[Darshan-commits] [Darshan] branch, dev-modular,	updated. darshan-2.3.1-172-g328f68b
    Service Account
    git at mcs.anl.gov
    Wed Sep  9 22:45:34 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  328f68bd9a8faa7128423f6589bb047d1ce4f6f8 (commit)
      from  10068d0076c8e93783ca2ebffcdd7725c4b4ce51 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit 328f68bd9a8faa7128423f6589bb047d1ce4f6f8
Author: Shane Snyder <snyder at cetuslac1.fst.alcf.anl.gov>
Date:   Thu Sep 10 03:43:45 2015 +0000
    allow modules to statically init
Summary of changes:
 darshan-runtime/Makefile.in        |   18 ++++++++++--------
 darshan-runtime/configure          |    2 +-
 darshan-runtime/lib/darshan-bgq.c  |    4 ----
 darshan-runtime/lib/darshan-core.c |   28 +++++++++++++++++++++++-----
 4 files changed, 34 insertions(+), 18 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/Makefile.in b/darshan-runtime/Makefile.in
index 85dbffb..40a3d42 100644
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -23,22 +23,24 @@ ifndef DISABLE_LDPRELOAD
 all: lib/libdarshan.so lib/darshan-null.po
 endif
+VPATH = $(srcdir)
+CFLAGS = -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I $(srcdir) -I$(srcdir)/../ @CFLAGS@ @CPPFLAGS@ -D_LARGEFILE64_SOURCE
+CFLAGS_SHARED = -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I$(srcdir) -I$(srcdir)/../ @CFLAGS@ @CPPFLAGS@ -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD
+LIBS = -lz @LIBBZ2@
 static-mod-objs = lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o
 dynamic-mod-objs = lib/darshan-posix.po lib/darshan-mpiio.po lib/darshan-hdf5.po lib/darshan-pnetcdf.po
 ifdef DARSHAN_USE_BGQ
 static-mod-objs += lib/darshan-bgq.o
 dynamic-mod-objs += lib/darshan-bgq.po
+CFLAGS += -DDARSHAN_BGQ
+CFLAGS_SHARED += -DDARSHAN_BGQ
 endif
-VPATH = $(srcdir)
-CFLAGS = -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I ../ -I $(srcdir) -I$(srcdir)/../ @CFLAGS@ @CPPFLAGS@ -D_LARGEFILE64_SOURCE
-CFLAGS_SHARED = -DDARSHAN_CONFIG_H=\"darshan-runtime-config.h\" -I . -I$(srcdir) -I$(srcdir)/../ @CFLAGS@ @CPPFLAGS@ -D_LARGEFILE64_SOURCE -shared -fpic -DPIC -DDARSHAN_PRELOAD
-LIBS = -lz @LIBBZ2@
 lib::
 	@mkdir -p $@
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index 9e206a3..b7929bc 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -4248,7 +4248,7 @@ $as_echo "no" >&6; }
     MPICH_LIB_OLD=0
 fi
-# check to see if the bgq instrumentation module should be built
+# check to see whether the bgq instrumentation module should be built
 # Check whether --enable-bgq_mod was given.
 if test "${enable_bgq_mod+set}" = set; then :
   enableval=$enable_bgq_mod;
diff --git a/darshan-runtime/lib/darshan-bgq.c b/darshan-runtime/lib/darshan-bgq.c
index a7bca70..b6ee623 100644
--- a/darshan-runtime/lib/darshan-bgq.c
+++ b/darshan-runtime/lib/darshan-bgq.c
@@ -18,11 +18,9 @@
 #include "darshan.h"
 #include "darshan-bgq-log-format.h"
-#ifdef __bgq__
 #include <spi/include/kernel/location.h>
 #include <spi/include/kernel/process.h>
 #include <firmware/include/personality.h>
-#endif
  * Simple module which captures BG/Q hardware specific information about
@@ -70,7 +68,6 @@ static void bgq_record_reduction_op(void* infile_v,void* inoutfile_v,int *len,MP
 static void capture(struct darshan_bgq_record *rec)
-#ifdef __bgq__
     Personality_t person;
     int r;
@@ -96,7 +93,6 @@ static void capture(struct darshan_bgq_record *rec)
         rec->counters[BGQ_DDRPERNODE] = person.DDR_Config.DDRSizeMB;
-#endif
     rec->rank = my_rank;
     rec->fcounters[BGQ_F_TIMESTAMP] = darshan_core_wtime();
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 07bb151..b534a1f 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -55,6 +55,21 @@ char* darshan_path_exclusions[] = {
 NULL
+#ifdef DARSHAN_BGQ
+extern void bgq_runtime_initialize();
+#endif
+/* array of init functions for modules which need to be statically
+ * initialized by darshan at startup time
+void (*mod_static_init_fns[])(void) =
+#ifdef DARSHAN_BGQ
+    &bgq_runtime_initialize,
+#endif
+    NULL
 #define DARSHAN_CORE_LOCK() pthread_mutex_lock(&darshan_core_mutex)
 #define DARSHAN_CORE_UNLOCK() pthread_mutex_unlock(&darshan_core_mutex)
@@ -196,6 +211,14 @@ void darshan_core_initialize(int argc, char **argv)
+    /* maybe bootstrap modules with static initializers */
+    i = 0;
+    while(mod_static_init_fns[i])
+        (*mod_static_init_fns[i])();
+        i++;
     if(internal_timing_flag)
         init_time = DARSHAN_MPI_CALL(PMPI_Wtime)() - init_start;
@@ -208,11 +231,6 @@ void darshan_core_initialize(int argc, char **argv)
-#ifdef __bgq__
-    extern void bgq_runtime_initialize();
-    bgq_runtime_initialize();
-#endif
     return;
hooks/post-receive
More information about the Darshan-commits
