[Darshan-commits] [Git][darshan/darshan][master] bug fixes in disabling instr. in modules
Shane Snyder
xgitlab at cels.anl.gov
Tue Aug 9 17:07:58 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
def2fe28 by Shane Snyder at 2016-08-09T14:30:52-07:00
7 changed files:
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-lustre.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-null.c
- darshan-runtime/lib/darshan-pnetcdf.c
- darshan-runtime/lib/darshan-posix.c
- darshan-runtime/lib/darshan-stdio.c
Changes:
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -69,11 +69,12 @@ static int my_rank = -1;
#define HDF5_PRE_RECORD() do { \
HDF5_LOCK(); \
- if(!hdf5_runtime && !instrumentation_disabled) hdf5_runtime_initialize(); \
- if(!hdf5_runtime) { \
- HDF5_UNLOCK(); \
- return(ret); \
+ if(!instrumentation_disabled) { \
+ if(!hdf5_runtime) hdf5_runtime_initialize(); \
+ if(hdf5_runtime) break; \
+ HDF5_UNLOCK(); \
+ return(ret); \
} while(0)
#define HDF5_POST_RECORD() do { \
@@ -339,6 +340,7 @@ static void hdf5_cleanup_runtime()
free(hdf5_runtime);
hdf5_runtime = NULL;
+ instrumentation_disabled = 0;
return;
@@ -365,6 +367,10 @@ static void hdf5_shutdown(
HDF5_LOCK();
assert(hdf5_runtime);
+ /* disable further instrumentation */
+ instrumentation_disabled = 1;
hdf5_rec_count = hdf5_runtime->file_rec_count;
/* if there are globally shared files, do a shared file reduction */
@@ -440,9 +446,6 @@ static void hdf5_shutdown(
/* shutdown internal structures used for instrumenting */
hdf5_cleanup_runtime();
- /* disable further instrumentation */
- instrumentation_disabled = 1;
HDF5_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-lustre.c
+++ b/darshan-runtime/lib/darshan-lustre.c
@@ -61,10 +61,14 @@ void darshan_instrument_lustre_file(const char* filepath, int fd)
int ret;
LUSTRE_LOCK();
+ if(instrumentation_disabled)
+ LUSTRE_UNLOCK();
+ return;
- /* try to init module if not already and if instrumentation isn't disabled */
- if(!lustre_runtime && !instrumentation_disabled)
- lustre_runtime_initialize();
+ /* try to init module if not already */
+ if(!lustre_runtime) lustre_runtime_initialize();
/* if we aren't initialized, just back out */
if(!lustre_runtime)
@@ -226,6 +230,10 @@ static void lustre_shutdown(
LUSTRE_LOCK();
assert(lustre_runtime);
+ /* disable further instrumentation while we shutdown */
lustre_runtime->record_buffer = *lustre_buf;
lustre_runtime->record_buffer_size = *lustre_buf_sz;
@@ -268,9 +276,7 @@ static void lustre_shutdown(
darshan_clear_record_refs(&(lustre_runtime->record_id_hash), 1);
free(lustre_runtime);
lustre_runtime = NULL;
LUSTRE_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -97,11 +97,12 @@ static int my_rank = -1;
#define MPIIO_PRE_RECORD() do { \
MPIIO_LOCK(); \
- if(!mpiio_runtime && !instrumentation_disabled) mpiio_runtime_initialize(); \
- if(!mpiio_runtime) { \
- MPIIO_UNLOCK(); \
- return(ret); \
+ if(!mpiio_runtime) mpiio_runtime_initialize(); \
+ if(mpiio_runtime) break; \
+ MPIIO_UNLOCK(); \
+ return(ret); \
} while(0)
#define MPIIO_POST_RECORD() do { \
@@ -1169,6 +1170,7 @@ static void mpiio_cleanup_runtime()
free(mpiio_runtime);
mpiio_runtime = NULL;
return;
@@ -1276,6 +1278,10 @@ static void mpiio_shutdown(
MPIIO_LOCK();
assert(mpiio_runtime);
mpiio_rec_count = mpiio_runtime->file_rec_count;
/* perform any final transformations on MPIIO file records before
@@ -1384,9 +1390,6 @@ static void mpiio_shutdown(
mpiio_cleanup_runtime();
MPIIO_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-null.c
+++ b/darshan-runtime/lib/darshan-null.c
@@ -116,11 +116,12 @@ static int my_rank = -1;
#define NULL_PRE_RECORD() do { \
NULL_LOCK(); \
- if(!null_runtime && !instrumentation_disabled) null_runtime_initialize(); \
- if(!null_runtime) { \
- NULL_UNLOCK(); \
- return(ret); \
+ if(!null_runtime) null_runtime_initialize(); \
+ if(null_runtime) break; \
+ NULL_UNLOCK(); \
+ return(ret); \
} while(0)
/* the NULL_POST_RECORD macro is executed after performing NULL
@@ -294,6 +295,7 @@ static void null_cleanup_runtime()
free(null_runtime);
null_runtime = NULL;
return;
@@ -315,6 +317,9 @@ static void null_shutdown(
NULL_LOCK();
assert(null_runtime);
/* NOTE: this function can be used to run collective operations prior to
* shutting down the module, as implied by the MPI communicator passed in
* as the first agrument. Typically, module developers will want to run a
@@ -336,9 +341,6 @@ static void null_shutdown(
null_cleanup_runtime();
NULL_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ b/darshan-runtime/lib/darshan-pnetcdf.c
@@ -65,11 +65,12 @@ static int my_rank = -1;
#define PNETCDF_PRE_RECORD() do { \
PNETCDF_LOCK(); \
- if(!pnetcdf_runtime && !instrumentation_disabled) pnetcdf_runtime_initialize(); \
- if(!pnetcdf_runtime) { \
- PNETCDF_UNLOCK(); \
- return(ret); \
+ if(!pnetcdf_runtime) pnetcdf_runtime_initialize(); \
+ if(pnetcdf_runtime) break; \
+ PNETCDF_UNLOCK(); \
+ return(ret); \
} while(0)
#define PNETCDF_POST_RECORD() do { \
@@ -336,6 +337,7 @@ static void pnetcdf_cleanup_runtime()
free(pnetcdf_runtime);
pnetcdf_runtime = NULL;
return;
@@ -363,6 +365,10 @@ static void pnetcdf_shutdown(
PNETCDF_LOCK();
assert(pnetcdf_runtime);
pnetcdf_rec_count = pnetcdf_runtime->file_rec_count;
@@ -439,9 +445,6 @@ static void pnetcdf_shutdown(
pnetcdf_cleanup_runtime();
PNETCDF_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -168,11 +168,12 @@ static int darshan_mem_alignment = 1;
#define POSIX_PRE_RECORD() do { \
POSIX_LOCK(); \
- if(!posix_runtime && !instrumentation_disabled) posix_runtime_initialize(); \
- if(!posix_runtime) { \
- POSIX_UNLOCK(); \
- return(ret); \
+ if(!posix_runtime) posix_runtime_initialize(); \
+ if(posix_runtime) break; \
+ POSIX_UNLOCK(); \
+ return(ret); \
} while(0)
#define POSIX_POST_RECORD() do { \
@@ -1684,6 +1685,7 @@ static void posix_cleanup_runtime()
free(posix_runtime);
posix_runtime = NULL;
return;
@@ -1783,6 +1785,10 @@ static void posix_shutdown(
POSIX_LOCK();
assert(posix_runtime);
+ /* disable instrumentation while we shutdown */
posix_rec_count = posix_runtime->file_rec_count;
/* perform any final transformations on POSIX file records before
@@ -1892,9 +1898,6 @@ static void posix_shutdown(
posix_cleanup_runtime();
POSIX_UNLOCK();
return;
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -160,11 +160,12 @@ static void stdio_cleanup_runtime();
#define STDIO_PRE_RECORD() do { \
STDIO_LOCK(); \
- if(!stdio_runtime && !instrumentation_disabled) stdio_runtime_initialize(); \
- if(!stdio_runtime) { \
- STDIO_UNLOCK(); \
- return(ret); \
+ if(!stdio_runtime) stdio_runtime_initialize(); \
+ if(stdio_runtime) break; \
+ STDIO_UNLOCK(); \
+ return(ret); \
} while(0)
#define STDIO_POST_RECORD() do { \
@@ -728,7 +729,11 @@ void DARSHAN_DECL(rewind)(FILE *stream)
* value in this wrapper.
STDIO_LOCK();
+ if(instrumentation_disabled) {
+ STDIO_UNLOCK();
+ return;
STDIO_UNLOCK();
return;
@@ -912,10 +917,6 @@ static void stdio_runtime_initialize()
/* try to store default number of records for this module */
stdio_buf_size = DARSHAN_DEF_MOD_REC_COUNT * sizeof(struct darshan_stdio_file);
- /* don't do anything if already initialized or instrumenation is disabled */
- if(stdio_runtime || instrumentation_disabled)
- return;
/* register the stdio module with darshan core */
darshan_core_register_module(
DARSHAN_STDIO_MOD,
@@ -1070,6 +1071,10 @@ static void stdio_shutdown(
STDIO_LOCK();
assert(stdio_runtime);
stdio_rec_count = stdio_runtime->file_rec_count;
@@ -1173,9 +1178,6 @@ static void stdio_shutdown(
STDIO_UNLOCK();
return;
@@ -1239,6 +1241,7 @@ static void stdio_cleanup_runtime()
free(stdio_runtime);
stdio_runtime = NULL;
return;
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/def2fe28c7684ac6662866baac07737df019c54f
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160809/2d1d43e6/attachment-0001.html>
More information about the Darshan-commits
