[Darshan-commits] Build failed in Jenkins: darshan-dev-modular-mpich-3.0.4-static #335
jenkins-ci at mcs.anl.gov
Sat Feb 20 00:05:30 CST 2016
See <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/335/changes>
Changes:
[ssnyder] bug fix in resetting of darshan mount info
[ssnyder] forgot to undefine hdf5/ncmpi symbols in ldopts
[...truncated 10043 lines...]
configure: creating ./config.status
config.status: creating Makefile
config.status: creating darshan-mk-log-dirs.pl
config.status: creating darshan-gen-cc.pl
config.status: creating darshan-gen-cxx.pl
config.status: creating darshan-gen-fortran.pl
config.status: creating darshan-config
config.status: creating share/craype-1.x/darshan-module
config.status: creating share/craype-2.x/darshan-module
config.status: creating lib/pkgconfig/darshan-runtime.pc
config.status: creating share/mpi-profile/darshan-cc.conf
config.status: creating share/mpi-profile/darshan-cxx.conf
config.status: creating share/mpi-profile/darshan-f.conf
config.status: creating share/mpi-profile/darshan-bg-cc.conf
config.status: creating share/mpi-profile/darshan-bg-cxx.conf
config.status: creating share/mpi-profile/darshan-bg-f.conf
config.status: creating share/ld-opts/darshan-base-ld-opts
config.status: creating darshan-runtime-config.h
config.status: darshan-runtime-config.h is unchanged
checking for a BSD-compatible install... /usr/bin/install -c
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for inflateEnd in -lz... yes
checking if bzlib is wanted... yes
checking for BZ2_bzCompressInit in -lbz2... yes
checking bzlib.h usability... yes
checking bzlib.h presence... yes
checking for bzlib.h... yes
checking for BZ2_bzCompressInit in -lbz2... (cached) yes
checking bzlib in /usr... ok
checking for inttypes.h... (cached) yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking for pdflatex... yes
checking for -halt-on-error argument to pdflatex... yes
checking whether byte ordering is bigendian... no
checking for off64_t... yes
checking for strndup... yes
config.status: creating darshan-job-summary/bin/darshan-job-summary.pl
config.status: creating maint/darshan-util.pc
config.status: creating darshan-util-config.h
config.status: darshan-util-config.h is unchanged
[darshan-dev-modular-mpich-3.0.4-static] $ /bin/bash /tmp/hudson229521935661913913.sh
mpicc -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I ../../darshan-runtime -I../../darshan-runtime/../ -g -O2 -D_LARGEFILE64_SOURCE -c ../../darshan-runtime/lib/darshan-core.c -o lib/darshan-core.o
ar rcs lib/libdarshan.a lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darshan-common.o lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o lib/lookup3.o lib/lookup8.o
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib>
install -m 755 lib/libdarshan.a <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib>
install -m 755 lib/libdarshan-stubs.a <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 darshan-mk-log-dirs.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 darshan-gen-cc.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 darshan-gen-cxx.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 darshan-gen-fortran.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 darshan-config <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/craype-1.x/modulefiles/darshan>
install -m 755 share/craype-1.x/darshan-module <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/craype-1.x/modulefiles/darshan/3.0.0-pre3>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/craype-2.x/modulefiles/darshan>
install -m 755 share/craype-2.x/darshan-module <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/craype-2.x/modulefiles/darshan/3.0.0-pre3>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/mpi-profile>
install -m 755 share/mpi-profile/darshan-cc.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/mpi-profile/darshan-cc.conf>
install -m 755 share/mpi-profile/darshan-cxx.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/mpi-profile/darshan-cxx.conf>
install -m 755 share/mpi-profile/darshan-f.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/mpi-profile/darshan-f.conf>
install -m 755 share/mpi-profile/darshan-bg-cc.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/mpi-profile/darshan-bg-cc.conf>
install -m 755 share/mpi-profile/darshan-bg-cxx.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/mpi-profile/darshan-bg-cxx.conf>
install -m 755 share/mpi-profile/darshan-bg-f.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/mpi-profile/darshan-bg-f.conf>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/ld-opts>
install -m 644 share/ld-opts/darshan-base-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/ld-opts/darshan-base-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-posix-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/ld-opts/darshan-posix-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-hdf5-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/ld-opts/darshan-hdf5-ld-opts>
install -m 644 ../../darshan-runtime/share/ld-opts/darshan-pnetcdf-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share/ld-opts/darshan-pnetcdf-ld-opts>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/pkgconfig>
install -m 644 lib/pkgconfig/darshan-runtime.pc <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/pkgconfig/darshan-runtime.pc>
make: Nothing to be done for `all'.
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 755 darshan-analyzer <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 darshan-convert <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 darshan-diff <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 darshan-parser <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 ../../darshan-util/darshan-summary-per-file.sh <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -m 755 libdarshan-util.a <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib>
install -m 644 ../../darshan-util/darshan-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/darshan-posix-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/darshan-mpiio-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/darshan-hdf5-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/darshan-pnetcdf-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/darshan-bgq-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/darshan-null-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/../darshan-posix-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/../darshan-mpiio-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/../darshan-hdf5-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/../darshan-pnetcdf-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 644 ../../darshan-util/../darshan-bgq-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include/uthash-1.9.2>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include/uthash-1.9.2/src>
install -m 644 uthash-1.9.2/src/uthash.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include/uthash-1.9.2/src/>
install -m 644 ../../darshan-util/../darshan-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/include>
install -m 755 darshan-job-summary/bin/darshan-job-summary.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/bin>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/TeX>
install -m 644 ../../darshan-util/darshan-job-summary/lib/TeX/Encode.pm <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/TeX/>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/Number>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/Number/Bytes>
install -m 644 ../../darshan-util/darshan-job-summary/lib/Number/Bytes/Human.pm <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/Number/Bytes>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share>
install -m 644 ../../darshan-util/darshan-job-summary/share/* <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/share>
install -m 644 maint/darshan-util.pc <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/pkgconfig>
[darshan-dev-modular-mpich-3.0.4-static] $ /bin/bash /tmp/hudson6175251428391555083.sh
Running <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/darshan-test/regression/test-cases/cxxpi.sh...>
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/libdarshan.a(darshan-hdf5.o)>: In function `__wrap_H5Fcreate':
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/build/darshan-runtime/../../darshan-runtime/lib/darshan-hdf5.c>:100: undefined reference to `H5Fcreate'
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/libdarshan.a(darshan-hdf5.o)>: In function `__wrap_H5Fopen':
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/build/darshan-runtime/../../darshan-runtime/lib/darshan-hdf5.c>:139: undefined reference to `H5Fopen'
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/libdarshan.a(darshan-hdf5.o)>: In function `__wrap_H5Fclose':
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/build/darshan-runtime/../../darshan-runtime/lib/darshan-hdf5.c>:175: undefined reference to `H5Fclose'
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/libdarshan.a(darshan-pnetcdf.o)>: In function `__wrap_ncmpi_create':
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/build/darshan-runtime/../../darshan-runtime/lib/darshan-pnetcdf.c>:97: undefined reference to `ncmpi_create'
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/libdarshan.a(darshan-pnetcdf.o)>: In function `__wrap_ncmpi_open':
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/build/darshan-runtime/../../darshan-runtime/lib/darshan-pnetcdf.c>:145: undefined reference to `ncmpi_open'
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/install/lib/libdarshan.a(darshan-pnetcdf.o)>: In function `__wrap_ncmpi_close':
<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/build/darshan-runtime/../../darshan-runtime/lib/darshan-pnetcdf.c>:188: undefined reference to `ncmpi_close'
collect2: ld returned 1 exit status
[proxy:0:0 at trounce] HYDU_create_process (./utils/launch/launch.c:75): execvp error on file <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/scratch/cxxpi> (No such file or directory)
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= EXIT CODE: 255
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
Error: failed to execute cxxpi
Error: failed to execute test case <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/darshan-test/regression/test-cases/cxxpi.sh>
Done.
Running <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/darshan-test/regression/test-cases/fperf-f77.sh...>
[proxy:0:0 at trounce] HYDU_create_process (./utils/launch/launch.c:75): execvp error on file <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/scratch/fperf-f77> (No such file or directory)
= EXIT CODE: 255
Error: failed to execute fperf-f77
Error: failed to execute test case <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/darshan-test/regression/test-cases/fperf-f77.sh>
Done.
Running <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/darshan-test/regression/test-cases/fperf-f90.sh...>
[proxy:0:0 at trounce] HYDU_create_process (./utils/launch/launch.c:75): execvp error on file <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/scratch/fperf-f90> (No such file or directory)
= EXIT CODE: 255
Error: failed to execute fperf-f90
Error: failed to execute test case <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/darshan-test/regression/test-cases/fperf-f90.sh>
Done.
Running <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/darshan-test/regression/test-cases/mpi-io-test.sh...>
[proxy:0:0 at trounce] HYDU_create_process (./utils/launch/launch.c:75): execvp error on file <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/scratch/mpi-io-test> (No such file or directory)
= EXIT CODE: 255
Error: failed to execute mpi-io-test
Error: failed to execute test case <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.0.4-static/ws/darshan-test/regression/test-cases/mpi-io-test.sh>
Done.
4 tests failed
Build step 'Execute shell' marked build as failure
Recording test results
More information about the Darshan-commits
