[Darshan-commits] [Git][darshan/darshan][lustre-mod] switch lustre to use array instead of hash table
Shane Snyder
xgitlab at cels.anl.gov
Thu Feb 25 13:11:00 CST 2016
Shane Snyder pushed to branch lustre-mod at darshan / darshan
Commits:
c3a85a3e by Shane Snyder at 2016-02-25T11:10:13-08:00
1 changed file:
- darshan-runtime/lib/darshan-lustre.c
Changes:
--- a/darshan-runtime/lib/darshan-lustre.c
+++ b/darshan-runtime/lib/darshan-lustre.c
@@ -22,27 +22,16 @@
#include "darshan.h"
#include "darshan-dynamic.h"
-/* TODO: once mmap merge is complete, we can just use an array
- * to store record data rather than a hash table -- in that
- * branch, register_record() returns whether the record
- * already exists, at which point we won't need to instrument
- * more data, since the Lustre record data is immutable. records
- * could just be appended to the array if there is no need to
- * search for a specific record.
+/* we just use a simple array for storing records. the POSIX module
+ * only calls into the Lustre module for new records, so we will never
+ * have to search for an existing Lustre record (assuming the Lustre
+ * data remains immutable as it is now).
-struct lustre_record_ref
- struct darshan_lustre_record *record;
- UT_hash_handle hlink;
struct lustre_runtime
- struct lustre_record_ref *ref_array;
struct darshan_lustre_record *record_array;
int record_array_size;
int record_array_ndx;
- struct lustre_record_ref *record_hash;
static struct lustre_runtime *lustre_runtime = NULL;
@@ -69,15 +58,16 @@ static void lustre_shutdown(void);
void darshan_instrument_lustre_file(char *filepath)
- struct lustre_record_ref *lustre_ref;
+ struct darshan_lustre_record *rec;
darshan_record_id rec_id;
- int limit_flag;
LUSTRE_LOCK();
/* make sure the lustre module is already initialized */
lustre_runtime_initialize();
- limit_flag = (lustre_runtime->record_array_ndx >= lustre_runtime->record_array_size);
+ /* if the array is full, we just back out */
+ if(lustre_runtime->record_array_ndx >= lustre_runtime->record_array_size)
+ return;
/* register a Lustre file record with Darshan */
darshan_core_register_record(
@@ -85,7 +75,7 @@ void darshan_instrument_lustre_file(char *filepath)
strlen(filepath),
DARSHAN_LUSTRE_MOD,
1,
- limit_flag,
+ 0,
&rec_id,
NULL);
@@ -93,24 +83,14 @@ void darshan_instrument_lustre_file(char *filepath)
if(rec_id == 0)
return;
- HASH_FIND(hlink, lustre_runtime->record_hash, &rec_id,
- sizeof(darshan_record_id), lustre_ref);
- if(!lustre_ref)
- /* no existing record, allocate a new one and add it to the hash */
- lustre_ref = &(lustre_runtime->ref_array[lustre_runtime->record_array_ndx]);
- lustre_ref->record = &(lustre_runtime->record_array[lustre_runtime->record_array_ndx]);
- lustre_ref->record->rec_id = rec_id;
- lustre_ref->record->rank = my_rank;
- /* TODO: gather lustre data, store in record hash */
- /* counters in lustre_ref->record->counters */
- lustre_ref->record->counters[LUSTRE_TEST_COUNTER] = 88;
- HASH_ADD(hlink, lustre_runtime->record_hash, record->rec_id,
- lustre_runtime->record_array_ndx++;
+ /* allocate a new lustre record and append it to the array */
+ rec = &(lustre_runtime->record_array[lustre_runtime->record_array_ndx++]);
+ rec->rec_id = rec_id;
+ rec->rank = my_rank;
+ /* TODO: gather lustre data, store in record hash */
+ /* counters in lustre_ref->record->counters */
+ rec->counters[LUSTRE_TEST_COUNTER] = 88;
LUSTRE_UNLOCK();
return;
@@ -152,17 +132,13 @@ static void lustre_runtime_initialize()
lustre_runtime->record_array_size = mem_limit / sizeof(struct darshan_lustre_record);
- lustre_runtime->ref_array = malloc(lustre_runtime->record_array_size *
- sizeof(struct lustre_record_ref));
lustre_runtime->record_array = malloc(lustre_runtime->record_array_size *
sizeof(struct darshan_lustre_record));
- if(!lustre_runtime->ref_array || !lustre_runtime->record_array)
+ if(!lustre_runtime->record_array)
lustre_runtime->record_array_size = 0;
return;
- memset(lustre_runtime->ref_array, 0, lustre_runtime->record_array_size *
memset(lustre_runtime->record_array, 0, lustre_runtime->record_array_size *
@@ -211,9 +187,6 @@ static void lustre_shutdown(void)
assert(lustre_runtime);
/* TODO: free data structures */
- HASH_CLEAR(hlink, lustre_runtime->record_hash);
- free(lustre_runtime->ref_array);
free(lustre_runtime->record_array);
free(lustre_runtime);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/c3a85a3ebe2097ed33150cf112d30ff2ced7ab46
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160225/4c2ba9cc/attachment.html>
More information about the Darshan-commits
