+static void darshan_log_print_bgq_rec_diff(void *file_rec1, char *file_name1,
+ void *file_rec2, char *file_name2);
struct darshan_mod_logutil_funcs bgq_logutils =
.log_get_record = &darshan_log_get_bgq_rec,
.log_put_record = &darshan_log_put_bgq_rec,
.log_print_record = &darshan_log_print_bgq_rec,
- .log_print_description = &darshan_log_print_bgq_description
+ .log_print_description = &darshan_log_print_bgq_description,
+ .log_print_diff = &darshan_log_print_bgq_rec_diff
static int darshan_log_get_bgq_rec(darshan_fd fd, void* bgq_buf,
@@ -131,6 +134,79 @@ static void darshan_log_print_bgq_description()
return;
+ struct darshan_bgq_record *file1 = (struct darshan_bgq_record *)file_rec1;
+ struct darshan_bgq_record *file2 = (struct darshan_bgq_record *)file_rec2;
+ int i;
+ /* NOTE: we assume that both input records are the same module format version */
+ for(i=0; i<BGQ_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_BGQ_MOD],
+ file1->rank, file1->f_id, bgq_counter_names[i],
+ file1->counters[i], file_name1, "", "");
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, bgq_counter_names[i],
+ file2->counters[i], file_name2, "", "");
+ else if(file1->counters[i] != file2->counters[i])
+ printf("- ");
+ printf("+ ");
+ for(i=0; i<BGQ_F_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_BGQ_MOD],
+ file1->rank, file1->f_id, bgq_f_counter_names[i],
+ file1->fcounters[i], file_name1, "", "");
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, bgq_f_counter_names[i],
+ file2->fcounters[i], file_name2, "", "");
+ else if(file1->fcounters[i] != file2->fcounters[i])
+ printf("- ");
+ printf("+ ");
+ return;
* Local variables:
* c-indent-level: 4
--- a/darshan-util/darshan-hdf5-logutils.c
+++ b/darshan-util/darshan-hdf5-logutils.c
@@ -36,13 +36,16 @@ static int darshan_log_put_hdf5_file(darshan_fd fd, void* hdf5_buf, int ver);
static void darshan_log_print_hdf5_file(void *file_rec,
static void darshan_log_print_hdf5_description(void);
+static void darshan_log_print_hdf5_file_diff(void *file_rec1, char *file_name1,
struct darshan_mod_logutil_funcs hdf5_logutils =
.log_get_record = &darshan_log_get_hdf5_file,
.log_put_record = &darshan_log_put_hdf5_file,
.log_print_record = &darshan_log_print_hdf5_file,
- .log_print_description = &darshan_log_print_hdf5_description
+ .log_print_description = &darshan_log_print_hdf5_description,
+ .log_print_diff = &darshan_log_print_hdf5_file_diff
static int darshan_log_get_hdf5_file(darshan_fd fd, void* hdf5_buf,
@@ -126,6 +129,79 @@ static void darshan_log_print_hdf5_description()
return;
+ struct darshan_hdf5_file *file1 = (struct darshan_hdf5_file *)file_rec1;
+ struct darshan_hdf5_file *file2 = (struct darshan_hdf5_file *)file_rec2;
+ int i;
+ for(i=0; i<HDF5_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_HDF5_MOD],
+ file1->rank, file1->f_id, hdf5_counter_names[i],
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, hdf5_counter_names[i],
+ printf("- ");
+ printf("+ ");
+ for(i=0; i<HDF5_F_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_HDF5_MOD],
+ file1->rank, file1->f_id, hdf5_f_counter_names[i],
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, hdf5_f_counter_names[i],
+ printf("- ");
+ printf("+ ");
+ return;
* Local variables:
* c-indent-level: 4
--- a/darshan-util/darshan-mpiio-logutils.c
+++ b/darshan-util/darshan-mpiio-logutils.c
@@ -36,13 +36,16 @@ static int darshan_log_put_mpiio_file(darshan_fd fd, void* mpiio_buf, int ver);
static void darshan_log_print_mpiio_file(void *file_rec,
static void darshan_log_print_mpiio_description(void);
+static void darshan_log_print_mpiio_file_diff(void *file_rec1, char *file_name1,
struct darshan_mod_logutil_funcs mpiio_logutils =
.log_get_record = &darshan_log_get_mpiio_file,
.log_put_record = &darshan_log_put_mpiio_file,
.log_print_record = &darshan_log_print_mpiio_file,
- .log_print_description = &darshan_log_print_mpiio_description
+ .log_print_description = &darshan_log_print_mpiio_description,
+ .log_print_diff = &darshan_log_print_mpiio_file_diff
static int darshan_log_get_mpiio_file(darshan_fd fd, void* mpiio_buf,
@@ -148,6 +151,79 @@ static void darshan_log_print_mpiio_description()
return;
+ struct darshan_mpiio_file *file1 = (struct darshan_mpiio_file *)file_rec1;
+ struct darshan_mpiio_file *file2 = (struct darshan_mpiio_file *)file_rec2;
+ int i;
+ for(i=0; i<MPIIO_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_MPIIO_MOD],
+ file1->rank, file1->f_id, mpiio_counter_names[i],
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, mpiio_counter_names[i],
+ printf("- ");
+ printf("+ ");
+ for(i=0; i<MPIIO_F_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_MPIIO_MOD],
+ file1->rank, file1->f_id, mpiio_f_counter_names[i],
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, mpiio_f_counter_names[i],
+ printf("- ");
+ printf("+ ");
+ return;
* Local variables:
* c-indent-level: 4
--- a/darshan-util/darshan-null-logutils.c
+++ b/darshan-util/darshan-null-logutils.c
@@ -38,6 +38,8 @@ static int darshan_log_put_null_record(darshan_fd fd, void* null_buf, int ver);
static void darshan_log_print_null_record(void *file_rec,
static void darshan_log_print_null_description(void);
+static void darshan_log_print_null_record_diff(void *file_rec1, char *file_name1,
/* structure storing each function needed for implementing the darshan
* logutil interface. these functions are used for reading, writing, and
@@ -48,7 +50,8 @@ struct darshan_mod_logutil_funcs null_logutils =
.log_get_record = &darshan_log_get_null_record,
.log_put_record = &darshan_log_put_null_record,
.log_print_record = &darshan_log_print_null_record,
- .log_print_description = &darshan_log_print_null_description
+ .log_print_description = &darshan_log_print_null_description,
+ .log_print_diff = &darshan_log_print_null_record_diff
/* retrieve a NULL record from log file descriptor 'fd', storing the
@@ -148,6 +151,79 @@ static void darshan_log_print_null_description()
return;
+ struct darshan_null_record *file1 = (struct darshan_null_record *)file_rec1;
+ struct darshan_null_record *file2 = (struct darshan_null_record *)file_rec2;
+ int i;
+ for(i=0; i<NULL_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_NULL_MOD],
+ file1->rank, file1->f_id, null_counter_names[i],
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, null_counter_names[i],
+ printf("- ");
+ printf("+ ");
+ for(i=0; i<NULL_F_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_NULL_MOD],
+ file1->rank, file1->f_id, null_f_counter_names[i],
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, null_f_counter_names[i],
+ printf("- ");
+ printf("+ ");
+ return;
* Local variables:
* c-indent-level: 4
--- a/darshan-util/darshan-pnetcdf-logutils.c
+++ b/darshan-util/darshan-pnetcdf-logutils.c
@@ -36,13 +36,16 @@ static int darshan_log_put_pnetcdf_file(darshan_fd fd, void* pnetcdf_buf, int ve
static void darshan_log_print_pnetcdf_file(void *file_rec,
static void darshan_log_print_pnetcdf_description(void);
+static void darshan_log_print_pnetcdf_file_diff(void *file_rec1, char *file_name1,
struct darshan_mod_logutil_funcs pnetcdf_logutils =
.log_get_record = &darshan_log_get_pnetcdf_file,
.log_put_record = &darshan_log_put_pnetcdf_file,
.log_print_record = &darshan_log_print_pnetcdf_file,
- .log_print_description = &darshan_log_print_pnetcdf_description
+ .log_print_description = &darshan_log_print_pnetcdf_description,
+ .log_print_diff = &darshan_log_print_pnetcdf_file_diff
static int darshan_log_get_pnetcdf_file(darshan_fd fd, void* pnetcdf_buf,
@@ -127,6 +130,78 @@ static void darshan_log_print_pnetcdf_description()
return;
+ struct darshan_pnetcdf_file *file1 = (struct darshan_pnetcdf_file *)file_rec1;
+ struct darshan_pnetcdf_file *file2 = (struct darshan_pnetcdf_file *)file_rec2;
+ int i;
+ for(i=0; i<PNETCDF_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_PNETCDF_MOD],
+ file1->rank, file1->f_id, pnetcdf_counter_names[i],
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, pnetcdf_counter_names[i],
+ printf("- ");
+ printf("+ ");
+ for(i=0; i<PNETCDF_F_NUM_INDICES; i++)
+ if(!file2)
+ printf("- ");
+ DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_PNETCDF_MOD],
+ file1->rank, file1->f_id, pnetcdf_f_counter_names[i],
+ else if(!file1)
+ printf("+ ");
+ file2->rank, file2->f_id, pnetcdf_f_counter_names[i],
+ printf("- ");
+ printf("+ ");
+ return;
* Local variables:
* c-indent-level: 4
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/4bbe8e640eeaea440a794de765a1b9fd54f8560d
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160108/3e89a654/attachment-0001.html>
More information about the Darshan-commits
