[Darshan-commits] Build failed in Jenkins: darshan-dev-modular-mpich-3.2-profile-conf #4
jenkins-ci at mcs.anl.gov jenkins-ci at mcs.anl.gov
Fri Nov 27 00:09:39 CST 2015
See <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/4/>
[...truncated 11718 lines...]
/usr/bin/install -c -m 644 MPI_Win_unlock_all.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPI_Win_unlock_all.html>
/usr/bin/install -c -m 644 MPI_Win_unlock.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPI_Win_unlock.html>
/usr/bin/install -c -m 644 MPI_Win_wait.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPI_Win_wait.html>
/usr/bin/install -c -m 644 MPI_Wtick.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPI_Wtick.html>
/usr/bin/install -c -m 644 MPI_Wtime.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPI_Wtime.html>
/usr/bin/install -c -m 644 MPIX_Comm_agree.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPIX_Comm_agree.html>
/usr/bin/install -c -m 644 MPIX_Comm_failure_ack.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPIX_Comm_failure_ack.html>
/usr/bin/install -c -m 644 MPIX_Comm_failure_get_acked.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPIX_Comm_failure_get_acked.html>
/usr/bin/install -c -m 644 MPIX_Comm_revoke.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPIX_Comm_revoke.html>
/usr/bin/install -c -m 644 MPIX_Comm_shrink.html <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/www3/MPIX_Comm_shrink.html>
if [ ! -e <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich> ] ; then mkdir -p <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich> ; fi
if [ -s ./doc/userguide/user.pdf ] ; then /usr/bin/install -c -m 644 ./doc/userguide/user.pdf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/user.pdf> ; fi
if [ -s ./doc/installguide/install.pdf ] ; then /usr/bin/install -c -m 644 ./doc/installguide/install.pdf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/install.pdf> ; fi
if [ -s ./doc/logging/logging.pdf ] ; then /usr/bin/install -c -m 644 ./doc/logging/logging.pdf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/share/doc/mpich/logging.pdf> ; fi
 mkdir -p '<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/include'>
 /usr/bin/install -c -m 644 src/binding/fortran/use_mpi/mpi.mod src/binding/fortran/use_mpi/mpi_sizeofs.mod src/binding/fortran/use_mpi/mpi_constants.mod src/binding/fortran/use_mpi/mpi_base.mod '<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/include'>
 /usr/bin/install -c -m 644 src/binding/cxx/mpicxx.h src/binding/fortran/mpif_h/mpif.h src/include/mpi.h '<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/include'>
 mkdir -p '<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/lib/pkgconfig'>
 /usr/bin/install -c -m 644 src/packaging/pkgconfig/mpich.pc '<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-install/lib/pkgconfig'>
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-3.2'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-3.2'>
Making install in examples
make[2]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-3.2/examples'>
make[3]: Entering directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-3.2/examples'>
make[3]: Nothing to be done for `install-exec-am'.
make[3]: Nothing to be done for `install-data-am'.
make[3]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-3.2/examples'>
make[2]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-3.2/examples'>
make[1]: Leaving directory `<https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/mpich-3.2'>
[darshan-dev-modular-mpich-3.2-profile-conf] $ /bin/bash /tmp/hudson4044102557711608982.sh
[darshan-dev-modular-mpich-3.2-profile-conf] $ /bin/bash /tmp/hudson5899267212690260992.sh
checking for a BSD-compatible install... /usr/bin/install -c
checking whether the mpicc compiler works... checking for gcc... mpicc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether mpicc accepts -g... yes
checking for mpicc option to accept ISO C89... none needed
yes
checking how to run the C preprocessor... mpicc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking zlib.h usability... yes
checking zlib.h presence... yes
checking for zlib.h... yes
checking for inflateEnd in -lz... yes
checking for inttypes.h... (cached) yes
checking whether the inttypes.h PRIxNN macros are broken... no
checking whether byte ordering is bigendian... no
checking for struct aiocb64... yes
checking for off64_t... yes
checking mntent.h usability... yes
checking mntent.h presence... yes
checking for mntent.h... yes
checking sys/mount.h usability... yes
checking sys/mount.h presence... yes
checking for sys/mount.h... yes
checking for MPI-IO support in MPI... yes
checking for MPI-IO prototypes without const qualifier... no
checking for MPI-IO prototypes with const qualifier... yes
checking for shared libraries in MPI... no
configure: WARNING: mpicc doesn't support shared objects; disabling LD_PRELOAD library
checking for MPIO_Request... yes
checking for old (pre-3.1.1) style MPICH library naming convention... no
checking for BG/Q environment... no
configure: creating ./config.status
config.status: creating Makefile
config.status: creating darshan-mk-log-dirs.pl
config.status: creating darshan-gen-cc.pl
config.status: creating darshan-gen-cxx.pl
config.status: creating darshan-gen-fortran.pl
config.status: creating darshan-base-ld-opts
config.status: creating darshan-config
config.status: creating share/craype-1.x/darshan-module
config.status: creating share/craype-2.x/darshan-module
config.status: creating lib/pkgconfig/darshan-runtime.pc
config.status: creating share/mpi-profile/darshan-cc.conf
config.status: creating share/mpi-profile/darshan-cxx.conf
config.status: creating share/mpi-profile/darshan-f.conf
config.status: creating share/mpi-profile/darshan-bg-cc.conf
config.status: creating share/mpi-profile/darshan-bg-cxx.conf
config.status: creating share/mpi-profile/darshan-bg-f.conf
config.status: creating darshan-runtime-config.h
config.status: darshan-runtime-config.h is unchanged
checking for gcc... gcc
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking if bzlib is wanted... yes
checking for BZ2_bzCompressInit in -lbz2... yes
checking bzlib.h usability... yes
checking bzlib.h presence... yes
checking for bzlib.h... yes
checking for BZ2_bzCompressInit in -lbz2... (cached) yes
checking bzlib in /usr... ok
checking for pdflatex... yes
checking for -halt-on-error argument to pdflatex... yes
checking for strndup... yes
config.status: creating darshan-job-summary/bin/darshan-job-summary.pl
config.status: creating maint/darshan-util.pc
config.status: creating darshan-util-config.h
config.status: darshan-util-config.h is unchanged
[darshan-dev-modular-mpich-3.2-profile-conf] $ /bin/bash /tmp/hudson3218319437522633926.sh
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib>
install -m 755 lib/libdarshan.a <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib>
install -m 755 lib/libdarshan-stubs.a <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 darshan-mk-log-dirs.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 darshan-gen-cc.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 darshan-gen-cxx.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 darshan-gen-fortran.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 darshan-config <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/craype-1.x/modulefiles/darshan>
install -m 755 share/craype-1.x/darshan-module <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/craype-1.x/modulefiles/darshan/3.0.0-pre2>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/craype-2.x/modulefiles/darshan>
install -m 755 share/craype-2.x/darshan-module <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/craype-2.x/modulefiles/darshan/3.0.0-pre2>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/mpi-profile>
install -m 755 share/mpi-profile/darshan-cc.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/mpi-profile/darshan-cc.conf>
install -m 755 share/mpi-profile/darshan-cxx.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/mpi-profile/darshan-cxx.conf>
install -m 755 share/mpi-profile/darshan-f.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/mpi-profile/darshan-f.conf>
install -m 755 share/mpi-profile/darshan-bg-cc.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/mpi-profile/darshan-bg-cc.conf>
install -m 755 share/mpi-profile/darshan-bg-cxx.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/mpi-profile/darshan-bg-cxx.conf>
install -m 755 share/mpi-profile/darshan-bg-f.conf <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/mpi-profile/darshan-bg-f.conf>
install -m 644 darshan-base-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/darshan-base-ld-opts>
install -m 644 ../../darshan-runtime/darshan-posix-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/darshan-posix-ld-opts>
install -m 644 ../../darshan-runtime/darshan-hdf5-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/darshan-hdf5-ld-opts>
install -m 644 ../../darshan-runtime/darshan-pnetcdf-ld-opts <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share/darshan-pnetcdf-ld-opts>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib/pkgconfig>
install -m 644 lib/pkgconfig/darshan-runtime.pc <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib/pkgconfig/darshan-runtime.pc>
make: Nothing to be done for `all'.
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 755 darshan-analyzer <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 darshan-convert <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 darshan-parser <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 ../../darshan-util/darshan-summary-per-file.sh <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -m 755 libdarshan-util.a <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib>
install -m 644 ../../darshan-util/darshan-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-posix-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-mpiio-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-hdf5-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-pnetcdf-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/darshan-bgq-logutils.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-posix-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-mpiio-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-hdf5-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-pnetcdf-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 644 ../../darshan-util/../darshan-bgq-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include/uthash-1.9.2>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include/uthash-1.9.2/src>
install -m 644 uthash-1.9.2/src/uthash.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include/uthash-1.9.2/src/>
install -m 644 ../../darshan-util/../darshan-log-format.h <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/include>
install -m 755 darshan-job-summary/bin/darshan-job-summary.pl <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/bin>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib/TeX>
install -m 644 ../../darshan-util/darshan-job-summary/lib/TeX/Encode.pm <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib/TeX/>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib/Number>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib/Number/Bytes>
install -m 644 ../../darshan-util/darshan-job-summary/lib/Number/Bytes/Human.pm <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib/Number/Bytes>
install -d <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share>
install -m 644 ../../darshan-util/darshan-job-summary/share/* <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/share>
install -m 644 maint/darshan-util.pc <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/install/lib/pkgconfig>
[darshan-dev-modular-mpich-3.2-profile-conf] $ /bin/bash /tmp/hudson1102738599512337680.sh
Running <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/darshan-test/regression/test-cases/cxxpi.sh...>
Process 0 of 4 is on thrash
Process 2Process 3 of 4 is on thrash
 of 4 is on thrash
Process 1 of 4 is on thrash
pi is approximately 3.14159 Error is 8.33331e-10
wall clock time = 0.000967026
Done.
Running <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/darshan-test/regression/test-cases/fperf-f77.sh...>
 Access size per process =      4194304  bytes, ntimes =            5
 Write bandwidth without file sync =    1298.0528707764845       Mbytes/sec
 Read bandwidth without prior file sync =    2177.3854872722322       Mbytes/sec
 Write bandwidth including file sync =    82.053010872963071       Mbytes/sec
 Read bandwidth after file sync =    2146.7629939187896       Mbytes/sec
Error: failed to open darshan log file <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/scratch/fperf-f77.darshan.gz.>
Error: failed to parse <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/scratch/fperf-f77.darshan.gz>
Error: failed to execute test case <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/darshan-test/regression/test-cases/fperf-f77.sh>
Done.
Running <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/darshan-test/regression/test-cases/fperf-f90.sh...>
 Write bandwidth without file sync =    1151.2457328981088       Mbytes/sec
 Read bandwidth without prior file sync =    2307.0962977497129       Mbytes/sec
 Write bandwidth including file sync =    89.552957931710992       Mbytes/sec
 Read bandwidth after file sync =    2591.4688140849967       Mbytes/sec
Error: failed to open darshan log file <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/scratch/fperf-f90.darshan.gz.>
Error: failed to parse <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/scratch/fperf-f90.darshan.gz>
Error: failed to execute test case <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/darshan-test/regression/test-cases/fperf-f90.sh>
Done.
Running <https://jenkins-ci.mcs.anl.gov/job/darshan-dev-modular-mpich-3.2-profile-conf/ws/darshan-test/regression/test-cases/mpi-io-test.sh...>
# Using mpi-io calls.
nr_procs = 4, nr_iter = 1, blk_sz = 16777216, coll = 0
# total_size = 67108864
# Write: min_t = 0.015573, max_t = 0.062444, mean_t = 0.039077, var_t = 0.000408
# Read:  min_t = 0.030639, max_t = 0.032267, mean_t = 0.031426, var_t = 0.000001
Write bandwidth = 1074.705248 Mbytes/sec
Read bandwidth = 2079.792643 Mbytes/sec
Done.
2 tests failed
Build step 'Execute shell' marked build as failure
Recording test results
More information about the Darshan-commits mailing list
