[Darshan-commits] [Git][darshan/darshan][dev-modular] bug fix for modules creating more than max records
Shane Snyder
gitlab at xgitlab.cels.anl.gov
Fri Sep 25 15:03:07 CDT 2015
Shane Snyder pushed to branch dev-modular at darshan / darshan
Commits:
928fdff4 by Shane Snyder at 2015-09-25T15:02:25Z
7 changed files:
- darshan-runtime/darshan-core.h
- darshan-runtime/lib/darshan-bgq.c
- darshan-runtime/lib/darshan-core.c
- darshan-runtime/lib/darshan-hdf5.c
- darshan-runtime/lib/darshan-mpiio.c
- darshan-runtime/lib/darshan-pnetcdf.c
- darshan-runtime/lib/darshan-posix.c
Changes:
--- a/darshan-runtime/darshan-core.h
+++ b/darshan-runtime/darshan-core.h
@@ -26,7 +26,7 @@
/* Environment variable to override __DARSHAN_MEM_ALIGNMENT */
#define DARSHAN_MEM_ALIGNMENT_OVERRIDE "DARSHAN_MEMALIGN"
-#define DARSHAN_CORE_MAX_RECORDS 4096
+#define DARSHAN_CORE_MAX_RECORDS 2048
/* TODO: revisit this default size if we change memory per module */
#define DARSHAN_CORE_COMP_BUF_SIZE (2 * 1024 * 1024)
--- a/darshan-runtime/lib/darshan-bgq.c
+++ b/darshan-runtime/lib/darshan-bgq.c
@@ -122,7 +122,7 @@ void bgq_runtime_initialize()
if(bgq_runtime || instrumentation_disabled)
return;
- /* register the "NULL" module with the darshan-core component */
+ /* register the BG/Q module with the darshan-core component */
darshan_core_register_module(
DARSHAN_BGQ_MOD,
&bgq_mod_fns,
@@ -161,6 +161,18 @@ void bgq_runtime_initialize()
&bgq_runtime->record.f_id,
&bgq_runtime->record.alignment);
+ /* if record is set to 0, darshan-core is out of space and will not
+ * track this record, so we should avoid tracking it, too
+ if(bgq_runtime->record.f_id == 0)
+ instrumentation_disabled = 1;
+ free(bgq_runtime);
+ bgq_runtime = NULL;
+ BGQ_UNLOCK();
+ return;
capture(&bgq_runtime->record);
BGQ_UNLOCK();
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -1549,6 +1549,8 @@ void darshan_core_register_record(
darshan_record_id tmp_rec_id;
struct darshan_core_record_ref *ref;
+ *rec_id = 0;
if(!darshan_core)
return;
--- a/darshan-runtime/lib/darshan-hdf5.c
+++ b/darshan-runtime/lib/darshan-hdf5.c
@@ -273,6 +273,16 @@ static struct hdf5_file_runtime* hdf5_file_by_name(const char *name)
&file_id,
NULL);
+ if(file_id == 0)
+ if(newname != name)
+ free(newname);
+ return(NULL);
/* search the hash table for this file record, and return if found */
HASH_FIND(hlink, hdf5_runtime->file_hash, &file_id, sizeof(darshan_record_id), file);
if(file)
--- a/darshan-runtime/lib/darshan-mpiio.c
+++ b/darshan-runtime/lib/darshan-mpiio.c
@@ -895,6 +895,16 @@ static struct mpiio_file_runtime* mpiio_file_by_name(const char *name)
&file_id,
NULL);
+ if(file_id == 0)
+ free(newname);
+ return(NULL);
HASH_FIND(hlink, mpiio_runtime->file_hash, &file_id, sizeof(darshan_record_id), file);
if(file)
--- a/darshan-runtime/lib/darshan-pnetcdf.c
+++ b/darshan-runtime/lib/darshan-pnetcdf.c
@@ -285,6 +285,16 @@ static struct pnetcdf_file_runtime* pnetcdf_file_by_name(const char *name)
&file_id,
NULL);
+ if(file_id == 0)
+ free(newname);
+ return(NULL);
HASH_FIND(hlink, pnetcdf_runtime->file_hash, &file_id, sizeof(darshan_record_id), file);
if(file)
--- a/darshan-runtime/lib/darshan-posix.c
+++ b/darshan-runtime/lib/darshan-posix.c
@@ -1526,6 +1526,16 @@ static struct posix_file_runtime* posix_file_by_name(const char *name)
&file_id,
&file_alignment);
+ if(file_id == 0)
+ free(newname);
+ return(NULL);
HASH_FIND(hlink, posix_runtime->file_hash, &file_id, sizeof(darshan_record_id), file);
if(file)
View it on GitLab: https://xgitlab.cels.anl.gov/darshan/darshan/commit/928fdff4f6dbc92f33988f09b93794d4e51c5dc8
URL: <http://lists.mcs.anl.gov/pipermail/darshan-commits/attachments/20150925/a2bb8fe6/attachment.html>
More information about the Darshan-commits
