[Darshan-commits] [Git][darshan/darshan][dev-stdio] start filling in fopen counters
Philip Carns
xgitlab at cels.anl.gov
Fri Apr 29 16:22:39 CDT 2016
Philip Carns pushed to branch dev-stdio at darshan / darshan
Commits:
28131252 by Phil Carns at 2016-04-29T17:22:27-04:00
2 changed files:
- darshan-runtime/lib/darshan-stdio.c
- darshan-stdio-log-format.h
Changes:
--- a/darshan-runtime/lib/darshan-stdio.c
+++ b/darshan-runtime/lib/darshan-stdio.c
@@ -135,15 +135,52 @@ static void stdio_shutdown(void);
#define STDIO_LOCK() pthread_mutex_lock(&stdio_runtime_mutex)
#define STDIO_UNLOCK() pthread_mutex_unlock(&stdio_runtime_mutex)
+/* TODO: remember to clean up stream_flag in posix module */
+/* TODO: remember to update start_timestamp logic in other modules */
+#define STDIO_RECORD_OPEN(__ret, __path, __tm1, __tm2) do { \
+ struct stdio_file_runtime* file; \
+ char* exclude; \
+ int tmp_index = 0; \
+ if(__ret == NULL) break; \
+ while((exclude = darshan_path_exclusions[tmp_index])) { \
+ if(!(strncmp(exclude, __path, strlen(exclude)))) \
+ break; \
+ tmp_index++; \
+ if(exclude) break; \
+ file = stdio_file_by_name_setstream(__path, __ret); \
+ if(!file) break; \
+ file->offset = 0; \
+ file->last_byte_written = 0; \
+ file->last_byte_read = 0; \
+ file->file_record->counters[STDIO_FOPENS] += 1; \
+ if(file->file_record->fcounters[STDIO_F_OPEN_START_TIMESTAMP] == 0 || \
+ file->file_record->fcounters[STDIO_F_OPEN_START_TIMESTAMP] > __tm1) \
+ file->file_record->fcounters[STDIO_F_OPEN_START_TIMESTAMP] = __tm1; \
+ file->file_record->fcounters[STDIO_F_OPEN_END_TIMESTAMP] = __tm2; \
+ DARSHAN_TIMER_INC_NO_OVERLAP(file->file_record->fcounters[STDIO_F_META_TIME], __tm1, __tm2, file->last_meta_end); \
+} while(0)
FILE* DARSHAN_DECL(fopen)(const char *path, const char *mode)
FILE* ret;
+ double tm1, tm2;
fprintf(stderr, "FOO: HELLO WORLD (FOPEN)\n");
MAP_OR_FAIL(fopen);
+ tm1 = darshan_core_wtime();
ret = __real_fopen(path, mode);
+ tm2 = darshan_core_wtime();
+ STDIO_LOCK();
+ stdio_runtime_initialize();
+ STDIO_RECORD_OPEN(ret, path, tm1, tm2);
+ STDIO_UNLOCK();
return(ret);
--- a/darshan-stdio-log-format.h
+++ b/darshan-stdio-log-format.h
@@ -56,18 +56,18 @@
#define STDIO_COUNTERS \
- /* count of number of 'bar' function calls */\
- X(STDIO_BARS) \
- /* arbitrary data value set by last call to 'bar' */\
- X(STDIO_BAR_DAT) \
+ /* count of fopens */\
+ X(STDIO_FOPENS) \
/* end of counters */\
X(STDIO_NUM_INDICES)
#define STDIO_F_COUNTERS \
- /* timestamp of the first call to function 'bar' */\
- X(STDIO_F_BAR_TIMESTAMP) \
- /* timer indicating duration of last call to 'bar' */\
- X(STDIO_F_BAR_DURATION) \
+ /* timestamp of first open */\
+ X(STDIO_F_OPEN_START_TIMESTAMP) \
+ /* timestamp of last open completion */\
+ X(STDIO_F_OPEN_END_TIMESTAMP) \
+ /* cumulative meta time */\
+ X(STDIO_F_META_TIME) \
X(STDIO_F_NUM_INDICES)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/2813125263dd0df65050808b627d6c6a3350f4fa
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160429/0c954527/attachment.html>
More information about the Darshan-commits
