[Darshan-commits] [Darshan] branch, dev-modular,	updated. darshan-2.3.1-168-gac26379
    Service Account
    git at mcs.anl.gov
    Thu Sep  3 16:36:42 CDT 2015
This is an automated email from the git hooks/post-receive script. It was
generated because a ref change was pushed to the repository containing
the project "".
The branch, dev-modular has been updated
       via  ac26379597807cf610c81a3945388d7f746f4c80 (commit)
       via  7e0566b7f583000e7ae82a98b7a94a68c915dbd0 (commit)
       via  835e28d98724d6685611fb5b485339aecd3417d0 (commit)
       via  760e827e12c90f773ed0358a820e23cf45b432fe (commit)
       via  94efcc1729a753e7cdb2894f8219262c67ba3961 (commit)
       via  7dc249cbc6ed3f9ef7263270443067a744d5111f (commit)
       via  c3f4cafd7cbb8a4d6bf044de9660fc95be93c2e7 (commit)
      from  3e3d2df8f841083834789a2bc9dc78800d8b9823 (commit)
Those revisions listed above that are new to this repository have
not appeared on any other notification email; so we list those
revisions in full, below.
- Log -----------------------------------------------------------------
commit ac26379597807cf610c81a3945388d7f746f4c80
Merge: 3e3d2df8f841083834789a2bc9dc78800d8b9823 7e0566b7f583000e7ae82a98b7a94a68c915dbd0
Author: Shane Snyder <ssnyder at mcs.anl.gov>
Date:   Thu Sep 3 16:36:06 2015 -0500
    Merge remote-tracking branch 'origin/dev-bgq-mod' into dev-modular
Summary of changes:
 darshan-bgq-log-format.h            |   63 +++++++
 darshan-log-format.h                |    3 +-
 darshan-runtime/Makefile.in         |   16 ++-
 darshan-runtime/lib/darshan-bgq.c   |  320 +++++++++++++++++++++++++++++++++++
 darshan-runtime/lib/darshan-core.c  |    5 +
 darshan-util/Makefile.in            |   10 +-
 darshan-util/darshan-bgq-logutils.c |  105 ++++++++++++
 darshan-util/darshan-bgq-logutils.h |   18 ++
 darshan-util/darshan-bgq-parser.c   |  217 ++++++++++++++++++++++++
 darshan-util/darshan-logutils.c     |    2 +-
 darshan-util/darshan-logutils.h     |    1 +
 11 files changed, 753 insertions(+), 7 deletions(-)
 create mode 100644 darshan-bgq-log-format.h
 create mode 100644 darshan-runtime/lib/darshan-bgq.c
 create mode 100644 darshan-util/darshan-bgq-logutils.c
 create mode 100644 darshan-util/darshan-bgq-logutils.h
 create mode 100644 darshan-util/darshan-bgq-parser.c
Diff of changes:
diff --git a/darshan-bgq-log-format.h b/darshan-bgq-log-format.h
new file mode 100644
index 0000000..82353fd
--- /dev/null
+++ b/darshan-bgq-log-format.h
@@ -0,0 +1,63 @@
+ * Copyright (C) 2015 University of Chicago.
+ * See COPYRIGHT notice in top-level directory.
+#ifndef __DARSHAN_BGQ_LOG_FORMAT_H
+#define __DARSHAN_BGQ_LOG_FORMAT_H
+#include "darshan-log-format.h"
+#define BGQ_COUNTERS \
+    X(BGQ_CSJOBID, "control system jobid") \
+    X(BGQ_NNODES, "number of BGQ compute nodes") \
+    X(BGQ_RANKSPERNODE, "number of MPI ranks per node") \
+    X(BGQ_DDRPERNODE, "size in MB of DDR3 per node") \
+    X(BGQ_INODES, "number of i/o nodes") \
+    X(BGQ_ANODES, "dimension of A torus") \
+    X(BGQ_BNODES, "dimension of B torus") \
+    X(BGQ_CNODES, "dimension of C torus") \
+    X(BGQ_DNODES, "dimension of D torus") \
+    X(BGQ_ENODES, "dimension of E torus") \
+    X(BGQ_TORUSENABLED, "which dimensions are torus") \
+    X(BGQ_NUM_INDICES, "end of counters")
+#define BGQ_F_COUNTERS \
+    X(BGQ_F_TIMESTAMP, "timestamp when data was collected") \
+    X(BGQ_F_NUM_INDICES, "end of counters")
+#define X(a, b) a,
+/* integer counters for the "BGQ" example module */
+enum darshan_bgq_indices
+    BGQ_COUNTERS
+/* floating point counters for the "BGQ" example module */
+enum darshan_bgq_f_indices
+    BGQ_F_COUNTERS
+#undef X
+/* the darshan_bgq_record structure encompasses the high-level data/counters
+ * which would actually be logged to file by Darshan for the "BGQ" example
+ * module. This example implementation logs the following data for each
+ * record:
+ *      - a corresponding Darshan record identifier
+ *      - the rank of the process responsible for the record
+ *      - integer I/O counters (operation counts, I/O sizes, etc.)
+ *      - floating point I/O counters (timestamps, cumulative timers, etc.)
+struct darshan_bgq_record
+    darshan_record_id f_id;
+    int64_t rank;
+    int alignment;
+    int64_t counters[BGQ_NUM_INDICES];
+    double fcounters[BGQ_F_NUM_INDICES];
+#endif /* __DARSHAN_BGQ_LOG_FORMAT_H */
diff --git a/darshan-log-format.h b/darshan-log-format.h
index 4f7cc6a..a7cc4e3 100644
--- a/darshan-log-format.h
+++ b/darshan-log-format.h
@@ -48,7 +48,8 @@
     X(DARSHAN_POSIX_MOD, "POSIX", posix_logutils) \
     X(DARSHAN_MPIIO_MOD, "MPI-IO", mpiio_logutils) \
     X(DARSHAN_HDF5_MOD, "HDF5", hdf5_logutils) \
-    X(DARSHAN_PNETCDF_MOD, "PNETCDF", pnetcdf_logutils)
+    X(DARSHAN_PNETCDF_MOD, "PNETCDF", pnetcdf_logutils) \
+    X(DARSHAN_BGQ_MOD, "BG/Q", bgq_logutils)
 /* unique identifiers to distinguish between available darshan modules */
 /* NOTES: - valid ids range from [0...DARSHAN_MAX_MODS-1]
diff --git a/darshan-runtime/Makefile.in b/darshan-runtime/Makefile.in
index e12238d..1acfa95 100644
--- a/darshan-runtime/Makefile.in
+++ b/darshan-runtime/Makefile.in
@@ -69,6 +69,15 @@ lib/darshan-mpiio.o: lib/darshan-mpiio.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdi
 lib/darshan-mpiio.po: lib/darshan-mpiio.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
 	$(CC) $(CFLAGS_SHARED) -c $< -o $@
+# BG/Q module
+lib/darshan-bgq.o: lib/darshan-bgq.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
+	$(CC) $(CFLAGS) -c $< -o $@
+lib/darshan-bgq.po: lib/darshan-bgq.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-mpiio-log-format.h | lib
+	$(CC) $(CFLAGS_SHARED) -c $< -o $@
 lib/darshan-hdf5.o: lib/darshan-hdf5.c darshan.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-hdf5-log-format.h | lib
@@ -99,14 +108,15 @@ lib/lookup8.o: lib/lookup8.c
 lib/lookup8.po: lib/lookup8.c
-lib/libdarshan.a: lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darshan-common.o lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o lib/lookup3.o lib/lookup8.o
+lib/libdarshan.a: lib/darshan-core-init-finalize.o lib/darshan-core.o lib/darshan-common.o lib/darshan-posix.o lib/darshan-mpiio.o lib/darshan-hdf5.o lib/darshan-pnetcdf.o lib/darshan-bgq.o lib/lookup3.o lib/lookup8.o
 	ar rcs $@ $^
+lib/libdarshan.so: lib/darshan-core-init-finalize.po lib/darshan-core.po lib/darshan-common.po lib/darshan-posix.po lib/darshan-mpiio.po lib/darshan-pnetcdf.po lib/darshan-bgq.po lib/lookup3.po lib/lookup8.po
+	$(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ -lpthread -lrt -lz -ldl
 lib/libdarshan-stubs.a: lib/darshan-hdf5-stubs.o lib/darshan-pnetcdf-stubs.o
 	ar rcs $@ $^
-lib/libdarshan.so: lib/darshan-core-init-finalize.po lib/darshan-core.po lib/darshan-common.po lib/darshan-posix.po lib/darshan-mpiio.po lib/darshan-hdf5.po lib/darshan-pnetcdf.po lib/lookup3.po lib/lookup8.po
-	$(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ -lpthread -lrt -lz -ldl
 install:: all
 	install -d $(libdir)
diff --git a/darshan-runtime/lib/darshan-bgq.c b/darshan-runtime/lib/darshan-bgq.c
index 0000000..a7bca70
--- /dev/null
+++ b/darshan-runtime/lib/darshan-bgq.c
@@ -0,0 +1,320 @@
+#define _XOPEN_SOURCE 500
+#define _GNU_SOURCE
+#include "darshan-runtime-config.h"
+#include <stdio.h>
+#include <unistd.h>
+#include <stdlib.h>
+#include <pthread.h>
+#include <assert.h>
+#include "uthash.h"
+#include "darshan.h"
+#include "darshan-bgq-log-format.h"
+#ifdef __bgq__
+#include <spi/include/kernel/location.h>
+#include <spi/include/kernel/process.h>
+#include <firmware/include/personality.h>
+#endif
+ * Simple module which captures BG/Q hardware specific information about
+ * the job.
+ * This module does not intercept any system calls. It just pulls data
+ * from the personality struct at initialization.
+ * Global runtime struct for tracking data needed at runtime
+struct bgq_runtime
+    struct darshan_bgq_record record;
+static struct bgq_runtime *bgq_runtime = NULL;
+static pthread_mutex_t bgq_runtime_mutex = PTHREAD_RECURSIVE_MUTEX_INITIALIZER_NP;
+/* the instrumentation_disabled flag is used to toggle functions on/off */
+static int instrumentation_disabled = 0;
+/* my_rank indicates the MPI rank of this process */
+static int my_rank = -1;
+static int darshan_mem_alignment = 1;
+/* internal helper functions for the "NULL" module */
+void bgq_runtime_initialize(void);
+/* forward declaration for module functions needed to interface with darshan-core */
+static void bgq_begin_shutdown(void);
+static void bgq_get_output_data(MPI_Comm mod_comm, darshan_record_id *shared_recs, int shared_rec_count, void **buffer, int *size);
+static void bgq_shutdown(void);
+static void bgq_setup_reduction(darshan_record_id *shared_recs,int *shared_rec_count,void **send_buf,void **recv_buf,int *rec_size);
+static void bgq_record_reduction_op(void* infile_v,void* inoutfile_v,int *len,MPI_Datatype *datatype);
+/* macros for obtaining/releasing the "NULL" module lock */
+#define BGQ_LOCK() pthread_mutex_lock(&bgq_runtime_mutex)
+#define BGQ_UNLOCK() pthread_mutex_unlock(&bgq_runtime_mutex)
+ * Function which updates all the counter data
+static void capture(struct darshan_bgq_record *rec)
+#ifdef __bgq__
+    Personality_t person;
+    int r;
+    rec->counters[BGQ_CSJOBID] = Kernel_GetJobID();
+    rec->counters[BGQ_RANKSPERNODE] = Kernel_ProcessCount();
+    rec->counters[BGQ_INODES] = MPIX_IO_node_id();
+    r = Kernel_GetPersonality(&person, sizeof(person));
+    if (r == 0)
+        rec->counters[BGQ_NNODES] = ND_TORUS_SIZE(person.Network_Config);
+        rec->counters[BGQ_ANODES] = person.Network_Config.Anodes;
+        rec->counters[BGQ_BNODES] = person.Network_Config.Bnodes;
+        rec->counters[BGQ_CNODES] = person.Network_Config.Cnodes;
+        rec->counters[BGQ_DNODES] = person.Network_Config.Dnodes;
+        rec->counters[BGQ_ENODES] = person.Network_Config.Enodes;
+        rec->counters[BGQ_TORUSENABLED] =
+            (((person.Network_Config.NetFlags & ND_ENABLE_TORUS_DIM_A) == ND_ENABLE_TORUS_DIM_A) << 0) |
+            (((person.Network_Config.NetFlags & ND_ENABLE_TORUS_DIM_B) == ND_ENABLE_TORUS_DIM_B) << 1) |
+            (((person.Network_Config.NetFlags & ND_ENABLE_TORUS_DIM_C) == ND_ENABLE_TORUS_DIM_C) << 2) |
+            (((person.Network_Config.NetFlags & ND_ENABLE_TORUS_DIM_D) == ND_ENABLE_TORUS_DIM_D) << 3) |
+            (((person.Network_Config.NetFlags & ND_ENABLE_TORUS_DIM_E) == ND_ENABLE_TORUS_DIM_E) << 4);
+        rec->counters[BGQ_DDRPERNODE] = person.DDR_Config.DDRSizeMB;
+#endif
+    rec->rank = my_rank;
+    rec->fcounters[BGQ_F_TIMESTAMP] = darshan_core_wtime();
+    return;
+ * Internal functions for manipulating BGQ module state *
+void bgq_runtime_initialize()
+    /* struct of function pointers for interfacing with darshan-core */
+    struct darshan_module_funcs bgq_mod_fns =
+        .begin_shutdown = bgq_begin_shutdown,
+        .get_output_data = bgq_get_output_data,
+        .shutdown = bgq_shutdown
+    int mem_limit;
+    char *recname = "darshan-internal-bgq";
+    BGQ_LOCK();
+    /* don't do anything if already initialized or instrumenation is disabled */
+    if(bgq_runtime || instrumentation_disabled)
+        return;
+    /* register the "NULL" module with the darshan-core component */
+    darshan_core_register_module(
+        DARSHAN_BGQ_MOD,
+        &bgq_mod_fns,
+        &my_rank,
+        &mem_limit,
+        &darshan_mem_alignment);
+    /* return if no memory assigned by darshan-core */
+    if(mem_limit == 0)
+        instrumentation_disabled = 1;
+        return;
+    /* no enough memory to fit bgq module */
+    if (mem_limit < sizeof(*bgq_runtime))
+        return;
+    /* initialize module's global state */
+    bgq_runtime = malloc(sizeof(*bgq_runtime));
+    if(!bgq_runtime)
+        return;
+    memset(bgq_runtime, 0, sizeof(*bgq_runtime));
+    darshan_core_register_record(
+        recname,
+        strlen(recname),
+        1,
+        DARSHAN_BGQ_MOD,
+        &bgq_runtime->record.f_id,
+        &bgq_runtime->record.alignment);
+    DARSHAN_MPI_CALL(PMPI_Comm_rank)(MPI_COMM_WORLD, &my_rank);
+    capture(&bgq_runtime->record);
+    BGQ_UNLOCK();
+    return;
+/* Perform any necessary steps prior to shutting down for the "NULL" module. */
+static void bgq_begin_shutdown()
+    BGQ_LOCK();
+    /* In general, we want to disable all wrappers while Darshan shuts down.
+     * This is to avoid race conditions and ensure data consistency, as
+     * executing wrappers could potentially modify module state while Darshan
+     * is in the process of shutting down.
+    BGQ_UNLOCK();
+    return;
+static int cmpr(const void *p1, const void *p2)
+    const uint64_t *a = (uint64_t*) p1;
+    const uint64_t *b = (uint64_t*) p2;
+    return ((*a == *b) ?  0 : ((*a < *b) ? -1 : 1));
+/* Pass output data for the "BGQ" module back to darshan-core to log to file. */
+    MPI_Comm mod_comm,
+    darshan_record_id *shared_recs,
+    int shared_rec_count,
+    void **buffer,
+    int *size)
+    /* Just set the output buffer to point at the array of the "BGQ" module's
+     * I/O records, and set the output size according to the number of records
+     * currently being tracked.
+    int nprocs;
+    int result;
+    uint64_t *ion_ids;
+    if (my_rank == 0)
+        DARSHAN_MPI_CALL(MPI_Comm_size)(mod_comm, &nprocs);
+        ion_ids = malloc(sizeof(*ion_ids)*nprocs);
+        result = (ion_ids != NULL);
+    DARSHAN_MPI_CALL(MPI_Bcast)(&result, 1, MPI_INT, 0, mod_comm);
+    if (bgq_runtime && result)
+        int i, found;
+        uint64_t val;
+        DARSHAN_MPI_CALL(MPI_Gather)(&bgq_runtime->record.counters[BGQ_INODES],
+                                     1,
+                                     MPI_LONG_LONG_INT,
+                                     ion_ids,
+                                     1,
+                                     0,
+                                     mod_comm);
+        if (my_rank == 0)
+            qsort(ion_ids, nprocs, sizeof(*ion_ids), cmpr);
+            for (i = 1, val = ion_ids[0], found = 1; i < nprocs; i++)
+                if (val != ion_ids[i])
+                    val = ion_ids[i];
+                    found += 1;
+            bgq_runtime->record.counters[BGQ_INODES] = found;
+    if ((bgq_runtime) && (my_rank == 0))
+        *buffer = &bgq_runtime->record;
+        *size = sizeof(struct darshan_bgq_record);
+    else
+        *buffer = NULL;
+        *size   = 0;
+    return;
+/* Shutdown the "BGQ" module by freeing up all data structures. */
+static void bgq_shutdown()
+    if (bgq_runtime)
+        free(bgq_runtime);
+        bgq_runtime = NULL;
+    return;
+    void* infile_v,
+    void* inoutfile_v,
+    int* len,
+    MPI_Datatype *datatype)
+    int i;
+    int j;
+    struct darshan_bgq_record *infile = infile_v;
+    struct darshan_bgq_record *inoutfile = inoutfile_v;
+    for (i = 0; i<*len; i++)
+        for (j = 0; j < BGQ_NUM_INDICES; j++)
+            if (infile->counters[j] != inoutfile->counters[j])
+                // unexpected
+                fprintf(stderr,
+                        "%lu counter mismatch: %d [%lu] [%lu]\n",
+                        infile->f_id,
+                        j,
+                        infile->counters[j],
+                        inoutfile->counters[j]);
+        infile++;
+        inoutfile++;
+    return;
+ * Local variables:
+ *  c-indent-level: 4
+ *  c-basic-offset: 4
+ * End:
+ * vim: ts=8 sts=4 sw=4 expandtab
diff --git a/darshan-runtime/lib/darshan-core.c b/darshan-runtime/lib/darshan-core.c
index 169dc56..07bb151 100644
--- a/darshan-runtime/lib/darshan-core.c
+++ b/darshan-runtime/lib/darshan-core.c
@@ -208,6 +208,11 @@ void darshan_core_initialize(int argc, char **argv)
+#ifdef __bgq__
+    extern void bgq_runtime_initialize();
+    bgq_runtime_initialize();
+#endif
     return;
diff --git a/darshan-util/Makefile.in b/darshan-util/Makefile.in
index 0fdf2ec..aad652e 100644
--- a/darshan-util/Makefile.in
+++ b/darshan-util/Makefile.in
@@ -69,10 +69,16 @@ darshan-pnetcdf-logutils.o: darshan-pnetcdf-logutils.c darshan-logutils.h darsha
 darshan-pnetcdf-logutils.po: darshan-pnetcdf-logutils.c darshan-logutils.h darshan-pnetcdf-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-pnetcdf-log-format.h | uthash-1.9.2
-libdarshan-util.so: darshan-logutils.po darshan-posix-logutils.po darshan-mpiio-logutils.po darshan-hdf5-logutils.po darshan-pnetcdf-logutils.po
+darshan-bgq-logutils.o: darshan-bgq-logutils.c darshan-logutils.h darshan-bgq-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-bgq-log-format.h | uthash-1.9.2
+darshan-bgq-logutils.po: darshan-bgq-logutils.c darshan-logutils.h darshan-bgq-logutils.h $(DARSHAN_LOG_FORMAT) $(srcdir)/../darshan-bgq-log-format.h | uthash-1.9.2
+libdarshan-util.so: darshan-logutils.po darshan-posix-logutils.po darshan-mpiio-logutils.po darshan-hdf5-logutils.po darshan-pnetcdf-logutils.po darshan-bgq-logutils.po
 	$(CC) $(CFLAGS_SHARED) $(LDFLAGS) -o $@ $^ $(LIBS)
-libdarshan-util.a: darshan-logutils.o darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o
+libdarshan-util.a: darshan-logutils.o darshan-posix-logutils.o darshan-mpiio-logutils.o darshan-hdf5-logutils.o darshan-pnetcdf-logutils.o darshan-bgq-logutils.o
 	ar rcs libdarshan-util.a $^
 jenkins-hash-gen: jenkins-hash-gen.c lookup3.o
diff --git a/darshan-util/darshan-bgq-logutils.c b/darshan-util/darshan-bgq-logutils.c
index 0000000..c538e20
--- /dev/null
+++ b/darshan-util/darshan-bgq-logutils.c
@@ -0,0 +1,105 @@
+#include "darshan-util-config.h"
+#include <stdio.h>
+#include <string.h>
+#include <inttypes.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
+#include <errno.h>
+#include "darshan-bgq-logutils.h"
+/* counter name strings for the POSIX module */
+#define X(a, b) #a,
+char *bgq_counter_names[] = {
+    BGQ_COUNTERS
+char *bgq_f_counter_names[] = {
+    BGQ_F_COUNTERS
+#undef X
+static int darshan_log_get_bgq_file(void** psx_buf_p, int* bytes_left,
+    void** file_rec, darshan_record_id* rec_id, int byte_swap_flag);
+static void darshan_log_print_bgq_file(void *file_rec,
+    char *file_name, char *mnt_pt, char *fs_type);
+struct darshan_mod_logutil_funcs bgq_logutils =
+    .log_get_record = &darshan_log_get_bgq_file,
+    .log_print_record = &darshan_log_print_bgq_file,
+    int i;
+    struct darshan_bgq_record *file = (struct darshan_bgq_record *)
+        (*psx_buf_p);
+    if(*bytes_left < sizeof(struct darshan_bgq_record))
+        return(-1);
+    if(byte_swap_flag)
+        /* swap bytes if necessary */
+        DARSHAN_BSWAP64(&file->f_id);
+        DARSHAN_BSWAP64(&file->rank);
+        for(i=0; i<BGQ_NUM_INDICES; i++)
+            DARSHAN_BSWAP64(&file->counters[i]);
+        for(i=0; i<BGQ_F_NUM_INDICES; i++)
+            DARSHAN_BSWAP64(&file->fcounters[i]);
+    /* update/set output variables */
+    *file_rec = (void *)file;
+    *rec_id = file->f_id;
+    *psx_buf_p = (file + 1); /* increment input buf by size of file record */
+    *bytes_left -= sizeof(struct darshan_bgq_record);
+    return(0);
+static void darshan_log_print_bgq_file(void *file_rec, char *file_name,
+    char *mnt_pt, char *fs_type)
+    int i;
+    struct darshan_bgq_record *bgq_file_rec =
+        (struct darshan_bgq_record *)file_rec;
+        DARSHAN_COUNTER_PRINT(darshan_module_names[DARSHAN_BGQ_MOD],
+            bgq_file_rec->rank, bgq_file_rec->f_id, bgq_counter_names[i],
+            bgq_file_rec->counters[i], file_name, mnt_pt, fs_type);
+        DARSHAN_F_COUNTER_PRINT(darshan_module_names[DARSHAN_BGQ_MOD],
+            bgq_file_rec->rank, bgq_file_rec->f_id, bgq_f_counter_names[i],
+            bgq_file_rec->fcounters[i], file_name, mnt_pt, fs_type);
+    return;
+ * End:
diff --git a/darshan-util/darshan-bgq-logutils.h b/darshan-util/darshan-bgq-logutils.h
index 0000000..a8bbb3a
--- /dev/null
+++ b/darshan-util/darshan-bgq-logutils.h
@@ -0,0 +1,18 @@
+#ifndef __DARSHAN_BGQ_LOG_UTILS_H
+#define __DARSHAN_BGQ_LOG_UTILS_H
+#include "darshan-logutils.h"
+extern char *bgq_counter_names[];
+extern char *bgq_f_counter_names[];
+extern struct darshan_mod_logutil_funcs bgq_logutils;
+#endif
diff --git a/darshan-util/darshan-bgq-parser.c b/darshan-util/darshan-bgq-parser.c
index 0000000..03fdc27
--- /dev/null
+++ b/darshan-util/darshan-bgq-parser.c
@@ -0,0 +1,217 @@
+#include <stdio.h>
+#include <fcntl.h>
+#include <zlib.h>
+#include <time.h>
+#include <getopt.h>
+#include "uthash-1.9.2/src/uthash.h"
+int main(int argc, char **argv)
+    int ret;
+    int i;
+    char *filename;
+    char tmp_string[4096];
+    darshan_fd fd;
+    struct darshan_header header;
+    struct darshan_job job;
+    struct darshan_record_ref *rec_hash = NULL;
+    struct darshan_record_ref *ref;
+    int mount_count;
+    char** mnt_pts;
+    char** fs_types;
+    time_t tmp_time = 0;
+    char *token;
+    char *save;
+    char buffer[DARSHAN_JOB_METADATA_LEN];
+    struct darshan_bgq_record next_file;
+    assert(argc == 2);
+    filename = argv[1];
+    struct stat sbuf;
+    stat(filename, &sbuf);
+    fd = darshan_log_open(filename, "r");
+    if(!fd)
+        fprintf(stderr, "darshan_log_open() failed to open %s\n.", filename);
+        return(-1);
+    /* read darshan log header */
+    ret = darshan_log_getheader(fd, &header);
+    if(ret < 0)
+        fprintf(stderr, "darshan_log_getheader() failed to read log header.\n");
+        darshan_log_close(fd);
+        return(-1);
+    /* read darshan job info */
+    ret = darshan_log_getjob(fd, &job);
+    if(ret < 0)
+        fprintf(stderr, "darshan_log_getjob() failed to read job data.\n");
+        return(-1);
+    /* get the original command line for this job */
+    ret = darshan_log_getexe(fd, tmp_string);
+    if(ret < 0)
+        fprintf(stderr, "Error: unable to read trailing job information.\n");
+        return(-1);
+    /* print job summary */
+    printf("# darshan log version: %s\n", header.version_string);
+    printf("# size of BGQ file statistics: %zu bytes\n", sizeof(struct darshan_bgq_record));
+    printf("# size of job statistics: %zu bytes\n", sizeof(struct darshan_job));
+    printf("# exe: %s\n", tmp_string);
+    printf("# uid: %" PRId64 "\n", job.uid);
+    printf("# jobid: %" PRId64 "\n", job.jobid);
+    printf("# start_time: %" PRId64 "\n", job.start_time);
+    tmp_time += job.start_time;
+    printf("# start_time_asci: %s", ctime(&tmp_time));
+    printf("# end_time: %" PRId64 "\n", job.end_time);
+    tmp_time = 0;
+    tmp_time += job.end_time;
+    printf("# end_time_asci: %s", ctime(&tmp_time));
+    printf("# nprocs: %" PRId64 "\n", job.nprocs);
+    printf("# run time: %" PRId64 "\n", job.end_time - job.start_time + 1);
+    for(token=strtok_r(job.metadata, "\n", &save);
+        token != NULL;
+        token=strtok_r(NULL, "\n", &save))
+        char *key;
+        char *value;
+        /* NOTE: we intentionally only split on the first = character.
+         * There may be additional = characters in the value portion
+         * (for example, when storing mpi-io hints).
+        strcpy(buffer, token);
+        key = buffer;
+        value = index(buffer, '=');
+        if(!value)
+            continue;
+        /* convert = to a null terminator to split key and value */
+        value[0] = '\0';
+        value++;
+        printf("# metadata: %s = %s\n", key, value);
+    /* get the mount information for this log */
+    ret = darshan_log_getmounts(fd, &mnt_pts, &fs_types, &mount_count);
+    if(ret < 0)
+        fprintf(stderr, "darshan_log_getmounts() failed to read mount information.\n");
+        return(-1);
+    /* print table of mounted file systems */
+    printf("\n# mounted file systems (mount point and fs type)\n");
+    printf("# -------------------------------------------------------\n");
+    for(i=0; i<mount_count; i++)
+        printf("# mount entry:\t%s\t%s\n", mnt_pts[i], fs_types[i]);
+    /* read hash of darshan records */
+    ret = darshan_log_gethash(fd, &rec_hash);
+    if(ret < 0)
+        fprintf(stderr, "darshan_log_getmap() failed to read record map.\n");
+        return(-1);
+    printf("\n*** FILE RECORD DATA ***\n");
+    ret = darshan_log_get_bgq_file(fd, &next_file);
+    if(ret < 0)
+        fprintf(stderr, "darshan_log_get_posix_file() failed to read next record.\n");
+        return(-1);
+    if(ret == 0)
+        printf("# no files opened.\n");
+        return(0);
+    /* loop over each stored POSIX file record and print counters */
+    i = 1;
+    do
+        /* get the pathname for this record */
+        HASH_FIND(hlink, rec_hash, &next_file.f_id, sizeof(darshan_record_id), ref);
+        assert(ref);
+        printf("\tRecord %d: id=%"PRIu64" (path=%s, rank=%"PRId64")\n",
+            i, next_file.f_id, ref->rec.name, next_file.rank);
+        printf(
+            "\t\tBGQ_CSJOBID:\t%"PRIu64"\n"
+            "\t\tBGQ_NNODES:\t%"PRIu64"\n"
+            "\t\tBGQ_RPN:\t%"PRIu64"\n"
+            "\t\tBGQ_DDRPERNODE:\t%"PRIu64"\n"
+            "\t\tBGQ_INODES:\t%"PRIu64"\n"
+            "\t\tBGQ_ANODES:\t%"PRIu64"\n"
+            "\t\tBGQ_BNODES:\t%"PRIu64"\n"
+            "\t\tBGQ_CNODES:\t%"PRIu64"\n"
+            "\t\tBGQ_DNODES:\t%"PRIu64"\n"
+            "\t\tBGQ_ENODES:\t%"PRIu64"\n"
+            "\t\tBGQ_TORUSEN:\t%"PRIx64"\n"
+            "\t\tBGQ_TIMESTAMP:\t%lf\n",
+            next_file.counters[BGQ_CSJOBID],
+            next_file.counters[BGQ_NNODES],
+            next_file.counters[BGQ_RANKSPERNODE],
+            next_file.counters[BGQ_DDRPERNODE],
+            next_file.counters[BGQ_INODES],
+            next_file.counters[BGQ_ANODES],
+            next_file.counters[BGQ_BNODES],
+            next_file.counters[BGQ_CNODES],
+            next_file.counters[BGQ_DNODES],
+            next_file.counters[BGQ_ENODES],
+            next_file.counters[BGQ_TORUSENABLED],
+            next_file.fcounters[BGQ_F_TIMESTAMP]);
+        i++;
+    } while((ret = darshan_log_get_bgq_file(fd, &next_file)) == 1);
+    /* free mount info */
+        free(mnt_pts[i]);
+        free(fs_types[i]);
+    if(mount_count > 0)
+        free(mnt_pts);
+        free(fs_types);
+    return(0);
diff --git a/darshan-util/darshan-logutils.c b/darshan-util/darshan-logutils.c
index 438257f..3a4327e 100644
--- a/darshan-util/darshan-logutils.c
+++ b/darshan-util/darshan-logutils.c
@@ -48,7 +48,7 @@ struct darshan_mod_logutil_funcs *mod_logutils[DARSHAN_MAX_MODS] =
     &mpiio_logutils,    /* MPI-IO */
     &hdf5_logutils,     /* HDF5 */
     &pnetcdf_logutils,  /* PNETCDF */
-    NULL,
+    &bgq_logutils,      /* BG/Q */
     NULL,
     NULL,
     NULL,
diff --git a/darshan-util/darshan-logutils.h b/darshan-util/darshan-logutils.h
index 544dba9..f188575 100644
--- a/darshan-util/darshan-logutils.h
+++ b/darshan-util/darshan-logutils.h
@@ -66,6 +66,7 @@ extern struct darshan_mod_logutil_funcs *mod_logutils[DARSHAN_MAX_MODS];
 #include "darshan-mpiio-logutils.h"
 #include "darshan-hdf5-logutils.h"
 #include "darshan-pnetcdf-logutils.h"
 darshan_fd darshan_log_open(const char *name);
 darshan_fd darshan_log_create(const char *name, enum darshan_comp_type comp_type);
hooks/post-receive
More information about the Darshan-commits
