[Darshan-commits] [Git][darshan/darshan][dev-modular] 2 commits: bug fix in darhsan-config linker options
Shane Snyder xgitlab at cels.anl.gov
Tue Feb 23 09:03:30 CST 2016
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
0a6399f3 by Shane Snyder at 2016-02-22T12:52:34-06:00
Since we had to modify HDF5/PnetCDF linker flags to work on Cray
by undefining appropriate symbols, we need to update the linker
options used in darshan-config. darshan-config linker options need
to include the stubs libraries and use '--start-group' and
'--end-group' flags to resolve the symbols correctly
47a6c64a by Shane Snyder at 2016-02-22T12:52:35-06:00
bug fix in reduction of min nonzero counters
5 changed files:
- darshan-runtime/darshan-config.in
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-pnetcdf.c
- darshan-runtime/lib/darshan-posix.c
Changes:
--- a/darshan-runtime/darshan-config.in
+++ b/darshan-runtime/darshan-config.in
@@ -12,7 +12,7 @@ DARSHAN_LD_FLAGS="@LDFLAGS@"
 #   in turn used one of those HLLs).
 PRE_LD_FLAGS="-L$DARSHAN_LIB_PATH $DARSHAN_LD_FLAGS -ldarshan -lz -Wl,@$DARSHAN_SHARE_PATH/ld-opts/darshan-base-ld-opts"
-POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -ldarshan -lz -lrt -lpthread"
+POST_LD_FLAGS="-L$DARSHAN_LIB_PATH -Wl,--start-group -ldarshan -ldarshan-stubs -Wl,--end-group -lz -lrt -lpthread"
 usage="\
 Usage: darshan-config [--pre-ld-flags] [--post-ld-flags]"
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -428,10 +428,11 @@ static void hdf5_record_reduction_op(void* infile_v, void* inoutfile_v,
         /* min non-zero (if available) value */
         for(j=HDF5_F_OPEN_TIMESTAMP; j<=HDF5_F_OPEN_TIMESTAMP; j++)
-            if(infile->fcounters[j] > inoutfile->fcounters[j] && inoutfile->fcounters[j] > 0)
-                tmp_file.fcounters[j] = inoutfile->fcounters[j];
-            else
+            if((infile->fcounters[j] < inoutfile->fcounters[j] &&
+               infile->fcounters[j] > 0) || inoutfile->fcounters[j] == 0)
                 tmp_file.fcounters[j] = infile->fcounters[j];
+            else
+                tmp_file.fcounters[j] = inoutfile->fcounters[j];
         /* max */
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -1096,10 +1096,11 @@ static void mpiio_record_reduction_op(
         for(j=MPIIO_F_OPEN_TIMESTAMP; j<=MPIIO_F_WRITE_START_TIMESTAMP; j++)
-            else
+            else
         /* max */
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ b/darshan-runtime/lib/darshan-pnetcdf.c
@@ -440,10 +440,11 @@ static void pnetcdf_record_reduction_op(void* infile_v, void* inoutfile_v,
         for(j=PNETCDF_F_OPEN_TIMESTAMP; j<=PNETCDF_F_OPEN_TIMESTAMP; j++)
-            else
+            else
         /* max */
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -1829,11 +1829,11 @@ static void posix_record_reduction_op(void* infile_v, void* inoutfile_v,
         for(j=POSIX_F_OPEN_TIMESTAMP; j<=POSIX_F_WRITE_START_TIMESTAMP; j++)
-               inoutfile->fcounters[j] > 0)
-            else
+            else
         /* max */
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/compare/4a743c81b6c1cd7412a8114a6cb9632c2c01ba27...47a6c64a63c94e6c8bec850abfa7633bdb3994cf
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160223/3f4f0cb2/attachment-0001.html>
More information about the Darshan-commits mailing list
