[Darshan-commits] [Git][darshan/darshan][master] modify darshan-logutils to sort mount info
Shane Snyder
xgitlab at cels.anl.gov
Wed Apr 27 09:07:30 CDT 2016
Shane Snyder pushed to branch master at darshan / darshan
Commits:
1eb2a5e4 by Shane Snyder at 2016-04-26T23:02:21-05:00
mount information is now sorted in order of descending mount
point lengths to fix a bug in matching file names to mount
points. the longest mount point string which matches the file
name is the corresponding mount. this change requires slight
changes to the darshan-logutils API, but does not modify the
log file format
4 changed files:
- darshan-util/darshan-convert.c
- darshan-util/darshan-logutils.c
- darshan-util/darshan-logutils.h
- darshan-util/darshan-parser.c
Changes:
--- a/darshan-util/darshan-convert.c
+++ b/darshan-util/darshan-convert.c
@@ -230,8 +230,7 @@ int main(int argc, char **argv)
darshan_fd outfile;
int i;
int mount_count;
- char** mnt_pts;
- char** fs_types;
+ struct darshan_mnt_info *mnt_data_array;
struct darshan_record_ref *rec_hash = NULL;
struct darshan_record_ref *ref, *tmp;
char mod_buf[DEF_MOD_BUF_SIZE];
@@ -299,7 +298,7 @@ int main(int argc, char **argv)
return(-1);
- ret = darshan_log_getmounts(infile, &mnt_pts, &fs_types, &mount_count);
+ ret = darshan_log_getmounts(infile, &mnt_data_array, &mount_count);
if(ret < 0)
darshan_log_close(infile);
@@ -308,7 +307,7 @@ int main(int argc, char **argv)
return(-1);
- ret = darshan_log_putmounts(outfile, mnt_pts, fs_types, mount_count);
+ ret = darshan_log_putmounts(outfile, mnt_data_array, mount_count);
if(ret < 0)
@@ -389,16 +388,8 @@ int main(int argc, char **argv)
darshan_log_close(outfile);
- for(i=0; i<mount_count; i++)
- free(mnt_pts[i]);
- free(fs_types[i]);
if(mount_count > 0)
- free(mnt_pts);
- free(fs_types);
+ free(mnt_data_array);
HASH_ITER(hlink, rec_hash, ref, tmp)
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -66,6 +66,7 @@ struct darshan_fd_int_state
struct darshan_dz_state dz;
+static int darshan_mnt_info_cmp(const void *a, const void *b);
static int darshan_log_getheader(darshan_fd fd);
static int darshan_log_putheader(darshan_fd fd);
static int darshan_log_seek(darshan_fd fd, off_t offset);
@@ -374,14 +375,14 @@ int darshan_log_putexe(darshan_fd fd, char *buf)
/* darshan_log_getmounts()
- * retrieves mount table information from the log. Note that mnt_pts and
- * fs_types are arrays that will be allocated by the function and must be
- * freed by the caller. count will indicate the size of the arrays
+ * retrieves mount table information from the log. Note that mnt_data_array
+ * is an array that will be allocated by the function and must be
+ * freed by the caller. count will indicate the size of the array
* returns 0 on success, -1 on failure
-int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
- char*** fs_types, int* count)
+int darshan_log_getmounts(darshan_fd fd, struct darshan_mnt_info **mnt_data_array,
+ int* count)
struct darshan_fd_int_state *state = fd->state;
char *pos;
@@ -416,34 +417,27 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
/* allocate output arrays */
- *mnt_pts = malloc((*count)*sizeof(char*));
- assert(*mnt_pts);
- *fs_types = malloc((*count)*sizeof(char*));
- assert(*fs_types);
+ *mnt_data_array = malloc((*count)*sizeof(**mnt_data_array));
+ assert(*mnt_data_array);
- /* work backwards through the table and parse each line (except for
+ /* work through the table and parse each line (except for
* first, which holds command line information)
- while((pos = strrchr(state->exe_mnt_data, '\n')) != NULL)
+ pos = state->exe_mnt_data;
+ while((pos = strchr(pos, '\n')) != NULL)
- /* overestimate string lengths */
- (*mnt_pts)[array_index] = malloc(DARSHAN_EXE_LEN);
- assert((*mnt_pts)[array_index]);
- (*fs_types)[array_index] = malloc(DARSHAN_EXE_LEN);
- assert((*fs_types)[array_index]);
- ret = sscanf(++pos, "%s\t%s", (*fs_types)[array_index],
- (*mnt_pts)[array_index]);
+ ret = sscanf(++pos, "%s\t%s", (*mnt_data_array)[array_index].mnt_type,
+ (*mnt_data_array)[array_index].mnt_path);
if(ret != 2)
fprintf(stderr, "Error: poorly formatted mount table in darshan log file.\n");
return(-1);
- pos--;
- *pos = '\0';
array_index++;
+ qsort(*mnt_data_array, *count, sizeof(**mnt_data_array), darshan_mnt_info_cmp);
return(0);
@@ -456,7 +450,8 @@ int darshan_log_getmounts(darshan_fd fd, char*** mnt_pts,
-int darshan_log_putmounts(darshan_fd fd, char** mnt_pts, char** fs_types, int count)
+int darshan_log_putmounts(darshan_fd fd, struct darshan_mnt_info *mnt_data_array,
+ int count)
int i;
@@ -472,7 +467,7 @@ int darshan_log_putmounts(darshan_fd fd, char** mnt_pts, char** fs_types, int co
tmp = mnt_dat;
for(i=count-1; i>=0; i--)
- sprintf(line, "\n%s\t%s", fs_types[i], mnt_pts[i]);
+ sprintf(line, "\n%s\t%s", mnt_data_array[i].mnt_type, mnt_data_array[i].mnt_path);
memcpy(tmp, line, strlen(line));
tmp += strlen(line);
@@ -827,6 +822,19 @@ void darshan_log_close(darshan_fd fd)
+ struct darshan_mnt_info *m_a = (struct darshan_mnt_info *)a;
+ struct darshan_mnt_info *m_b = (struct darshan_mnt_info *)b;
+ if(strlen(m_a->mnt_path) > strlen(m_b->mnt_path))
+ return(-1);
+ else if(strlen(m_a->mnt_path) < strlen(m_b->mnt_path))
+ return(1);
+ else
+ return(0);
/* read the header of the darshan log and set internal fd data structures
* NOTE: this is the only portion of the darshan log that is uncompressed
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -47,6 +47,12 @@ struct darshan_record_ref
UT_hash_handle hlink;
+struct darshan_mnt_info
+ char mnt_type[DARSHAN_EXE_LEN];
+ char mnt_path[DARSHAN_EXE_LEN];
/* functions to be implemented by each module for integration with
* darshan log file utilities (e.g., parser & convert tools)
@@ -115,10 +121,10 @@ int darshan_log_getjob(darshan_fd fd, struct darshan_job *job);
int darshan_log_putjob(darshan_fd fd, struct darshan_job *job);
int darshan_log_getexe(darshan_fd fd, char *buf);
int darshan_log_putexe(darshan_fd fd, char *buf);
- char*** fs_types, int* count);
- char** fs_types, int count);
+ int* count);
+ int count);
int darshan_log_gethash(darshan_fd fd, struct darshan_record_ref **hash);
int darshan_log_puthash(darshan_fd fd, struct darshan_record_ref *hash);
int darshan_log_getmod(darshan_fd fd, darshan_module_id mod_id,
--- a/darshan-util/darshan-parser.c
+++ b/darshan-util/darshan-parser.c
@@ -205,8 +205,7 @@ int main(int argc, char **argv)
struct darshan_record_ref *ref, *tmp_ref;
int mount_count;
- char** mnt_pts;
- char** fs_types;
time_t tmp_time = 0;
char *token;
char *save;
@@ -248,7 +247,7 @@ int main(int argc, char **argv)
/* get the mount information for this log */
- ret = darshan_log_getmounts(fd, &mnt_pts, &fs_types, &mount_count);
+ ret = darshan_log_getmounts(fd, &mnt_data_array, &mount_count);
if(ret < 0)
darshan_log_close(fd);
@@ -318,7 +317,8 @@ int main(int argc, char **argv)
printf("# -------------------------------------------------------\n");
- printf("# mount entry:\t%s\t%s\n", mnt_pts[i], fs_types[i]);
+ printf("# mount entry:\t%s\t%s\n", mnt_data_array[i].mnt_path,
+ mnt_data_array[i].mnt_type);
if(mask & OPTION_BASE)
@@ -417,10 +417,11 @@ int main(int argc, char **argv)
/* get mount point and fs type associated with this record */
for(j=0; j<mount_count; j++)
- if(strncmp(mnt_pts[j], ref->rec.name, strlen(mnt_pts[j])) == 0)
+ if(strncmp(mnt_data_array[j].mnt_path, ref->rec.name,
+ strlen(mnt_data_array[j].mnt_path)) == 0)
- mnt_pt = mnt_pts[j];
- fs_type = fs_types[j];
+ mnt_pt = mnt_data_array[j].mnt_path;
+ fs_type = mnt_data_array[j].mnt_type;
break;
@@ -633,15 +634,9 @@ cleanup:
/* free mount info */
- free(mnt_pts[i]);
if(mount_count > 0)
- free(mnt_pts);
- free(fs_types);
return(ret);
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/1eb2a5e4d71f390269143c7147a34f1d0a8377a3
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20160427/c907ae89/attachment.html>
More information about the Darshan-commits
