[Darshan-commits] [Darshan] branch, dev-modular, updated. darshan-2.3.1-170-gefd4d7e
Service Account git at mcs.anl.gov
Wed Sep 9 16:35:22 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  efd4d7e7bba6578d0d53e678dcceb8649cd038c9 (commit)
      from  fc94307057726297593d0a5af8e5c4c8ebfc50f6 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit efd4d7e7bba6578d0d53e678dcceb8649cd038c9
Author: Shane Snyder <snyder at cetuslac1.fst.alcf.anl.gov>
Date:   Wed Sep 9 21:33:59 2015 +0000
    add autoconf check for building bgq mod
Summary of changes:
 darshan-runtime/configure    |   47 ++++++++++++++++++++++++++++++++++++++++-
 darshan-runtime/configure.in |   28 +++++++++++++++++++++++-
 2 files changed, 71 insertions(+), 4 deletions(-)
Diff of changes:
diff --git a/darshan-runtime/configure b/darshan-runtime/configure
index 0896cb7..0abf264 100755
--- a/darshan-runtime/configure
+++ b/darshan-runtime/configure
@@ -692,6 +692,7 @@ with_log_path_by_env
 with_log_hints
 with_log_path
 with_jobid_env
+enable_bgq_mod
       ac_precious_vars='build_alias
 host_alias
@@ -1314,6 +1315,7 @@ Optional Features:
   --disable-cuserid       Disables attempted use of cuserid() at run time
   --disable-ld-preload    Disables support for LD_PRELOAD library
   --enable-group-readable-logs Set log files to be group readable
+  --disable-bgq-mod       Disables compilation and use of BG/Q module (for BG/Q systems)
 Optional Packages:
   --with-PACKAGE[=ARG]    use PACKAGE [ARG=yes]
@@ -4065,8 +4067,6 @@ fi
 done
-#CP_WRAPPERS="-Wl,-u,MPI_Init,-u,MPI_Wtime,-wrap,write,-wrap,open,-wrap,creat,-wrap,creat64,-wrap,open64,-wrap,close,-wrap,read,-wrap,lseek,-wrap,lseek64,-wrap,pread,-wrap,pwrite,-wrap,readv,-wrap,writev,-wrap,__xstat,-wrap,__lxstat,-wrap,__fxstat,-wrap,__xstat64,-wrap,__lxstat64,-wrap,__fxstat64,-wrap,mmap,-wrap,mmap64,-wrap,fopen,-wrap,fclose,-wrap,fread,-wrap,fwrite,-wrap,fseek,-wrap,fopen64,-wrap,pread64,-wrap,pwrite64,-wrap,fsync,-wrap,fdatasync,-wrap,ncmpi_create,-wrap,ncmpi_open,-wrap,ncmpi_close,-wrap,H5Fcreate,-wrap,H5Fopen,-wrap,H5Fclose,-wrap,aio_write,-wrap,aio_write64,-wrap,aio_read,-wrap,aio_read64,-wrap,lio_listio,-wrap,lio_listio64,-wrap,aio_return,-wrap,aio_return64,-wrap,mkstemp,-wrap,mkostemp,-wrap,mkstemps,-wrap,mkostemps"
 # We need to know the value of the $libdir and $bindir variables so that
 # we can reference the correct path in the darshan compiler wrappers.
 # Unfortunately, those two variables are not normally evaluated by autoconf.
@@ -4247,6 +4247,49 @@ $as_echo "no" >&6; }
     MPICH_LIB_OLD=0
 fi
+# check to see if the bgq instrumentation module should be built
+# Check whether --enable-bgq_mod was given.
+if test "${enable_bgq_mod+set}" = set; then :
+  enableval=$enable_bgq_mod;
+else
+  enable_bgq_mod=check
+fi
+if test x$enable_bgq_mod != xno; then
+    { $as_echo "$as_me:${as_lineno-$LINENO}: checking for BG/Q environment" >&5
+$as_echo_n "checking for BG/Q environment... " >&6; }
+    cat confdefs.h - <<_ACEOF >conftest.$ac_ext
+/* end confdefs.h.  */
+        #ifndef __bgq__
+        #error __bgq__ not set
+        #endif
+int
+main ()
+  return 0;
+_ACEOF
+if ac_fn_c_try_compile "$LINENO"; then :
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: yes" >&5
+$as_echo "yes" >&6; }
+        DARSHAN_USE_BGQ=1
+else
+  { $as_echo "$as_me:${as_lineno-$LINENO}: result: no" >&5
+$as_echo "no" >&6; }
+        if
+            test "x$enable_bgq_mod" = xyes; then :
+  as_fn_error $? "BG/Q module enabled in non-BG/Q environment" "$LINENO" 5
+fi
+fi
+rm -f core conftest.err conftest.$ac_objext conftest.$ac_ext
+fi
 DARSHAN_VERSION="3.0.0-pre1"
diff --git a/darshan-runtime/configure.in b/darshan-runtime/configure.in
index 313574c..33fc4c0 100644
--- a/darshan-runtime/configure.in
+++ b/darshan-runtime/configure.in
@@ -180,8 +180,6 @@ CFLAGS="$old_cflags"
 AC_CHECK_HEADERS(mntent.h sys/mount.h)
@@ -285,6 +283,31 @@ AS_IF([$CC -show foo.c -o foo |grep lmpich >& /dev/null],
     AC_MSG_RESULT(no)
     MPICH_LIB_OLD=0)
+AC_ARG_ENABLE(
+    [bgq_mod],
+    [  --disable-bgq-mod       Disables compilation and use of BG/Q module (for BG/Q systems)],
+    [enable_bgq_mod=check]
+    AC_MSG_CHECKING(for BG/Q environment)
+    AC_TRY_COMPILE([
+        #ifndef __bgq__
+        #endif
+        AC_MSG_RESULT(yes)
+        DARSHAN_USE_BGQ=1,
+        AC_MSG_RESULT(no)
+        AS_IF([
+            test "x$enable_bgq_mod" = xyes],
+            AC_MSG_ERROR(BG/Q module enabled in non-BG/Q environment),
+fi
 DARSHAN_VERSION="AC_PACKAGE_VERSION"
 AC_SUBST(darshan_lib_path)
@@ -294,6 +317,7 @@ AC_SUBST(__CP_LOG_PATH)
 AC_SUBST(DISABLE_LDPRELOAD)
 AC_SUBST(DARSHAN_VERSION)
 AC_SUBST(MPICH_LIB_OLD)
+AC_SUBST(DARSHAN_USE_BGQ)
 AC_OUTPUT(Makefile
 darshan-mk-log-dirs.pl
 darshan-gen-cc.pl
hooks/post-receive
More information about the Darshan-commits mailing list
