[Darshan-commits] [Git][darshan/darshan][dev-modular] cleanup darshan-test directory
Shane Snyder xgitlab at cels.anl.gov
Mon Feb 15 16:48:20 CST 2016
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
919fe4a9 by Shane Snyder at 2016-02-15T16:47:36-06:00
moved most test programs and previous darshan output
to the 2.x directory
86 changed files:
- darshan-test/analysis.sql → darshan-test/2.x/analysis.sql
- darshan-test/cp-bench.c → darshan-test/2.x/cp-bench.c
- darshan-test/cp-realpath-bench.c → darshan-test/2.x/cp-realpath-bench.c
- darshan-test/cp-search-bench.c → darshan-test/2.x/cp-search-bench.c
- darshan-test/cp-wtime-bench.c → darshan-test/2.x/cp-wtime-bench.c
- darshan-test/cp-wtimewrap-bench.c → darshan-test/2.x/cp-wtimewrap-bench.c
- darshan-test/darshan-anon-core-hours.pl → darshan-test/2.x/darshan-anon-core-hours.pl
- darshan-test/darshan-file-counter-hack.pl → darshan-test/2.x/darshan-file-counter-hack.pl
- darshan-test/darshan-gather-counts.pl → darshan-test/2.x/darshan-gather-counts.pl
- darshan-test/darshan-gather-intervals.pl → darshan-test/2.x/darshan-gather-intervals.pl
- darshan-test/darshan-gather-mpi-posix-usage.pl → darshan-test/2.x/darshan-gather-mpi-posix-usage.pl
- darshan-test/darshan-gather-stats.pl → darshan-test/2.x/darshan-gather-stats.pl
- darshan-test/darshan.mysql → darshan-test/2.x/darshan.mysql
- darshan-test/example-output/README.txt → darshan-test/2.x/example-output/README.txt
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.0_id178062_12-31-64877_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.0_id178062_12-31-64877_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.10_id178062_12-31-64874_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.10_id178062_12-31-64874_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.11_id178062_12-31-64875_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.11_id178062_12-31-64875_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.12_id178062_12-31-64874_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.12_id178062_12-31-64874_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.13_id178062_12-31-64878_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.13_id178062_12-31-64878_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.14_id178062_12-31-64878_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.14_id178062_12-31-64878_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.15_id178062_12-31-64878_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.15_id178062_12-31-64878_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.1_id178062_12-31-64874_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.1_id178062_12-31-64874_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.2_id178062_12-31-64879_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.2_id178062_12-31-64879_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.3_id178062_12-31-64875_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.3_id178062_12-31-64875_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.4_id178062_12-31-64876_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.4_id178062_12-31-64876_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.5_id178062_12-31-64872_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.5_id178062_12-31-64872_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.6_id178062_12-31-64878_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.6_id178062_12-31-64878_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.7_id178062_12-31-64875_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.7_id178062_12-31-64875_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.8_id178062_12-31-64878_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.8_id178062_12-31-64878_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.9_id178062_12-31-64880_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.9_id178062_12-31-64880_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-2.0.0_id180936_12-31-64879_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.0.0_id180936_12-31-64879_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-2.0.2_id205555_12-8-36850-17729250439914587931_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.0.2_id205555_12-8-36850-17729250439914587931_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-2.1.1_id240158_6-23-63667-13564362473375795675_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.1.1_id240158_6-23-63667-13564362473375795675_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-2.2.0_id100_2-29-58016-11764280592576253912_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.2.0_id100_2-29-58016-11764280592576253912_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-2.2.4_id100_12-13-62209-215568122286385789_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.2.4_id100_12-13-62209-215568122286385789_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-2.2.5_id100_1-1-168-10859250841018226043_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.2.5_id100_1-1-168-10859250841018226043_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc32-2.2.6_id100_1-1-169-3365979776611785968_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.2.6_id100_1-1-169-3365979776611785968_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.4_id47560_12-13-67385-3671058397549123273_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.4_id47560_12-13-67385-3671058397549123273_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.5_id60773_2-26-55789-7981255518662743653_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.5_id60773_2-26-55789-7981255518662743653_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.6_id80230_4-23-63443-13434414552960059406_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.6_id80230_4-23-63443-13434414552960059406_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.8_id121829_8-28-59756-8698475815754165825_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.8_id121829_8-28-59756-8698475815754165825_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.9_id259616_5-6-66953-5018725671498589377_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.9_id259616_5-6-66953-5018725671498589377_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-ppc64-2.3.1_id426989_3-13-61875-4723177368895607730_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.3.1_id426989_3-13-61875-4723177368895607730_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86-2.0.0_id3251_7-16-33980_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86-2.0.0_id3251_7-16-33980_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86-2.0.2_id18650_12-7-37315-16484262108403302634_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86-2.0.2_id18650_12-7-37315-16484262108403302634_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86-2.1.1_id19454_6-23-43783-16484262108403302634_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86-2.1.1_id19454_6-23-43783-16484262108403302634_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86-64-2.2.4_id20631_12-13-43744-16977121959925885678_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86-64-2.2.4_id20631_12-13-43744-16977121959925885678_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86-64-2.2.6_id23755_4-23-38771-2124448682003854839_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86-64-2.2.6_id23755_4-23-38771-2124448682003854839_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86_64-2.0.0_id16795_7-16-38059_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.0.0_id16795_7-16-38059_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86_64-2.0.2_id15172_12-8-37621-274509493643487663_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.0.2_id15172_12-8-37621-274509493643487663_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86_64-2.1.1_id20947_6-23-63417-274509493643487663_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.1.1_id20947_6-23-63417-274509493643487663_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86_64-2.2.0_id3850_2-29-36600-13333843235489639491_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.2.0_id3850_2-29-36600-13333843235489639491_1.darshan.gz
- darshan-test/example-output/carns_mpi-io-test-x86_64-2.2.5_id5824_2-27-41403-11500169623986228326_1.darshan.gz → darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.2.5_id5824_2-27-41403-11500169623986228326_1.darshan.gz
- darshan-test/example-output/pcarns_mpi-io-test-x86_64-2.2.8_id12451_8-28-46056-5041743303181360857_1.darshan.gz → darshan-test/2.x/example-output/pcarns_mpi-io-test-x86_64-2.2.8_id12451_8-28-46056-5041743303181360857_1.darshan.gz
- darshan-test/example-output/pcarns_mpi-io-test-x86_64-2.2.9_id8751_5-6-43885-16506732777848558488_1.darshan.gz → darshan-test/2.x/example-output/pcarns_mpi-io-test-x86_64-2.2.9_id8751_5-6-43885-16506732777848558488_1.darshan.gz
- darshan-test/example-output/pcarns_mpi-io-test-x86_64-2.3.1_id13154_3-13-47125-7023224190677163982_1.darshan.gz → darshan-test/2.x/example-output/pcarns_mpi-io-test-x86_64-2.3.1_id13154_3-13-47125-7023224190677163982_1.darshan.gz
- darshan-test/gz-bench.c → darshan-test/2.x/gz-bench.c
- darshan-test/gztest.c → darshan-test/2.x/gztest.c
- darshan-test/parallel-fsstats.pl → darshan-test/2.x/parallel-fsstats.pl
- darshan-test/patches/99_cu_futimens.patch → darshan-test/2.x/patches/99_cu_futimens.patch
- darshan-test/patches/README → darshan-test/2.x/patches/README
- darshan-test/patches/coreutils-cp-mpi.patch → darshan-test/2.x/patches/coreutils-cp-mpi.patch
- darshan-test/patches/darshan-coll-write-single.patch → darshan-test/2.x/patches/darshan-coll-write-single.patch
- darshan-test/patches/darshan-coll-write-strategy-test.patch → darshan-test/2.x/patches/darshan-coll-write-strategy-test.patch
- darshan-test/pcarns_cp_id25476_1-16-15155_2.darshan.gz → darshan-test/2.x/pcarns_cp_id25476_1-16-15155_2.darshan.gz
- darshan-test/perf/350665.output → darshan-test/2.x/perf/350665.output
- darshan-test/perf/350690.output → darshan-test/2.x/perf/350690.output
- darshan-test/perf/350892.output → darshan-test/2.x/perf/350892.output
- darshan-test/perf/354969.output → darshan-test/2.x/perf/354969.output
- darshan-test/perf/README → darshan-test/2.x/perf/README
- darshan-test/perf/harms_IOR_id350665_2-8-78651_12.darshan.gz → darshan-test/2.x/perf/harms_IOR_id350665_2-8-78651_12.darshan.gz
- darshan-test/perf/harms_IOR_id350690_2-8-83458_1.darshan.gz → darshan-test/2.x/perf/harms_IOR_id350690_2-8-83458_1.darshan.gz
- darshan-test/perf/harms_IOR_id350892_2-9-74258_1.darshan.gz → darshan-test/2.x/perf/harms_IOR_id350892_2-9-74258_1.darshan.gz
- darshan-test/perf/harms_partshared_id354969_2-25-56979_1.darshan.gz → darshan-test/2.x/perf/harms_partshared_id354969_2-25-56979_1.darshan.gz
- darshan-test/perf/partshared.c → darshan-test/2.x/perf/partshared.c
- darshan-test/perf/single_and_multi_file.ior → darshan-test/2.x/perf/single_and_multi_file.ior
- darshan-test/seek-test.c → darshan-test/2.x/seek-test.c
- darshan-test/stat-perf.c → darshan-test/2.x/stat-perf.c
- darshan-test/test-darshan-compiles-alcf2.sh → darshan-test/2.x/test-darshan-compiles-alcf2.sh
- darshan-test/test-darshan-compiles.sh → darshan-test/2.x/test-darshan-compiles.sh
- darshan-test/test-darshan-log-formats.sh → darshan-test/2.x/test-darshan-log-formats.sh
- − darshan-test/ADDING-COUNTERS.txt
- − darshan-test/cuserid-test.c
- − darshan-test/fsstats-merge.pl
- − darshan-test/fsstats-runner.bash
- − darshan-test/output.txt
Changes:
--- a/darshan-test/analysis.sql
+++ b/darshan-test/2.x/analysis.sql
--- a/darshan-test/cp-bench.c
+++ b/darshan-test/2.x/cp-bench.c
--- a/darshan-test/cp-realpath-bench.c
+++ b/darshan-test/2.x/cp-realpath-bench.c
--- a/darshan-test/cp-search-bench.c
+++ b/darshan-test/2.x/cp-search-bench.c
--- a/darshan-test/cp-wtime-bench.c
+++ b/darshan-test/2.x/cp-wtime-bench.c
--- a/darshan-test/cp-wtimewrap-bench.c
+++ b/darshan-test/2.x/cp-wtimewrap-bench.c
--- a/darshan-test/darshan-anon-core-hours.pl
+++ b/darshan-test/2.x/darshan-anon-core-hours.pl
--- a/darshan-test/darshan-file-counter-hack.pl
+++ b/darshan-test/2.x/darshan-file-counter-hack.pl
--- a/darshan-test/darshan-gather-counts.pl
+++ b/darshan-test/2.x/darshan-gather-counts.pl
--- a/darshan-test/darshan-gather-intervals.pl
+++ b/darshan-test/2.x/darshan-gather-intervals.pl
--- a/darshan-test/darshan-gather-mpi-posix-usage.pl
+++ b/darshan-test/2.x/darshan-gather-mpi-posix-usage.pl
--- a/darshan-test/darshan-gather-stats.pl
+++ b/darshan-test/2.x/darshan-gather-stats.pl
--- a/darshan-test/darshan.mysql
+++ b/darshan-test/2.x/darshan.mysql
--- a/darshan-test/example-output/README.txt
+++ b/darshan-test/2.x/example-output/README.txt
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.0_id178062_12-31-64877_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.0_id178062_12-31-64877_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.10_id178062_12-31-64874_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.10_id178062_12-31-64874_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.11_id178062_12-31-64875_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.11_id178062_12-31-64875_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.12_id178062_12-31-64874_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.12_id178062_12-31-64874_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.13_id178062_12-31-64878_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.13_id178062_12-31-64878_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.14_id178062_12-31-64878_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.14_id178062_12-31-64878_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.15_id178062_12-31-64878_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.15_id178062_12-31-64878_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.1_id178062_12-31-64874_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.1_id178062_12-31-64874_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.2_id178062_12-31-64879_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.2_id178062_12-31-64879_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.3_id178062_12-31-64875_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.3_id178062_12-31-64875_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.4_id178062_12-31-64876_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.4_id178062_12-31-64876_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.5_id178062_12-31-64872_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.5_id178062_12-31-64872_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.6_id178062_12-31-64878_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.6_id178062_12-31-64878_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.7_id178062_12-31-64875_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.7_id178062_12-31-64875_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.8_id178062_12-31-64878_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.8_id178062_12-31-64878_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-1.1.9_id178062_12-31-64880_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-1.1.9_id178062_12-31-64880_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-2.0.0_id180936_12-31-64879_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.0.0_id180936_12-31-64879_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-2.0.2_id205555_12-8-36850-17729250439914587931_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.0.2_id205555_12-8-36850-17729250439914587931_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-2.1.1_id240158_6-23-63667-13564362473375795675_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.1.1_id240158_6-23-63667-13564362473375795675_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-2.2.0_id100_2-29-58016-11764280592576253912_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.2.0_id100_2-29-58016-11764280592576253912_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-2.2.4_id100_12-13-62209-215568122286385789_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.2.4_id100_12-13-62209-215568122286385789_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-2.2.5_id100_1-1-168-10859250841018226043_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.2.5_id100_1-1-168-10859250841018226043_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc32-2.2.6_id100_1-1-169-3365979776611785968_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc32-2.2.6_id100_1-1-169-3365979776611785968_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.4_id47560_12-13-67385-3671058397549123273_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.4_id47560_12-13-67385-3671058397549123273_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.5_id60773_2-26-55789-7981255518662743653_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.5_id60773_2-26-55789-7981255518662743653_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.6_id80230_4-23-63443-13434414552960059406_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.6_id80230_4-23-63443-13434414552960059406_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.8_id121829_8-28-59756-8698475815754165825_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.8_id121829_8-28-59756-8698475815754165825_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc64-2.2.9_id259616_5-6-66953-5018725671498589377_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.2.9_id259616_5-6-66953-5018725671498589377_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-ppc64-2.3.1_id426989_3-13-61875-4723177368895607730_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-ppc64-2.3.1_id426989_3-13-61875-4723177368895607730_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86-2.0.0_id3251_7-16-33980_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86-2.0.0_id3251_7-16-33980_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86-2.0.2_id18650_12-7-37315-16484262108403302634_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86-2.0.2_id18650_12-7-37315-16484262108403302634_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86-2.1.1_id19454_6-23-43783-16484262108403302634_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86-2.1.1_id19454_6-23-43783-16484262108403302634_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86-64-2.2.4_id20631_12-13-43744-16977121959925885678_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86-64-2.2.4_id20631_12-13-43744-16977121959925885678_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86-64-2.2.6_id23755_4-23-38771-2124448682003854839_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86-64-2.2.6_id23755_4-23-38771-2124448682003854839_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86_64-2.0.0_id16795_7-16-38059_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.0.0_id16795_7-16-38059_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86_64-2.0.2_id15172_12-8-37621-274509493643487663_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.0.2_id15172_12-8-37621-274509493643487663_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86_64-2.1.1_id20947_6-23-63417-274509493643487663_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.1.1_id20947_6-23-63417-274509493643487663_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86_64-2.2.0_id3850_2-29-36600-13333843235489639491_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.2.0_id3850_2-29-36600-13333843235489639491_1.darshan.gz differ
Binary files a/darshan-test/example-output/carns_mpi-io-test-x86_64-2.2.5_id5824_2-27-41403-11500169623986228326_1.darshan.gz and b/darshan-test/2.x/example-output/carns_mpi-io-test-x86_64-2.2.5_id5824_2-27-41403-11500169623986228326_1.darshan.gz differ
Binary files a/darshan-test/example-output/pcarns_mpi-io-test-x86_64-2.2.8_id12451_8-28-46056-5041743303181360857_1.darshan.gz and b/darshan-test/2.x/example-output/pcarns_mpi-io-test-x86_64-2.2.8_id12451_8-28-46056-5041743303181360857_1.darshan.gz differ
Binary files a/darshan-test/example-output/pcarns_mpi-io-test-x86_64-2.2.9_id8751_5-6-43885-16506732777848558488_1.darshan.gz and b/darshan-test/2.x/example-output/pcarns_mpi-io-test-x86_64-2.2.9_id8751_5-6-43885-16506732777848558488_1.darshan.gz differ
Binary files a/darshan-test/example-output/pcarns_mpi-io-test-x86_64-2.3.1_id13154_3-13-47125-7023224190677163982_1.darshan.gz and b/darshan-test/2.x/example-output/pcarns_mpi-io-test-x86_64-2.3.1_id13154_3-13-47125-7023224190677163982_1.darshan.gz differ
--- a/darshan-test/gz-bench.c
+++ b/darshan-test/2.x/gz-bench.c
--- a/darshan-test/gztest.c
+++ b/darshan-test/2.x/gztest.c
--- a/darshan-test/parallel-fsstats.pl
+++ b/darshan-test/2.x/parallel-fsstats.pl
--- a/darshan-test/patches/99_cu_futimens.patch
+++ b/darshan-test/2.x/patches/99_cu_futimens.patch
--- a/darshan-test/patches/README
+++ b/darshan-test/2.x/patches/README
--- a/darshan-test/patches/coreutils-cp-mpi.patch
+++ b/darshan-test/2.x/patches/coreutils-cp-mpi.patch
--- a/darshan-test/patches/darshan-coll-write-single.patch
+++ b/darshan-test/2.x/patches/darshan-coll-write-single.patch
--- a/darshan-test/patches/darshan-coll-write-strategy-test.patch
+++ b/darshan-test/2.x/patches/darshan-coll-write-strategy-test.patch
Binary files a/darshan-test/pcarns_cp_id25476_1-16-15155_2.darshan.gz and b/darshan-test/2.x/pcarns_cp_id25476_1-16-15155_2.darshan.gz differ
--- a/darshan-test/perf/350665.output
+++ b/darshan-test/2.x/perf/350665.output
--- a/darshan-test/perf/350690.output
+++ b/darshan-test/2.x/perf/350690.output
--- a/darshan-test/perf/350892.output
+++ b/darshan-test/2.x/perf/350892.output
--- a/darshan-test/perf/354969.output
+++ b/darshan-test/2.x/perf/354969.output
--- a/darshan-test/perf/README
+++ b/darshan-test/2.x/perf/README
Binary files a/darshan-test/perf/harms_IOR_id350665_2-8-78651_12.darshan.gz and b/darshan-test/2.x/perf/harms_IOR_id350665_2-8-78651_12.darshan.gz differ
Binary files a/darshan-test/perf/harms_IOR_id350690_2-8-83458_1.darshan.gz and b/darshan-test/2.x/perf/harms_IOR_id350690_2-8-83458_1.darshan.gz differ
Binary files a/darshan-test/perf/harms_IOR_id350892_2-9-74258_1.darshan.gz and b/darshan-test/2.x/perf/harms_IOR_id350892_2-9-74258_1.darshan.gz differ
Binary files a/darshan-test/perf/harms_partshared_id354969_2-25-56979_1.darshan.gz and b/darshan-test/2.x/perf/harms_partshared_id354969_2-25-56979_1.darshan.gz differ
--- a/darshan-test/perf/partshared.c
+++ b/darshan-test/2.x/perf/partshared.c
--- a/darshan-test/perf/single_and_multi_file.ior
+++ b/darshan-test/2.x/perf/single_and_multi_file.ior
--- a/darshan-test/seek-test.c
+++ b/darshan-test/2.x/seek-test.c
--- a/darshan-test/stat-perf.c
+++ b/darshan-test/2.x/stat-perf.c
--- a/darshan-test/test-darshan-compiles-alcf2.sh
+++ b/darshan-test/2.x/test-darshan-compiles-alcf2.sh
--- a/darshan-test/test-darshan-compiles.sh
+++ b/darshan-test/2.x/test-darshan-compiles.sh
--- a/darshan-test/test-darshan-log-formats.sh
+++ b/darshan-test/2.x/test-darshan-log-formats.sh
darshan-test/ADDING-COUNTERS.txt deleted
--- a/darshan-test/ADDING-COUNTERS.txt
+++ /dev/null
@@ -1,17 +0,0 @@
-Notes from Florin Isaila re: adding new counters as of 2014/03/06
-1. Added the counters in darshan-log-format.h
-2. Added the names of the counters in darshan-util/darshan-logutils.c
-3. Added the new profiled function declarations (e.g., PMPI_Sent) in
-darshan-runtime/darshan-dynamic.h
- - DARSHAN_EXTERN_DECL(...)
-4. Added the new profiled function declarations (e.g., PMPI_Sent) in
-darshan-runtime/lib/darshan-mpi-init-finalize.c
- - DARSHAN_FORWARD_DECL(...)
- - MAP_OR_FAIL(...)
-5. Updated the reducer in darshan-runtime/lib/darshan-mpi-io.c in the
-function:
- static void darshan_file_reduce(void* infile_v,
-   void* inoutfile_v, int *len,
-   MPI_Datatype *datatype);
darshan-test/cuserid-test.c deleted
--- a/darshan-test/cuserid-test.c
+++ /dev/null
@@ -1,23 +0,0 @@
-#define _XOPEN_SOURCE
-#include <stdio.h>
-#include <unistd.h>
-#include <mpi.h>
-int main(int argc, char **argv)
-    int rank;
-    char user_string[L_cuserid];
-    MPI_Init(&argc,&argv);
-    MPI_Comm_rank(MPI_COMM_WORLD, &rank);
-    cuserid(user_string);
-    printf("rank %d: user: %s\n", rank, user_string);
-    MPI_Finalize();
-    return(0);
darshan-test/fsstats-merge.pl deleted
--- a/darshan-test/fsstats-merge.pl
+++ /dev/null
@@ -1,754 +0,0 @@
-#!/usr/bin/perl -w
-#  (C) 2010 by Argonne National Laboratory.
-#  Portions of this code including histogram package and routines for
-#  printing human readable sizes and percentages taken from fsstats 1.4.5
-#  Copyright (c) 2005 Panasas, Inc.
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2 of the License, or
-# (at your option) any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-use Cwd;
-use Getopt::Long;
-use English;
-# files to process
-my @csv_files = ();
-process_args();
-my $special_files = 0;
-my $skipped_hlink = 0;
-my $skipped_snapshot = 0;
-my $total_cap_used = 0;
-my $total_size = 0;
-my $slink_relative = 0;
-my $slink_absolute = 0;
-my $slink_relative_pct = 0;
-my $slink_absolute_pct = 0;
-my ($size_histo,
-    $cap_histo,
-    $pos_ovhd_histo,
-    $neg_ovhd_histo,
-    $dir_histo,
-    $dirkb_histo,
-    $fname_histo,
-    $slink_histo,
-    $hlink_histo,
-    $mtime_files_histo,
-    $mtime_bytes_histo,
-    $ctime_files_histo,
-    $ctime_bytes_histo,
-    $atime_files_histo,
-    $atime_bytes_histo);
-# initialize new histogram data structures (copied from fsstats program)
-$size_histo  = Histo->new(min => 0, incr => 1,  log_incr => 1, integer_vals => 0);
-$cap_histo   = Histo->new(min => 0, incr => 1,  log_incr => 1, integer_vals => 0);
-$pos_ovhd_histo  = Histo->new(min => 0, incr => 1, log_incr => 1, integer_vals => 0);
-$neg_ovhd_histo  = Histo->new(min => 0, incr => 1, log_incr => 1, integer_vals => 0);
-$dir_histo   = Histo->new(min => 0, incr => 1,  log_incr => 1);
-$dirkb_histo = Histo->new(min => 0, incr => 1,  log_incr => 1, integer_vals => 0);
-#Be careful in choosing the value of 'max' for histos.
-#If the log_incr is set for them, the largest value+1 in the last bucket will be a power of 2.
-#If it is not set the largest value+1 in the last bucket will be some multiple of the 'max' value.
-#To be able to toggle log_incr off and on without having to change anything else 'max' should be
-#chosen carefully. Otherwise results may look wrong.
-#Hence if the max value chosen is 'n', then n+1 should be a power of 2. And n+1 should also be a
-#multiple of the 'incr' value.
-#Dont play with min values.
-# $fname_histo = Histo->new(min => 0, max => 120, incr => 8);
-$fname_histo = Histo->new(min => 0, max => 127, incr => 8);
-# $slink_histo = Histo->new(min => 0, max => 120, incr => 8);
-$slink_histo = Histo->new(min => 0, max => 127, incr => 8);
-$hlink_histo = Histo->new(min => 0, incr => 1,  log_incr => 1);
-$mtime_files_histo = Histo->new(min => 0, incr => 1, log_incr => 1, integer_vals => 0);
-$mtime_bytes_histo = Histo->new(min => 0, incr => 1, log_incr => 1, integer_vals => 0);
-$ctime_files_histo = Histo->new(min => 0, incr => 1, log_incr => 1, integer_vals => 0);
-$ctime_bytes_histo = Histo->new(min => 0, incr => 1, log_incr => 1, integer_vals => 0);
-$atime_files_histo = Histo->new(min => 0, incr => 1, log_incr => 1, integer_vals => 0);
-$atime_bytes_histo = Histo->new(min => 0, incr => 1, log_incr => 1, integer_vals => 0);
-# loop through specified csv files
-foreach my $file ( @csv_files )
-    open(CSV, "$file") || die("Error opening file $file: $!\n");
-    add_summary(CSV);
-    add_histogram(CSV, $size_histo, "file size");
-    add_histogram(CSV, $cap_histo, "capacity used");
-    add_histogram(CSV, $pos_ovhd_histo, "positive overhead");
-    add_histogram(CSV, $neg_ovhd_histo, "negative overhead");
-    add_histogram(CSV, $dir_histo, "directory size (entries)");
-    add_histogram(CSV, $dirkb_histo, "directory size");
-    add_histogram(CSV, $fname_histo, "filename length");
-    add_histogram(CSV, $hlink_histo, "link count");
-    add_histogram(CSV, $slink_histo, "symlink target length");
-    add_histogram(CSV, $mtime_files_histo, "mtime (files)");
-    add_histogram(CSV, $mtime_bytes_histo, "mtime (KB)");
-    add_histogram(CSV, $ctime_files_histo, "ctime (files)");
-    add_histogram(CSV, $ctime_bytes_histo, "ctime (KB)");
-    add_histogram(CSV, $atime_files_histo, "atime (files)");
-    add_histogram(CSV, $atime_bytes_histo, "atime (KB)");
-    close(CSV);
-print_output();
-exit 0;
-sub print_output
-    open($fh, ">-") || die("Error opening output.\n");
-    printf($fh "#Generated by fsstats-merge.pl (fsstats v1.4.5)\n");
-    printf($fh "#Comment: This is a comment line that can be modified or repeated before\n");
-    printf($fh "#uploading to record voluntarily added information.\n\n");
-    printf($fh "skipped special files,%d\n", $special_files);
-    printf($fh "skipped duplicate hardlinks,%d\n", $skipped_hlink);
-    printf($fh "skipped snapshot dirs,%d\n", $skipped_snapshot);
-    printf($fh "total capacity used,%s\n", kb_to_print($total_cap_used));
-    printf($fh "total user data,%s\n", kb_to_print($total_size));
-    printf($fh "percent overhead,%f\n", ovhd_pct($total_size, $total_cap_used)/100);
-    printf($fh "\n");
-    $size_histo->print_csv($fh, "file size", "KB");
-    $cap_histo->print_csv($fh, "capacity used", "KB");
-    $pos_ovhd_histo->print_csv($fh, "positive overhead", "KB");
-    $neg_ovhd_histo->print_csv($fh, "negative overhead", "KB");
-    $dir_histo->print_csv($fh, "directory size (entries)", "ents");
-    $dirkb_histo->print_csv($fh, "directory size", "KB");
-    $fname_histo->print_csv($fh, "filename length", "chars");
-    $hlink_histo->print_csv($fh, "link count", "links");
-    $slink_histo->print_csv($fh, "symlink target length", "chars");
-    printf($fh "relative symlink target pct,%f\n" .
-           "absolute symlink target pct,%f\n",
-         $slink_relative ? $slink_relative / $slink_histo->{count} : 0,
-         $slink_absolute ? $slink_absolute / $slink_histo->{count} : 0);
-    $mtime_files_histo->print_csv($fh, "mtime (files)", "days");
-    $mtime_bytes_histo->print_csv($fh, "mtime (KB)", "days");
-    $ctime_files_histo->print_csv($fh, "ctime (files)", "days");
-    $ctime_bytes_histo->print_csv($fh, "ctime (KB)", "days");
-    $atime_files_histo->print_csv($fh, "atime (files)", "days");
-    $atime_bytes_histo->print_csv($fh, "atime (KB)", "days");
-sub process_args
-    use vars qw( $opt_help );
-    Getopt::Long::Configure("no_ignore_case", "bundling");
-    GetOptions( "help" );
-    if($opt_help)
-        print_help();
-        exit(0);
-    # there should be at least two remaining arguments (file names)
-    if($#ARGV < 1)
-        print "Error: invalid arguments.\n";
-        print_help();
-        exit(1);
-    @csv_files = @ARGV;
-    return;
-sub print_help
-    print <<EOF;
-Usage: $PROGRAM_NAME file file [file ...]
-    --help          Prints this help message
-Purpose:
-    This script reads multiple csv files generated by fsstats 1.4.5 and
-    merges the statistics into a single csv file which is printed to stdout.
-EOF
-    return;
-# add_summary()
-# adds summary fields from the specified file handle
-sub add_summary
-    my ($file) = @_;
-    my $line = "";
-    my $version = "";
-    seek($file, 0, 0);
-    while($line = <$file>)
-        if ($line =~ /Generated by.*fsstats v([\d\.]+)/) { $version = $1; }
-        if ($line =~ /^skipped special files,(.*)/) {$special_files += $1;}
-        if ($line =~ /^skipped duplicate hardlinks,(.*)/) {$skipped_hlink += $1;}
-        if ($line =~ /^skipped snapshot dirs,(.*)/) {$skipped_snapshot += $1;}
-        if ($line =~ /^total capacity used,(.*)/) {$total_cap_used += print_to_kb($1);}
-        if ($line =~ /^total user data,(.*)/) {$total_size += print_to_kb($1);}
-        # NOTE: deliberately don't accumulate slink percentage; we have to do
-        # a calculation later so that they are weighted properly.  See
-        # special case in add_histogram() subroutine.
-        if ($line =~ /^relative symlink target pct,(.*)/) {$slink_relative_pct = $1;}
-        if ($line =~ /^absolute symlink target pct,(.*)/) {$slink_absolute_pct = $1;}
-    if($version ne "1.4.5")
-        die("Error: csv file not generated by fsstats v1.4.5.\n");
-# add_histogram()
-# finds the specified histogram in a csv file and sums it to the existing
-# histogram data structure
-sub add_histogram
-    my $file = $_[0]; # open file handle
-    # $_[1] is the data structure we are adding to
-    my $name = quotemeta($_[2]); # name of the histogram
-    # save some global values; we need to replace/adjust those manually
-    # after adding in the histogram because we no longer know the actual
-    # value of each data point
-    my $old_count = $_[1]->{count};
-    my $old_total_val = $_[1]->{total_val};
-    my $old_min_val = $_[1]->{min_val};
-    my $old_max_val = $_[1]->{max_val};
-    my $count = 0;
-    my $average = 0;
-    my $min = 0;
-    my $max = 0;
-    my $total_count = 0;
-        # look for specified histogram
-        if($line =~ /^histogram,$name$/)
-                if($line =~ /^count,(.*),/) {$count = $1;}
-                elsif($line =~ /^average,(.*),/) {$average = $1;}
-                elsif($line =~ /^min,(.*),/) {$min = $1;}
-                elsif($line =~ /^max,(.*),/) {$max = $1;}
-                elsif($line =~ /^bucket min,bucket max,/) {} # key
-                elsif($line =~
-                /^([0-9]*\.?[0-9]*),([0-9]*\.?\-?[0-9]*),([0-9]*\.?[0-9]*),([0-9]*\.?[0-9]*),([0-9]*\.?[0-9]*),([0-9]*\.?[0-9]*),([0-9]*\.?[0-9]*),([0-9]*\.?[0-9]*)/)
-                    if ($3 > 0)
-                        $_[1]->add(($6/$3), $3);
-                        $total_count += $3;
-                elsif($line =~ /^\s*$/)
-                    # stop when we hit a blank line
-                    last;
-                else
-                    print $line;
-                    die("Error: poorly formated csv file.\n");
-            last;
-    # work backwards to relative and absolute slink counters
-    if($name eq quotemeta("symlink target length"))
-        $slink_relative += $slink_relative_pct * $total_count;
-        $slink_absolute += $slink_absolute_pct * $total_count;
-    # fix min and max value
-    if(defined $old_min_val && $old_min_val < $min)
-        {$_[1]->{min_val} = $old_min_val;}
-    else
-        {$_[1]->{min_val} = $min;}
-    if(defined $old_max_val && $old_max_val < $max)
-        {$_[1]->{max_val} = $old_max_val;}
-    else
-        {$_[1]->{max_val} = $max;}
-# convert a printable value to KB
-sub print_to_kb {
-    my ($arg) = @_;
-    my ($value, $unit) = split(/ /, $arg);
-    my $num = 0;
-    if($unit eq "TB")
-        $num = $value * (1024*1024*1024);
-    elsif($unit eq "GB")
-        $num = $value * (1024*1024);
-    elsif($unit eq "MB")
-        $num = $value * (1024);
-    elsif($unit eq "KB")
-        $num = $value;
-    return $num;
-# The routines in this section were taken directly from fsstats 1.4.5 by
-# Marc Unangst <munangst at panasas.com> and Shobhit Dayal
-# <sdayal at andrew.cmu.edu>
-# Compute the percent overhead for a given capacity-used and size.
-# This method of computing overhead computes "percentage of the
-# capacity used that is overhead" and ranges from 0% (no overhead) to
-# 100% (size==0 and cap>0, space is all overhead).
-sub ovhd_pct {
-    my ($size, $cap) = @_;
-    if ($cap == 0) {
-    return 0;
-    return (($cap - $size)/$cap)*100;
-# convert a KB value to a "printable" value (GB, MB, or KB) depending
-# on its magnitude. returns a string suitable for printing.
-sub kb_to_print {
-  my ($kb) = @_;
-  my $num;
-  my $unit;
-  if($kb > 1024*1024*1024) {
-    $num = $kb / (1024*1024*1024);
-    $unit = "TB";
-  elsif($kb > 1024*1024) {
-    $num = $kb / (1024*1024);
-    $unit = "GB";
-  elsif($kb > 1024) {
-    $num = $kb / 1024;
-    $unit = "MB";
-  else {
-    $num = $kb;
-    $unit = "KB";
-  return sprintf("%.2f %s", $num, $unit);
-##### Histo.pm #####
-# Histo.pm
-# Histogram module for Perl.
-# Author: Marc Unangst <munangst at panasas.com>
-# Copyright (c) 2005 Panasas, Inc.  All rights reserved.
-use strict;
-package Histo;
-# Constructor for a new Histo object.  The arguments are a hash
-# of parameter/value pairs.  The "min" and "incr" parameters
-# must be supplied.  "max" and "log_incr" are optional.
-sub new {
-  my $type = shift;
-  my %params = @_;
-  my $self = {};
-  die "Histo->new: required parameters not set\n"
-    unless (defined $params{min} && defined $params{incr});
-  $self->{min} = $params{min};
-#  $self->{max} = $params{max}-1 if defined $params{max};
-  $self->{max} = $params{max} if defined $params{max};
-  $self->{incr} = $params{incr};
-  if(defined $params{integer_vals}) {
-     $self->{integer_vals} = $params{integer_vals};
-  else {
-     $self->{integer_vals} = 1;
-  $self->{count} = 0;
-  $self->{total_val} = 0;
-  if($params{log_incr}) {
-    $self->{log_incr} = $params{log_incr};
-    $self->{bucket_max} = [$self->{min}+$self->{log_incr}];
-  else {
-    $self->{log_incr} = 0;
-  $self->{buckets} = [];
-  $self->{buckets_val} = [];
-  bless $self, $type;
-# Add a new data point to the histogram.
-# @arg  $val
-#   Value to add to the histogram
-# @arg  $count
-#   Optional; if specified, the weight of the item being added.
-#   Calling add($x, 3) is the same as calling add($x) three times.
-sub add ($$;$) {
-  my $self = shift;
-  my ($val, $count) = @_;
-  if(!defined $count) {
-    $count = 1;
-  if(!defined $self->{min_val} || $val < $self->{min_val}) {
-    $self->{min_val} = $val;
-  if(!defined $self->{max_val} || $val > $self->{max_val}) {
-    $self->{max_val} = $val;
-#  if(int($val) != $val) {
-#    $self->{integer_vals} = 0;
-  $self->{count} += $count;
-  $self->{total_val} += ($val*$count);
-  #$self->{total_val} += $val;
-  if(defined $self->{max} && $val > $self->{max}) {
-    $self->{over_max} += $count;
-    $self->{over_max_buckets_val} += $val*$count;
-  elsif($val < $self->{min}) {
-    $self->{under_min} += $count;
-    $self->{under_min_buckets_val} += $val*$count;
-  else {
-     my $b;
-     my $val_to_use = $val;
-# NOTE: not applicable in the fsstats-merge.pl script
-#     if($self == $pos_ovhd_histo || $self == $neg_ovhd_histo) {
-#        $val_to_use = $size;
-     if($self->{log_incr}) {
-        $b = 0;
-        my $x = $self->{bucket_max}[0];
-        while($val_to_use >= $x+1) {
-           $x = $x*2 + 1;
-           $b++;
-           if($b > $#{$self->{bucket_max}}) {
-              $self->{bucket_max}[$b] = $x;
-     else {
-        $b = int (($val_to_use - $self->{min}) / $self->{incr});
-    #print STDERR "sample $val into bucket $b\n";
-    $self->{buckets}[$b] += $count;
-    $self->{buckets_val}[$b] += $val*$count;
-    if(!defined $self->{largest_bucket} ||
-	 $self->{buckets}[$b] > $self->{largest_bucket}) {
-      $self->{largest_bucket} = $self->{buckets}[$b];
-# Get maximum value of the specified bucket.
-# @arg  $b
-#   bucket number
-# @internal
-sub _get_bucket_max ($$) {
-  my $self = shift;
-  my ($b) = @_;
-#  my $epsilon;   dont need this
-#  if($self->{integer_vals}) {
-#    $epsilon = 1;
-#    $epsilon = 0;
-#  else {
-#   $epsilon = 0.1;
-    if($b <= $#{$self->{bucket_max}}) {
-#     return ($self->{bucket_max}[$b]-$epsilon);
-      return ($self->{bucket_max}[$b]);
-    else {
-      return undef;
-  else {
-    #return ($self->{incr}*($b+1))-$epsilon;
-    return (($self->{incr}*($b+1)) -1);
-# Get minimum value of the specified bucket.
-# @arg  $b
-#   bucket number
-# @internal
-sub _get_bucket_min ($$) {
-  my $self = shift;
-  my ($b) = @_;
-    if($b == 0) {
-      return $self->{min};
-    elsif($b <= $#{$self->{bucket_max}}) {
-#     return $self->{bucket_max}[$b-1]
-      return $self->{bucket_max}[$b-1]+1;
-    else {
-      return undef;
-  else {
-    return ($self->{min} + $self->{incr}*($b));
-# Print the histogram contents to STDOUT.
-# @arg  $prefix
-#   String to prefix each output line with.
-# @arg  $unit_str
-#   String that describes the units of the histogram items.
-sub print ($$$) {
-  my $self = shift;
-  my ($prefix, $unit_str) = @_;
-  my $c = 0;
-  my $d = 0;
-#  my $prev_pct = 0;
-  my $width;
-  my $fmt;
-#  if ($self->{integer_vals}) {
-    $width = length sprintf("%d", $self->_get_bucket_max($#{$self->{buckets}}));
-    $fmt = "d";
-#  else {
-#    $width = length sprintf("%.1f", $self->_get_bucket_max($#{$self->{buckets}}));
-#    $fmt = ".1f"
-  my $bwidth = 0;
-  if (defined $self->{largest_bucket}) {
-    $bwidth = length sprintf("%d", $self->{largest_bucket});
-  if($bwidth < 5) {
-    $bwidth = 5;
-  my $bwidth_val = length sprintf("%.2f", $self->{total_val});
-  printf("%scount=%d avg=%.2f %s\n", $prefix,
-         $self->{count},
-         $self->{count} > 0 ? $self->{total_val} / $self->{count} : 0,
-         $unit_str);
-  my ($min_val, $max_val);
-  $min_val = defined $self->{min_val} ? $self->{min_val} : "0";
-  $max_val = defined $self->{max_val} ? $self->{max_val} : "0";
-  printf("%smin=%.2f %s max=%.2f %s\n", $prefix,
-         $min_val, $unit_str, $max_val, $unit_str);
-  if(defined $self->{under_min} &&  $self->{under_min} > 0) {
-    $c += $self->{under_min};
-    $d += $self->{under_min_buckets_val};
-    printf("%s[%${width}s<%${width}${fmt} %s]: %${bwidth}d (%5.2f%%) (%6.2f%% cumulative) %${bwidth_val}.2f %s (%5.2f%%) (%6.2f%% cumulative)\n", $prefix, " ", $self->{min}, $unit_str,
-           $c, ($c/$self->{count})*100, ($c/$self->{count})*100,
-           $d, $unit_str, ($d/$self->{total_val})*100, ($d/$self->{total_val})*100);
-  for(my $b = 0; $b <= $#{$self->{buckets}}; $b++) {
-    if($self->{buckets}->[$b]) {
-      my $x = $self->{buckets}->[$b];
-      my $y = $self->{buckets_val}->[$b];
-      $c += $x;
-      $d += $y;
-      my $pct = ($x / $self->{count}) * 100;
-      my $cum_pct = ($c / $self->{count}) * 100;
-      # if all the files parsed are zero bytes, the total_val will be zero but count will be a positive number
-      my $y_pct = 0;
-      my $y_cum_pct = 0;
-      if($self->{total_val}) {
-         $y_pct = ($y / $self->{total_val}) * 100;
-         $y_cum_pct = ($d / $self->{total_val}) * 100;
-      if ($self->{integer_vals}) {
-	      printf("%s[%${width}${fmt}-%${width}${fmt} %s]: %${bwidth}d (%5.2f%%) (%6.2f%% cumulative) %${bwidth_val}.2f %s (%5.2f%%) (%6.2f%% cumulative) \n", $prefix,
-		      $self->_get_bucket_min($b), $self->_get_bucket_max($b),
-		      $unit_str, $x, $pct, $cum_pct, $y, $unit_str, $y_pct, $y_cum_pct);
-     }else {
-	     printf("%s[%${width}${fmt}-%${width}${fmt} %s): %${bwidth}d (%5.2f%%) (%6.2f%% cumulative) %${bwidth_val}.2f %s (%5.2f%%) (%6.2f%% cumulative)\n", $prefix,
-		      $self->_get_bucket_min($b), $self->_get_bucket_max($b)+1,
- #     $prev_pct = $cum_pct;
-  if(defined $self->{over_max} && $self->{over_max} > 0) {
-    $c += $self->{over_max};
-    $d += $self->{over_max_buckets_val};
-    printf("%s[%${width}s>%${width}${fmt} %s]: %${bwidth}d (%5.2f%%) (%6.2f%% cumulative) %${bwidth_val}.2f %s (%5.2f%%) (%6.2f%% cumulative)\n", $prefix, " ", $self->{max}, $unit_str,
-          $self->{over_max}, ($self->{over_max} / $self->{count})*100, ($c / $self->{count})*100,
-          $self->{over_max_buckets_val}, $unit_str, ($self->{over_max_buckets_val} / $self->{total_val})*100, ($d/$self->{total_val})*100);
-# Print histogram contents to a CSV-format file.
-# @arg  $fh
-#   filehandle to print to
-# @arg  $name
-#   descriptive name of this histogram, to identify it in the file
-# @arg  $unit_str
-#   string that describes the units of the histogram items
-sub print_csv {
-  my $self = shift;
-  my ($fh, $name, $unit_str) = @_;
-  my $c = 0;
-  my $d = 0;
-  printf($fh "histogram,%s\n", $name);
-  printf($fh "count,%d,items\n",
-	 $self->{count});
-  printf($fh "average,%f,%s\n",
-	 $unit_str);
-  printf($fh "min,%d,%s\n", $min_val, $unit_str);
-  printf($fh "max,%d,%s\n", $max_val, $unit_str);
-  print $fh "bucket min,bucket max,count,percent,cumulative pct,val count,percent,cumulative pct\n";
-  if (defined $self->{under_min} && $self->{under_min} > 0) {
-    printf($fh "%d,%d,%d,%f,%f,%f,%f,%f\n",
-          -1, $self->{min}, $c, $c/$self->{count}, $c/$self->{count},
-          $d, $d/$self->{total_val}, $d/$self->{total_val});
-  for (my $b = 0; $b <= $#{$self->{buckets}}; $b++) {
-    if (defined $self->{buckets}->[$b] && $self->{buckets}->[$b] != 0) {
-      $c += $x;
-      $d += $y;
-      my $pct = $x / $self->{count};
-      my $cum_pct = $c / $self->{count};
-      my $y_pct = 0;
-         $y_pct = $y / $self->{total_val};
-         $y_cum_pct = $d / $self->{total_val};
-      if($self->{integer_vals}) {
-               $x, $pct, $cum_pct, $y, $y_pct, $y_cum_pct);
-      else {
-  if (defined $self->{over_max} && $self->{over_max} > 0) {
-           $self->{max}, -1, $self->{over_max}, $self->{over_max}/$self->{count}, $c/$self->{count},
-           $self->{over_max_buckets_val},  $self->{over_max_buckets_val}/$self->{total_val}, $d/$self->{total_val});
-  print $fh "\n";
-__END__
darshan-test/fsstats-runner.bash deleted
--- a/darshan-test/fsstats-runner.bash
+++ /dev/null
@@ -1,54 +0,0 @@
-#!/bin/bash
-#      See COPYRIGHT in top-level directory.
-# usage: fsstats-runner.bash <hostname> <path>
-# make this configurable or something...
-FSSTATS_PATH=/home/harms/darshan/trunk/test
-if [ "${#}" != 4 ]
-then
-    echo "Error: bad arguments"
-    exit 1
-fi
-HOST=${1}
-FS_PATH=${2}
-CHKPNT=${3}
-RESTART=${4}
-# the output file name will be the path that was scanned, but with equals
-# signs in place of the slashes
-OUT_FILE=`echo $FS_PATH | sed -e 's/\//=/g'`
-OUT_FILE="${OUT_FILE}.csv"
-# launch remote command
-if [ $RESTART -eq 1 ];
-then
-    ssh -oBatchMode=yes -n $HOST "${FSSTATS_PATH}/fsstats -r $CHKPNT -c $CHKPNT -o /tmp/pfsstats-$$.csv $FS_PATH >& /dev/null"
-else
-    ssh -oBatchMode=yes -n $HOST "${FSSTATS_PATH}/fsstats -c $CHKPNT -o /tmp/pfsstats-$$.csv $FS_PATH >& /dev/null"
-fi
-if [ "${?}" != 0 ]
-then
-    exit 1
-fi
-# retrieve output file
-scp -oBatchMode=yes $HOST:/tmp/pfsstats-$$.csv $OUT_FILE >& /dev/null
-if [ "${?}" != 0 ]
-then
-    exit 1
-fi
-# delete file on remote host
-ssh -oBatchMode=yes -n $HOST "rm -f /tmp/pfsstats-$$.csv >& /dev/null"
-if [ "${?}" != 0 ]
-then
-    exit 1
-fi
-exit 0
darshan-test/output.txt deleted
--- a/darshan-test/output.txt
+++ /dev/null
@@ -1,2544 +0,0 @@
-# size of file statistics: 992 bytes
-# exe: /home/pcarns/working/chutzpah/trunk/chutzpah/test/coreutils-6.9/src/cp bin/[ bin/411toppm bin/4xml bin/4xpath bin/4xslt bin/4xupdate bin/822-date bin/a2p bin/a2ping bin/abrowser bin/abrowser-3.0 bin/aclocal bin/aclocal-1.10 bin/aconnect bin/acpi bin/acpi_fakekey bin/acpi_listen bin/acroread bin/addpart bin/addr2line bin/afm2tfm bin/alacarte bin/allcm bin/allec bin/allneeded bin/alsamixer bin/amarok bin/amarokapp bin/amarokcollectionscanner bin/amarok_daapserver.rb bin/amarok_libvisual bin/amarok_proxy.rb bin/amidi bin/amixer bin/amuFormat.sh bin/animate bin/anytopnm bin/aoss bin/aplay bin/aplaymidi bin/apm bin/apmsleep bin/apport-cli bin/apport-unpack bin/appres bin/apropos bin/apt-cache bin/apt-cdrom bin/apt-config bin/apt-extracttemplates bin/apt-ftparchive bin/apt-get bin/aptitude bin/aptitude-create-state-bundle bin/aptitude-run-state-bundle bin/apt-key bin/apt-mark bin/apt-sortpkgs bin/apturl bin/ar bin/arecord bin/arecordmidi bin/arm2hpdl b<TRUNCATED>
-# uid: 1000
-# start_time: 1232118755
-# end_time: 1232118811
-# nprocs: 1
-# run time: 57
-# number of records available: 5472
-# using gzip default compression settings.
-<records>	<native size>	<compressed size>	<percentage>
-1	992	80	0.919355
-2	1984	125	0.936996
-3	2976	179	0.939852
-4	3968	221	0.944304
-5	4960	266	0.946371
-6	5952	305	0.948757
-7	6944	342	0.950749
-8	7936	376	0.952621
-9	8928	409	0.954189
-10	9920	441	0.955544
-11	10912	474	0.956562
-12	11904	502	0.957829
-13	12896	537	0.958359
-14	13888	564	0.959389
-15	14880	615	0.958669
-16	15872	653	0.958858
-17	16864	686	0.959322
-18	17856	710	0.960237
-19	18848	747	0.960367
-20	19840	777	0.960837
-21	20832	799	0.961646
-22	21824	815	0.962656
-23	22816	866	0.962044
-24	23808	901	0.962156
-25	24800	923	0.962782
-26	25792	940	0.963555
-27	26784	975	0.963598
-28	27776	1003	0.963890
-29	28768	1033	0.964092
-30	29760	1059	0.964415
-31	30752	1094	0.964425
-32	31744	1120	0.964718
-33	32736	1155	0.964718
-34	33728	1181	0.964985
-35	34720	1224	0.964747
-36	35712	1249	0.965026
-37	36704	1285	0.964990
-38	37696	1315	0.965116
-39	38688	1360	0.964847
-40	39680	1392	0.964919
-41	40672	1438	0.964644
-42	41664	1477	0.964550
-43	42656	1510	0.964601
-44	43648	1538	0.964764
-45	44640	1572	0.964785
-46	45632	1599	0.964959
-47	46624	1621	0.965232
-48	47616	1641	0.965537
-49	48608	1675	0.965541
-50	49600	1701	0.965706
-51	50592	1747	0.965469
-52	51584	1780	0.965493
-53	52576	1814	0.965498
-54	53568	1842	0.965614
-55	54560	1885	0.965451
-56	55552	1920	0.965438
-57	56544	1969	0.965178
-58	57536	2001	0.965222
-59	58528	2037	0.965196
-60	59520	2064	0.965323
-61	60512	2098	0.965329
-62	61504	2121	0.965514
-63	62496	2157	0.965486
-64	63488	2182	0.965631
-65	64480	2215	0.965648
-66	65472	2244	0.965726
-67	66464	2278	0.965726
-68	67456	2304	0.965844
-69	68448	2342	0.965784
-70	69440	2368	0.965899
-71	70432	2400	0.965925
-72	71424	2440	0.965838
-73	72416	2475	0.965822
-74	73408	2504	0.965889
-75	74400	2536	0.965914
-76	75392	2563	0.966004
-77	76384	2610	0.965831
-78	77376	2646	0.965803
-79	78368	2677	0.965841
-80	79360	2702	0.965953
-81	80352	2734	0.965975
-82	81344	2762	0.966045
-83	82336	2793	0.966078
-84	83328	2818	0.966182
-85	84320	2850	0.966200
-86	85312	2873	0.966324
-87	86304	2907	0.966317
-88	87296	2932	0.966413
-89	88288	2965	0.966417
-90	89280	2991	0.966499
-91	90272	3036	0.966368
-92	91264	3069	0.966372
-93	92256	3116	0.966224
-94	93248	3151	0.966208
-95	94240	3181	0.966246
-96	95232	3206	0.966335
-97	96224	3239	0.966339
-98	97216	3264	0.966425
-99	98208	3300	0.966398
-100	99200	3323	0.966502
-101	100192	3374	0.966325
-102	101184	3406	0.966339
-103	102176	3452	0.966215
-104	103168	3487	0.966201
-105	104160	3532	0.966091
-106	105152	3566	0.966087
-107	106144	3603	0.966056
-108	107136	3629	0.966127
-109	108128	3657	0.966179
-110	109120	3681	0.966266
-111	110112	3713	0.966280
-112	111104	3740	0.966338
-113	112096	3771	0.966359
-114	113088	3799	0.966407
-115	114080	3846	0.966287
-116	115072	3879	0.966291
-117	116064	3911	0.966303
-118	117056	3938	0.966358
-119	118048	3983	0.966259
-120	119040	4017	0.966255
-121	120032	4048	0.966276
-122	121024	4072	0.966354
-123	122016	4103	0.966373
-124	123008	4129	0.966433
-125	124000	4163	0.966427
-126	124992	4190	0.966478
-127	125984	4223	0.966480
-128	126976	4250	0.966529
-129	127968	4298	0.966413
-130	128960	4331	0.966416
-131	129952	4377	0.966318
-132	130944	4409	0.966329
-133	131936	4444	0.966317
-134	132928	4472	0.966358
-135	133920	4507	0.966346
-136	134912	4531	0.966415
-137	135904	4563	0.966425
-138	136896	4589	0.966478
-139	137888	4642	0.966335
-140	138880	4678	0.966316
-141	139872	4700	0.966398
-142	140864	4728	0.966436
-143	141856	4770	0.966374
-144	142848	4797	0.966419
-145	143840	4832	0.966407
-146	144832	4867	0.966396
-147	145824	4894	0.966439
-148	146816	4911	0.966550
-149	147808	4952	0.966497
-150	148800	4982	0.966519
-151	149792	5008	0.966567
-152	150784	5036	0.966601
-153	151776	5069	0.966602
-154	152768	5092	0.966668
-155	153760	5138	0.966584
-156	154752	5174	0.966566
-157	155744	5208	0.966561
-158	156736	5233	0.966613
-159	157728	5263	0.966632
-160	158720	5292	0.966658
-161	159712	5325	0.966659
-162	160704	5351	0.966703
-163	161696	5380	0.966728
-164	162688	5407	0.966765
-165	163680	5428	0.966838
-166	164672	5450	0.966904
-167	165664	5470	0.966981
-168	166656	5490	0.967058
-169	167648	5519	0.967080
-170	168640	5545	0.967119
-171	169632	5581	0.967099
-172	170624	5606	0.967144
-173	171616	5638	0.967148
-174	172608	5663	0.967192
-175	173600	5700	0.967166
-176	174592	5725	0.967209
-177	175584	5770	0.967138
-178	176576	5804	0.967130
-179	177568	5847	0.967072
-180	178560	5880	0.967070
-181	179552	5904	0.967118
-182	180544	5922	0.967199
-183	181536	5966	0.967136
-184	182528	6000	0.967128
-185	183520	6030	0.967143
-186	184512	6053	0.967195
-187	185504	6090	0.967171
-188	186496	6119	0.967190
-189	187488	6164	0.967123
-190	188480	6195	0.967132
-191	189472	6231	0.967114
-192	190464	6260	0.967133
-193	191456	6286	0.967167
-194	192448	6307	0.967228
-195	193440	6342	0.967215
-196	194432	6366	0.967258
-197	195424	6391	0.967297
-198	196416	6409	0.967370
-199	197408	6433	0.967413
-200	198400	6451	0.967485
-201	199392	6487	0.967466
-202	200384	6518	0.967472
-203	201376	6540	0.967523
-204	202368	6557	0.967599
-205	203360	6582	0.967634
-206	204352	6601	0.967698
-207	205344	6627	0.967727
-208	206336	6650	0.967771
-209	207328	6700	0.967684
-210	208320	6735	0.967670
-211	209312	6758	0.967713
-212	210304	6775	0.967785
-213	211296	6820	0.967723
-214	212288	6857	0.967700
-215	213280	6904	0.967629
-216	214272	6938	0.967621
-217	215264	6979	0.967579
-218	216256	7010	0.967585
-219	217248	7052	0.967539
-220	218240	7086	0.967531
-221	219232	7128	0.967486
-222	220224	7162	0.967479
-223	221216	7194	0.967480
-224	222208	7222	0.967499
-225	223200	7265	0.967451
-226	224192	7299	0.967443
-227	225184	7332	0.967440
-228	226176	7360	0.967459
-229	227168	7390	0.967469
-230	228160	7419	0.967483
-231	229152	7453	0.967476
-232	230144	7477	0.967512
-233	231136	7514	0.967491
-234	232128	7538	0.967527
-235	233120	7571	0.967523
-236	234112	7599	0.967541
-237	235104	7632	0.967538
-238	236096	7658	0.967564
-239	237088	7690	0.967565
-240	238080	7715	0.967595
-241	239072	7749	0.967587
-242	240064	7775	0.967613
-243	241056	7807	0.967613
-244	242048	7833	0.967639
-245	243040	7863	0.967647
-246	244032	7889	0.967672
-247	245024	7917	0.967689
-248	246016	7943	0.967713
-249	247008	7977	0.967705
-250	248000	8003	0.967730
-251	248992	8034	0.967734
-252	249984	8061	0.967754
-253	250976	8094	0.967750
-254	251968	8120	0.967774
-255	252960	8145	0.967801
-256	253952	8162	0.967860
-257	254944	8192	0.967867
-258	255936	8218	0.967890
-259	256928	8249	0.967894
-260	257920	8276	0.967913
-261	258912	8325	0.967846
-262	259904	8358	0.967842
-263	260896	8394	0.967826
-264	261888	8420	0.967849
-265	262880	8451	0.967852
-266	263872	8479	0.967867
-267	264864	8510	0.967870
-268	265856	8538	0.967885
-269	266848	8585	0.967828
-270	267840	8620	0.967817
-271	268832	8663	0.967775
-272	269824	8695	0.967775
-273	270816	8740	0.967727
-274	271808	8774	0.967720
-275	272800	8820	0.967669
-276	273792	8854	0.967662
-277	274784	8891	0.967644
-278	275776	8917	0.967666
-279	276768	8965	0.967608
-280	277760	9000	0.967598
-281	278752	9034	0.967591
-282	279744	9061	0.967610
-283	280736	9099	0.967589
-284	281728	9120	0.967628
-285	282720	9155	0.967618
-286	283712	9178	0.967650
-287	284704	9224	0.967601
-288	285696	9257	0.967598
-289	286688	9290	0.967595
-290	287680	9314	0.967624
-291	288672	9347	0.967621
-292	289664	9372	0.967645
-293	290656	9418	0.967597
-294	291648	9451	0.967594
-295	292640	9485	0.967588
-296	293632	9512	0.967606
-297	294624	9532	0.967647
-298	295616	9554	0.967681
-299	296608	9586	0.967681
-300	297600	9613	0.967698
-301	298592	9662	0.967641
-302	299584	9695	0.967638
-303	300576	9743	0.967586
-304	301568	9777	0.967579
-305	302560	9810	0.967577
-306	303552	9834	0.967604
-307	304544	9868	0.967597
-308	305536	9894	0.967618
-309	306528	9944	0.967559
-310	307520	9978	0.967553
-311	308512	10013	0.967544
-312	309504	10037	0.967571
-313	310496	10068	0.967574
-314	311488	10093	0.967597
-315	312480	10140	0.967550
-316	313472	10173	0.967547
-317	314464	10209	0.967535
-318	315456	10234	0.967558
-319	316448	10271	0.967543
-320	317440	10297	0.967562
-321	318432	10334	0.967547
-322	319424	10359	0.967570
-323	320416	10393	0.967564
-324	321408	10422	0.967574
-325	322400	10467	0.967534
-326	323392	10502	0.967525
-327	324384	10536	0.967520
-328	325376	10561	0.967542
-329	326368	10587	0.967561
-330	327360	10604	0.967608
-331	328352	10639	0.967599
-332	329344	10664	0.967620
-333	330336	10684	0.967657
-334	331328	10701	0.967703
-335	332320	10736	0.967694
-336	333312	10762	0.967712
-337	334304	10780	0.967754
-338	335296	10798	0.967796
-339	336288	10836	0.967778
-340	337280	10870	0.967772
-341	338272	10887	0.967816
-342	339264	10905	0.967857
-343	340256	10939	0.967851
-344	341248	10968	0.967859
-345	342240	10986	0.967900
-346	343232	11003	0.967943
-347	344224	11040	0.967928
-348	345216	11066	0.967945
-349	346208	11084	0.967985
-350	347200	11101	0.968027
-351	348192	11135	0.968021
-352	349184	11162	0.968034
-353	350176	11180	0.968073
-354	351168	11198	0.968112
-355	352160	11233	0.968103
-356	353152	11261	0.968113
-357	354144	11279	0.968151
-358	355136	11296	0.968192
-359	356128	11330	0.968186
-360	357120	11355	0.968204
-361	358112	11373	0.968242
-362	359104	11389	0.968285
-363	360096	11422	0.968281
-364	361088	11452	0.968285
-365	362080	11470	0.968322
-366	363072	11486	0.968364
-367	364064	11536	0.968313
-368	365056	11569	0.968309
-369	366048	11616	0.968266
-370	367040	11652	0.968254
-371	368032	11698	0.968215
-372	369024	11732	0.968208
-373	370016	11764	0.968207
-374	371008	11794	0.968211
-375	372000	11816	0.968237
-376	372992	11836	0.968267
-377	373984	11866	0.968271
-378	374976	11893	0.968283
-379	375968	11914	0.968311
-380	376960	11933	0.968344
-381	377952	11968	0.968335
-382	378944	11992	0.968354
-383	379936	12035	0.968324
-384	380928	12070	0.968314
-385	381920	12102	0.968313
-386	382912	12128	0.968327
-387	383904	12162	0.968320
-388	384896	12184	0.968345
-389	385888	12221	0.968330
-390	386880	12246	0.968347
-391	387872	12291	0.968312
-392	388864	12324	0.968308
-393	389856	12360	0.968296
-394	390848	12383	0.968318
-395	391840	12413	0.968321
-396	392832	12439	0.968335
-397	393824	12486	0.968295
-398	394816	12521	0.968286
-399	395808	12564	0.968257
-400	396800	12598	0.968251
-401	397792	12637	0.968232
-402	398784	12665	0.968241
-403	399776	12711	0.968205
-404	400768	12747	0.968194
-405	401760	12791	0.968163
-406	402752	12826	0.968154
-407	403744	12858	0.968153
-408	404736	12885	0.968164
-409	405728	12918	0.968161
-410	406720	12944	0.968175
-411	407712	12980	0.968164
-412	408704	13003	0.968185
-413	409696	13049	0.968150
-414	410688	13085	0.968139
-415	411680	13130	0.968106
-416	412672	13167	0.968093
-417	413664	13214	0.968056
-418	414656	13247	0.968053
-419	415648	13282	0.968045
-420	416640	13310	0.968054
-421	417632	13341	0.968056
-422	418624	13365	0.968074
-423	419616	13415	0.968030
-424	420608	13449	0.968025
-425	421600	13482	0.968022
-426	422592	13510	0.968031
-427	423584	13542	0.968030
-428	424576	13571	0.968036
-429	425568	13615	0.968007
-430	426560	13649	0.968002
-431	427552	13680	0.968004
-432	428544	13705	0.968020
-433	429536	13743	0.968005
-434	430528	13773	0.968009
-435	431520	13808	0.968001
-436	432512	13838	0.968006
-437	433504	13872	0.968000
-438	434496	13897	0.968016
-439	435488	13927	0.968020
-440	436480	13956	0.968026
-441	437472	13991	0.968019
-442	438464	14019	0.968027
-443	439456	14050	0.968029
-444	440448	14077	0.968039
-445	441440	14106	0.968045
-446	442432	14134	0.968054
-447	443424	14166	0.968053
-448	444416	14191	0.968068
-449	445408	14240	0.968029
-450	446400	14275	0.968022
-451	447392	14312	0.968010
-452	448384	14338	0.968023
-453	449376	14375	0.968011
-454	450368	14402	0.968022
-455	451360	14434	0.968021
-456	452352	14459	0.968036
-457	453344	14493	0.968031
-458	454336	14520	0.968041
-459	455328	14556	0.968032
-460	456320	14583	0.968042
-461	457312	14616	0.968039
-462	458304	14643	0.968050
-463	459296	14678	0.968042
-464	460288	14703	0.968057
-465	461280	14746	0.968032
-466	462272	14782	0.968023
-467	463264	14817	0.968016
-468	464256	14842	0.968031
-469	465248	14876	0.968026
-470	466240	14905	0.968031
-471	467232	14936	0.968033
-472	468224	14963	0.968043
-473	469216	14989	0.968055
-474	470208	15007	0.968084
-475	471200	15041	0.968079
-476	472192	15067	0.968091
-477	473184	15099	0.968091
-478	474176	15127	0.968098
-479	475168	15158	0.968100
-480	476160	15185	0.968109
-481	477152	15215	0.968113
-482	478144	15241	0.968125
-483	479136	15272	0.968126
-484	480128	15298	0.968138
-485	481120	15329	0.968139
-486	482112	15357	0.968146
-487	483104	15389	0.968146
-488	484096	15417	0.968153
-489	485088	15446	0.968158
-490	486080	15472	0.968170
-491	487072	15509	0.968159
-492	488064	15535	0.968170
-493	489056	15562	0.968180
-494	490048	15580	0.968207
-495	491040	15630	0.968170
-496	492032	15661	0.968171
-497	493024	15691	0.968174
-498	494016	15718	0.968183
-499	495008	15750	0.968182
-500	496000	15778	0.968190
-501	496992	15814	0.968181
-502	497984	15839	0.968194
-503	498976	15872	0.968191
-504	499968	15899	0.968200
-505	500960	15933	0.968195
-506	501952	15958	0.968208
-507	502944	16002	0.968183
-508	503936	16038	0.968175
-509	504928	16068	0.968178
-510	505920	16095	0.968187
-511	506912	16128	0.968184
-512	507904	16154	0.968195
-513	508896	16186	0.968194
-514	509888	16215	0.968199
-515	510880	16249	0.968194
-516	511872	16275	0.968205
-517	512864	16309	0.968200
-518	513856	16338	0.968205
-519	514848	16375	0.968194
-520	515840	16401	0.968205
-521	516832	16447	0.968177
-522	517824	16481	0.968173
-523	518816	16526	0.968147
-524	519808	16560	0.968142
-525	520800	16604	0.968118
-526	521792	16639	0.968112
-527	522784	16660	0.968132
-528	523776	16681	0.968152
-529	524768	16728	0.968123
-530	525760	16760	0.968122
-531	526752	16798	0.968110
-532	527744	16826	0.968117
-533	528736	16858	0.968116
-534	529728	16885	0.968125
-535	530720	16930	0.968100
-536	531712	16964	0.968096
-537	532704	17001	0.968085
-538	533696	17025	0.968100
-539	534688	17072	0.968071
-540	535680	17107	0.968065
-541	536672	17137	0.968068
-542	537664	17166	0.968073
-543	538656	17197	0.968074
-544	539648	17222	0.968087
-545	540640	17257	0.968080
-546	541632	17283	0.968091
-547	542624	17319	0.968083
-548	543616	17348	0.968088
-549	544608	17378	0.968091
-550	545600	17403	0.968103
-551	546592	17436	0.968101
-552	547584	17461	0.968113
-553	548576	17493	0.968112
-554	549568	17517	0.968126
-555	550560	17548	0.968127
-556	551552	17572	0.968141
-557	552544	17603	0.968142
-558	553536	17631	0.968148
-559	554528	17665	0.968144
-560	555520	17694	0.968149
-561	556512	17736	0.968130
-562	557504	17771	0.968124
-563	558496	17815	0.968102
-564	559488	17849	0.968098
-565	560480	17891	0.968079
-566	561472	17925	0.968075
-567	562464	17955	0.968078
-568	563456	17984	0.968083
-569	564448	18031	0.968056
-570	565440	18066	0.968050
-571	566432	18097	0.968051
-572	567424	18125	0.968057
-573	568416	18162	0.968048
-574	569408	18187	0.968060
-575	570400	18219	0.968059
-576	571392	18244	0.968071
-577	572384	18278	0.968067
-578	573376	18303	0.968079
-579	574368	18339	0.968071
-580	575360	18364	0.968083
-581	576352	18397	0.968080
-582	577344	18422	0.968092
-583	578336	18457	0.968086
-584	579328	18482	0.968098
-585	580320	18514	0.968097
-586	581312	18535	0.968115
-587	582304	18572	0.968106
-588	583296	18597	0.968117
-589	584288	18631	0.968113
-590	585280	18655	0.968126
-591	586272	18683	0.968133
-592	587264	18708	0.968144
-593	588256	18739	0.968145
-594	589248	18762	0.968159
-595	590240	18788	0.968169
-596	591232	18805	0.968194
-597	592224	18845	0.968179
-598	593216	18870	0.968190
-599	594208	18905	0.968185
-600	595200	18931	0.968194
-601	596192	18965	0.968190
-602	597184	18989	0.968202
-603	598176	19021	0.968202
-604	599168	19044	0.968216
-605	600160	19088	0.968195
-606	601152	19123	0.968189
-607	602144	19153	0.968192
-608	603136	19178	0.968203
-609	604128	19223	0.968181
-610	605120	19254	0.968182
-611	606112	19290	0.968174
-612	607104	19315	0.968185
-613	608096	19348	0.968183
-614	609088	19374	0.968192
-615	610080	19405	0.968193
-616	611072	19429	0.968205
-617	612064	19473	0.968185
-618	613056	19508	0.968179
-619	614048	19542	0.968175
-620	615040	19568	0.968184
-621	616032	19615	0.968159
-622	617024	19649	0.968155
-623	618016	19673	0.968167
-624	619008	19691	0.968189
-625	620000	19723	0.968189
-626	620992	19750	0.968196
-627	621984	19782	0.968195
-628	622976	19809	0.968203
-629	623968	19833	0.968215
-630	624960	19850	0.968238
-631	625952	19885	0.968232
-632	626944	19910	0.968243
-633	627936	19942	0.968242
-634	628928	19966	0.968254
-635	629920	20012	0.968231
-636	630912	20047	0.968225
-637	631904	20092	0.968204
-638	632896	20129	0.968195
-639	633888	20161	0.968195
-640	634880	20188	0.968202
-641	635872	20225	0.968193
-642	636864	20253	0.968199
-643	637856	20286	0.968197
-644	638848	20314	0.968202
-645	639840	20351	0.968194
-646	640832	20375	0.968205
-647	641824	20413	0.968195
-648	642816	20439	0.968204
-649	643808	20476	0.968195
-650	644800	20501	0.968206
-651	645792	20533	0.968205
-652	646784	20557	0.968217
-653	647776	20593	0.968210
-654	648768	20617	0.968221
-655	649760	20653	0.968214
-656	650752	20678	0.968224
-657	651744	20711	0.968222
-658	652736	20736	0.968232
-659	653728	20770	0.968228
-660	654720	20795	0.968238
-661	655712	20828	0.968236
-662	656704	20856	0.968241
-663	657696	20878	0.968256
-664	658688	20895	0.968278
-665	659680	20916	0.968294
-666	660672	20933	0.968316
-667	661664	20965	0.968315
-668	662656	20990	0.968324
-669	663648	21011	0.968340
-670	664640	21029	0.968360
-671	665632	21052	0.968373
-672	666624	21069	0.968394
-673	667616	21089	0.968411
-674	668608	21107	0.968431
-675	669600	21139	0.968430
-676	670592	21167	0.968435
-677	671584	21216	0.968409
-678	672576	21247	0.968410
-679	673568	21297	0.968382
-680	674560	21329	0.968381
-681	675552	21374	0.968361
-682	676544	21409	0.968355
-683	677536	21458	0.968329
-684	678528	21493	0.968324
-685	679520	21530	0.968316
-686	680512	21560	0.968318
-687	681504	21590	0.968320
-688	682496	21614	0.968331
-689	683488	21661	0.968308
-690	684480	21699	0.968299
-691	685472	21732	0.968296
-692	686464	21763	0.968297
-693	687456	21801	0.968287
-694	688448	21827	0.968295
-695	689440	21858	0.968296
-696	690432	21883	0.968305
-697	691424	21918	0.968300
-698	692416	21943	0.968310
-699	693408	21973	0.968312
-700	694400	21996	0.968324
-701	695392	22028	0.968323
-702	696384	22053	0.968332
-703	697376	22085	0.968331
-704	698368	22110	0.968340
-705	699360	22142	0.968340
-706	700352	22170	0.968344
-707	701344	22203	0.968342
-708	702336	22228	0.968351
-709	703328	22263	0.968346
-710	704320	22287	0.968357
-711	705312	22323	0.968350
-712	706304	22348	0.968359
-713	707296	22379	0.968360
-714	708288	22407	0.968365
-715	709280	22441	0.968361
-716	710272	22466	0.968370
-717	711264	22501	0.968365
-718	712256	22525	0.968375
-719	713248	22558	0.968373
-720	714240	22586	0.968378
-721	715232	22616	0.968379
-722	716224	22641	0.968388
-723	717216	22676	0.968383
-724	718208	22702	0.968391
-725	719200	22734	0.968390
-726	720192	22760	0.968397
-727	721184	22792	0.968396
-728	722176	22817	0.968405
-729	723168	22848	0.968406
-730	724160	22873	0.968414
-731	725152	22903	0.968416
-732	726144	22927	0.968426
-733	727136	22958	0.968427
-734	728128	22983	0.968435
-735	729120	23014	0.968436
-736	730112	23038	0.968446
-737	731104	23069	0.968446
-738	732096	23093	0.968456
-739	733088	23126	0.968454
-740	734080	23151	0.968463
-741	735072	23183	0.968462
-742	736064	23208	0.968470
-743	737056	23244	0.968464
-744	738048	23268	0.968474
-745	739040	23300	0.968473
-746	740032	23325	0.968481
-747	741024	23354	0.968484
-748	742016	23380	0.968491
-749	743008	23415	0.968486
-750	744000	23439	0.968496
-751	744992	23470	0.968496
-752	745984	23495	0.968505
-753	746976	23525	0.968506
-754	747968	23550	0.968515
-755	748960	23582	0.968514
-756	749952	23607	0.968522
-757	750944	23636	0.968525
-758	751936	23661	0.968533
-759	752928	23690	0.968536
-760	753920	23716	0.968543
-761	754912	23747	0.968543
-762	755904	23773	0.968550
-763	756896	23803	0.968552
-764	757888	23828	0.968560
-765	758880	23858	0.968562
-766	759872	23883	0.968570
-767	760864	23925	0.968555
-768	761856	23958	0.968553
-769	762848	23990	0.968552
-770	763840	24016	0.968559
-771	764832	24048	0.968558
-772	765824	24073	0.968566
-773	766816	24105	0.968565
-774	767808	24130	0.968573
-775	768800	24176	0.968554
-776	769792	24209	0.968551
-777	770784	24246	0.968544
-778	771776	24274	0.968548
-779	772768	24304	0.968549
-780	773760	24329	0.968557
-781	774752	24365	0.968551
-782	775744	24389	0.968561
-783	776736	24424	0.968556
-784	777728	24448	0.968565
-785	778720	24483	0.968560
-786	779712	24508	0.968568
-787	780704	24542	0.968564
-788	781696	24567	0.968572
-789	782688	24598	0.968572
-790	783680	24623	0.968580
-791	784672	24655	0.968579
-792	785664	24683	0.968583
-793	786656	24715	0.968582
-794	787648	24741	0.968589
-795	788640	24771	0.968590
-796	789632	24798	0.968595
-797	790624	24835	0.968588
-798	791616	24860	0.968596
-799	792608	24894	0.968592
-800	793600	24919	0.968600
-801	794592	24953	0.968596
-802	795584	24980	0.968602
-803	796576	25015	0.968597
-804	797568	25040	0.968605
-805	798560	25074	0.968601
-806	799552	25098	0.968610
-807	800544	25133	0.968605
-808	801536	25166	0.968603
-809	802528	25207	0.968591
-810	803520	25238	0.968591
-811	804512	25279	0.968578
-812	805504	25309	0.968580
-813	806496	25346	0.968573
-814	807488	25376	0.968574
-815	808480	25416	0.968563
-816	809472	25447	0.968563
-817	810464	25479	0.968562
-818	811456	25504	0.968570
-819	812448	25542	0.968562
-820	813440	25572	0.968563
-821	814432	25620	0.968542
-822	815424	25659	0.968533
-823	816416	25717	0.968500
-824	817408	25748	0.968500
-825	818400	25777	0.968503
-826	819392	25796	0.968518
-827	820384	25841	0.968501
-828	821376	25877	0.968496
-829	822368	25908	0.968496
-830	823360	25936	0.968500
-831	824352	25982	0.968482
-832	825344	26017	0.968477
-833	826336	26049	0.968477
-834	827328	26078	0.968479
-835	828320	26128	0.968457
-836	829312	26161	0.968455
-837	830304	26196	0.968450
-838	831296	26220	0.968459
-839	832288	26266	0.968441
-840	833280	26299	0.968439
-841	834272	26354	0.968411
-842	835264	26386	0.968410
-843	836256	26430	0.968395
-844	837248	26463	0.968393
-845	838240	26500	0.968386
-846	839232	26531	0.968387
-847	840224	26575	0.968372
-848	841216	26614	0.968362
-849	842208	26643	0.968365
-850	843200	26669	0.968372
-851	844192	26705	0.968366
-852	845184	26733	0.968370
-853	846176	26780	0.968352
-854	847168	26817	0.968345
-855	848160	26852	0.968341
-856	849152	26878	0.968347
-857	850144	26912	0.968344
-858	851136	26938	0.968351
-859	852128	26972	0.968347
-860	853120	26994	0.968358
-861	854112	27039	0.968343
-862	855104	27074	0.968338
-863	856096	27111	0.968332
-864	857088	27136	0.968339
-865	858080	27172	0.968334
-866	859072	27198	0.968340
-867	860064	27233	0.968336
-868	861056	27258	0.968344
-869	862048	27305	0.968325
-870	863040	27340	0.968321
-871	864032	27374	0.968318
-872	865024	27398	0.968327
-873	866016	27438	0.968317
-874	867008	27467	0.968320
-875	868000	27499	0.968319
-876	868992	27537	0.968312
-877	869984	27573	0.968306
-878	870976	27599	0.968313
-879	871968	27631	0.968312
-880	872960	27658	0.968317
-881	873952	27689	0.968317
-882	874944	27714	0.968325
-883	875936	27758	0.968310
-884	876928	27790	0.968310
-885	877920	27827	0.968303
-886	878912	27853	0.968310
-887	879904	27887	0.968307
-888	880896	27916	0.968310
-889	881888	27963	0.968292
-890	882880	27996	0.968290
-891	883872	28026	0.968292
-892	884864	28053	0.968297
-893	885856	28097	0.968283
-894	886848	28129	0.968282
-895	887840	28175	0.968266
-896	888832	28208	0.968264
-897	889824	28244	0.968259
-898	890816	28271	0.968264
-899	891808	28307	0.968259
-900	892800	28336	0.968262
-901	893792	28384	0.968243
-902	894784	28420	0.968238
-903	895776	28454	0.968235
-904	896768	28486	0.968235
-905	897760	28530	0.968221
-906	898752	28564	0.968218
-907	899744	28607	0.968205
-908	900736	28641	0.968203
-909	901728	28674	0.968201
-910	902720	28704	0.968203
-911	903712	28748	0.968189
-912	904704	28782	0.968186
-913	905696	28816	0.968184
-914	906688	28843	0.968189
-915	907680	28876	0.968187
-916	908672	28902	0.968193
-917	909664	28950	0.968175
-918	910656	28983	0.968173
-919	911648	29018	0.968170
-920	912640	29045	0.968175
-921	913632	29080	0.968171
-922	914624	29105	0.968178
-923	915616	29141	0.968173
-924	916608	29165	0.968182
-925	917600	29201	0.968177
-926	918592	29225	0.968185
-927	919584	29260	0.968181
-928	920576	29286	0.968187
-929	921568	29319	0.968186
-930	922560	29344	0.968193
-931	923552	29378	0.968190
-932	924544	29407	0.968193
-933	925536	29438	0.968194
-934	926528	29467	0.968196
-935	927520	29497	0.968198
-936	928512	29522	0.968205
-937	929504	29554	0.968205
-938	930496	29582	0.968208
-939	931488	29614	0.968208
-940	932480	29643	0.968211
-941	933472	29675	0.968210
-942	934464	29699	0.968218
-943	935456	29720	0.968229
-944	936448	29740	0.968242
-945	937440	29773	0.968240
-946	938432	29798	0.968247
-947	939424	29819	0.968258
-948	940416	29838	0.968271
-949	941408	29859	0.968283
-950	942400	29880	0.968294
-951	943392	29910	0.968295
-952	944384	29944	0.968293
-953	945376	29986	0.968281
-954	946368	30021	0.968278
-955	947360	30063	0.968267
-956	948352	30098	0.968263
-957	949344	30128	0.968264
-958	950336	30156	0.968268
-959	951328	30185	0.968271
-960	952320	30213	0.968274
-961	953312	30254	0.968264
-962	954304	30291	0.968259
-963	955296	30326	0.968255
-964	956288	30354	0.968259
-965	957280	30388	0.968256
-966	958272	30415	0.968261
-967	959264	30459	0.968248
-968	960256	30493	0.968245
-969	961248	30527	0.968242
-970	962240	30555	0.968246
-971	963232	30589	0.968243
-972	964224	30615	0.968249
-973	965216	30650	0.968245
-974	966208	30679	0.968248
-975	967200	30712	0.968246
-976	968192	30739	0.968251
-977	969184	30781	0.968240
-978	970176	30817	0.968236
-979	971168	30848	0.968236
-980	972160	30874	0.968242
-981	973152	30917	0.968230
-982	974144	30952	0.968226
-983	975136	30996	0.968214
-984	976128	31029	0.968212
-985	977120	31062	0.968211
-986	978112	31087	0.968217
-987	979104	31120	0.968216
-988	980096	31145	0.968223
-989	981088	31175	0.968224
-990	982080	31202	0.968229
-991	983072	31236	0.968226
-992	984064	31261	0.968233
-993	985056	31292	0.968233
-994	986048	31321	0.968236
-995	987040	31351	0.968237
-996	988032	31376	0.968244
-997	989024	31421	0.968230
-998	990016	31457	0.968226
-999	991008	31493	0.968221
-1000	992000	31521	0.968225
-1001	992992	31553	0.968224
-1002	993984	31580	0.968229
-1003	994976	31612	0.968228
-1004	995968	31637	0.968235
-1005	996960	31680	0.968223
-1006	997952	31715	0.968220
-1007	998944	31746	0.968220
-1008	999936	31774	0.968224
-1009	1000928	31797	0.968232
-1010	1001920	31816	0.968245
-1011	1002912	31849	0.968243
-1012	1003904	31875	0.968249
-1013	1004896	31906	0.968249
-1014	1005888	31932	0.968255
-1015	1006880	31955	0.968263
-1016	1007872	31977	0.968273
-1017	1008864	32014	0.968267
-1018	1009856	32039	0.968274
-1019	1010848	32071	0.968273
-1020	1011840	32099	0.968277
-1021	1012832	32133	0.968274
-1022	1013824	32159	0.968280
-1023	1014816	32190	0.968280
-1024	1015808	32213	0.968288
-1025	1016800	32261	0.968272
-1026	1017792	32295	0.968270
-1027	1018784	32347	0.968249
-1028	1019776	32384	0.968244
-1029	1020768	32430	0.968230
-1030	1021760	32465	0.968226
-1031	1022752	32486	0.968237
-1032	1023744	32505	0.968249
-1033	1024736	32549	0.968237
-1034	1025728	32582	0.968235
-1035	1026720	32620	0.968229
-1036	1027712	32645	0.968235
-1037	1028704	32668	0.968244
-1038	1029696	32688	0.968255
-1039	1030688	32735	0.968240
-1040	1031680	32770	0.968236
-1041	1032672	32815	0.968223
-1042	1033664	32849	0.968221
-1043	1034656	32893	0.968209
-1044	1035648	32926	0.968207
-1045	1036640	32968	0.968197
-1046	1037632	33002	0.968195
-1047	1038624	33034	0.968194
-1048	1039616	33060	0.968200
-1049	1040608	33096	0.968196
-1050	1041600	33120	0.968203
-1051	1042592	33155	0.968199
-1052	1043584	33182	0.968204
-1053	1044576	33214	0.968203
-1054	1045568	33241	0.968208
-1055	1046560	33275	0.968205
-1056	1047552	33301	0.968211
-1057	1048544	33348	0.968196
-1058	1049536	33385	0.968191
-1059	1050528	33415	0.968192
-1060	1051520	33443	0.968196
-1061	1052512	33475	0.968195
-1062	1053504	33502	0.968199
-1063	1054496	33534	0.968199
-1064	1055488	33559	0.968205
-1065	1056480	33588	0.968208
-1066	1057472	33614	0.968213
-1067	1058464	33642	0.968216
-1068	1059456	33669	0.968220
-1069	1060448	33698	0.968223
-1070	1061440	33725	0.968227
-1071	1062432	33758	0.968226
-1072	1063424	33787	0.968228
-1073	1064416	33816	0.968230
-1074	1065408	33846	0.968232
-1075	1066400	33869	0.968240
-1076	1067392	33889	0.968251
-1077	1068384	33906	0.968264
-1078	1069376	33927	0.968274
-1079	1070368	33962	0.968271
-1080	1071360	33988	0.968276
-1081	1072352	34011	0.968284
-1082	1073344	34031	0.968294
-1083	1074336	34065	0.968292
-1084	1075328	34087	0.968301
-1085	1076320	34136	0.968285
-1086	1077312	34171	0.968281
-1087	1078304	34217	0.968268
-1088	1079296	34252	0.968264
-1089	1080288	34301	0.968248
-1090	1081280	34333	0.968248
-1091	1082272	34384	0.968230
-1092	1083264	34419	0.968227
-1093	1084256	34467	0.968211
-1094	1085248	34501	0.968209
-1095	1086240	34542	0.968200
-1096	1087232	34572	0.968202
-1097	1088224	34608	0.968198
-1098	1089216	34636	0.968201
-1099	1090208	34671	0.968198
-1100	1091200	34699	0.968201
-1101	1092192	34747	0.968186
-1102	1093184	34777	0.968187
-1103	1094176	34810	0.968186
-1104	1095168	34834	0.968193
-1105	1096160	34856	0.968202
-1106	1097152	34873	0.968215
-1107	1098144	34917	0.968204
-1108	1099136	34953	0.968200
-1109	1100128	34985	0.968199
-1110	1101120	35014	0.968201
-1111	1102112	35050	0.968197
-1112	1103104	35078	0.968201
-1113	1104096	35107	0.968203
-1114	1105088	35135	0.968206
-1115	1106080	35169	0.968204
-1116	1107072	35196	0.968208
-1117	1108064	35217	0.968218
-1118	1109056	35234	0.968231
-1119	1110048	35265	0.968231
-1120	1111040	35290	0.968237
-1121	1112032	35326	0.968233
-1122	1113024	35352	0.968238
-1123	1114016	35384	0.968237
-1124	1115008	35413	0.968240
-1125	1116000	35445	0.968239
-1126	1116992	35473	0.968242
-1127	1117984	35505	0.968242
-1128	1118976	35531	0.968247
-1129	1119968	35564	0.968246
-1130	1120960	35592	0.968249
-1131	1121952	35625	0.968247
-1132	1122944	35650	0.968253
-1133	1123936	35681	0.968254
-1134	1124928	35709	0.968257
-1135	1125920	35743	0.968254
-1136	1126912	35771	0.968258
-1137	1127904	35801	0.968259
-1138	1128896	35830	0.968261
-1139	1129888	35859	0.968263
-1140	1130880	35887	0.968266
-1141	1131872	35931	0.968255
-1142	1132864	35966	0.968252
-1143	1133856	35986	0.968262
-1144	1134848	36007	0.968272
-1145	1135840	36039	0.968271
-1146	1136832	36066	0.968275
-1147	1137824	36115	0.968260
-1148	1138816	36148	0.968258
-1149	1139808	36182	0.968256
-1150	1140800	36205	0.968263
-1151	1141792	36253	0.968249
-1152	1142784	36287	0.968247
-1153	1143776	36333	0.968234
-1154	1144768	36370	0.968229
-1155	1145760	36405	0.968226
-1156	1146752	36430	0.968232
-1157	1147744	36461	0.968232
-1158	1148736	36487	0.968237
-1159	1149728	36520	0.968236
-1160	1150720	36547	0.968240
-1161	1151712	36584	0.968235
-1162	1152704	36609	0.968241
-1163	1153696	36640	0.968241
-1164	1154688	36668	0.968244
-1165	1155680	36693	0.968250
-1166	1156672	36712	0.968261
-1167	1157664	36760	0.968246
-1168	1158656	36792	0.968246
-1169	1159648	36829	0.968241
-1170	1160640	36855	0.968246
-1171	1161632	36889	0.968244
-1172	1162624	36915	0.968249
-1173	1163616	36957	0.968240
-1174	1164608	36986	0.968242
-1175	1165600	37030	0.968231
-1176	1166592	37066	0.968227
-1177	1167584	37097	0.968228
-1178	1168576	37125	0.968231
-1179	1169568	37157	0.968230
-1180	1170560	37183	0.968235
-1181	1171552	37210	0.968239
-1182	1172544	37238	0.968242
-1183	1173536	37262	0.968248
-1184	1174528	37284	0.968256
-1185	1175520	37314	0.968257
-1186	1176512	37338	0.968264
-1187	1177504	37370	0.968263
-1188	1178496	37396	0.968268
-1189	1179488	37426	0.968269
-1190	1180480	37449	0.968276
-1191	1181472	37480	0.968277
-1192	1182464	37507	0.968281
-1193	1183456	37537	0.968282
-1194	1184448	37562	0.968287
-1195	1185440	37585	0.968294
-1196	1186432	37605	0.968304
-1197	1187424	37651	0.968292
-1198	1188416	37684	0.968291
-1199	1189408	37726	0.968282
-1200	1190400	37757	0.968282
-1201	1191392	37787	0.968283
-1202	1192384	37815	0.968286
-1203	1193376	37865	0.968271
-1204	1194368	37897	0.968270
-1205	1195360	37931	0.968268
-1206	1196352	37956	0.968274
-1207	1197344	38001	0.968262
-1208	1198336	38034	0.968261
-1209	1199328	38075	0.968253
-1210	1200320	38102	0.968257
-1211	1201312	38150	0.968243
-1212	1202304	38182	0.968243
-1213	1203296	38207	0.968248
-1214	1204288	38225	0.968259
-1215	1205280	38260	0.968256
-1216	1206272	38285	0.968262
-1217	1207264	38336	0.968246
-1218	1208256	38369	0.968244
-1219	1209248	38417	0.968231
-1220	1210240	38450	0.968229
-1221	1211232	38486	0.968226
-1222	1212224	38512	0.968230
-1223	1213216	38560	0.968217
-1224	1214208	38596	0.968213
-1225	1215200	38615	0.968223
-1226	1216192	38635	0.968233
-1227	1217184	38675	0.968226
-1228	1218176	38706	0.968226
-1229	1219168	38741	0.968223
-1230	1220160	38766	0.968229
-1231	1221152	38798	0.968228
-1232	1222144	38825	0.968232
-1233	1223136	38858	0.968231
-1234	1224128	38885	0.968235
-1235	1225120	38914	0.968237
-1236	1226112	38939	0.968242
-1237	1227104	38972	0.968241
-1238	1228096	39001	0.968243
-1239	1229088	39035	0.968241
-1240	1230080	39063	0.968244
-1241	1231072	39097	0.968242
-1242	1232064	39123	0.968246
-1243	1233056	39158	0.968243
-1244	1234048	39182	0.968249
-1245	1235040	39216	0.968247
-1246	1236032	39245	0.968249
-1247	1237024	39275	0.968250
-1248	1238016	39304	0.968252
-1249	1239008	39351	0.968240
-1250	1240000	39386	0.968237
-1251	1240992	39423	0.968233
-1252	1241984	39449	0.968237
-1253	1242976	39496	0.968225
-1254	1243968	39532	0.968221
-1255	1244960	39578	0.968209
-1256	1245952	39612	0.968207
-1257	1246944	39646	0.968205
-1258	1247936	39671	0.968211
-1259	1248928	39697	0.968215
-1260	1249920	39717	0.968224
-1261	1250912	39753	0.968221
-1262	1251904	39780	0.968224
-1263	1252896	39825	0.968214
-1264	1253888	39860	0.968211
-1265	1254880	39906	0.968199
-1266	1255872	39940	0.968197
-1267	1256864	39971	0.968198
-1268	1257856	39998	0.968201
-1269	1258848	40047	0.968188
-1270	1259840	40081	0.968186
-1271	1260832	40124	0.968177
-1272	1261824	40158	0.968175
-1273	1262816	40180	0.968182
-1274	1263808	40200	0.968191
-1275	1264800	40232	0.968191
-1276	1265792	40257	0.968196
-1277	1266784	40293	0.968193
-1278	1267776	40319	0.968197
-1279	1268768	40366	0.968185
-1280	1269760	40398	0.968185
-1281	1270752	40418	0.968194
-1282	1271744	40439	0.968202
-1283	1272736	40459	0.968211
-1284	1273728	40476	0.968222
-1285	1274720	40525	0.968209
-1286	1275712	40556	0.968209
-1287	1276704	40603	0.968197
-1288	1277696	40635	0.968197
-1289	1278688	40672	0.968192
-1290	1279680	40699	0.968196
-1291	1280672	40747	0.968183
-1292	1281664	40780	0.968182
-1293	1282656	40800	0.968191
-1294	1283648	40818	0.968202
-1295	1284640	40851	0.968200
-1296	1285632	40880	0.968202
-1297	1286624	40909	0.968204
-1298	1287616	40936	0.968208
-1299	1288608	40977	0.968201
-1300	1289600	41011	0.968199
-1301	1290592	41037	0.968203
-1302	1291584	41063	0.968207
-1303	1292576	41084	0.968215
-1304	1293568	41105	0.968224
-1305	1294560	41150	0.968213
-1306	1295552	41184	0.968211
-1307	1296544	41230	0.968200
-1308	1297536	41262	0.968200
-1309	1298528	41293	0.968200
-1310	1299520	41318	0.968205
-1311	1300512	41352	0.968203
-1312	1301504	41379	0.968207
-1313	1302496	41411	0.968206
-1314	1303488	41437	0.968211
-1315	1304480	41479	0.968203
-1316	1305472	41515	0.968199
-1317	1306464	41550	0.968197
-1318	1307456	41573	0.968203
-1319	1308448	41606	0.968202
-1320	1309440	41629	0.968209
-1321	1310432	41665	0.968205
-1322	1311424	41691	0.968209
-1323	1312416	41729	0.968204
-1324	1313408	41754	0.968209
-1325	1314400	41803	0.968196
-1326	1315392	41835	0.968196
-1327	1316384	41868	0.968195
-1328	1317376	41892	0.968200
-1329	1318368	41941	0.968187
-1330	1319360	41973	0.968187
-1331	1320352	42008	0.968184
-1332	1321344	42031	0.968191
-1333	1322336	42068	0.968187
-1334	1323328	42094	0.968191
-1335	1324320	42141	0.968179
-1336	1325312	42176	0.968177
-1337	1326304	42200	0.968182
-1338	1327296	42217	0.968193
-1339	1328288	42268	0.968179
-1340	1329280	42303	0.968176
-1341	1330272	42335	0.968176
-1342	1331264	42361	0.968180
-1343	1332256	42382	0.968188
-1344	1333248	42402	0.968196
-1345	1334240	42447	0.968186
-1346	1335232	42483	0.968183
-1347	1336224	42519	0.968180
-1348	1337216	42548	0.968182
-1349	1338208	42595	0.968170
-1350	1339200	42627	0.968170
-1351	1340192	42671	0.968161
-1352	1341184	42707	0.968157
-1353	1342176	42742	0.968155
-1354	1343168	42769	0.968158
-1355	1344160	42803	0.968156
-1356	1345152	42831	0.968159
-1357	1346144	42862	0.968159
-1358	1347136	42889	0.968163
-1359	1348128	42925	0.968160
-1360	1349120	42950	0.968164
-1361	1350112	42981	0.968165
-1362	1351104	43007	0.968169
-1363	1352096	43036	0.968171
-1364	1353088	43061	0.968176
-1365	1354080	43092	0.968176
-1366	1355072	43120	0.968179
-1367	1356064	43151	0.968179
-1368	1357056	43179	0.968182
-1369	1358048	43212	0.968181
-1370	1359040	43239	0.968184
-1371	1360032	43272	0.968183
-1372	1361024	43297	0.968188
-1373	1362016	43334	0.968184
-1374	1363008	43360	0.968188
-1375	1364000	43382	0.968195
-1376	1364992	43399	0.968206
-1377	1365984	43432	0.968205
-1378	1366976	43460	0.968207
-1379	1367968	43504	0.968198
-1380	1368960	43539	0.968196
-1381	1369952	43584	0.968186
-1382	1370944	43616	0.968185
-1383	1371936	43647	0.968186
-1384	1372928	43673	0.968190
-1385	1373920	43704	0.968190
-1386	1374912	43732	0.968193
-1387	1375904	43778	0.968182
-1388	1376896	43812	0.968181
-1389	1377888	43859	0.968169
-1390	1378880	43894	0.968167
-1391	1379872	43915	0.968175
-1392	1380864	43932	0.968185
-1393	1381856	43964	0.968185
-1394	1382848	43991	0.968188
-1395	1383840	44021	0.968189
-1396	1384832	44050	0.968191
-1397	1385824	44079	0.968193
-1398	1386816	44104	0.968198
-1399	1387808	44140	0.968194
-1400	1388800	44167	0.968198
-1401	1389792	44200	0.968197
-1402	1390784	44226	0.968201
-1403	1391776	44260	0.968199
-1404	1392768	44285	0.968204
-1405	1393760	44318	0.968203
-1406	1394752	44346	0.968205
-1407	1395744	44376	0.968206
-1408	1396736	44403	0.968209
-1409	1397728	44424	0.968217
-1410	1398720	44447	0.968223
-1411	1399712	44492	0.968213
-1412	1400704	44526	0.968212
-1413	1401696	44549	0.968218
-1414	1402688	44569	0.968226
-1415	1403680	44622	0.968211
-1416	1404672	44656	0.968209
-1417	1405664	44676	0.968217
-1418	1406656	44693	0.968227
-1419	1407648	44730	0.968224
-1420	1408640	44755	0.968228
-1421	1409632	44805	0.968215
-1422	1410624	44837	0.968215
-1423	1411616	44881	0.968206
-1424	1412608	44915	0.968204
-1425	1413600	44937	0.968211
-1426	1414592	44956	0.968220
-1427	1415584	44991	0.968217
-1428	1416576	45016	0.968222
-1429	1417568	45057	0.968215
-1430	1418560	45094	0.968211
-1431	1419552	45120	0.968215
-1432	1420544	45138	0.968225
-1433	1421536	45160	0.968232
-1434	1422528	45178	0.968241
-1435	1423520	45200	0.968248
-1436	1424512	45217	0.968258
-1437	1425504	45251	0.968256
-1438	1426496	45275	0.968261
-1439	1427488	45300	0.968266
-1440	1428480	45318	0.968275
-1441	1429472	45341	0.968281
-1442	1430464	45358	0.968291
-1443	1431456	45380	0.968298
-1444	1432448	45398	0.968307
-1445	1433440	45423	0.968312
-1446	1434432	45440	0.968322
-1447	1435424	45466	0.968326
-1448	1436416	45483	0.968336
-1449	1437408	45508	0.968340
-1450	1438400	45525	0.968350
-1451	1439392	45549	0.968355
-1452	1440384	45565	0.968366
-1453	1441376	45591	0.968370
-1454	1442368	45608	0.968380
-1455	1443360	45630	0.968386
-1456	1444352	45648	0.968396
-1457	1445344	45671	0.968401
-1458	1446336	45688	0.968411
-1459	1447328	45734	0.968401
-1460	1448320	45767	0.968400
-1461	1449312	45791	0.968405
-1462	1450304	45810	0.968414
-1463	1451296	45830	0.968421
-1464	1452288	45849	0.968430
-1465	1453280	45871	0.968436
-1466	1454272	45889	0.968445
-1467	1455264	45911	0.968452
-1468	1456256	45927	0.968462
-1469	1457248	45949	0.968469
-1470	1458240	45966	0.968478
-1471	1459232	45993	0.968481
-1472	1460224	46010	0.968491
-1473	1461216	46057	0.968480
-1474	1462208	46090	0.968479
-1475	1463200	46117	0.968482
-1476	1464192	46136	0.968490
-1477	1465184	46161	0.968495
-1478	1466176	46180	0.968503
-1479	1467168	46202	0.968509
-1480	1468160	46219	0.968519
-1481	1469152	46241	0.968525
-1482	1470144	46258	0.968535
-1483	1471136	46279	0.968542
-1484	1472128	46295	0.968552
-1485	1473120	46321	0.968556
-1486	1474112	46338	0.968565
-1487	1475104	46383	0.968556
-1488	1476096	46415	0.968556
-1489	1477088	46439	0.968560
-1490	1478080	46458	0.968569
-1491	1479072	46481	0.968574
-1492	1480064	46497	0.968584
-1493	1481056	46520	0.968590
-1494	1482048	46537	0.968600
-1495	1483040	46584	0.968589
-1496	1484032	46618	0.968587
-1497	1485024	46645	0.968590
-1498	1486016	46663	0.968599
-1499	1487008	46688	0.968603
-1500	1488000	46705	0.968612
-1501	1488992	46730	0.968616
-1502	1489984	46747	0.968626
-1503	1490976	46770	0.968631
-1504	1491968	46790	0.968639
-1505	1492960	46815	0.968643
-1506	1493952	46832	0.968652
-1507	1494944	46855	0.968658
-1508	1495936	46875	0.968665
-1509	1496928	46900	0.968669
-1510	1497920	46917	0.968679
-1511	1498912	46937	0.968686
-1512	1499904	46957	0.968693
-1513	1500896	47005	0.968682
-1514	1501888	47040	0.968679
-1515	1502880	47086	0.968669
-1516	1503872	47118	0.968669
-1517	1504864	47139	0.968676
-1518	1505856	47157	0.968684
-1519	1506848	47202	0.968675
-1520	1507840	47234	0.968674
-1521	1508832	47283	0.968663
-1522	1509824	47317	0.968661
-1523	1510816	47363	0.968651
-1524	1511808	47395	0.968650
-1525	1512800	47419	0.968655
-1526	1513792	47441	0.968661
-1527	1514784	47461	0.968668
-1528	1515776	47479	0.968677
-1529	1516768	47513	0.968675
-1530	1517760	47537	0.968680
-1531	1518752	47560	0.968685
-1532	1519744	47581	0.968691
-1533	1520736	47621	0.968686
-1534	1521728	47653	0.968685
-1535	1522720	47679	0.968688
-1536	1523712	47697	0.968697
-1537	1524704	47723	0.968700
-1538	1525696	47741	0.968709
-1539	1526688	47766	0.968713
-1540	1527680	47783	0.968722
-1541	1528672	47809	0.968725
-1542	1529664	47826	0.968734
-1543	1530656	47848	0.968740
-1544	1531648	47865	0.968749
-1545	1532640	47908	0.968742
-1546	1533632	47943	0.968739
-1547	1534624	47964	0.968745
-1548	1535616	47982	0.968754
-1549	1536608	48003	0.968760
-1550	1537600	48020	0.968770
-1551	1538592	48070	0.968757
-1552	1539584	48102	0.968756
-1553	1540576	48141	0.968751
-1554	1541568	48167	0.968755
-1555	1542560	48197	0.968755
-1556	1543552	48222	0.968759
-1557	1544544	48246	0.968764
-1558	1545536	48265	0.968771
-1559	1546528	48290	0.968775
-1560	1547520	48306	0.968785
-1561	1548512	48341	0.968782
-1562	1549504	48367	0.968785
-1563	1550496	48401	0.968784
-1564	1551488	48427	0.968787
-1565	1552480	48450	0.968792
-1566	1553472	48468	0.968800
-1567	1554464	48501	0.968799
-1568	1555456	48526	0.968803
-1569	1556448	48570	0.968794
-1570	1557440	48603	0.968793
-1571	1558432	48638	0.968790
-1572	1559424	48664	0.968794
-1573	1560416	48685	0.968800
-1574	1561408	48704	0.968808
-1575	1562400	48727	0.968813
-1576	1563392	48749	0.968818
-1577	1564384	48774	0.968822
-1578	1565376	48790	0.968832
-1579	1566368	48816	0.968835
-1580	1567360	48833	0.968844
-1581	1568352	48883	0.968832
-1582	1569344	48916	0.968830
-1583	1570336	48942	0.968833
-1584	1571328	48959	0.968842
-1585	1572320	48998	0.968837
-1586	1573312	49025	0.968840
-1587	1574304	49059	0.968838
-1588	1575296	49084	0.968841
-1589	1576288	49107	0.968846
-1590	1577280	49125	0.968855
-1591	1578272	49149	0.968859
-1592	1579264	49167	0.968867
-1593	1580256	49189	0.968873
-1594	1581248	49206	0.968882
-1595	1582240	49240	0.968880
-1596	1583232	49269	0.968881
-1597	1584224	49290	0.968887
-1598	1585216	49310	0.968894
-1599	1586208	49346	0.968891
-1600	1587200	49372	0.968894
-1601	1588192	49396	0.968898
-1602	1589184	49416	0.968905
-1603	1590176	49460	0.968897
-1604	1591168	49493	0.968895
-1605	1592160	49527	0.968893
-1606	1593152	49550	0.968898
-1607	1594144	49587	0.968894
-1608	1595136	49612	0.968898
-1609	1596128	49637	0.968902
-1610	1597120	49655	0.968910
-1611	1598112	49688	0.968908
-1612	1599104	49714	0.968911
-1613	1600096	49736	0.968917
-1614	1601088	49753	0.968926
-1615	1602080	49784	0.968925
-1616	1603072	49809	0.968929
-1617	1604064	49835	0.968932
-1618	1605056	49853	0.968940
-1619	1606048	49886	0.968939
-1620	1607040	49911	0.968942
-1621	1608032	49933	0.968948
-1622	1609024	49951	0.968956
-1623	1610016	49972	0.968962
-1624	1611008	49990	0.968970
-1625	1612000	50012	0.968975
-1626	1612992	50029	0.968984
-1627	1613984	50050	0.968990
-1628	1614976	50066	0.968999
-1629	1615968	50088	0.969004
-1630	1616960	50105	0.969013
-1631	1617952	50126	0.969019
-1632	1618944	50146	0.969025
-1633	1619936	50170	0.969030
-1634	1620928	50186	0.969039
-1635	1621920	50234	0.969028
-1636	1622912	50267	0.969027
-1637	1623904	50291	0.969031
-1638	1624896	50309	0.969039
-1639	1625888	50329	0.969045
-1640	1626880	50348	0.969052
-1641	1627872	50372	0.969057
-1642	1628864	50388	0.969066
-1643	1629856	50423	0.969063
-1644	1630848	50453	0.969063
-1645	1631840	50480	0.969066
-1646	1632832	50502	0.969071
-1647	1633824	50542	0.969065
-1648	1634816	50572	0.969066
-1649	1635808	50610	0.969061
-1650	1636800	50642	0.969060
-1651	1637792	50668	0.969063
-1652	1638784	50690	0.969069
-1653	1639776	50719	0.969070
-1654	1640768	50743	0.969074
-1655	1641760	50794	0.969061
-1656	1642752	50826	0.969060
-1657	1643744	50852	0.969063
-1658	1644736	50870	0.969071
-1659	1645728	50892	0.969076
-1660	1646720	50913	0.969082
-1661	1647712	50935	0.969087
-1662	1648704	50952	0.969096
-1663	1649696	50990	0.969091
-1664	1650688	51022	0.969090
-1665	1651680	51046	0.969094
-1666	1652672	51067	0.969100
-1667	1653664	51089	0.969106
-1668	1654656	51105	0.969114
-1669	1655648	51126	0.969120
-1670	1656640	51143	0.969128
-1671	1657632	51180	0.969125
-1672	1658624	51205	0.969128
-1673	1659616	51232	0.969130
-1674	1660608	51250	0.969138
-1675	1661600	51294	0.969130
-1676	1662592	51328	0.969128
-1677	1663584	51358	0.969128
-1678	1664576	51386	0.969130
-1679	1665568	51410	0.969134
-1680	1666560	51428	0.969141
-1681	1667552	51449	0.969147
-1682	1668544	51465	0.969156
-1683	1669536	51511	0.969147
-1684	1670528	51545	0.969144
-1685	1671520	51578	0.969143
-1686	1672512	51597	0.969150
-1687	1673504	51622	0.969153
-1688	1674496	51639	0.969161
-1689	1675488	51674	0.969159
-1690	1676480	51700	0.969162
-1691	1677472	51733	0.969160
-1692	1678464	51757	0.969164
-1693	1679456	51775	0.969172
-1694	1680448	51792	0.969180
-1695	1681440	51840	0.969169
-1696	1682432	51877	0.969165
-1697	1683424	51897	0.969172
-1698	1684416	51918	0.969177
-1699	1685408	51963	0.969169
-1700	1686400	51997	0.969167
-1701	1687392	52033	0.969164
-1702	1688384	52056	0.969168
-1703	1689376	52094	0.969164
-1704	1690368	52120	0.969166
-1705	1691360	52153	0.969165
-1706	1692352	52177	0.969169
-1707	1693344	52213	0.969166
-1708	1694336	52243	0.969166
-1709	1695328	52275	0.969165
-1710	1696320	52302	0.969167
-1711	1697312	52325	0.969172
-1712	1698304	52347	0.969177
-1713	1699296	52378	0.969177
-1714	1700288	52404	0.969179
-1715	1701280	52440	0.969176
-1716	1702272	52470	0.969176
-1717	1703264	52505	0.969174
-1718	1704256	52531	0.969177
-1719	1705248	52578	0.969167
-1720	1706240	52614	0.969164
-1721	1707232	52672	0.969148
-1722	1708224	52704	0.969147
-1723	1709216	52748	0.969139
-1724	1710208	52780	0.969138
-1725	1711200	52823	0.969131
-1726	1712192	52856	0.969130
-1727	1713184	52891	0.969127
-1728	1714176	52917	0.969130
-1729	1715168	52953	0.969127
-1730	1716160	52980	0.969129
-1731	1717152	53022	0.969122
-1732	1718144	53054	0.969121
-1733	1719136	53080	0.969124
-1734	1720128	53098	0.969131
-1735	1721120	53126	0.969133
-1736	1722112	53151	0.969136
-1737	1723104	53185	0.969134
-1738	1724096	53209	0.969138
-1739	1725088	53255	0.969129
-1740	1726080	53289	0.969127
-1741	1727072	53337	0.969117
-1742	1728064	53369	0.969116
-1743	1729056	53419	0.969105
-1744	1730048	53451	0.969104
-1745	1731040	53477	0.969107
-1746	1732032	53501	0.969111
-1747	1733024	53548	0.969101
-1748	1734016	53581	0.969100
-1749	1735008	53615	0.969098
-1750	1736000	53639	0.969102
-1751	1736992	53669	0.969102
-1752	1737984	53694	0.969106
-1753	1738976	53740	0.969097
-1754	1739968	53773	0.969095
-1755	1740960	53809	0.969092
-1756	1741952	53835	0.969095
-1757	1742944	53884	0.969084
-1758	1743936	53916	0.969084
-1759	1744928	53962	0.969075
-1760	1745920	53994	0.969074
-1761	1746912	54021	0.969076
-1762	1747904	54047	0.969079
-1763	1748896	54090	0.969072
-1764	1749888	54122	0.969071
-1765	1750880	54156	0.969069
-1766	1751872	54185	0.969070
-1767	1752864	54232	0.969061
-1768	1753856	54265	0.969060
-1769	1754848	54302	0.969056
-1770	1755840	54327	0.969059
-1771	1756832	54353	0.969062
-1772	1757824	54371	0.969069
-1773	1758816	54399	0.969071
-1774	1759808	54423	0.969074
-1775	1760800	54456	0.969073
-1776	1761792	54481	0.969076
-1777	1762784	54515	0.969074
-1778	1763776	54539	0.969078
-1779	1764768	54573	0.969076
-1780	1765760	54599	0.969079
-1781	1766752	54645	0.969070
-1782	1767744	54676	0.969070
-1783	1768736	54711	0.969068
-1784	1769728	54735	0.969072
-1785	1770720	54773	0.969067
-1786	1771712	54799	0.969070
-1787	1772704	54836	0.969066
-1788	1773696	54862	0.969069
-1789	1774688	54903	0.969063
-1790	1775680	54928	0.969066
-1791	1776672	54976	0.969057
-1792	1777664	55009	0.969055
-1793	1778656	55044	0.969053
-1794	1779648	55068	0.969057
-1795	1780640	55113	0.969049
-1796	1781632	55146	0.969047
-1797	1782624	55179	0.969046
-1798	1783616	55202	0.969051
-1799	1784608	55236	0.969049
-1800	1785600	55262	0.969051
-1801	1786592	55308	0.969043
-1802	1787584	55340	0.969042
-1803	1788576	55377	0.969038
-1804	1789568	55402	0.969042
-1805	1790560	55432	0.969042
-1806	1791552	55457	0.969045
-1807	1792544	55476	0.969052
-1808	1793536	55493	0.969059
-1809	1794528	55541	0.969050
-1810	1795520	55572	0.969050
-1811	1796512	55620	0.969040
-1812	1797504	55654	0.969038
-1813	1798496	55686	0.969037
-1814	1799488	55710	0.969041
-1815	1800480	55742	0.969040
-1816	1801472	55767	0.969044
-1817	1802464	55818	0.969032
-1818	1803456	55852	0.969031
-1819	1804448	55894	0.969024
-1820	1805440	55925	0.969024
-1821	1806432	55973	0.969015
-1822	1807424	56004	0.969014
-1823	1808416	56051	0.969005
-1824	1809408	56085	0.969004
-1825	1810400	56130	0.968996
-1826	1811392	56162	0.968995
-1827	1812384	56208	0.968987
-1828	1813376	56241	0.968985
-1829	1814368	56278	0.968982
-1830	1815360	56304	0.968985
-1831	1816352	56353	0.968975
-1832	1817344	56385	0.968974
-1833	1818336	56415	0.968974
-1834	1819328	56441	0.968977
-1835	1820320	56477	0.968974
-1836	1821312	56500	0.968978
-1837	1822304	56534	0.968977
-1838	1823296	56559	0.968980
-1839	1824288	56588	0.968981
-1840	1825280	56610	0.968986
-1841	1826272	56640	0.968986
-1842	1827264	56664	0.968990
-1843	1828256	56697	0.968988
-1844	1829248	56719	0.968993
-1845	1830240	56747	0.968995
-1846	1831232	56771	0.968998
-1847	1832224	56803	0.968998
-1848	1833216	56826	0.969002
-1849	1834208	56857	0.969002
-1850	1835200	56879	0.969007
-1851	1836192	56909	0.969007
-1852	1837184	56933	0.969011
-1853	1838176	56956	0.969015
-1854	1839168	56973	0.969022
-1855	1840160	57022	0.969012
-1856	1841152	57056	0.969011
-1857	1842144	57103	0.969002
-1858	1843136	57135	0.969001
-1859	1844128	57172	0.968998
-1860	1845120	57198	0.969000
-1861	1846112	57245	0.968992
-1862	1847104	57277	0.968991
-1863	1848096	57302	0.968994
-1864	1849088	57325	0.968998
-1865	1850080	57361	0.968995
-1866	1851072	57389	0.968997
-1867	1852064	57424	0.968995
-1868	1853056	57448	0.968998
-1869	1854048	57486	0.968994
-1870	1855040	57512	0.968997
-1871	1856032	57561	0.968987
-1872	1857024	57597	0.968984
-1873	1858016	57631	0.968983
-1874	1859008	57661	0.968983
-1875	1860000	57691	0.968983
-1876	1860992	57720	0.968984
-1877	1861984	57738	0.968991
-1878	1862976	57758	0.968997
-1879	1863968	57795	0.968994
-1880	1864960	57819	0.968997
-1881	1865952	57865	0.968989
-1882	1866944	57900	0.968987
-1883	1867936	57944	0.968980
-1884	1868928	57978	0.968978
-1885	1869920	58016	0.968974
-1886	1870912	58042	0.968977
-1887	1871904	58075	0.968975
-1888	1872896	58100	0.968979
-1889	1873888	58134	0.968977
-1890	1874880	58160	0.968979
-1891	1875872	58206	0.968971
-1892	1876864	58242	0.968968
-1893	1877856	58286	0.968961
-1894	1878848	58320	0.968960
-1895	1879840	58353	0.968959
-1896	1880832	58381	0.968960
-1897	1881824	58428	0.968951
-1898	1882816	58463	0.968949
-1899	1883808	58498	0.968947
-1900	1884800	58522	0.968951
-1901	1885792	58566	0.968944
-1902	1886784	58600	0.968942
-1903	1887776	58644	0.968935
-1904	1888768	58677	0.968934
-1905	1889760	58714	0.968930
-1906	1890752	58739	0.968934
-1907	1891744	58774	0.968931
-1908	1892736	58799	0.968934
-1909	1893728	58847	0.968925
-1910	1894720	58882	0.968923
-1911	1895712	58928	0.968915
-1912	1896704	58963	0.968913
-1913	1897696	59008	0.968905
-1914	1898688	59043	0.968903
-1915	1899680	59082	0.968899
-1916	1900672	59108	0.968902
-1917	1901664	59132	0.968905
-1918	1902656	59150	0.968912
-1919	1903648	59172	0.968917
-1920	1904640	59191	0.968923
-1921	1905632	59220	0.968924
-1922	1906624	59247	0.968926
-1923	1907616	59298	0.968915
-1924	1908608	59333	0.968913
-1925	1909600	59366	0.968912
-1926	1910592	59394	0.968913
-1927	1911584	59427	0.968912
-1928	1912576	59451	0.968916
-1929	1913568	59471	0.968921
-1930	1914560	59491	0.968927
-1931	1915552	59524	0.968926
-1932	1916544	59550	0.968928
-1933	1917536	59578	0.968930
-1934	1918528	59604	0.968932
-1935	1919520	59623	0.968939
-1936	1920512	59641	0.968945
-1937	1921504	59672	0.968945
-1938	1922496	59699	0.968947
-1939	1923488	59730	0.968947
-1940	1924480	59757	0.968949
-1941	1925472	59801	0.968942
-1942	1926464	59836	0.968940
-1943	1927456	59882	0.968932
-1944	1928448	59917	0.968930
-1945	1929440	59948	0.968930
-1946	1930432	59977	0.968931
-1947	1931424	60023	0.968923
-1948	1932416	60056	0.968922
-1949	1933408	60084	0.968923
-1950	1934400	60114	0.968924
-1951	1935392	60145	0.968924
-1952	1936384	60174	0.968925
-1953	1937376	60204	0.968925
-1954	1938368	60232	0.968926
-1955	1939360	60261	0.968927
-1956	1940352	60290	0.968928
-1957	1941344	60325	0.968926
-1958	1942336	60349	0.968930
-1959	1943328	60378	0.968931
-1960	1944320	60403	0.968934
-1961	1945312	60424	0.968939
-1962	1946304	60439	0.968947
-1963	1947296	60485	0.968939
-1964	1948288	60519	0.968937
-1965	1949280	60551	0.968937
-1966	1950272	60580	0.968938
-1967	1951264	60601	0.968943
-1968	1952256	60620	0.968949
-1969	1953248	60649	0.968950
-1970	1954240	60677	0.968951
-1971	1955232	60714	0.968948
-1972	1956224	60739	0.968951
-1973	1957216	60782	0.968945
-1974	1958208	60813	0.968945
-1975	1959200	60860	0.968936
-1976	1960192	60892	0.968936
-1977	1961184	60928	0.968933
-1978	1962176	60954	0.968936
-1979	1963168	60988	0.968934
-1980	1964160	61012	0.968937
-1981	1965152	61057	0.968930
-1982	1966144	61090	0.968929
-1983	1967136	61124	0.968927
-1984	1968128	61149	0.968930
-1985	1969120	61177	0.968932
-1986	1970112	61203	0.968934
-1987	1971104	61228	0.968937
-1988	1972096	61251	0.968941
-1989	1973088	61297	0.968933
-1990	1974080	61333	0.968931
-1991	1975072	61364	0.968931
-1992	1976064	61390	0.968933
-1993	1977056	61426	0.968931
-1994	1978048	61451	0.968934
-1995	1979040	61480	0.968934
-1996	1980032	61506	0.968937
-1997	1981024	61552	0.968929
-1998	1982016	61589	0.968926
-1999	1983008	61637	0.968917
-2000	1984000	61672	0.968915
-2001	1984992	61708	0.968913
-2002	1985984	61732	0.968916
-2003	1986976	61772	0.968912
-2004	1987968	61803	0.968911
-2005	1988960	61837	0.968910
-2006	1989952	61861	0.968913
-2007	1990944	61909	0.968905
-2008	1991936	61941	0.968904
-2009	1992928	61989	0.968896
-2010	1993920	62021	0.968895
-2011	1994912	62068	0.968887
-2012	1995904	62102	0.968885
-2013	1996896	62135	0.968884
-2014	1997888	62162	0.968886
-2015	1998880	62190	0.968888
-2016	1999872	62214	0.968891
-2017	2000864	62243	0.968892
-2018	2001856	62268	0.968895
-2019	2002848	62305	0.968892
-2020	2003840	62338	0.968891
-2021	2004832	62368	0.968891
-2022	2005824	62396	0.968893
-2023	2006816	62430	0.968891
-2024	2007808	62456	0.968893
-2025	2008800	62488	0.968893
-2026	2009792	62512	0.968896
-2027	2010784	62542	0.968897
-2028	2011776	62568	0.968899
-2029	2012768	62606	0.968896
-2030	2013760	62634	0.968897
-2031	2014752	62665	0.968897
-2032	2015744	62691	0.968899
-2033	2016736	62722	0.968899
-2034	2017728	62747	0.968902
-2035	2018720	62771	0.968906
-2036	2019712	62790	0.968911
-2037	2020704	62820	0.968912
-2038	2021696	62849	0.968913
-2039	2022688	62872	0.968917
-2040	2023680	62892	0.968922
-2041	2024672	62925	0.968921
-2042	2025664	62950	0.968924
-2043	2026656	62979	0.968925
-2044	2027648	63004	0.968928
-2045	2028640	63051	0.968920
-2046	2029632	63086	0.968918
-2047	2030624	63107	0.968922
-2048	2031616	63125	0.968929
-2049	2032608	63148	0.968933
-2050	2033600	63169	0.968937
-2051	2034592	63203	0.968936
-2052	2035584	63231	0.968937
-2053	2036576	63277	0.968930
-2054	2037568	63312	0.968928
-2055	2038560	63354	0.968922
-2056	2039552	63387	0.968921
-2057	2040544	63429	0.968916
-2058	2041536	63452	0.968919
-2059	2042528	63490	0.968916
-2060	2043520	63514	0.968919
-2061	2044512	63552	0.968916
-2062	2045504	63575	0.968920
-2063	2046496	63609	0.968918
-2064	2047488	63632	0.968922
-2065	2048480	63653	0.968927
-2066	2049472	63671	0.968933
-2067	2050464	63705	0.968931
-2068	2051456	63728	0.968935
-2069	2052448	63762	0.968934
-2070	2053440	63786	0.968937
-2071	2054432	63816	0.968937
-2072	2055424	63843	0.968939
-2073	2056416	63869	0.968942
-2074	2057408	63893	0.968945
-2075	2058400	63928	0.968943
-2076	2059392	63952	0.968946
-2077	2060384	63998	0.968939
-2078	2061376	64032	0.968937
-2079	2062368	64062	0.968938
-2080	2063360	64090	0.968939
-2081	2064352	64138	0.968931
-2082	2065344	64172	0.968929
-2083	2066336	64216	0.968923
-2084	2067328	64251	0.968921
-2085	2068320	64284	0.968920
-2086	2069312	64311	0.968922
-2087	2070304	64354	0.968916
-2088	2071296	64385	0.968916
-2089	2072288	64419	0.968914
-2090	2073280	64445	0.968916
-2091	2074272	64471	0.968919
-2092	2075264	64493	0.968923
-2093	2076256	64527	0.968921
-2094	2077248	64556	0.968922
-2095	2078240	64604	0.968914
-2096	2079232	64636	0.968914
-2097	2080224	64673	0.968911
-2098	2081216	64697	0.968914
-2099	2082208	64744	0.968906
-2100	2083200	64779	0.968904
-2101	2084192	64809	0.968904
-2102	2085184	64837	0.968906
-2103	2086176	64873	0.968903
-2104	2087168	64896	0.968907
-2105	2088160	64930	0.968906
-2106	2089152	64955	0.968908
-2107	2090144	64988	0.968907
-2108	2091136	65014	0.968910
-2109	2092128	65048	0.968908
-2110	2093120	65077	0.968909
-2111	2094112	65111	0.968908
-2112	2095104	65139	0.968909
-2113	2096096	65178	0.968905
-2114	2097088	65210	0.968904
-2115	2098080	65247	0.968902
-2116	2099072	65273	0.968904
-2117	2100064	65319	0.968897
-2118	2101056	65354	0.968895
-2119	2102048	65387	0.968894
-2120	2103040	65415	0.968895
-2121	2104032	65451	0.968893
-2122	2105024	65477	0.968895
-2123	2106016	65512	0.968893
-2124	2107008	65533	0.968898
-2125	2108000	65567	0.968896
-2126	2108992	65593	0.968898
-2127	2109984	65626	0.968897
-2128	2110976	65654	0.968899
-2129	2111968	65683	0.968900
-2130	2112960	65710	0.968901
-2131	2113952	65755	0.968895
-2132	2114944	65792	0.968892
-2133	2115936	65823	0.968892
-2134	2116928	65852	0.968893
-2135	2117920	65896	0.968886
-2136	2118912	65931	0.968885
-2137	2119904	65965	0.968883
-2138	2120896	65991	0.968885
-2139	2121888	66026	0.968883
-2140	2122880	66053	0.968885
-2141	2123872	66086	0.968884
-2142	2124864	66111	0.968887
-2143	2125856	66144	0.968886
-2144	2126848	66169	0.968889
-2145	2127840	66202	0.968888
-2146	2128832	66228	0.968890
-2147	2129824	66262	0.968889
-2148	2130816	66289	0.968890
-2149	2131808	66319	0.968891
-2150	2132800	66345	0.968893
-2151	2133792	66378	0.968892
-2152	2134784	66404	0.968894
-2153	2135776	66436	0.968894
-2154	2136768	66461	0.968896
-2155	2137760	66493	0.968896
-2156	2138752	66522	0.968897
-2157	2139744	66571	0.968888
-2158	2140736	66606	0.968886
-2159	2141728	66640	0.968885
-2160	2142720	66672	0.968884
-2161	2143712	66708	0.968882
-2162	2144704	66733	0.968885
-2163	2145696	66769	0.968882
-2164	2146688	66797	0.968884
-2165	2147680	66830	0.968883
-2166	2148672	66855	0.968885
-2167	2149664	66906	0.968876
-2168	2150656	66938	0.968876
-2169	2151648	66983	0.968869
-2170	2152640	67016	0.968868
-2171	2153632	67059	0.968862
-2172	2154624	67091	0.968862
-2173	2155616	67112	0.968866
-2174	2156608	67130	0.968872
-2175	2157600	67153	0.968876
-2176	2158592	67169	0.968883
-2177	2159584	67190	0.968888
-2178	2160576	67208	0.968893
-2179	2161568	67237	0.968894
-2180	2162560	67260	0.968898
-2181	2163552	67294	0.968897
-2182	2164544	67319	0.968899
-2183	2165536	67350	0.968899
-2184	2166528	67376	0.968901
-2185	2167520	67397	0.968906
-2186	2168512	67415	0.968912
-2187	2169504	67445	0.968912
-2188	2170496	67468	0.968916
-2189	2171488	67489	0.968920
-2190	2172480	67506	0.968927
-2191	2173472	67550	0.968921
-2192	2174464	67585	0.968919
-2193	2175456	67620	0.968917
-2194	2176448	67646	0.968919
-2195	2177440	67692	0.968912
-2196	2178432	67731	0.968908
-2197	2179424	67761	0.968909
-2198	2180416	67787	0.968911
-2199	2181408	67829	0.968906
-2200	2182400	67864	0.968904
-2201	2183392	67896	0.968903
-2202	2184384	67923	0.968905
-2203	2185376	67957	0.968904
-2204	2186368	67986	0.968905
-2205	2187360	68019	0.968904
-2206	2188352	68045	0.968906
-2207	2189344	68092	0.968898
-2208	2190336	68125	0.968897
-2209	2191328	68160	0.968896
-2210	2192320	68186	0.968898
-2211	2193312	68225	0.968894
-2212	2194304	68252	0.968896
-2213	2195296	68284	0.968895
-2214	2196288	68310	0.968898
-2215	2197280	68359	0.968889
-2216	2198272	68395	0.968887
-2217	2199264	68417	0.968891
-2218	2200256	68439	0.968895
-2219	2201248	68473	0.968894
-2220	2202240	68501	0.968895
-2221	2203232	68534	0.968894
-2222	2204224	68559	0.968897
-2223	2205216	68595	0.968894
-2224	2206208	68620	0.968897
-2225	2207200	68667	0.968890
-2226	2208192	68702	0.968888
-2227	2209184	68746	0.968882
-2228	2210176	68781	0.968880
-2229	2211168	68805	0.968883
-2230	2212160	68823	0.968889
-2231	2213152	68868	0.968882
-2232	2214144	68903	0.968881
-2233	2215136	68934	0.968880
-2234	2216128	68960	0.968883
-2235	2217120	68991	0.968883
-2236	2218112	69017	0.968885
-2237	2219104	69066	0.968877
-2238	2220096	69101	0.968875
-2239	2221088	69146	0.968868
-2240	2222080	69179	0.968867
-2241	2223072	69224	0.968861
-2242	2224064	69259	0.968859
-2243	2225056	69303	0.968853
-2244	2226048	69335	0.968853
-2245	2227040	69370	0.968851
-2246	2228032	69398	0.968852
-2247	2229024	69434	0.968850
-2248	2230016	69459	0.968853
-2249	2231008	69493	0.968851
-2250	2232000	69521	0.968853
-2251	2232992	69555	0.968851
-2252	2233984	69583	0.968853
-2253	2234976	69615	0.968852
-2254	2235968	69642	0.968854
-2255	2236960	69689	0.968847
-2256	2237952	69723	0.968845
-2257	2238944	69758	0.968843
-2258	2239936	69786	0.968845
-2259	2240928	69833	0.968837
-2260	2241920	69870	0.968835
-2261	2242912	69915	0.968828
-2262	2243904	69957	0.968824
-2263	2244896	69987	0.968824
-2264	2245888	70014	0.968826
-2265	2246880	70051	0.968823
-2266	2247872	70076	0.968826
-2267	2248864	70108	0.968825
-2268	2249856	70133	0.968828
-2269	2250848	70154	0.968832
-2270	2251840	70174	0.968837
-2271	2252832	70210	0.968835
-2272	2253824	70239	0.968836
-2273	2254816	70285	0.968829
-2274	2255808	70319	0.968828
-2275	2256800	70362	0.968822
-2276	2257792	70396	0.968821
-2277	2258784	70426	0.968821
-2278	2259776	70455	0.968822
-2279	2260768	70489	0.968821
-2280	2261760	70518	0.968822
-2281	2262752	70551	0.968821
-2282	2263744	70578	0.968822
-2283	2264736	70615	0.968820
-2284	2265728	70639	0.968823
-2285	2266720	70671	0.968822
-2286	2267712	70698	0.968824
-2287	2268704	70732	0.968823
-2288	2269696	70757	0.968825
-2289	2270688	70804	0.968818
-2290	2271680	70839	0.968816
-2291	2272672	70870	0.968816
-2292	2273664	70894	0.968819
-2293	2274656	70926	0.968819
-2294	2275648	70950	0.968822
-2295	2276640	70995	0.968816
-2296	2277632	71027	0.968815
-2297	2278624	71059	0.968815
-2298	2279616	71088	0.968816
-2299	2280608	71127	0.968812
-2300	2281600	71153	0.968814
-2301	2282592	71190	0.968812
-2302	2283584	71216	0.968814
-2303	2284576	71251	0.968812
-2304	2285568	71276	0.968815
-2305	2286560	71313	0.968812
-2306	2287552	71339	0.968814
-2307	2288544	71358	0.968819
-2308	2289536	71375	0.968826
-2309	2290528	71422	0.968819
-2310	2291520	71455	0.968818
-2311	2292512	71488	0.968817
-2312	2293504	71516	0.968818
-2313	2294496	71547	0.968818
-2314	2295488	71575	0.968819
-2315	2296480	71596	0.968824
-2316	2297472	71614	0.968829
-2317	2298464	71640	0.968831
-2318	2299456	71658	0.968837
-2319	2300448	71685	0.968839
-2320	2301440	71703	0.968844
-2321	2302432	71743	0.968840
-2322	2303424	71776	0.968839
-2323	2304416	71811	0.968838
-2324	2305408	71840	0.968838
-2325	2306400	71886	0.968832
-2326	2307392	71919	0.968831
-2327	2308384	71951	0.968831
-2328	2309376	71975	0.968834
-2329	2310368	72023	0.968826
-2330	2311360	72054	0.968826
-2331	2312352	72082	0.968827
-2332	2313344	72107	0.968830
-2333	2314336	72138	0.968830
-2334	2315328	72165	0.968832
-2335	2316320	72187	0.968835
-2336	2317312	72207	0.968840
-2337	2318304	72226	0.968845
-2338	2319296	72246	0.968850
-2339	2320288	72291	0.968844
-2340	2321280	72326	0.968842
-2341	2322272	72354	0.968843
-2342	2323264	72382	0.968845
-2343	2324256	72427	0.968839
-2344	2325248	72460	0.968838
-2345	2326240	72487	0.968839
-2346	2327232	72505	0.968845
-2347	2328224	72532	0.968847
-2348	2329216	72555	0.968850
-2349	2330208	72577	0.968854
-2350	2331200	72595	0.968859
-2351	2332192	72626	0.968859
-2352	2333184	72654	0.968861
-2353	2334176	72677	0.968864
-2354	2335168	72700	0.968867
-2355	2336160	72728	0.968869
-2356	2337152	72752	0.968872
-2357	2338144	72786	0.968870
-2358	2339136	72810	0.968873
-2359	2340128	72855	0.968867
-2360	2341120	72889	0.968866
-2361	2342112	72936	0.968859
-2362	2343104	72967	0.968859
-2363	2344096	72999	0.968858
-2364	2345088	73022	0.968862
-2365	2346080	73061	0.968858
-2366	2347072	73086	0.968861
-2367	2348064	73135	0.968853
-2368	2349056	73166	0.968853
-2369	2350048	73213	0.968846
-2370	2351040	73249	0.968844
-2371	2352032	73279	0.968844
-2372	2353024	73304	0.968847
-2373	2354016	73336	0.968846
-2374	2355008	73364	0.968848
-2375	2356000	73408	0.968842
-2376	2356992	73444	0.968840
-2377	2357984	73481	0.968837
-2378	2358976	73508	0.968839
-2379	2359968	73539	0.968839
-2380	2360960	73567	0.968840
-2381	2361952	73604	0.968838
-2382	2362944	73631	0.968839
-2383	2363936	73667	0.968837
-2384	2364928	73693	0.968839
-2385	2365920	73726	0.968838
-2386	2366912	73750	0.968841
-2387	2367904	73777	0.968843
-2388	2368896	73799	0.968847
-2389	2369888	73831	0.968846
-2390	2370880	73854	0.968850
-2391	2371872	73886	0.968849
-2392	2372864	73913	0.968851
-2393	2373856	73958	0.968845
-2394	2374848	73993	0.968843
-2395	2375840	74015	0.968847
-2396	2376832	74034	0.968852
-2397	2377824	74082	0.968845
-2398	2378816	74114	0.968844
-2399	2379808	74146	0.968844
-2400	2380800	74171	0.968846
-2401	2381792	74193	0.968850
-2402	2382784	74214	0.968854
-2403	2383776	74249	0.968852
-2404	2384768	74277	0.968854
-2405	2385760	74308	0.968854
-2406	2386752	74336	0.968855
-2407	2387744	74371	0.968853
-2408	2388736	74398	0.968855
-2409	2389728	74430	0.968854
-2410	2390720	74458	0.968855
-2411	2391712	74488	0.968856
-2412	2392704	74512	0.968859
-2413	2393696	74547	0.968857
-2414	2394688	74574	0.968859
-2415	2395680	74608	0.968857
-2416	2396672	74633	0.968860
-2417	2397664	74656	0.968863
-2418	2398656	74674	0.968868
-2419	2399648	74724	0.968860
-2420	2400640	74757	0.968860
-2421	2401632	74792	0.968858
-2422	2402624	74817	0.968860
-2423	2403616	74854	0.968858
-2424	2404608	74880	0.968860
-2425	2405600	74905	0.968862
-2426	2406592	74925	0.968867
-2427	2407584	74959	0.968865
-2428	2408576	74984	0.968868
-2429	2409568	75021	0.968865
-2430	2410560	75045	0.968868
-2431	2411552	75079	0.968867
-2432	2412544	75106	0.968869
-2433	2413536	75142	0.968866
-2434	2414528	75167	0.968869
-2435	2415520	75197	0.968869
-2436	2416512	75225	0.968870
-2437	2417504	75247	0.968874
-2438	2418496	75266	0.968879
-2439	2419488	75298	0.968879
-2440	2420480	75325	0.968880
-2441	2421472	75357	0.968880
-2442	2422464	75384	0.968881
-2443	2423456	75407	0.968885
-2444	2424448	75427	0.968889
-2445	2425440	75461	0.968888
-2446	2426432	75487	0.968890
-2447	2427424	75520	0.968889
-2448	2428416	75543	0.968892
-2449	2429408	75576	0.968891
-2450	2430400	75603	0.968893
-2451	2431392	75638	0.968891
-2452	2432384	75664	0.968893
-2453	2433376	75718	0.968884
-2454	2434368	75756	0.968881
-2455	2435360	75793	0.968878
-2456	2436352	75826	0.968877
-2457	2437344	75857	0.968877
-2458	2438336	75888	0.968877
-2459	2439328	75941	0.968868
-2460	2440320	75981	0.968864
-2461	2441312	76019	0.968861
-2462	2442304	76050	0.968861
-2463	2443296	76087	0.968859
-2464	2444288	76113	0.968861
-2465	2445280	76164	0.968853
-2466	2446272	76198	0.968851
-2467	2447264	76235	0.968849
-2468	2448256	76257	0.968853
-2469	2449248	76300	0.968848
-2470	2450240	76324	0.968850
-2471	2451232	76353	0.968851
-2472	2452224	76378	0.968854
-2473	2453216	76410	0.968853
-2474	2454208	76436	0.968855
-2475	2455200	76478	0.968851
-2476	2456192	76506	0.968852
-2477	2457184	76540	0.968851
-2478	2458176	76565	0.968853
-2479	2459168	76612	0.968846
-2480	2460160	76648	0.968844
-2481	2461152	76681	0.968843
-2482	2462144	76707	0.968845
-2483	2463136	76753	0.968839
-2484	2464128	76786	0.968838
-2485	2465120	76817	0.968838
-2486	2466112	76851	0.968837
-2487	2467104	76883	0.968837
-2488	2468096	76913	0.968837
-2489	2469088	76946	0.968836
-2490	2470080	76972	0.968838
-2491	2471072	77004	0.968838
-2492	2472064	77032	0.968839
-2493	2473056	77066	0.968838
-2494	2474048	77090	0.968841
-2495	2475040	77137	0.968834
-2496	2476032	77173	0.968832
-2497	2477024	77200	0.968834
-2498	2478016	77223	0.968837
-2499	2479008	77257	0.968836
-2500	2480000	77285	0.968837
-2501	2480992	77313	0.968838
-2502	2481984	77338	0.968840
-2503	2482976	77369	0.968840
-2504	2483968	77391	0.968844
-2505	2484960	77424	0.968843
-2506	2485952	77449	0.968845
-2507	2486944	77496	0.968839
-2508	2487936	77531	0.968837
-2509	2488928	77568	0.968835
-2510	2489920	77594	0.968837
-2511	2490912	77626	0.968836
-2512	2491904	77652	0.968838
-2513	2492896	77672	0.968843
-2514	2493888	77693	0.968847
-2515	2494880	77722	0.968847
-2516	2495872	77747	0.968850
-2517	2496864	77794	0.968843
-2518	2497856	77831	0.968841
-2519	2498848	77867	0.968839
-2520	2499840	77893	0.968841
-2521	2500832	77947	0.968832
-2522	2501824	77984	0.968829
-2523	2502816	78034	0.968822
-2524	2503808	78066	0.968821
-2525	2504800	78097	0.968821
-2526	2505792	78121	0.968824
-2527	2506784	78151	0.968824
-2528	2507776	78175	0.968827
-2529	2508768	78210	0.968825
-2530	2509760	78237	0.968827
-2531	2510752	78285	0.968820
-2532	2511744	78318	0.968819
-2533	2512736	78352	0.968818
-2534	2513728	78382	0.968818
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/919fe4a9a14845d55cc535bc7cc8a129a299a800
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160215/dd6c584d/attachment-0001.html>
More information about the Darshan-commits mailing list
